Friday,23,September,2022,11:04:07:47604
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: WVWZZZ3CZJE023481 License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZJE023481 Mileage: 71274km-44287miles
Address 01: Engine (J623-DCZA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 DL HW: 04L 907 309 M
Component: R4 1.6l TDI H25 1937
Revision: B4H25--- CVN: 78A17BD2D45710C1
Coding: 0119001203251D097000
Shop #: WSC 05311 115 00322
ASAM Dataset: EV_ECM16TDI01104L906026DL 004003
ROD: EV_ECM16TDI01104L906026DL_004.rod
VCID: 77ABEFCC5F46DBF3D69-8022
VINID: 9E69EAAAA0D3A9A54008310804599FCE39
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 51427000000973
Coding: 0FEC928F34220B6F477B060840C449F0492CD0E2600292710040F078C002420000000012121212B835351919323200
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
VCID: 78A9ECF05258D48BDF3-802C
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 103
Mileage: 69232 km
Date: 2022.08.20
Time: 12:49:18
Part No SW: 3Q0 959 435 F HW: 3Q0 959 435 F
Component: VWKESSYMQB 027 0906
Revision: 00027000 Serial number: 0445813148
Coding: 102F0F0623
ROD: EV_KessyHellaMQBAB.rod
VCID: 3D273DE43DFA31A3CC5-8068
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to temp low voltage]
Reset counter: 137
Mileage: 71158 km
Date: 2022.09.16
Time: 16:57:24
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
ZAT_pressed: OFF
Park selector lever position: Not engaged and not locked
Enabling immobilizer: Condition met
Control Module Voltage: 8.551 V
Vehicle speed: 0.0 km/h
Engine RPM: 0.0 /min
Status of vehicle locking: Vehicle unlocked at single door
Coding information: Not coded
Driver door: Open
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Part No SW: 5G0 907 426 AT HW: 5G0 907 426 AT
Component: AC Manuell H03 1801
Revision: 00001K06
Coding: 12120104202110001000400000000006
ROD: EV_ACManueBHBVW37X_004.rod
VCID: 7DA7FDE47D7AF1A38C5-8028
B10CD 00 [008] - -
Fault Frequency: 6
Reset counter: 137
Mileage: 71158 km
Date: 2022.09.16
Time: 16:31:51
Voltage terminal 30: 11.5 V
CAN input signal(s) status-Back-up lamp: OFF
Part No SW: 5Q0 937 086 BK HW: 5Q0 937 086 BF
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865814061700GZ
Shop #: WSC 00015 115 00001
ROD: EV_BCMBOSCH_018.rod
VCID: 045188001E90806BC3B-8050
Wiper motor control module:
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170523 043 0607
Serial number: 170613180829
Subsystem 2 - Part No SW: 3G0 941 633 L HW: 3G0 941 633 L
Component: E1 - LDS MQB H01 0032
Serial number: 07 03 2017 10000347
Serial number: 000000000ZY1714330QT
Serial number: 00000000000069975116
66314 - Positioning Motors for Headlight Range
B1528 F1 [008] - Control Voltage Implausible
Reset counter: 111
Mileage: 69486 km
Date: 2022.08.24
Time: 10:41:30
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: gültiges Funktelegramm
Voltage: 12.9 V
Outside temperature: 15.0 °C
204546 - Remote key 2
Reset counter: 60
Mileage: 69176 km
Date: 2022.07.26
Time: 11:34:33
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: operated
last_wakeup: no cause for fault protection
Voltage: 12.2 V
Outside temperature: 26.0 °C
262936 - Sensor for anti-theft alarm system
B1330 29 [008] - Signal Implausible
Reset counter: 126
Mileage: 69891 km
Date: 2022.08.31
Time: 07:04:01
CAN-Bus_aktiv: On
OFF: operated
last_wakeup: Pin A15 LIN3
Voltage: 12.5 V
Outside temperature: 14.5 °C
Part No SW: 3Q0 959 655 BJ HW: 3Q0 959 655 BJ
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W5PBT8XS2
Coding: 98FCC0C0000000005C5400CF008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 074B9F0C2FA6AB73A69-8052
Subsystem 1 - Part No SW: ----------- HW: 454 001 606 17
Serial number: 357000000001F55D362M
Subsystem 2 - Part No SW: ----------- HW: 454 001 606 17
Serial number: 358000000007E55D362S
Subsystem 3 - Part No SW: ----------- HW: 454 800 106 17
Serial number: 35100DE61B00E000000P
Subsystem 4 - Part No SW: ----------- HW: 454 801 605 17
Serial number: 352007ACB8C10000000S
Subsystem 5 - Part No SW: ----------- HW: 454 800 706 17
Serial number: 35500E5B024100000007
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Revision: FF033033 Serial number: 20170623100220
Coding: 0400
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
Address 17: Instruments
Part No SW: 3Q0 907 530 F HW: 3Q0 907 530 B
Component: GW MQB Mid 517 5304
Serial number: 13061710521284
Coding: 030300045F085900FB000048080F00010001070000000000000000000000
Shop #: WSC 05311 115 00074
GVL: 01503C0000000600400C00000000480000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod (VIN: N/A)
VCID: 323D1ED8F4A4FEDB217-8066
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 39170001610200087223
Coding: 28FFFF
Serial number: 75886000001706090912
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 0803201700010004
8526361 - LV Energy Management
B1802 F1 [008] - Warning Triggered
Reset counter: 137
Mileage: 71158 km
Date: 2022.09.16
Time: 16:57:19
Terminal 30 power supply: 11.4 V
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Component: ELV-MQBB H05 0032
Serial number: 17000153491009
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD1D4312285C318D-8024
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 270517EER04623
Coding: 00300A208001020000001000
VCID: 41DF411441025543A8D-8014
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005776550
Coding: 0D0000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 0107
Shop #: WSC 00015 115 00322
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D75504552A7963945-8010
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 110617EFA4141A
Coding: 003000208001020000001000
VCID: 40D944104A085C4BA73-8014
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005768548
Coding: 050000
Part No SW: 3Q0 035 820 C HW: 3Q0 035 820 C
Component: MU-S-D-ER 721 0842
Coding: 02840200FF00000051110101008808401F0800C60120010137
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 290FF9B4D972BD0390D-807C
Subsystem 1 - Part No SW: 5G6 919 605 HW: 5G6 919 605
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZHT1763919
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 97
Mileage: 71158 km
Date: 2022.09.19
Time: 19:33:18
Voltage terminal 30: 11.4 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
7228 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Efficiency assist (0x3C) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 97
Mileage: 71158 km
Date: 2022.09.19
Time: 19:33:21
BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:44, VBatt start/end: 12.1V/12.2V)-----------
