Sunday,30,October,2022,21:43:57:21285
VCDS Version: 22.9.0.0 (x64) HEX-NET2 CB: 0.4623.4
Workshop Code: 123 12345 023456
VIN: WA1FVAF19KD006905 License Plate:
Mileage: 50016km-31078mi Repair Order:
Chassis Type: F1-AU58 (4K0)
Scan: 01 02 03 06 09 13 15 16 17 19 36 3C 42 44 46 47 52 5F 61 69
6D 74 81 82 A5 BB BC C4 CA CB CC CD CF D6 D7 DB DC DE
VIN: WA1FVAF19KD006905 Mileage: 50016km-31078miles
82-Head Up Display -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DCBD) Labels: None
Part No SW: 4M8 907 559 A HW: 06M 907 309 G
Component: V6 3.0l TFSI H11 0003
Revision: B8H11000 CVN: A185EFD6
Coding: 2A2A0012257E010E34286000000400000000000000000000
Shop #: WSC 10569 003 1048576
ASAM Dataset: EV_ECM30TFS0114M8907559A 001003
ROD: EV_ECM30TFS0114M8907559A.rod
VCID: 3D2C56DE5DF49CB3CC5-8068
VINID: 9D105699158125B50000624014CB3DEED2
Readiness: 1110 0101
Part No SW: 4M0 927 158 AM HW: 0D5 927 156 P
Component: 0D5 30TFSINAR H05 1004
Revision: --H05--- CVN: 434FF4CE00009238
Coding: 100000
Shop #: WSC 31414 041 00001
ASAM Dataset: EV_TCMALX52011 002015
ROD: EV_TCMALX52011_VW53.rod
VCID: 7F506CD617784EA39E9-802A
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP H01 0705
Serial number: 1808201008
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M6 907 379 N HW: 4M6 907 379
Component: ESP9 Premium H06 0850
CVN: 96E0A93A
Coding: 28AA169631A20B9C93A75C911882D6E2F43A8914688CD0C93A186B472F5C91
Shop #: WSC 31414 244 00001
ROD: EV_ESP9BOSCHCMP_AU58.rod
VCID: 48C2370A0236C91B6F3-801C
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M8 959 760 B HW: 4M6 959 760 B
Component: MEM-BFS 009 0064
Serial number: 00000340514600
Coding: 011CB2400001BEA14843010101010000810000070700878700000000000000
Shop #: WSC 17361 004 1048576
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
VCID: 3FD02CD657F88EA3DE9-806A
Valve block 1 in front seat passenger side:
Subsystem 1 - Part No SW: 4M0 907 182 HW: 4M0 907 182
Component: N477 VB1 BFSv H06 0030
Serial number: SJ800106081840258096
Coding: BF2F00
Valve block 2 in front seat passenger side:
Subsystem 2 - Part No SW: 4M0 907 182 A HW: 4M0 907 182 A
Component: N478 VB2 BFSv H06 0030
Serial number: SJ8001110818114701C0
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Coding: 07000363C0290CDD070E17889CFF9C38131B37110406009781010A001B331601086309020010000000000303004308181802000044010104000000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74BAB3FA2E3E1DFBF3B-8020
Wiper motor control module:
Subsystem 1 - Part No SW: 4M8 955 119 HW: 4N1 955 119
Component: J400FRWISCH 052 0997
Serial number: 904753F0401813100151
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 21768440X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4K1 941 501 A HW: 4K1 941 501 A
Component: E1 - LTM H09 0086
Serial number: 16S14.05.2200690151
Subsystem 4 - Part No SW: 4N0 907 410 B HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600368Z012P02
Coding: 250000
Automatic dimming interior mirror:
Subsystem 5 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE128051823610002
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 L HW: 4K0 947 135 L
Component: Dachmodul H42 0413
Serial number: Q00608977
Coding: 0D0104
Adjustable Steering Column Control Module:
Subsystem 7 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA133581000053314942
Coding: 0A0100
Blower 1 for left front backrest:
Subsystem 8 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V512 LLR1SLvL H03 0012
Serial number: L14DI17600725
Blower 1 for left front seat cushion:
Subsystem 9 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V514 LLR1SKvL H03 0012
Serial number: L14DI21900355
Blower 1 for right front backrest:
Subsystem 10 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V516 LLR1SLvR H03 0012
Serial number: L14DI17600713
Blower 1 for right front seat cushion:
Subsystem 11 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V518 LLR1SKvR H03 0012
Serial number: L14DI17800861
Front windshield washer pump:
Subsystem 12 - Part No SW: 4N0 907 605 C HW: 4N0 907 605 A
Component: J1100/SWP H21 0015
Serial number: 00000000001821400188
Coding: 020000
393476 - High Pressure Sensor
B10AE 21 [009] - Signal Amplitude Too Low
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:28
average_Voltage_terminals: 12.50 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 15.00 °C
interior_temperature: 19.00 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4M0 907 561 L HW: 4K0 907 561
Component: LRR4R H04 0332
Coding: D6659F5C78082C00010360E1000000BE4A1246484481009E04
Shop #: WSC 00023 444 00000
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 392442CE49DCA093E0D-806C
2342 - Databus
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:24
Control Module temperature: 49 °C
Voltage terminal 15: 12.3 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s˛
Adaptive distance regulation: status: ACC_reversible_error
Steering_angle-Data: -348.900 °
Yaw_rate-Data: -0.011 rad/s
adjustment_calculation: On
Misalignment angle: horiz: 0.077 °
Misalignment angle: horiz: fast algorithm: 0.379 °
Congestion pilot: status: OFF
Outside temperature: 15.00 °C
Sensor blindness: radar: no blindness detected
0795 - Databus
[FAULT_APS_RELEVANT_ERROR]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:24
2341 - Databus
[FAULT_LIDAR_ERROR]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:24
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 K HW: 4N0 959 655 K
Component: AirbagVW31 H02 2710
Serial number: 003YUM0087BT
Coding: AECCFCC000C00000A000003FF20D410000C5
Shop #: WSC 31414 028 00001
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_VW53.rod
VCID: 44DA233A3E1EED7B83B-8010
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2018213000700000
Coding: 02F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2018216606200000
Coding: 02F001
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J18000A22XQ0I
Coding: 303038
Subsystem 4 - Part No SW: ----------- HW: 480 001 708 18
Serial number: 35700000000D47DCA23-
Subsystem 5 - Part No SW: ----------- HW: 480 001 708 18
Serial number: 3580000000082B50633B
Subsystem 6 - Part No SW: ----------- HW: 480 030 908 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C144084D012CE%
Subsystem 7 - Part No SW: ----------- HW: 480 030 908 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C1440049D02E1W
Subsystem 8 - Part No SW: ----------- HW: 480 031 807 18
Component: FrontSensor_D 002 0149
Serial number: 355001C14F384D00E80A
Subsystem 9 - Part No SW: ----------- HW: 480 031 807 18
Component: FrontSensor_P 002 0149
Serial number: 356001C143DE027129DA
Crash sensor for side airbag: B-pillar: driver side:
Subsystem 10 - Part No SW: ----------- HW: 480 030 908 18
Component: SideSens_B_Df 002 0149
Serial number: 352001C1440044E02FE%
Crash sensor for side airbag: B-pillar: passenger side:
Subsystem 11 - Part No SW: ----------- HW: 480 030 908 18
Component: SideSens_B_Pf 002 0149
Serial number: 355001C144004A60FB50
9466644 - Crash Signal
B1073 14 [137] - Open or Short to Ground
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:25
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4N0 907 129 Q HW: 4N0 907 129 Q
ROD: EV_SMLSKLOAU736_AU58.rod
Address 17: Instruments (J285) Labels: None-SRI2
Part No SW: 4K0 920 890 C HW: 4K0 920 890 C
Component: FBenUSAACC--- H11 0153
Coding: 8BC610E77C88410D0283E1609880680008003000
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2E0E61928092772B45F-807A
Part No SW: 4K0 907 468 C HW: 4K0 907 468 C
Component: Gateway H05 0117
Serial number: 18F01003775401
Coding: 020100050004064054960000005B0132DC9A00471C000000097D078E10000000
Shop #: WSC 12345 123 23456
GVL: F1513C080800000082FC88000100C800110E0070000000000000000000000000
ASAM Dataset: EV_Gatew31xAU65x 003160
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 343A73FA6EBE5DFB33B-8060
Subsystem 1 - Part No SW: 4M8 951 523 A HW: 4M8 951 523 A
Component: J453 MFL H03 0004
Serial number: 20180808160356 31205
Subsystem 2 - Part No SW: 4K0 915 181 A HW: 4K0 915 181 A
Serial number: 75885202001808240EFD
16711990 - Ethernet Databus Branch 1
U122C 00 [009] - No Communication
[Ethernet_databus_no_communication_port_1]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:24
Ethernet counter checksum error: branch 1: 0
Ethernet counter connection interruptions: branch 1: 25
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 009 0064
Serial number: 00000340500866
Coding: 011C9A400001BEA14803010101010000810000070700878700000000004000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
Valve block 1 in front seat driver side:
Component: N475 VB1 FSv H06 0030
Serial number: SJ800115081840258340
Coding: BF2F00
Valve block 2 in front seat driver side:
Component: N476 VB2 FSv H06 0030
Serial number: SJ8001180818114700A2
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 E HW: 4N0 907 566 A
Component: MRR_HR H12 0265
Coding: 1FFC00
Shop #: WSC 31414 243 00001
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_VW53.rod
VCID: 382247CA72D6B99B1F3-806C
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 793 J HW: 4M1 959 793 D
Component: TSG FS001 0425
Serial number: YE007RH410213
Coding: 001DDB43520014C2A009A434
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 46DE39320822DF6B9DF-8012
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Coding: B2000101010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 31347AEE91AC68D358D-8064
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 FP HW: 8W0 907 064 DP
Component: BCM2 MLBevo 025 0405
Coding: 0134000049A100C0650FA0046C01C80203004000810422502F0400200F04823F001E0101010F01
ASAM Dataset: EV_BCM2HellaAU736 015015
ROD: EV_BCM2HellaAU736_015_AU58.rod
VCID: 0F70DC1627D85E236E9-805A
Subsystem 1 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000158892
left tail lamp 1:
Subsystem 2 - Part No SW: 4M8 945 069 C HW: 4M8 945 069 C
Component: SHL_li1 H04 0004
Serial number: 069C1808080000006234
Subsystem 3 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11143506
left tail lamp 2:
Subsystem 4 - Part No SW: 4M8 945 217 G HW: 4M8 945 217 G
Component: SHL_li2 H04 0004
Serial number: 217G1808030000005429
Right rear tail lamp 1:
Subsystem 5 - Part No SW: 4M8 945 070 C HW: 4M8 945 070 C
Component: SHL_re1 H04 0004
Serial number: 070C0101010000000000
Right rear tail lamp 2:
Subsystem 6 - Part No SW: 4M8 945 218 G HW: 4M8 945 218 G
Component: SHL_re2 H04 0004
Serial number: 218G1808030000005429
Part No SW: 4N0 035 223 C HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0170
Revision: 00000001 Serial number: AUZ8ZAJ6S008NEB
Coding: 0135360A00AAAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
ROD: EV_AMPMst16C1Gen2pALPI.rod
VCID: 241A83BADE5ECD7BA3B-8070
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M1 959 792 J HW: 4M1 959 792 D
Component: TSG BFS001 0425
Serial number: YE007RH305736
Coding: 001DDB035E0014C2A009A434
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 45DC3E3E3524D473945-8010
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 084 D HW: 4K0 035 084 A
Component: MU-H-LNS-US 046 2711
Coding: 0135360100000000C1110002061C00302F0001E401F008048E
ROD: EV_MUHigGen2pALPI_AU27.rod
VCID: 270094B6AF682663869-8072
Data carrier:
Subsystem 1 - Part No: V03 959 804 BM
Component: MIB2P_EU_Q120 0440
Multimedia System 1:
Subsystem 2 - Part No SW: 4M8 919 605 B HW: 4M8 919 605
Component: DU AU536 High H41 0147
Serial number: INX00105071800100257
Compact disc data bank:
Component: Gracenote2 1006
Volume Control 1:
Subsystem 4 - Part No SW: 4N1 919 616 B HW: 4N1 919 616
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000156366004
Multimedia System 5:
Subsystem 5 - Part No SW: 4N0 919 603 C HW: 4N0 919 603
Component: DU AU651 Bot H41 0147
Serial number: INX00130061800050726
Media Player 1:
Subsystem 6 - Part No SW: 4N0 035 123 HW: 4N0 035 123
Component: DISC PLAYER H06 0006
Serial number: AUZ8ZCJKJ00G920
Media socket:
Subsystem 7 - Part No SW: 4N0 035 726 A HW: 4N0 035 726
Component: MediaConnectL 014 0133
Serial number: 051800501372007
1598 - Data Set Implausible
B2012 00 [009] - -
[Control module (data record download) - implausible data record for visible MMI system languages]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:23
Voltage terminal 30: 12.5 V
B201A 00 [009] - -
[Check software version management]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:30
Status_Software_Version_Management-module_name: UPDATESTARTED
Address 61: Battery Regul. (J1120) Labels: 4M0-915-105.clb
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 2904928EB97C101390D-807C
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 E HW: 4M0 907 383
Component: Anhaenger H27 0253
Revision: 9C001003 Serial number: 0490784772
Coding: 0210000200000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
Part No SW: 4M0 959 107 D HW: 4M0 959 107 A
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C737-6252-2
Coding: 28B0
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW27.rod
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4M8 907 777 N HW: 4M8 907 777
Component: Fahrwerk-SG H51 2031
Serial number: 2907180804
Coding: B85C5850F840
ASAM Dataset: EV_ChassContrContiAU651 001011
ROD: EV_ChassContrContiAU651_001_AU58.rod
VCID: 4CCA0B1A164E253B4BB-8018
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130377181
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4N1 713 041 D HW: 4N1 713 041 C
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 18071348276260
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736_VW53.rod
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 4M8 919 617 B HW: 4M8 919 617 B
Component: HeadupDisplay H06 1815
Coding: 4700E0
ASAM Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_AU58.rod
VCID: 3C2A5BDA46EE95BBFBB-8068
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AR HW: 4N0 907 107 H
Component: zFAS Var C H09 0295
Coding: 020184000000000000FFD60000F0C70C139F7600000000000000000000969401019BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001006
ROD: EV_ZFASAU516_001.rod
2114638 - Databus
[LS1_SensorHeader_LS1_Fehler]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:23
233538 - Front Left Center Parking Aid Sensor
B10F8 31 [009] - No Signal
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:28
233552 - Front Right Parking Aid Sensor
B10FA 31 [009] - No Signal
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:28
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:23
Part No SW: 4M1 959 795 J HW: 4M1 959 795 D
Component: TSG HFS003 0425
Serial number: YE007RGR28895
Coding: 000DDB03000014C2E008A024
Component: TSG HBFS003 0425
Serial number: YE007RGR28898
Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
Component: PCU10 022 0324
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
VCID: 3A265DC24CDAAB8BE97-806E
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Coding: 228040053632
ROD: EV_SunRoofCONTIAU736_009_AU58.rod
VCID: 75BC8EFE254404F3C45-8020
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4M0 909 145 AA HW: 4M0 909 145 E
Component: HAL_MLBevoH08 0698
Revision: -------- Serial number: CCC_098_B_1122_
Coding: 42242A00
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010.rod
VCID: 6FB0BC9647183E230E9-803A
Address CC: Starter-Generator (----) Labels:* None
Part No SW: 4N0 903 028 N HW: 4N0 903 028 N
Component: BSG-HP1-65 H17 0523
Serial number: 13081800020083
Coding: 20000400000000
ASAM Dataset: EV_Start48VAU651 001006
ROD: EV_Start48VAU651_001.rod
VCID: 363E49F278C24FEB0DF-8062
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0202
ASAM Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 353C4EFE65C444F3045-8060
11575298 - No Basic Setting
B2010 00 [009] - -
[Error_while_adjustment]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:23
Control Module temperature-Host: external temperature: 40 °C
Control Module temperature-Zynq: internal temperature: 56 °C
Control Module temperature-Host: internal temperature: 38 °C
Control Module temperature-Zynq: external temperature: 28 °C
Voltage terminal 15: 12.166 V
Performed adjustment-Year: 2000
Performed adjustment-Month: 5
Performed adjustment-Day: 20
Performed adjustment-recorded yaw angle: -4.77 °
Performed adjustment-Saved pitch angle: 0.86 °
Performed adjustment-Store sway angle: -1.24 °
Status adjustment-Status: Marginal conditions have not been met
Status adjustment-Reason: Engine running
11562752 - invalid data record
B2005 00 [009] - -
[DSDL_Dataset_invalid]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:23
Voltage terminal 15: 12.185 V
11562500 - Control Module Does Not Match Vehicle
B2006 00 [009] - -
[wrong_VIN_detected]
Reset counter: 174
Mileage: 50016 km
Date: 2022.10.30
Time: 12:40:24
Voltage terminal 15: 12.297 V
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0265
Coding: 1FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_VW53.rod
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0030
ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 72B6B5E2542A13CBE17-8026
ASAM Dataset: EV_LMSRightHELLAAU58X 001013
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 E HW: 4N0 907 669 A
Component: MRR_VR H12 0265
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651_VW53.rod
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H12 0265
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4N0 035 502 A HW: 4N0 035 502 A
Component: WLC Front H10 0061
Coding: 800000
Shop #: WSC 31414 043 00001
ROD: EV_Charg1MobilDevicAU651.rod
VCID: 221685A2C44AC34BD17-8076
End----------(Elapsed Time: 02:31, VBatt start/end: 12.4V/12.3V)-----------
