Infotainment System
Hendy264
Glasgow, UK
C?ID=411893
First of all hello and thanks for letting me join, I am new to this vcds stuff so please be gentle :)
This question has probably been asked a thousand times, so this will be its 1001 time :)
MIB unit, I have a 2017 passat and this unit is base line crap no app connect no mirror link I went onto the vcds software and activated all that I could find on infotainment and mirror link, I now have the "app connect" logo in the menu but that is all, and when I click on it I get "app connect starting" but it never does. Does my MIB need the codes for this like 0006030 etc for this to work and if it is not in the MIB do I need to purchase from dealer to activate it using vcds, hope this makes sense
Hi and welcome.
My guess is that these features will require SWAP codes, but please post an Auto-Scan for context, so people can see how your car is equipped and configured.
downtime
Finland
C?ID=280813
Yep. Uwe is correct. No coding will bring you salvation. You need heavier weapons to add SWaP to the unit
AINils
Germany (AIB)
C?ID=56975
Appconnect starting means Unit is 819 or 820 Part Nr ;-) So no Appconnect after activation. But will wait for Autoscan to see If iam right
Hendy264
Glasgow, UK
C?ID=411893
I will do a full scan later today and post it, thanks for replys
Hendy264
Glasgow, UK
C?ID=411893
Sorry about the delay :)
Friday,23,September,2022,11:04:07:47604
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVWZZZ3CZJE023481   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZJE023481   Mileage: 71274km-44287miles
Address 01: Engine (J623-DCZA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 DL    HW: 04L 907 309 M
   Component: R4 1.6l TDI   H25 1937
   Revision: B4H25---    CVN: 78A17BD2D45710C1
   Coding: 0119001203251D097000
   Shop #: WSC 05311 115 00322
   ASAM Dataset: EV_ECM16TDI01104L906026DL 004003
   ROD: EV_ECM16TDI01104L906026DL_004.rod
   VCID: 77ABEFCC5F46DBF3D69-8022
   VINID: 9E69EAAAA0D3A9A54008310804599FCE39
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 51427000000973
   Coding: 0FEC928F34220B6F477B060840C449F0492CD0E2600292710040F078C002420000000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
   VCID: 78A9ECF05258D48BDF3-802C
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 103
                    Mileage: 69232 km
                    Date: 2022.08.20
                    Time: 12:49:18
   Part No SW: 3Q0 959 435 F    HW: 3Q0 959 435 F
   Component: VWKESSYMQB    027 0906
   Revision: 00027000    Serial number: 0445813148
   Coding: 102F0F0623
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3D273DE43DFA31A3CC5-8068
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 137
                    Mileage: 71158 km
                    Date: 2022.09.16
                    Time: 16:57:24
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Park selector lever position: Not engaged and not locked
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 8.551 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked at single door
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5G0 907 426 AT    HW: 5G0 907 426 AT
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 12120104202110001000400000000006
   VCID: 7DA7FDE47D7AF1A38C5-8028
          B10CD 00 [008] - -
                    Reset counter: 137
                    Mileage: 71158 km
                    Date: 2022.09.16
                    Time: 16:31:51
                    Voltage terminal 30: 11.5 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 086 BK    HW: 5Q0 937 086 BF
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865814061700GZ
   Shop #: WSC 00015 115 00001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 045188001E90806BC3B-8050
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170523  043 0607
   Serial number:         170613180829
   Subsystem 2 - Part No SW: 3G0 941 633 L    HW: 3G0 941 633 L
   Serial number: 07 03 2017  10000347
   Serial number: 000000000ZY1714330QT
   Serial number: 00000000000069975116
66314 - Positioning Motors for Headlight Range
          B1528 F1 [008] - Control Voltage Implausible
                    Reset counter: 111
                    Mileage: 69486 km
                    Date: 2022.08.24
                    Time: 10:41:30
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 12.9 V
                    Outside temperature: 15.0 °C
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 60
                    Mileage: 69176 km
                    Date: 2022.07.26
                    Time: 11:34:33
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
                    Outside temperature: 26.0 °C
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
                    Reset counter: 126
                    Mileage: 69891 km
                    Date: 2022.08.31
                    Time: 07:04:01
                    CAN-Bus_aktiv: On
                    OFF: operated
                    last_wakeup: Pin A15 LIN3
                    Voltage: 12.5 V
                    Outside temperature: 14.5 °C
   Part No SW: 3Q0 959 655 BJ    HW: 3Q0 959 655 BJ
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W5PBT8XS2
   Coding: 98FCC0C0000000005C5400CF008800000065
   Shop #: WSC 05314 000 00001
   VCID: 074B9F0C2FA6AB73A69-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 001 606 17
   Serial number: 357000000001F55D362M
   Subsystem 2 - Part No SW: -----------    HW: 454 001 606 17
   Serial number: 358000000007E55D362S
   Subsystem 3 - Part No SW: -----------    HW: 454 800 106 17
   Serial number: 35100DE61B00E000000P
   Subsystem 4 - Part No SW: -----------    HW: 454 801 605 17
   Serial number: 352007ACB8C10000000S
   Subsystem 5 - Part No SW: -----------    HW: 454 800 706 17
   Serial number: 35500E5B024100000007
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20170623100220
   Coding: 0400
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
Address 17: Instruments
   Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5304
   Serial number: 13061710521284
   Coding: 030300045F085900FB000048080F00010001070000000000000000000000
   Shop #: WSC 05311 115 00074
   GVL: 01503C0000000600400C00000000480000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod (VIN: N/A)
   VCID: 323D1ED8F4A4FEDB217-8066
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 39170001610200087223
   Coding: 28FFFF
   Serial number: 75886000001706090912
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 0803201700010004
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 137
                    Mileage: 71158 km
                    Date: 2022.09.16
                    Time: 16:57:19
                    Terminal 30 power supply: 11.4 V
                    Terminal 15: On
   Serial number: 17000153491009
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD1D4312285C318D-8024
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 270517EER04623
   Coding: 00300A208001020000001000
   VCID: 41DF411441025543A8D-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005776550
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 0107
   Shop #: WSC 00015 115 00322
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D75504552A7963945-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 110617EFA4141A
   Coding: 003000208001020000001000
   VCID: 40D944104A085C4BA73-8014
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005768548
   Coding: 050000
   Part No SW: 3Q0 035 820 C    HW: 3Q0 035 820 C
   Component: MU-S-D-ER     721 0842
   Coding: 02840200FF00000051110101008808401F0800C60120010137
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 290FF9B4D972BD0390D-807C
   Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZHT1763919
          U1014 00 [009] - -
                    Reset counter: 97
                    Mileage: 71158 km
                    Date: 2022.09.19
                    Time: 19:33:18
                    Voltage terminal 30: 11.4 V
7228 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Efficiency assist (0x3C) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 97
                    Mileage: 71158 km
                    Date: 2022.09.19
                    Time: 19:33:21
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:44, VBatt start/end: 12.1V/12.2V)-----------
AINils
Germany (AIB)
C?ID=56975
As i told you yesterday, it's a 820 Unit (3Q0 035 820 C) this isnt capable of Appconnect or RVC. This unit has not enough RAM and CPU Power ti use that feature. If unit was a 3Q0 035 820 B from Dephi you can crossflash them to 824 Part Nr, but in this case throw unit in thrash an buy 824 or 842 from Delphi and appconnect is possible
Hendy264
Glasgow, UK
C?ID=411893
Thank you, I shall see if I can source a better unit :)
Hendy264
Glasgow, UK
C?ID=411893
I have sourced and fitted a new Delphi unit, and the car is now at a workshop having the "component protection" removed, but the garage doing this has told me it will return the car back to "end of line" settings .....then I knew this because I read it in one of these posts, however he has also told me that it would clear the MIB2 I have withe the protection on it back to what I had in the car to start with......is this correct, Have I just wasted £70 or will I be able to activate everything it had on it with vcds ? I have not got the car with me at the moment, but the unit I have now was a full of features one sat nav app connect etc etc, as it all workeded other than volume.
TIA
Hendy264
Glasgow, UK
C?ID=411893
Monday,03,October,2022,17:55:04:47604
VIN: WVWZZZ3CZJE023481   Mileage: 71661km-44528miles
   Coding: 102F0F0623
   Revision: 00001K06
   Coding: 0400
   Part No SW: 3G0 920 941 C    HW: 3G0 920 941 C
   Component: KOMBI         202 0310
   Coding: 27A40A102380060001082B001000000000000000
   VCID: 2615F288C86C927BBDF-8072
   Generator:
   Coding: 28FFFF
   Analog clock:
   Coding: 0D0000
   Coding: 0107
   Coding: 050000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02840201FF00000051110101008808802F0206E601200000BF
   VCID: 313F11D4F1A2C5C358D-8064
11 Faults Found:
          U1014 00 [009] - -
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:46
                    Voltage terminal 30: 12.6 V
          B201A 00 [009] - -
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:46
                    Status_Software_Version_Management-module_name: C
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:46
6698 - Optical data bus
          U1049 00 [009] - Open circuit
          [Optical data bus: open circuit: wakeup]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:50
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:49
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:49
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:49
7184 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Seat adjustment/seat memory (0x10) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:49
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:49
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:49
7199 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Reversible belt tensioner (0x1F) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 117
                    Mileage: 71661 km
                    Date: 2022.10.03
                    Time: 17:34:49
End----------(Elapsed Time: 01:14, VBatt start/end: 12.3V/12.2V)-----------
Hendy264
Glasgow, UK
C?ID=411893
I have pasted a new auto scan, I have my car back from the garage who de-activated the "CP" and now I have the message saying I need an activation key, I also have no BT so my phone will not connect , so...do I need to go and spend more money to a dealer to get an activation key as all the functions on the vcds for infotainment system are all red channel not available message.............someone please tell me if this is something vcds can sort, Thanks
downtime
Finland
C?ID=280813
Take it back and tell them to finish it up properly. They did not restore your existing activation keys (FeCs) to the unit so that is why the BT is not working. For the other features like appconnect and nav, dealer is not able to help. You need to find someone who is able to "hack" the unit for you to accept custom FeCs.
Unfortunately Delphi is not the easiest one to do so you will need to find basically someone local with the appropriate hardware.
Hendy264
Glasgow, UK
C?ID=411893
Tuesday,04,October,2022,11:36:53:47604
VIN: WVWZZZ3CZJE023481   Mileage: 71716km-44562miles
   Coding: 102F0F0623
   Revision: 00001K06
   Coding: 0400
   Generator:
   Coding: 28FFFF
   Analog clock:
   Coding: 0D0000
   Coding: 0107
   Coding: 050000
   Coding: 02840201FF00000051110101008808801F0006E601200000BF
10 Faults Found:
          U1014 00 [009] - -
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:20
                    Voltage terminal 30: 12.0 V
                    Byte_Coding_Condition-byte_5_condition: ERROR
                    Byte_Coding_Condition-byte_6_condition: ERROR
                    Byte_Coding_Condition-byte_7_condition: ERROR
2565 - GPS Antenna
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:21
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:44
                    Voltage terminal 30: 12.2 V
          U1111 00 [009] - -
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:24
          U1111 00 [009] - -
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:24
          U1111 00 [009] - -
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:24
          U1111 00 [009] - -
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:24
          U1111 00 [009] - -
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:24
          U1111 00 [009] - -
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:24
          U1111 00 [009] - -
                    Reset counter: 118
                    Mileage: 71716 km
                    Date: 2022.10.04
                    Time: 11:33:24
End----------(Elapsed Time: 01:14, VBatt start/end: 12.2V/12.2V)-----------
downtime
Finland
C?ID=280813
You can do coding and adaptations to match your old unit with VCDS but you cannot get the Bluetooth and other stuff to work which need the activation key
