Hill Hold Assist Problem
steved1969
C?ID=357860
After fitting new pads to my 2019 Caddy Petrol DSG hill hold assist doesn't work properly someone said adaptations needs to be carried out to reset the brakes, could someone please tell me how to do it? Thanks in advance for any help given.
Westbury, UK
Do we have an Auto-Scan of your Caddy?, if yes please post a link to it but if not please post one.
Some ABS controllers have the parking brake integrated but some don't, and the procedure varies.
steved1969
C?ID=357860
Its a normal manual handbrake i have to get the scan off another computer to post it
steved1969
C?ID=357860
VCDS Version: 22.9.0.0 (x64)  HEX-NET CB: 0.4623.4
Dealer/Shop Name: vcds
VIN: WV1ZZZ2KZKX103352   License Plate: EF19WUM
Mileage: 64130km-39848mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 20 25 42 44 46 4C 52 5F 61
VIN: WV1ZZZ2KZKX103352   Mileage: 64130km-39848miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 T    HW: 04E 907 309 BK
   Component: R4 1.4l TFS   H24 2363
   Revision: R9H24---    CVN: 0EEB5B9B
   Coding: 00250072236415080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM14TFS01104E906027T 001007
   ROD: EV_ECM14TFS01104E906027T.rod
   VCID: 35222374942D6425A0-8060
   VINID: 9E606AAAA09BA9BA010030C5086D1BB703
5604 - Park/Neutral Switch Input Circuit
          P0850 00 [032] - Open or Short to Plus
                    Mileage: 63943 km
                    Date: 2022.09.16
                    Time: 14:37:07
                    Engine RPM: 914.50 /min
                    Normed load value: 29.4 %
                    Coolant temperature: 88 ∞C
                    Intake air temperature: 53 ∞C
                    Voltage terminal 30: 14.583 V
                    Unlearning counter according OBD: 35
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 1
                    Brake actuated status-Bits 0-7: 3
                    Selector lever position-Bits 0-7: 8
                    Adaptation status of neutral position sensor-Bits 0-7: 0
                    Engine status: COENG_RUNNING
   Part No SW: 0AM 300 043 F    HW: 0AM 927 769 F
   Component: GSG DQ200G2_PQ  050 2601
   Revision: 00005008    Serial number: CU501902286947
   Shop #: WSC 35110 377 08192
   VCID: 2E100C18B97B57FDE1-807A
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Revision: 00000000    Serial number: 60679000000706
   Coding: 1079429B9262B4810878427B49842DD379F7F0
   VCID: 40CC42A0DBEFD18D03-8014
0320 - System Function Test Activated
          C101F 00 [009] - -
                    Reset counter: 243
                    Mileage: 63945 km
                    Date: 2022.09.16
                    Time: 14:53:37
0321 - System Function Test
          C102A F0 [008] - Could not be Performed
                    Fault Frequency: 11
                    Reset counter: 33
                    Mileage: 63945 km
                    Date: 2022.09.16
                    Time: 15:00:19
   Part No SW: 1K8 907 426 AT    HW: 1K8 907 426 AT
   Component: AC Manuell    H21 0909
   Revision: 00001003
   Coding: 0010004003
   VCID: 054293B4844D34A570-8050
   Part No SW: 5K0 937 086 AD    HW: 5K0 937 086 AD
   Component: BCM PQ35 M+   122 0193
   Revision: BD122001
   Coding: 4F1A581EE025E16A088800889440096C0755000842208A60E48487000045
   VCID: 76A0E478C1AB2F3D69-8022
   Subsystem 1 - Part No: 2K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 13031  61  0715
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 250319 05  50  0106
   Coding: 0228DD
   Component: LIN BACKUP HO  H01 0009
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39461903301180
   Coding: 0131061051
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00.rod
   VCID: 3B36354CB209B25556-806E
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 1703190438A9C0
   Coding: 00001000FE033B
   ROD: EV_ACCBEGVW361.rod
   VCID: 36202478892B6F3DA9-8062
   Part No SW: 2K5 959 655 D    HW: 2K5 959 655 D
   Component: VW10Airbag00K 010 0018
   Revision: --------    Serial number: 003EL005VN3E
   Coding: 00000000000000000000000000000000304B
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D323B54AC1DBC6568-8068
   Serial number: 3497ARB40635UKVSPGH+
   Serial number: 3507ARB405V5UAL0KPON
   Part No SW: 1K5 953 521 CM    HW: 5K0 953 569 BC
   Revision: FF010042    Serial number: 20190311100092
   Coding: 088AC60008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7AB8F048FDB34B5D0D-802E
   Subsystem 1 - Part No SW: 2K0 959 442 A    HW: 2K0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 0621923394400184BC2B
   Coding: 2C0000
   Part No SW: 2K5 920 976 H    HW: 2K5 920 976 H
   Component: KOMBI         H02 2030
   Coding: 410A011300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   Part No SW: 7N0 907 530 BQ    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1691
   Revision:   H56       Serial number: 190319F1001547
   Coding: 357431
   VCID: 004C82A0936F118D43-8054
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 020201E700000100000000
   ASAM Dataset: EV_HighBeamAssisAU316 001004
   ROD: EV_HighBeamAssisAU316.rod
   VCID: 2D120B147C7D2CE5D8-8078
   Component: IMMO          H02 2030
   Coding: 000002
   VCID: 6A98C0088D13FBDDFD-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71AAD76468C50805BC-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 315    3501
   Revision: 00H22000
   VCID: 393A2F447035804544-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72A8D8686DC3331D45-8026
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0475
   Serial number: VWZAZ2W0807321
   Coding: 063307013C00000011111101008808001F0100C600200100CF
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2502F334248D14A510-8070
   Subsystem 1 - Part No SW: 5NA 919 866 AS    HW: -----------
   Component: ECE1 2021  --- 1520
   Component: Batt.regelung H56 1691
   Coding: 032F7856
   VCID: 71AAD764A8C50805BC-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 7588580300190301086B
End----------(Elapsed Time: 01:20, VBatt start/end: 14.6V/14.6V)-----------
Address 03: DTCs cleared
Address 01: DTCs cleared
Address 03,7E0 907 379 Q,channel MAS02138-Hill-start assistant,adapted from,Late ,to,Early ,
Address 03,7E0 907 379 Q,channel MAS02138-Hill-start assistant,adapted from,Early ,to,Early ,
AINils
Germany (AIB)
C?ID=56975
Your car only have HSA (Hill Start Assist), but no Hill descent control!
Use this coding and HDC is active: 1079429B9262B6810878427B49846DD379F7F0
steved1969
C?ID=357860
I need to know how to adapt the brakes i was told
AINils
Germany (AIB)
C?ID=56975
Sorry missunderstood your post, was my fault. In this case no need to adapt brakes as there's no option in this ABS to do job like this
steved1969
C?ID=357860
I posted to a VCDS group on facebook, my question was hill hold assist is not working properly it rolls back, he said if you have fitted new brakes adaptations need to be made, he never told me how to do it and i cant find anywhere online how to do it. I presume they need to be calibrated then all will be well
AINils
Germany (AIB)
C?ID=56975
There's no calibration, if car isnt equipped by EPB.
But coding of car is actually you don't have Hill Hold Assist
Westbury, UK
What happened before which dpoesn't happen after changing the pads (front or rear or both)?
