Trouble with ACC retrofit
brendan_
Boston, MA, USA
C?ID=516305
I have been working on retrofitting various driver assistance systems into my 2015 Golf MK7 TDI Variant. I have the lane assistance camera fitted, although the wiring harness has no arrived yet, so I am continuing this retrofit as if I do not have a lane assistance camera. I have fitted new steering wheel buttons on the left side to include ACC and driver assistance, as shown below.
I have finally got a chance to mount and wire the radar, although there are a few issues. I'm not even quite sure what the errors are, aside from calibration. I will post the scan below, any help is appreciated.
Thursday,15,September,2022,18:11:37:55940
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: 3VWCA7AU3FM515369   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU3FM515369   Mileage: 171466km-106544miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9459
   Revision: 85H23---    CVN: B5ADD45238D3FF82B866C2AD
   Coding: 011D0012034410081000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B23395723E80893F21-806E
   VINID: 0E69D34474650D67450450C624EBB8C5E7
Readiness: 0 0 0 1 1
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01503163011 CVN: 0000EF4F
   Shop #: WSC 00066 790 00218
   ROD: EV_TCMDQ250021.rod
   VCID: 2313E137BB585053DA1-8076
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 51085000000641
   Coding: 04FA6AA124210971007A020681CC2520562490004081A4B200630050C002
   Shop #: WSC 00046 000 00000
   VCID: 47CB55A76F205C73669-8012
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:10
   Revision: 00021000    Serial number: 0365009729
   Coding: 030C0C
   Shop #: WSC 12345 123 61029
   VCID: 3A2D3C532CD2319BE97-806E
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104202100000000000010000000
   VCID: 05579FAF15AC8E63D45-8050
   Part No SW: 5Q0 937 087 S    HW: 5Q0 937 087 S
   Revision: --------    Serial number: 8658061116000M
   Coding: 0001184240C182F969E44000000403001808000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4BC369977348B813421-801E
   Component: WWS    150327  043 0581
   Serial number:         150518181529
   Subsystem 2 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
   Component: RLHSS  052 0122
   Serial number: S7Y20M10D30H19M14S05
   Coding: 00A8DD
   Humidity sensor: interior:
565764 - LED Light Bar
          B1664 31 [009] - No Signal
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:08
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 14.4 V
                    Outside temperature: 19.5 ∞C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Coding: 35000001CFEFCF28949F81A461400000000000000099400000
   VCID: 44D142AB5E16776B83B-8010
10 Faults Found:
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
                    Control Module temperature: 53 ∞C
                    Voltage terminal 15: 14.3 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
201218 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING2SWAP_GRP_ACC_EXTS]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
201217 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING2SWAP_GRP_ACC_TYPE]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
201219 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING2SWAP_GRP_AWV_TYPE]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
201225 - No Enable Identifications Active
          B2032 00 [009] - -
          [FAULT_SWAP_NO_FAS_FUNCTION]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
1233 - Databus
          [FAULT_TIMEOUT_HCA_01]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 126
                    Mileage: 171466 km
                    Date: 2022.09.15
                    Time: 18:09:07
   Serial number: 003GCR01MTC-
   Shop #: WSC 01383 790 50316
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J150002Q8BT0I
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 002 403 15
   Serial number: 3570000000053D41831A
   Subsystem 3 - Part No SW: -----------    HW: 480 002 403 15
   Serial number: 35800000000870718318
   Subsystem 4 - Part No SW: -----------    HW: 480 403 103 15
   Serial number: 3510002C71941315012E
   Subsystem 5 - Part No SW: -----------    HW: 480 403 103 15
   Serial number: 3520002A31A87850C1E5
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 15
   Serial number: 3550002C3194131211EO
   Subsystem 7 - Part No SW: -----------    HW: 480 402 603 15
   Serial number: 3560002C31941313D38Y
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150407400739
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045182AB1E96B76BC3B-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA5121A2580CF0502087E001000000000000000
   VCID: 6597BF2FF5EC6E63745-8030
   Revision: --------    Serial number: 01101410803011
   Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
   GVL: 01503C0000000600400C80008000C80000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BDD473342289DBE17-8026
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 33180001093480031439
   Coding: 2C0000
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0056486
   Revision: 00000000    Serial number: 15000072186002
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07030
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431126B0EB6C7EB33B-8060
   Serial number: 01071506050371
   Coding: 003113205000040000000000
   VCID: 43D341B75B187053BA1-8016
   Serial number: 00000000000001068099
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   Serial number: 141016060509XD
   Coding: 003113205C00040000000000
   VCID: 42DD44B34402795BB17-8016
   Serial number: 00000000000001127988
   Coding: 091000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730200FF00000051220001001808001F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6C81CA0B16065F2B2BB-8038
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  252 8130
   Serial number: VWZ6ZMW0235535
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:31, VBatt start/end: 14.4V/14.4V)-----------
Cuzoe
C?ID=279487
I don't see any component protection faults so I assume either you've taken care of that or you haven't done another ignition cycle or the car is going to recognize something there that doesn't "belong."
The ABS fault is a coding issue, either something isn't coded properly in the ABS or you missed something in the engine module -01. Just a mismatch.
Several of the faults in the radar are due to missing swap codes. Do you have a plan for those? The features of that radar are locked vua swap codes, unlike the older round style radar that only had component protection. There are different swap codes depending on what you plan to have active... basic ACC, ACC with stop and go, ACC with follow to stop, ACC with prediction (pACC, requires nav), etc. And then with some of these there is a different swap code if you have the lane assist camera, camera plus this radar bumps the maximum ACC speed from 160 kmh to 220 kmh.
The missing message faults are for things that can probably be fixed in coding, for example the PSD faults are for missing nav data. It doesn't look like you have navigation so the radar needs to be coded appropriately... not to look for nav data.
Anyway, once you get the swap codes figured out then you can go about figuring out what else you need to code to get rid of your incorrectly coded and missing message faults. Whether that's changing the coding of other modules or changing the coding of the radar so it's not looking for those things.
brendan_
Boston, MA, USA
C?ID=516305
Thank you, I will look into all of those and see how far I can get.
brendan_
Boston, MA, USA
C?ID=516305
I posted here a few days ago about a few different faults coming from the ACC radar. I’ve flashed it with a different firmware and successfully calibrated it. Now I’m down to about 5 remaining faults. Most of them are incorrect coding, etc. The only issue is that for some reason I am unable to code the module. I always get the error, “request out of range” and can’t do anything past that. Any help would be appreciated, thanks.
Monday,19,September,2022,21:45:56:55940
VIN: 3VWCA7AU3FM515369   Mileage: 172001km-106876miles
   Coding: 011D0012036410081000
   Coding: 030C0C
   Revision: 00001K01
   Coding: 00A8DD
                    Reset counter: 137
                    Mileage: 172001 km
                    Date: 2022.09.19
                    Time: 21:44:07
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.3 V
                    Outside temperature: 17.0 °C
   Part No SW: 5Q0 907 572 R    HW: 5Q0 907 572 J
   Component: ACC BOSCH MQB H11 0771
   Coding: 00000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 46D558A3682A457B9DF-8012
1810 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_AWV_CODING_IMPLAUSIBLE]
                    Reset counter: 137
                    Mileage: 172001 km
                    Date: 2022.09.19
                    Time: 21:44:06
                    Control Module temperature: 48 °C
                    Voltage terminal 15-Voltage: 12.1 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
1811 - Control module not coded
          U1013 00 [009] - -
          [FAULT_ECU_NO_CODING]
                    Reset counter: 137
                    Mileage: 172001 km
                    Date: 2022.09.19
                    Time: 21:44:06
          B2032 00 [009] - -
                    Reset counter: 137
                    Mileage: 172001 km
                    Date: 2022.09.19
                    Time: 21:44:06
1807 - No Enable Identifications Active
          B2032 00 [009] - -
          [FAULT_SWAP_NO_FSID_ACTIVE]
                    Reset counter: 137
                    Mileage: 172001 km
                    Date: 2022.09.19
                    Time: 21:44:06
1116 - Databus
          [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                    Reset counter: 137
                    Mileage: 172001 km
                    Date: 2022.09.19
                    Time: 21:44:07
   Coding: 303138
   Coding: 0410
   Coding: 0BA5121A2580CF0502887E011000000000000000
   Generator:
   Coding: 2C0000
   Coding: 011000
   Coding: 0102
   Coding: 091000
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 137
                    Mileage: 172001 km
                    Date: 2022.09.19
                    Time: 21:44:10
                    Voltage terminal 30: 12.2 V
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:32, VBatt start/end: 12.3V/12.2V)-----------
sers77
Norway
C?ID=26140
Code one by one..
AINils
Germany (AIB)
C?ID=56975
You have to add/restore FEC Code in it, and also dataset for Golf. Without no coding possible and helpful
Threads merged. Please don't start a new thread when you already have one going about the same stuff in the same car.
downtime
Finland
C?ID=280813
I have tried, but even changing one bit it still doesn’t accept. I will flash it again or try new parameters and see if that helps.
Did you write the correct swaps or not? What FeC codes you wrote to the radar?
It still complains about incorrect swap code.
sers77
Norway
C?ID=26140
Did you Login aswell, before each coding?
AINils
Germany (AIB)
C?ID=56975
Mate first you have to restore FEC or add them, without you can't do anything like that. Send me from measuring value your public key of your ACC Module, maybe can fix it by remote session
Cuzoe
C?ID=279487
NAR Golf Mk7 TDI, ACC was not available from factory. We're talking about retrofit anyway so it's going to be adding FEC's that were never there, not restoring.
Spacewalker
Poland
C?ID=159607
..... when you do retrofithing, you must do all what is need
AINils
Germany (AIB)
C?ID=56975
Then you have to add them manually. If he will give me you Public key from measuring values, maybe can help you remote in VCDS!
