Looking to fix radio first can anyone help? (2005 8P A3)
Knighty0007
Dorset, UK
HUC-2H
Not sure if this scan is right place! Onto the other matters but needs some tunes whilst working!
Wednesday,14,September,2022,01:20:39:57378
VCDS Version: 22.9.0.0 (x64)
VIN: WAUZZZ8P5AA097806   License Plate: NEW
Mileage: 267010km-165912mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WAUZZZ8P5AA097806   Mileage: 267010km-165912miles
   Part No SW: 03L 906 023 M    HW: 03L 906 023 L
   Component: R4 1.6l TDI   H23 9979
   Revision: --H23---    Serial number: AUX7Z0INFNK0GL CVN: 4F2DF892
   Coding: 00114034032501080000
   Shop #: WSC 06314 000 00000
   ASAM Dataset: EV_ECM16TDI02103L906023M 003017
   ROD: EV_ECM16TDI02103L906023JK_003.rod
   VCID: 306AB78C6BC3710DF3-8064
   VINID: 9D196AAAA2201514402472001811494430
9867 - Coolant Pump 2
          P261A 00 [237] - Open circuit
                    Mileage: 266963 km
                    Date: 2022.09.12
                    Time: 21:05:34
                    Engine RPM: 776.75 /min
                    Normed load value: 7.5 %
                    Coolant temperature: 84 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 14.118 V
                    Coolant temperature at radiator outlet: actual value-TCO_2: 85 °C
                    Battery voltage: 14.1 V
9870 - Coolant pump 2
          P261B 00 [096] - Implausible signal
                    Mileage: 266992 km
                    Date: 2022.09.12
                    Time: 23:55:30
                    Engine RPM: 1250.25 /min
                    Vehicle speed: 34 km/h
                    Coolant temperature: 85 °C
                    Intake air temperature: 22 °C
                    Coolant temperature at radiator outlet: actual value-TCO_2: 84 °C
Readiness: 1 1 0 0 0
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 13422012092B0001C81304E4901F0091380800
   VCID: 7AFE55A4F53F7B5D0D-802E
                    Reset counter: 165
                    Mileage: 266939 km
                    Date: 2022.09.12
                    Time: 03:03:33
                    Count: 2
                    Count: 4608
                    Count: 73
                    Count: 44032
                    Count: 65280
Address 08: Auto HVAC        Labels: 8P0-820-047.clb
   Part No SW: 8P0 820 047 D    HW: 8P0 820 047 D
   Component: J255  Klima Man H08 0060
   Revision: 00H08004    Serial number: 00000000000000
   VCID: 316CB288A8C97805FC-8064
   Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
   Component: BCM PQ35  M   105 0575
   Revision: 00105 AJ
   Coding: 0E000A2FB005F064207041E0000001DC431A29AA004DC122E4008F800041
   Shop #: WSC 12345 123 61029
   VCID: 326EBD846DCF431D85-8066
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 4 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
                    Reset counter: 124
                    Mileage: 266939 km
                    Date: 2022.09.11
                    Time: 23:59:45
                    Voltage: 12.50 V
                        Term 50 On
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 36
                    Reset counter: 128
                    Mileage: 266939 km
                    Date: 2022.09.12
                    Time: 00:23:15
                    Voltage: 12.45 V
                        Term 50 On
                    Fault Status: 00101010
                    Fault Frequency: 13
                    Reset counter: 168
                    Mileage: 266939 km
                    Date: 2022.09.12
                    Time: 03:03:44
                    Voltage: 13.85 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93640931708603
   Coding: 000003
   VCID: 428EED44DD6FF39D15-8016
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 124
                    Mileage: 266939 km
                    Date: 2022.09.12
                    Time: 03:03:38
                    Temperature: 17.0°C
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FB004BD5J
   Coding: 30314238303830303037554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FA8D470163D0EF58A-801A
   Serial number: 3572DRB40000A22492CR
   Serial number: 3582DRB40000A210F0CR
   Serial number: 35128RB4000052ED31CP
   Serial number: 35228RB4000052ED911L
   Serial number: 35547RB400005D17458N
   Serial number: 35647RB400005D171DDY
9437210 - Igniter for Driver's Airbag
          B1000 1A [137] - Resistance Too Low
9437466 - Igniter 2 for Driver's Airbag
          B1001 1A [137] - Resistance Too Low
                    Mileage: 266939 km
                    Date: 2022.09.12
                    Time: 00:00:57
9437696 - Igniter for Passenger's Airbag
          B1002 00 [000] - -
0000 - ROD - Unknown Error Code
          - 00 [000]
          - 00 [000]
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0002042
   VCID: 4686F1543147CFBD39-8012
   Component: E0221           H02 0030
   Part No SW: 8P0 920 982 J    HW: 8P0 920 982 J
   Component: KOMBIINSTR. VDO H03 0990
   Revision: D0H03004    Serial number: 224NI004012653
   Coding: 0004408
   Shop #: WSC 12345 111 45725
   VCID: 408AE74C1363E18D03-8014
   Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
   Component: J533  Gateway   H17 0231
   Revision:   H17       Serial number: 1321J09B2102DD
   Coding: E9A07F06000202042103
   VCID: 6BD060E04A65D2D586-803E
   Revision: D0H03004    Serial number: AUX7Z0INFNK0GL
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 M    HW: 8P0 959 801 M
   Component: Tuer-SG         H04 0100
   Coding: 0135860
   VCID: 4584F6580C41C4A530-8010
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 232    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
                    Fault Status: 00101101
                    Reset counter: 165
                    Mileage: 266946 km
                    Date: 2022.09.12
                    Time: 10:22:19
                    Voltage: 14.00 V
                        DU
                    Temperature: 26.0°C
                    RPM: 1274 /min
                    Speed: 20.0 km/h
                    Speed: 20.0 km/h
   Part No SW: 8P0 959 802 M    HW: 8P0 959 802 M
   Coding: 0135860
   Part No SW: 8P0 035 152 E    HW: 8P0 035 152 E
   Component: R Chorus2+      H03 0280
   Revision: 00H03000    Serial number: AUZ1Z2I5627942
   Coding: 0200021
   VCID: 2D54AEF8B4F11CE5D8-8078
                    Time Indication: 15
                    Reset counter: 124
                    Mileage: 266939 km
                    Date: 2022.09.12
                    Time: 00:01:53
   Part No SW: 1K0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H17 0231
   Revision: --------    Serial number: 1321J09B2102DD
   Coding: 0303085A
   VCID: 68DA1FEC9B93F9CDEB-803C
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 124
                    Mileage: 266939 km
                    Date: 2022.09.11
                    Time: 23:57:19
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0131216
   Shop #: WSC 06314 000 1012544
   VCID: 428EED441D6FF39D15-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0131216
   VCID: 4380E8400275FA951E-8016
End-------------------------(Elapsed Time: 02:27)--------------------------
Knighty0007
Dorset, UK
HUC-2H
Have I put this scan in wrong place! Apologies if I have complete beginner!
What exactly is wrong with the radio?
The coding doesn't look far off. In fact, it's no obvious to me why it thinks it's "Incorrectly Coded".
OK, one speaker is flagged "Open Circuit". That will have to be hunted down with a multimeter.
Knighty0007
Dorset, UK
HUC-2H
I removed Radio and unplugged it. I also refitted some door cards. After replacing no sound or very low treble sound! The scan comes back with two faults bass speaker left hand door and wrong code or something similar..Checked speaker at door no definate issue accept plug a lit green oxidised? Guess its more likely I damaged a wire at speaker connection plug or in the loom or near door checked wiring at door no problems that I can see? Guess I will need to check wires for continuancy or unravel black cloth coating to find any broken wires. Worse still I could have damages something in radio although I was reasonably carefull removing it..The diagnositics advice is a little vague and I am not great at intepretatation of faults.. Just where to start Radio wires or speaker or Radio coding. I think maybe I'm over-complicating it...Not sure what too look at first as it could be one of 4 Things?
Westbury, UK
Check the wiring and connectors you disturbed while working in the door, and also that the connector in the back of the radio is fully seated and locked.
Time for the multimeter and the mark 1 eyeball :thumbs:
  • Agree
Knighty0007
Dorset, UK
HUC-2H
Turns out I have green connectors at speakers...Plus all speakers are shot nothing at rear doors soundwise driver side gone and passenger side rubbish! and very poor tweeters..Guess 12 years or more of use warrants a new set! Funny because week before when I purchased the vehicle had reasonable sound onto the other list of faults secondary water pump - airbags - steering. The list grows OMG the fun of second hand cars...Thanks for advice Uwe and PetrolDave :)
