- Aug 8, 2018
- 11
- 1
- Washington, USA
- C?ID=335812
It's been a while since my last post. This one has to do with the "01044 - Control Module Incorrectly Coded" and I can't seem to get past having this one removed. The ACC has had Component Protection removed and I have yet to calibrate the sensor which I will do when I get the materials to build it. The dealership in my area does not do CP or calibration, hence having to figure things out on my own. However, I'm still not able to resolve the issue of the coding for the ACC unit. Any advice to get over this? Much appreciated in advance. I have tried "002F81 and 002F88" with no resolution. Address 5F is still something I am working on as I am trying to figure out how to properly clone my 3g+ HDD to SSD, but I haven't had much success on it to show up and work correctly with the SSD.
Saturday,17,September,2022,05:38:21:50312
VCDS Version: 22.3.1.4 (x64) HEX-NET CB: 0.4615.4
VIN: WA1CCAFP0GA006085 License Plate: AUDI SQ5
Mileage: 151220km-93963mi Repair Order: ACC Retrofit
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
56 57 5C 5F 62 69 6C 6D 72 A9
VIN: WA1CCAFP0GA006085 Mileage: 151220km-93963miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CTUD) Labels:. 06E-907-551-CGW.clb
Part No SW: 8R0 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07--- CVN: 8B77F6E0
Coding: 2A2A0034055600060000
Shop #: WSC 10008 005 104857
ASAM Dataset: EV_ECM30TFS0218R0907551G 001007
ROD: EV_ECM30TFS0218R0907551G.rod
VCID: 3C34C298B7AF2F6FD3-8068
VINID: 9D10534D15A001744000600814A9000A86
7193 - Function Restriction due to Faults in Other Modules
U1113 00 [037] - -
Mileage: 151228 km
Date: 2022.09.17
Time: 05:16:11
Engine RPM: 701.00 /min
Normed load value: 9.0 %
Coolant temperature: 94 °C
Intake air temperature: 60 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 14.319 V
Engine speed: actual: 0 /min
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 96.00 °C
Engine: operating status: ES
Engine load: 0.000000 %
Vehicle speed: actual: 0 km/h
7201 - Function Restriction due to Implausible Message(s)
U1112 00 [036] - -
Mileage: 151228 km
Date: 2022.09.17
Time: 05:16:11
Engine speed: actual: 672 /min
MAF_ENVD: 87.15294 mg/stroke
Coolant temperature (unfiltered): 94.50 °C
Engine: operating status: IS
Engine load: 8.984375 %
Readiness: 1110 1101
Part No SW: 8R0 927 158 AB HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H19 1003
Revision: --H19--- CVN: DEE0EE05
VCID: 7DB20F9CEC35E667A4-8028
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 309D1801
Shop #: WSC 01832 002 1048576
VCID: 116A432CC8ADF20750-8044
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0D854040000000000000
Shop #: WSC 06335 000 00000
VCID: 085C6E48BBF7B3CF87-805C
Subsystem 1 - Part No SW: 8K0 959 754 BP HW: 8K0 959 754 BP
Serial number: 0815000063049009
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000090651002
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01210520151992
Coding: 6601228000
VCID: 77BE1DB4C609CC37FE-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001080605301
Coding: 26000091817CAFE2150048C300003D0D0F9CE708A2090221000008004000030100000034000000
VCID: 78BC1E88CB17C34FF7-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 150518 H12 0050
Serial number: 90243014150511052032
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 20311398
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000000805151307
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01F14C7F
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: A80889A7000000000001
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0110
Coding: 002F88
Shop #: WSC 06335 123 12345
VCID: 373EDDB486890C373E-8062
00234 - Sensor for Automatic Distance Regulation Misadjusted
Reset counter: 79
Mileage: 151228 km
Date: 2022.09.17
Time: 05:31:55
Temperature: 52.0°C
Voltage: 12.16 V
Hex Value: 0x0031
Lateral Accel.: 0.46 m/s^2
Reset counter: 79
Mileage: 151228 km
Date: 2022.09.17
Time: 05:31:55
Temperature: 52.0°C
Voltage: 12.16 V
Hex Value: 0x005C
03110 - Active Steering Control Module (J792)
Reset counter: 79
Mileage: 151228 km
Date: 2022.09.17
Time: 05:31:55
Temperature: 52.0°C
Voltage: 12.16 V
Hex Value: 0x0084
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED13SKZB
Coding: 303635313832383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CD49258E70F9FEF63-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R150000LRQ2
Serial number: 6334MSME51687965K
Serial number: 6344MSME51684228A
Serial number: 6352QSME7156446CM
Serial number: 6362QSME0C572150A
Serial number: 63732SME7353537C1
Serial number: 63832SME73535742-
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372PCC000F3
Coding: 0000FF
VCID: 44C4BA78C75F57AFAB-8010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 C HW: 8R0 920 982 C
Component: KOMBIINSTR. H35 0567
Revision: 00200000 Serial number: 03T283K5G
Coding: 8BBF22004701D705020000
VCID: 3B36C184BAA12857DA-806E
Part No SW: 8R0 907 468 AA HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0070
Revision: 1Z130032 Serial number: 3241Z155100E80
Coding: 80C103FF00
VCID: 7EB00890E933FD7FBD-802A
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 0252556703
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02018E646E6E645A5A253D3E00
Shop #: WSC 02391 785 00200
VCID: 7CB40298FF2FEF6F93-8028
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000149976267
Coding: 00581B00000000000000
VCID: 42C8BC60DD4B599F99-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0369618640
Coding: 010221
VCID: 3FCEB594A6B93477F6-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0369116461
Coding: 010221
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000149989454
Coding: 011D13215E00440004
VCID: 4FEE85541E19A4F706-801A
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0020841143
Coding: 100001010000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45C2A77CC4656EA7BC-8010
Revision: 00002001 Serial number: 0368647548
Coding: 013E0E3A20FA70958730053200040009
Component: GTO BF H01 0080
Serial number: 00000000000000994882
Subsystem 2 - Part No: 8K0 951 177
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 5 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813044309806
VCID: 2D12FFDC74D5B6E754-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000149853809
VCID: 4ED098501913ADFF0D-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 20000000629534
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A38C480BD9B115FC1-806E
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156E%0F8268802
Coding: 020007010000000001
VCID: 24041AF8271F77AF8B-8070
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4F0 919 129 G HW: 4F0 919 129
Component: HybridTV-DVB H07 0550
Revision: R0070000 Serial number: 76301302652801
Coding: 06020100
VCID: 302CE6A863E7DB0F7F-8064
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 HW: 4E0 907 217 C
Component: J759 HC 0020
Revision: 00H07001 Serial number: 100210A0400020
Coding: 0122104
Shop #: WSC 06715 666 37409
VCID: 76A010B00103B53FE5-8022
Part No SW: 8R1 035 746 H HW: 8R1 035 746 G
Component: H-BNT-NA H43 0937
Revision: -------- Serial number: 523E%0FB004993
Coding: 1A0200060205E9EF7D82AF5E00000403140000000000000000
VCID: 3C34C298BFAF2F6FD3-8068
Subsystem 1 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130E.0F3359764
Subsystem 2 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002244495
03389 - Data Set Implausible
Reset counter: 79
Mileage: 151228 km
Date: 2022.09.17
Time: 05:05:32
Voltage: 14.40 V
Bin. Bits: 010
Reset counter: 79
Mileage: 151228 km
Date: 2022.09.17
Time: 05:05:36
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000100
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000150914588
Coding: 010C13204000240004
VCID: 46C0A070F16365BFB5-8012
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00008200400388
Coding: 0200000000000000
VCID: 3620D0B08183F53F25-8062
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-JA4A8SX
Coding: 1030010
VCID: 3424EAB857FFE72F1B-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D32CF9CA4B52667E4-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000150914587
Part No SW: 8R0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 150514201399
End----------(Elapsed Time: 02:21, VBatt start/end: 12.2V/12.2V)-----------
