- Feb 18, 2014
- 155
- 86
- Northern ireland
- C?ID=104757
Hi guys, I was wondering if anyone knows the security access to adapt the injector codings for idle controlon these engines?? I already tried the suggested 27971 from the pop up box but all I get is a "refused to send seed" error and I cant reprogramme the new injectors.
Thursday,02,July,2015,10:33:09:06416
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: TMBCT21Z1B2029348 License Plate: JIG9674
Mileage: 114200km-70960mi Repair Order: SBTAXIS
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCT21Z1B2029348 Mileage: 114200km-70960miles
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AG HW: 03L 906 023 AG
Component: 1,6l R4 CR td H23 9971
Revision: --H23--- Serial number:
Coding: 00114014030500080000
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_ECM16TDI02103L906023AG 003010
ROD: EV_ECM16TDI02103L906023A_VW32.rod
VCID: 6BDED784829CE079AB2-803E
Readiness: 0110 1000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0105
Revision: 00H35001
Coding: 0017665
Shop #: WSC 73430 790 00999
VCID: 7BFEE7C43AFC70F93B2-802E
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3T0 820 047 M HW: 3T0 820 047 M
Component: Climatic 150 0303
Revision: 00006001
Coding: 0000000002
ROD: EV_ClimaBasis_SK35.rod
VCID: 39723DCCB84082E969E-806C
9481200 - Coolant Pressure
B10AB F0 [009] - Too Low
Reset counter: 8
Mileage: 114024 km
Date: 2015.04.04
Time: 11:42:51
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 D HW: 1K0 937 084 D
Component: BCM PQ35 B 103 0615
Revision: 00103 AD
Coding: 48180AB8A05BB1C04010008011000024420000AE524D81605C4440000040
VCID: 2F6603947E045C59C7A-807A
Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 05081 26 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Subsystem 3 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
02391 - Terminal 30 Reference
Reset counter: 3
Mileage: 113885 km
Date: 2015.03.30
Time: 15:04:05
Voltage: 12.25 V
Term 50 Off
Reset counter: 48
Mileage: 114019 km
Date: 2015.04.04
Time: 10:55:06
Voltage: 14.20 V
Term 50 Off
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC1Z8WTO
Coding: 0020788
VCID: 3D7A29DC6468BEC9456-8068
Subsystem 1 - Serial number: 6332MSME5575182DH
Subsystem 2 - Serial number: 6342MSME557534236
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BJ HW: 5K0 953 569 C
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100820300363
Coding: 5080040000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 75EAF1FCD4D826894D6-8020
Part No SW: 1Z0 920 903 M HW: 1Z0 920 903 M
Component: KOMBI H04 0405
Coding: 410B00
VCID: 3F8653D4A664ACD957A-806A
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 020810F2002005
Coding: E9807F0600020200001303
VCID: 6DDAD99C7488EE49B56-8038
Component: IMMO H04 0405
VCID: 6AD0D2808D66F971D04-803F
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2120
Coding: 0000756
VCID: 489448083BAAEB61E60-801D
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 316205ECA8304AA9D1E-8064
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 47964B3436B4E419EFA-8012
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 010 0054
Revision: 0A001001 Serial number: SKZ1Z3K8456899
Coding: 000004000001
VCID: 356A31FC9C5866898D6-8060
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
VCID: 32600AE0AD3671B1A84-8067
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0008336
VCID: 336E0FE4522C78B9A32-8066
End-------------------------(Elapsed Time: 02:04)--------------------------
