Hi Guys,
Do you have idea, how to get work the led DRL and parking lights in this 2018 Arona?
Following was made: Originally it had a basic front lights without any leds, but after a frontal damage new halogen lights were installed with LED DRL and led parking lights.
New lamps:
Right lamp: 6F1 941 015B
Left lamp: 6F1 941 016B
Low beam, high beam and turn indicators are running well, but the LED DRL and LED parking lights have DTC-s, see the Auto-scan...
I know its old type cable as it is asking upgrade, but now we could only read it only with this and if needs there is an upgraded one available as well.
New lamps:
VIN: VSSZZZKJZJR118435 License Plate: SXV300
Chassis Type: KJ-SE27 (2Q0)
Scan: 01 03 08 09 13 15 17 19 44 5F
Address 01: Engine (J623-DGTD) Labels: None
Part No SW: 04L 906 056 LK HW: 04L 907 445 F
Component: R4 1.6l TDI H01 5931
Revision: 22101001
Coding: 01114012430415090000
Shop #: WSC 00049 770 00143
ASAM Dataset: EV_ECM16TDI03004L906056LK 004013
ROD: N/A
VCID: 010DF13D9016C64E85-8054
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM16TDI03004L906056LK" (SE27)
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 2Q0 614 517 AA HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0222
Serial number: 08506454180106
Coding: 890D53573D4291B5CA00BC1912DF11A649345126444A24244854525445488865922C8A6422522424122A4A2AA249C6423D926342BC
Shop #: WSC 00049 770 00156
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: N/A
VCID: 6DD5BD8DBC8E322E51-8038
No ASAM data for: "EV_Brake1BOSCHESPMQBA0" (SE27)
No Faults Found
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 6F1 820 045 D HW: 6F1 820 045 D
Component: SG_AC_Manuell H01 0301
Coding: 810010000802010011000400020000000000000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001011
ROD: N/A
VCID: 244398A92FC43366CE-8070
No ASAM data for: "EV_ACManuePrehMQBA0" (SE27)
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q0 937 089 HW: 2Q0 937 089
Component: BCM A0 Std H97 0915
Serial number: 07001802500776
ASAM Dataset: EV_BCMA0 204001
ROD: N/A
VCID: 77F99FE5CED288FEBB-8022
Subsystem 1 - Part No SW: 2Q1 959 881 HW: 2Q1 959 881
Component: FHSG_DRV 001 0001
Serial number: 00000000000018277983
Coding: 13000C
Subsystem 2 - Part No SW: 2Q1 959 882 HW: 2Q1 959 882
Component: FHSG_PSG 001 0001
Serial number: 00000000000018436200
Coding: 09000C
Subsystem 3 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000018658075
Subsystem 4 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000018331862
Coding: 190000
No ASAM data for: "EV_BCMA0" (SE27)
18698 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 10
Mileage: 102627 km
Date: 2021.11.30
Time: 01:35:34
19210 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 10
Mileage: 102627 km
Date: 2021.11.30
Time: 01:35:34
Address 13: Auto Dist. Reg (J428) Labels:. 2Q0-907-572.clb
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 2A00600100F78728749C8145004087
ROD: N/A
VCID: 3E774AC1A16879B6B8-806A
No ASAM data for: "EV_ACCMRRCONTIVW376" (SE27)
No Faults Found
Address 15: Airbags (J234) Labels: None
Part No SW: 5QF 959 655 L HW: 5QF 959 655 L
Component: Airbag VW22 006 0520
Revision: -------- Serial number: 003XNP0ESVE%
Coding: 88CCC0C000000000585400CF000C00000065
ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
ROD: N/A
VCID: 5FC9D745462250BED3-800A
Subsystem 1 - Part No SW: ----------- HW: 454 001 001 18
Serial number: 3570000000041348CB2H
Subsystem 2 - Part No SW: ----------- HW: 454 001 001 18
Serial number: 3580000000039479DB2V
Subsystem 3 - Part No SW: ----------- HW: 454 801 101 18
Serial number: 3510074B10313000000$
Subsystem 4 - Part No SW: ----------- HW: 454 801 101 18
Serial number: 3520000020113000000H
Subsystem 5 - Part No SW: ----------- HW: 454 800 812 17
Component: FrontSensor_D 307 0189
Serial number: 355003B87AE12000000Q
No ASAM data for: "EV_AirbaVW22TS6VW48X" (SE27)
Address 17: Instruments (J285) Labels: None
Part No SW: 6F0 920 731 HW: 6F0 920 731
Component: KOMBI 106 0450
Coding: 0424090221000008018800011000000000000000
Shop #: WSC 00049 770 00221
ASAM Dataset: EV_DashBoardVDDMQBA0 001020
ROD: N/A
VCID: 62CFDEB175507D56FC-8036
No ASAM data for: "EV_DashBoardVDDMQBA0" (SE27)
No Faults Found
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 2Q0 909 901 HW: 2Q0 937 089
Component: GW MQB A0 H97 0915
Coding: 030100044F086A00E8000040000F00010001070000000000000000000000
ASAM Dataset: EV_GatewA0 013020
ROD: N/A
VCID: 6FE9A785B682C03E63-803A
Subsystem 2 - Part No SW: 5F0 959 537 HW: 5F0 959 537
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G1276241017
Coding: 001000
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 1003C6C1
No ASAM data for: "EV_GatewA0" (SE27)
Address 44: Steering Assist (J792) Labels: None
Part No SW: 2Q1 909 144 J HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 610 6030
Serial number: 01HCM0P5CB4J012
Coding: 00000000000000000000020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: N/A
VCID: 397D59DDB8465E8E8D-806C
No ASAM data for: "EV_SteerAssisTRWG4LMQBA0" (SE27)
10529280 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 10
Mileage: 102627 km
Date: 2021.11.30
Time: 01:35:32
Part No SW: 6F0 035 888 HW: 6F0 035 888
Component: MU-E--ER 052 7315
Serial number: 09011800010959
Coding: 041206003C00000011110001010008002F0000840000010000
ROD: N/A
VCID: 6CD3B08987943B2646-8038
No ASAM data for: "EV_MUEnt4CGen2LGE" (SE27)
No Faults Found
End-------------------------(Elapsed Time: 02:49)--------------------------
