Developer diagnostic session in 5F (hardware 760035067B) for Touareg CR
Vne
Brisbane, Australia
C?ID=501097
Hi all, I'm looking for a way of enabling the "development mode" diagnostic session in 5F.
Tried login S12345 but it doesn't work. I read elsewhere on the forum that maybe this isn't enabled in my label file?
Motive - I need to be in this diagnostic mode so that I can set the adaptation channel "development mode" to "active" - needed to get to the green engineering menu.
I can use OBDEleven to do this, but I'd rather do everything through VCDS :)
Autoscan below.
Saturday,17,September,2022,17:42:17:24072
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVGZZZCRZMD002748   License Plate:
Chassis Type: CR-VW53 (4K1)
Scan: 01 02 03 06 09 13 15 16 17 19 29 2B 36 39 3C 42 44 46 47 52
          5F 61 65 6D 74 81 82 84 A5 AC BA BB BC C4 CB CF D4 D5 D6 D7
          DB DC DE
VIN: WVGZZZCRZMD002748   Mileage: 14438km-8971miles
C4-DC/DC Converter -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
D4-Roll Control 1 -- Status: OK 0000
D5-Roll Control 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DMVB)       Labels: None
   Part No SW: 760 907 409     HW: 057 907 309 B
   Component: 4.0l V8 TDI   H45 0004
   Revision: D1H45---    CVN: 3C20F3FBCB07ACF48947E11D8947E11DD6C3ECFE
   Coding: 292A4012056E050334280000000400000000000000000000
   Shop #: WSC 31414 033 00001
   ASAM Dataset: EV_ECM40TDI011760907409 001006
   ROD: EV_ECM40TDI011_VW53.rod
   VCID: 5AED9D733C9A995BC97-800E
   VINID: 9E65EAAAA4E2A9D5000021C4201E7321AE
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 760 927 158 G    HW: 0D6 927 156 K
   Component: 0D6  40TDIRdW H05 1001
   Revision: --H05---    CVN: 6BBF8CA5
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 2411E38B4E5E1FABA3B-8070
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M6 907 379 AF    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0857
   CVN: BB85F83B
   Coding: 2DA73AB730A20B9896A54D951C8516E6E93AE9B45C0CD069B2386867975C97
   ROD: EV_ESP9BOSCHCMP_VW53.rod
   VCID: 015F8A1FF18CEA83E8D-8054
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000416282166
   Coding: 0138BA000001B6A1C8000101210100008900000707008F8F00000000215000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D2736EFCDF44E63CC5-8068
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001080720402588A8
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ8001050720114700BB
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 JE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0712
   Coding: 07501B40E13B0009170F17085B6B0C40000B321100200093011008007B25F6019BC5011B0417C8170000030100D129085800040044010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 7AADFDF39C5AB95BA97-802E
   Subsystem 1 - Part No SW: 762 955 113     HW: 762 955 113
   Component: WIPER 230720  011 0420
   Serial number: VZ1SKA 1001458230720
   Serial number: 25069946X81A955555A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 762 941 633     HW: 762 941 633
   Component: E1 - LTM  H06 0054
   Serial number: 13S28.07.2000140167
   Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
   Serial number: GX1CE121022020810556
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 760 947 105 AB    HW: 760 947 105 AB
   Component: Dachelektroni  H32 0057
   Serial number: 00001248840000000000
   Subsystem 6 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H07 0200
   Serial number: WA141817000083304394
   Coding: 020300
   Subsystem 7 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BK209A5866
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BK20631121
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BK20731921
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BK213A9438
   Part No SW: 760 907 561 D    HW: 760 907 561 A
   Component: LRR4R         H04 0490
   Coding: 326547D478000400000020A000000034451246484401009E01
   ASAM Dataset: EV_ACCBOSCHAU65X 002026
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 1D67D66F6D342E63EC5-8048
   Part No SW: 4M0 959 655 P    HW: 4M0 959 655 R
   Component: AirbagVW31    H17 2844
   Serial number: 003YYM009F6.
   Coding: 88FCC0C00CC0000058540000009D39A80065
   Shop #: WSC 31414 030 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 48C9573B92361BCB6F3-801C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4N0 980 945 B    HW: 4N0 980 945 B
   Component: BeltPretRevFL  H21 0115
   Serial number: 00AI2020192672700000
   Coding: 04F001
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4N0 980 946 B    HW: 4N0 980 946 B
   Component: BeltPretRevFR  H21 0115
   Serial number: 00AI2020192668400000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 002 807 20
   Serial number: 357000000002585C0A4I
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 20
   Serial number: 35800000000883B02A4J
   Subsystem 5 - Part No SW: -----------    HW: 480 033 007 20
   Serial number: 351002C00E44CCC13E5I
   Subsystem 6 - Part No SW: -----------    HW: 480 033 007 20
   Serial number: 352002C0832A6910FBAD
   Subsystem 7 - Part No SW: -----------    HW: 480 030 207 20
   Component: FrontSensor_D  002 0189
   Serial number: 355002C0832B2DB04EBK
   Subsystem 8 - Part No SW: -----------    HW: 480 030 207 20
   Component: FrontSensor_P  002 0189
   Serial number: 356002C0832B6E30CD9N
   Subsystem 9 - Part No SW: -----------    HW: 480 032 807 20
   Component: PedP_Sensor_D  002 014A
   Serial number: 228002C004F53AB05BFJ
   Subsystem 10 - Part No SW: -----------    HW: 480 032 807 20
   Component: PedP_Sensor_P  002 014A
   Serial number: 229002C08939F9E0DB8/
   Subsystem 11 - Part No SW: -----------    HW: 480 032 907 20
   Component: PedP_Sensor_C  002 014A
   Serial number: 230001C2445671F10C8/
   Subsystem 12 - Part No SW: -----------    HW: 480 002 307 20
   Serial number: I0M00000000C068D79CL
   Subsystem 13 - Part No SW: -----------    HW: 480 002 307 20
   Serial number: I0N00000000D068D79CN
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 760 953 507 C    HW: 760 953 507 C
   Component: Lenks.Modul   H03 0006
   ROD: EV_SMLSKLOAU736_VW53.rod
   Part No SW: 762 920 790 C    HW: 762 920 790 C
   Component: FHybRDW       H14 0409
   Coding: A5A630E27E88000800A86B2EF0F05800FC0000A0
   ASAM Dataset: EV_DashBoardAU65X 001018
   ROD: EV_DashBoardAU65X_VW53.rod
   Control head driving profile:
   Subsystem 1 - Part No SW: 760 927 531 G    HW: 760 927 531 G
   Component: E881 BedieFPA  001 0460
   Serial number: 000000091171TGG000NT
   Level control system control head:
   Subsystem 2 - Part No SW: 760 927 135 B    HW: 760 927 135 B
   Component: E281 BedieNiv  001 0110
   Serial number: 000000091171TGM000NJ
16777058 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [BAP_OnlineFunctions_0x2A communication error bap_error_timeout heartbeat]
                    Reset counter: 32
                    Mileage: 14438 km
                    Date: 2022.09.17
                    Time: 17:39:04
   Part No SW: 4K1 907 468 M    HW: 4K1 907 468 C
   Component: Gateway       H06 0506
   Serial number: F0454940581781
   Coding: 0303000700088E407F07000000DB053A5E9E00073C0000000300000000000000
   GVL: F1593C088844020002FC88000100C800010C0070000000000000000000000000
   ASAM Dataset: EV_Gatew31xAU65x 003210
   ROD: EV_Gatew31xAU65x_VW53.rod
   VCID: 3FDB4CE7C7F85C73DE9-806A
   Subsystem 1 - Part No SW: 1EA 959 442 B    HW: 1EA 959 442 B
   Component: MFL  H03 0217
   Serial number: 17036218081832000790
   Coding: AF6702
   Serial number: 4733625005
   Subsystem 3 - Part No SW: 5H0 959 542 C    HW: 5H0 959 542 C
   Component: KLR_JSS_1Zone  074 0019
   Serial number: 3131681AA20203128501
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H07 0022
   ROD: EV_LCMLeftCONTIAU426_VW53.rod
   VCID: 30391FDB0AA6B30B573-8064
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 20000004263001
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 343113CBFEBE8F2B33B-8060
   Serial number: 00000416281942
   Coding: 01389A400001BEA1C8000101210100008900000707008F8F00000000215000
   Shop #: WSC 31414 053 00001
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ800103082040258817
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ8001030820114701C5
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 4N0 907 566 K    HW: 4N0 907 566 A
   Component: MRR_HR H14 0486
   Coding: 47F400
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_VW53.rod
   VCID: 3E2531E3C0F2557BD5F-806A
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0430
   Serial number: YE007TFB07716
   Coding: 003F9A00DE01048200013092
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 46D5590398220DBB9DF-8012
   Coding: B2130301000100
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D15D304AA811B217-8066
   Part No SW: 4N0 907 064 EP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H16 0224
   Coding: 01352C002F302048732B80061C00080003004000044F02502F0400000F08803F001F31D40D0001
   ASAM Dataset: EV_BCM2CONTIAU651 011009
   ROD: EV_BCM2CONTIAU651_011.rod
   ID - sensor:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY2019017DG
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000001144269
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14674974
   Rear spoiler control module:
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 E    HW: 3Q0 035 466 E
   Component: MIB2_amp_P_VW H55 0340
   Revision: 00000001    Serial number: VWZ8Z1LMB00P51C
   Coding: 1235060001AAAA2AAA0000000000
   ASAM Dataset: EV_AMPMst16CFGen2ALPI 001001
   ROD: EV_AMPMst16CFGen2ALPI.rod
   VCID: 313F1ADF01ACBA0358D-8064
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0430
   Serial number: YE007TF425285
   Coding: 003F9A00DE01048200013090
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 45D75E0FA52406A3945-8010
   Part No SW: 760 035 067 B    HW: 760 035 067 B
   Component: MU-H-LN-RW    057 2838
   Coding: 023506080000000043510002000908301F0200E601A004005F
   ROD: EV_MUHigGen2pALPI_VW53.rod
   VCID: 1471B34B9EFE6F2B53B-8040
   Subsystem 1 - Part No SW: 762 919 618     HW: 762 919 618
   Component: ABT_Prem_R  H40 5211
   Serial number: VWZ6ZGX2090106
   Subsystem 2 - Part No: V03 959 809 AF
   Component: MIB2P_RW_Q321  0573
   Compact disc data bank:
   Component: Gracenote2  4012
   Volume Control 1:
   Subsystem 4 - Part No SW: 762 927 341     HW: 762 927 341
   Component: VW536LLB  H06 0109
   Serial number: 2020020600000144
   Media socket:
   Subsystem 5 - Part No SW: 760 035 953     HW: ÿÿÿÿÿÿÿÿÿÿ
017 0414
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4M0 915 169 F    HW: 4M0 915 169 E
   Component: BMS_48V_SCAP  H07 0114
   Serial number: 202000001500111
   ASAM Dataset: EV_SCAP0213061 001004
   ROD: EV_SCAP0213061.rod
   VCID: 363529C3E8C29D3B0DF-8062
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 3F0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFVW536   H06 0003
   Serial number: 40000000035144
   ASAM Dataset: EV_RDKHUFVW536 002002
   ROD: EV_RDKHUFVW536.rod
   VCID: 6597BE8F05E426A3745-8030
   Part No SW: 4M0 959 107 G    HW: 4M0 959 107 C
   Component: HDSG-Modul    H14 0172
   Revision: --------    Serial number: A2-C756-6240-8
   Coding: 1778
   VCID: 372B24C7EFC86433169-8062
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 S    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H37 1253
   Serial number: 3007201052
   Coding: 32506948F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 49CF523F893CE2C370D-801C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132012626
   Coding: 303030
   Part No SW: 762 713 041 B    HW: 4M2 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20072060953343
   ROD: EV_GSMWaehlZFAU736_VW53.rod
   VCID: 117FBA5FA1EC9A0378D-8044
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 762 919 608 B    HW: 762 919 608 B
   Component: HeadupDisplay H06 0214
   Coding: DF40C8
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 221DE593544A119BD17-8076
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 760 907 547 A    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H13 0084
   Serial number: 645976300202030
   Coding: 200111
   ASAM Dataset: EV_NightVisioG3AUTOLVW536 001003
   ROD: EV_NightVisioG3AUTOLVW536.rod
   VCID: 1E65D1636032357BF5F-804A
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H07 0007
   Serial number: 639589400B2017500024
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* Redir Fail!
   Part No SW: 4K4 907 117 D    HW: 4K4 907 117
   Component: zFAS Var C    H09 0364
   Coding: 04C284000000000000FBD60000F8C40E5B9B5600000000800000000000961403E4BBBA000000000000000080C00000000000000000000000F9C080000000000000001C90000000B00080008000000000008040000020
   ASAM Dataset: EV_ZFASAU516 003008
   ROD: EV_ZFASAU516_003_VW53.rod
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 E    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0007
   ASAM Dataset: EV_RDCMINERGAU736 005014
   ROD: EV_RDCMINERGAU736_VW53.rod
   VCID: 333310D7FBB088132A1-8066
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Component: AEMevo        H10 0132
   ASAM Dataset: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_006.rod
   Part No SW: 4M1 959 595 J    HW: 4M1 959 595 D
   Component: TSG HFS004 0430
   Serial number: YE007TFI17304
   Coding: 003E92000000048000013080
   Component: TSG HBFS004 0430
   Serial number: YE007TFI17307
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 682     HW: 4K0 959 682
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC20303000230
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_VW53.rod
   VCID: 76B5E9C3A842DD3BCDF-8022
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_
   Coding: 42248A00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 6FBBDCA7D718ECF30E9-803A
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H14 0486
   Coding: 47F400
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_VW53.rod
Address D4: Roll Control 1 (----)       Labels: None
   Part No SW: 971 907 156 Q    HW: 971 907 156 L
   Component: EAWSH17 0113
   Serial number: 00120200721070
   ASAM Dataset: EV_EAWSSchaeFront 008001
   ROD: EV_EAWSSchaeFront_VW53.rod
   VCID: 2E0501A31092A5FB45F-807A
Address D5: Roll Control 2 (----)       Labels: None
   Serial number: 00120200729047
   ASAM Dataset: EV_EAWSSchaeRear 008001
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 AA    HW: 7PP 941 592 A
   Component: LED1L         H09 4002
   ROD: EV_LEDModLeftMELCOAU736_VW51.rod
   VCID: 176BC4478F084433369-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H09 4002
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 K    HW: 4N0 907 669 A
   Component: MRR_VR H14 0485
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
   ROD: EV_FrontCorneRadarS1AU651_VW53.rod
   VCID: 42DD4513B40A319BB17-8016
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H14 0485
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
   ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400000
   VCID: 2313E0974B501893DA1-8076
End----------(Elapsed Time: 02:54, VBatt start/end: 12.2V/12.2V)-----------
Well, it can't be enabled in a file that doesn't exist, right?
@Dana ...?
Vne
Brisbane, Australia
C?ID=501097
@Dana ...?
Ha true!
Cut me some slack, I'm new to VCDS :)
AINils
Germany (AIB)
C?ID=56975
Just be patient, Dana will release fast I think.
But actually there's no need for it I think. GEM /DEV Menu is locked in these units from factory
Hi Guys,
I don't know if this Gen 2 unit will allow Dev mode but I added that 5F part number to the redirect so it will load 4M0-035-MIB-HGH2.clb data.
I'll send you an email containing that file if we don't have enough new files to create a new VCDS updater. We should have this sorted out within 30 min.
Vne
Brisbane, Australia
C?ID=501097
@Dana thank you, that worked perfectly.
I can now enable dev mode and get to "TestMenu" which has a bunch of things like HMI debug, SWDL, Test & Erprobung and "Green Engineering Browser Menu". My italic, interesting name.
Tapping on "Green Engineering Browser Window" is not so successful ("No connection available. Please reload the page"). Maybe it's a thing with the MH2P units. I'll continue my investigations.
Thanks again 👍
