2.0TDI Tiguan 2017- running rough
Martymc1
C?ID=107715
Fitted engine to a 2017 Tiguan, drive about 30 miles no problems now it’s jerking badly under acceleration especially in higher gears. Scanned with VCDS and no fault codes. Looked at live data but don’t see anything obvious. Anyone know what live data would be best to check. Starts and idles grand but if u put the foot down and lift straight off it seems to hunt up and down a bit before settling back to nice idle. Thanks
MasterTommy
Amsterdam
C?ID=295586
Is the ECM giving any codes? This would be a situation where deleting codes and seeing what comes back is not a good idea, instead observe sporadic codes that only appear every once in a while.
Whats the odometer reading?
Autoscan?
Reset adaptations after fitting engine?
Martymc1
C?ID=107715
here’s link to video of it idleing.
Martymc1
C?ID=107715
Thanks for the quick reply Tommy
69000 but engine is out of a 2019 that had delivery miles. Was dropped in complete except the dpf.
I reset adaptions after fitting and before test drive.
No codes showing since I put it in. Even when it’s running rough and it will barley drive in 5th and 6th gear it’s that bad it still doesn’t throw a code.
Il get an auto scan tomorrow and post it. Hi
MasterTommy
Amsterdam
C?ID=295586
Mileage would be relevant for the gearbox mostly.
Adaptations: Did you also reset the gearbox adaptations?
What was the cause of death of the old engine? Same engine code or different?
Martymc1
C?ID=107715
Gearbox is manual 6speed so didn’t reset anything to do with gearbox.
Old engine injector went and flushed engine with diesel. When replaced there was rattle from bearings. Engine fitted was same engine code DFG.
Martymc1
C?ID=107715
Seems to do it even if boost pipe to inlet is removed. Car drove perfect for bout 30 miles then this just came into it all of a sudden.
Martymc1
C?ID=107715
Monday,19,September,2022,11:56:09:48937
VCDS Version: 22.9.0.0 (x64)
VIN: WVGZZZ5NZJW314792 License Plate: TIGUAN 19/09
Mileage: 112134km-69676mi Repair Order:
Chassis Type 5N-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 4B 52 5F A5 BB BC CA
VIN: WVGZZZ5NZJW314792 Mileage: 112134km-69676miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 JC HW: 04L 907 309 P
Component: R4 2.0l TDI X25 3023
Revision: B4X25--- CVN: DBFBCE1D37C5C2A2
Coding: 0119001203471D082000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
ROD: EV_ECM20TDI01104L906026GQ_004.rod
VCID: 74ECC9FCDF04062D57-8020
VINID: 9E65EAAAA15EA9A9C30441C908C2A18519
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 51657000000321
Coding: 0AEE929A34210B70477E070962C54950492CD0E2E046927D34605078C02A4200002F641A1B13111435351919323200
VCID: 76E8F3F4C978143D69-8022
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 140
Mileage: 112012 km
Date: 2022.09.16
Time: 10:57:03
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 N HW: 5NA 907 044 N
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000E00566733
Coding: 0012012420211001110510000010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
VCID: 4A907704ED0020DDDD-801E
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 103
Mileage: 111990 km
Date: 2022.09.14
Time: 19:57:31
Outside temperature: 14.0 °C
Engine RPM: 0 /min
Temperature downstream of evaporator: 24.7 °C
Refrigerant pressure: 1.0 bar
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001719301130
ROD: EV_BCMBOSCH_018.rod
VCID: 09128808A8866BC514-805C
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 170601 033 0372
Serial number: 00000001705300302501
Component: RLHS 042 0105
Serial number: S5Y17M06D29H04M14S45
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000038690131
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Reset counter: 96
Mileage: 111990 km
Date: 2022.09.14
Time: 20:10:12
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: OFF
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.1 V
264452 - No Communications with Anti-Theft Sensor
U10F4 00 [009] - -
Reset counter: 96
Mileage: 111990 km
Date: 2022.09.14
Time: 19:57:30
Terminal 15 status: On
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
Part No SW: 3Q0 919 294 B HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0029
Serial number: 001306177478031
Coding: 0071451801
ASAM Dataset: EV_EPHBO18VW3260000 007018
ROD: EV_EPHBO18VW3260000_SK37.rod
VCID: 38743DCC83ECA24DBB-806C
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 2A0067C158FF8728749C8145604087
VCID: 3E782BD4A1C89C7D71-806A
2068 - Databus
Fault Frequency: 14
Reset counter: 143
Mileage: 111990 km
Date: 2022.09.15
Time: 18:04:07
Voltage terminal 15: 14.6 V
Control Module temperature: 25 °C
Velocity_vehicle_reference: 17.19 m/s
Longitudinal_acceleration_vehicle_reference: 1.69 m/s²
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWR34CHDD
Coding: 98CCC0C00C0000005C5400CF008800000065
Left seat belt tensioner:
Serial number: 5NC857705C0011R01661
Coding: 80000D
Right seat belt tensioner:
Serial number: 5NC857706C0006R00042
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 001 407 17
Serial number: 3570000000059990952K
Subsystem 4 - Part No SW: ----------- HW: 480 001 407 17
Serial number: 358000000003A180952B
Subsystem 5 - Part No SW: ----------- HW: 480 402 806 17
Serial number: 3510001C924A431252F-
Subsystem 6 - Part No SW: ----------- HW: 480 402 806 17
Serial number: 3520001C52527AF5C235
Subsystem 7 - Part No SW: ----------- HW: 480 402 806 17
Serial number: 3550001AF25B1D15230$
Subsystem 8 - Part No SW: ----------- HW: 480 401 910 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001A5275C8A66312
Subsystem 9 - Part No SW: ----------- HW: 480 401 910 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001C12645284219R
Subsystem 10 - Part No SW: ----------- HW: 480 401 910 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001C12645284C80R
Subsystem 11 - Part No SW: ----------- HW: 480 000 911 17
Serial number: I0M0000000010354B82V
Subsystem 12 - Part No SW: ----------- HW: 480 000 911 17
Serial number: I0N0000000018C24B823
Part No SW: 3Q0 953 521 CS HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20170117500308
Coding: 0010
Shop #: WSC 00002 790 00051
ROD: EV_SMLSVALEOMQB.rod
VCID: 030E9A208AAA31955E-8056
617752 - Selector Lever Park Position Lock Switch
B1162 29 [009] - Signal Implausible
Reset counter: 96
Mileage: 111990 km
Date: 2022.09.15
Time: 18:03:23
Ubat 30 Voltage: 14.20 V
Ignition State: On
Terminal 15: 13.40 V
A/D #1: 0.39 %
A/D #2: 0.00 %
A/D #3: 0.00 %
Part No SW: 5NA 920 791 B HW: 5NA 920 791 B
Component: KOMBI 407 3193
Coding: 27AD00006F8C060001887F031401000000000000
VCID: 42805F24D530F89D15-8016
16776982 - Databus
Reset counter: 96
Mileage: 111990 km
Date: 2022.09.14
Time: 20:06:32
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 16061710802510
Coding: 030500045F087300FB07225E0A0F00010001070000000000000000000000
GVL: 01D63C0000000000408C80000000480010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 336E0AE09A8A41158E-8066
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 39170001672310097246
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 1481374304
Serial number: HA1-00019.05.17
Coding: 0101
Component: TSG FS 020 0041
Serial number: 090417ED90843A
Coding: 003F0220D001048000001000
VCID: 438E5A20CA2AF1951E-8016
Component: EPS_MQB_ZFLS 128 1072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 458A4438C41ECFA530-8010
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Component: TSG BFS 020 0041
Serial number: 100617EFA19362
Coding: 003F0020DE01048000001000
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER H41 0469
Serial number: VWZAZ2T1424066
Coding: 02730601FF00000051110101008808001F0506E6012000008F
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 32600FE46590481D85-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT1911844
Subsystem 2 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
1637 - Interface for External Media
U11B8 00 [008] - No Communications
Reset counter: 143
Mileage: 112117 km
Date: 2022.09.16
Time: 15:23:37
Voltage terminal 30: 13.3 V
Interface for external media: status-Status: Open circuit
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 11071711P10866
Coding: 0003070600000401000213448150A90094000E200040
VCID: 3C7C21DCB7D48E6D5F-8068
Component: TSG HFS 020 0041
Serial number: 020717EG13818B
Coding: 002A00200100048000001000
Component: TSG HBFS 020 0041
Serial number: 060617EF606124
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:02)--------------------------
Martymc1
C?ID=107715
If I flock turbo actuator vaccine pipe and give it Rev it doesn’t do it but it goes into limp mode so not sure if it’s just a red hearing or not.
JMR
Romania
C?ID=432218
sounds like it's running on 3 pistons...?
Martymc1
C?ID=107715
Done a compression test and alls good that way. Even swapped over set of injectors to rule them out and no difference. Engine runs perfect until I give it a hard Rev and let off quick when sitting and when driving if I drive up the road accelerating steady it drives ok till I get too 3rd gear then u start to feel it starting to shake. 5th and 6th are near impossible if u try accelerating it really shakes bad but if u keep steady speed not as bad. Anyone know could it be a balance shaft? Or would it be doing it all the time.
Martymc1
C?ID=107715
Anyone know could egr be causing this? EGR was turned off and stage one map on last engine. When this engine was fitted and all adaptions carried out except EGR as it was turned off. So could driving the car after adaptions have somehow cause EGR to start to function incorrectly or even set slightly open hence the problem and no codes?
