Resolved Audi Q5 3.2 Simos 8.2 ECM reading baro pressure incorrectly, check engine light P0106
Resolved
Samanna
Maryland, USA
C?ID=24006
Need some thoughts, input from any who have been down this road-
Current ecm in vehicle is reading ambient pressure at ~90 kPa, while the manifold pressure sensor is reading static atmospheric pressure correctly at ~99kPa. I have purchased a used replacement ecm that is reading atmospheric pressure correctly. I had the closest dealer attempt to marry new used ecm to vehicle unsuccessfully. $300. later -Tech could not, or is incapable or unwilling to program used ecm to vehicle using the odis system. Service stated "we were able to communicate with the used ecm, however odis was requiring the recoding of 14 additional modules. A new blank ecm would need to be ordered and programmed to the car. Estimate for the repair $3500. ECM on backorder."
At this point I have plan b and c in mind, but would like and need input from any immobilizer experts as to how you would approach same situation, or did to program a used simos Immobilizer 5(?) ecm to an Audi vehicle. Thanks in advance!
Hi and welcome.
Please post an Auto-Scan for context.
@EuroX or @Jetta 97 may be able to do a data transfer from your old ECU to your new one if you send them both.
Samanna
Maryland, USA
C?ID=24006
I was going to post a scan however many crucial modules has various communication and immobilizer codes from the swapping of ecms in and out by me during problem solving, plus dealer visit. I can go ahead a post that busy scan. Forthcoming...
From what I've read anything more than a 100 hPa difference between both barometric pressure inputs will set the baro DTC. ?
Data transfer was plan b, if I could find a resource capable and willing.
thanks
I would suggest clearing as many fault codes as can possibly be cleared first, then posting as "clean" a scan as you can get right now, which would show the faults that still exist.
EuroX
Northern NJ USA
C?ID=208579
I would transfer data from one ecm to the other. ODIS should be able to adapt a used ECM unless the dealer had some rookie try to do it that didn't know what they were doing. They should of ran replacement test plan for ECM. It will pull all relevant data and transfer into new ecm. I suspect maybe they had the used ECM installed and couldn't talk to the vehicle for some reason.
In any case it is possible to transfer but at a distance there may be some hoops to jump through. Get in touch if need be.
Samanna
Maryland, USA
C?ID=24006
Wednesday,14,September,2022,13:07:31:52247
VCDS Version: 22.9.0.0
VIN: WA1VKAFP2AA052634   License Plate:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
          5F 62 6C 6D 72
VIN: WA1VKAFP2AA052634   Mileage: 205540km-127716miles
Address 01: Engine (J623-CALB)       Labels:| 06E-907-559-CAL.clb
   Part No SW: 8R0 907 559 G    HW: 8F0 907 559 A
   Component: 3.2 SIMOS8.2  H06 0004
   Revision: --------    CVN: 6030C727
   Coding: 0121000A190F0121
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
   ROD: EV_ECM32FSI0218R0907559G.rod
   VCID: 4487A9DECF57C8AD27-8010
   VINID: 9D10666D15A009144014218310A6581700
6010 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0106 00 [175] - Implausible Signal
                    Mileage: 205540 km
                    Date: 2022.09.14
                    Time: 13:03:28
                    Engine RPM: 697.00 /min
                    Normed load value: 39.2 %
                    Coolant temperature: 72 �C
                    Intake air temperature: 62 �C
                    Ambient air pressure: 900 mbar
                    Voltage terminal 30: 12.898 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 157.96470 mg/stroke
                    Coolant temperature (unfiltered): 75.8 �C
                    Engine: operating status: IS
                    Battery voltage: 13.000000 V
                    Vehicle speed: actual: 0 km/h
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8R0 927 158 F    HW: 0B6 927 156
   Component: 0B6 32 FSIUSA H05 0005
   Revision: --H05---    CVN: 1C14BFCA
   Coding: 001012
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 408FA5CEDB4FD48D03-8014
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 041D18
   VCID: 4A9B87E6E5731EDDDD-801E
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0326
   Coding: 0D0500
   VCID: 040769DE87D708AD67-8050
   Subsystem 1 - Part No SW: 8T0 959 754 G    HW: 8T0 959 754 G
   Component: FBSAUDIB8 IDG  H38 0060
   Serial number: 0509000059240004
   Serial number: 0209000081395010
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Fault Status: 00100111
                    Reset counter: 239
                    Mileage: 205540 km
                    Date: 2022.09.14
                    Time: 11:15:42
                    Reset counter: 199
                    Mileage: 205540 km
                    Date: 2022.09.14
                    Time: 13:03:40
   Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01291020090254
   Coding: 46112000
   VCID: 7AFB1726F5134E5D0D-802E
   Component: BCM1 1.0      H28 0380
   Revision: 10028001    Serial number: 00000000379865
   Coding: 26001091063CAF010000080300001D0D0F1C460800010161000000
   VCID: 3C77D13EBFA7B06D5F-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 091026  H10 0041
   Serial number: 90243014091024030903
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10657906
   Coding: 024D25
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002210092146
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840930701864
   Coding: 300105
   VCID: 408FA5CED34FD48D03-8014
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 D    HW: 8R0 959 655 D
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003FRD054PGM
   Coding: 303633313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4581B4DAC46DF1A530-8010
   Subsystem 1 - Part No SW: 8R0 959 339     HW: 8R0 959 339
   Serial number: 5810000R09000054AA
   Serial number: 6334MSME4C3535038
   Serial number: 6344MSME4B242563B
   Serial number: 6352QSME0742001E5
   Serial number: 6362QSME68412D32H
   Serial number: 63732SME3C410D22-
   Serial number: 63832SME1D401B3A0
   Revision: --------    Serial number: 90304IK3000OJ
   Coding: 000017
   VCID: 3D71DC3AA4BDB96568-8068
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 K    HW: 8R0 920 980 K
   Component: KOMBIINSTR.   H10 0255
   Revision: 00000000    Serial number: CJK34CXA9
   Coding: 881722000300D705020000
   VCID: 4189A0CAD845DD850C-8014
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0105
   Revision: FB900055    Serial number: 5500F09A06005C
   Coding: 00C303
   VCID: 000F65CE93CF148D43-8054
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140741313
   Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001010021101
   Coding: 00581B00000044440000
   Part No SW: 8R0 907 566     HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH10 0020
   Revision: 00H10000    Serial number: 6PZ 009 014-04
   Coding: 0000009
   VCID: 7BF512223A29775516-802E
   Subsystem 1 - Part No: 8R0 907 568
   Component: J0770_SWA_Slave_H08 0020
   Subsystem 2 - Serial number: 6PZ 009 014-24
   Subsystem 3 - Serial number: 5F24.10.0900H010003CL10321�
   Subsystem 4 - Serial number: L10321�
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009575970
   Coding: 011D13205E00440004
   VCID: 4581B4DACC6DF1A530-8010
   Revision: 00002001    Serial number: 0123330993
   Coding: 0126023A207A749504B0053200000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000182198
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H01 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H01 0220
   Part No SW: 8T0 035 223 AL    HW: 8T0 035 223 H
   Component: DSP Prem      H09 0200
   Revision: 00009001    Serial number: 34890000166902
   VCID: 78FF0D2ECB1F5C4D7B-802C
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009589262
   VCID: 4487A9DEC757C8AD27-8010
   Revision: 00000003    Serial number: 10000000355340
   VCID: 3467F91E97F7782D97-8060
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 3467F91E57F7782D97-8060
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335J4097536597
   Coding: 020000010000000001
   VCID: 1D313CBA047DD96548-8048
                    Reset counter: 219
                    Mileage: 204410 km
                    Date: 2009.07.23
                    Time: 05:38:16
                    Bin. Bits: 00000000 00001000
   Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
   Component: H-BN-NA       H45 0116
   Revision: --------    Serial number: 490JZ097533136
   Coding: 010200060005A1EF51000F0E000000030000
   Shop #: WSC 08476 002 1048576
   VCID: 387FCD2E8B9F9C4DBB-806C
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356KQ091104092
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000395072
   Component: CD-Database  1293
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102222889
   Coding: 010C13204000240004
   VCID: 428BAFC6DD43C69D15-8016
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J99A25R
   Coding: 1020010
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B75D222BAA9B75556-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H27 0300
   Serial number: 8R0827852B
   Revision:             Serial number: 0000102223126
End-------------------------(Elapsed Time: 04:27)--------------------------
Samanna
Maryland, USA
C?ID=24006
@ Uwe: Clean "as is" scan.
Baro code immediately after start.
@ EuroX: Oh, I can find northern NJ if necessary.... :>)
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
thanks
When I do data transfer ,I transfer only Immobilizer part , so this way used ECU stays in same condition as it was before just immobilizer parts is transfer .
Simos 8.2 is very complicate ECU to do data transfer from original ECU to donor and not many people will know what to do and how to do this.
MasterTommy
Amsterdam
C?ID=295586
This^
ODIS guided function will not work with the used ECM module if you start the session with it already installed.
As far as i know, you start the procedure with the original ECM installed, then follow the guided function for replacing a control module.
EuroX
Northern NJ USA
C?ID=208579
This^
Correct this is the proper way and only way to do a successful ecm replacement with ODIS.
Jetta 97
C?ID=81680
This^
So what happens if is Original ECU is missing or Dead????
I have done many times with used ECU install and done it with out any problem.
EuroX
Northern NJ USA
C?ID=208579
I have never run into this issue. Even with a dead ecu ODIS will ask what currently installed and try to pull data out. I don't know the circumstances but something does not sound right, personally sounds like dealer dicking the OP around if you ask me or someone that didn't know how to RTFS.
Westbury, UK
Hopefully this works:
Nope, just two small blue squares with a ? in them :confused:
Samanna
Maryland, USA
C?ID=24006
Attempted to post a picture of the work order from dealer, but I'm obviously doing something incorrectly. Apologies.
EuroX
Northern NJ USA
C?ID=208579
FIND ANOTHER DEALER, THEY ARE TRYING TO FUCK YOU. Coding of other module is most likely due to CP being active after the ECM change. Request copy of log please if you want forward it to me so I'll be able to tell you whether you need to ream a service managers ass out for tech's that are trying to take advantage of customers.
IN NO FUCKING WAY SHAPE OR FORM CAN A RECODE OF ANY MODULE CAUSE DAMAGE TO THE VEHICLE.PERIOD. FURTHER MORE WHEN THEY ADAPT A USED ECM IT SHOULD AUTOMATICALLY CHANGE THE CODING OF THAT ECM. AFTER THAT ITS JUST CP THAT NEEDS TO BE UPDATED. COMMON AND NORMAL PROCEDURE WHEN CHANGING ANY MODULE IN THE CAR WETHER IT BE NEW OR USED.
Better yet ill pull the log now and I'll get back to you.
Got it pulled looks like the car was there 9.13.22 at 12:19pm
Samanna
Maryland, USA
C?ID=24006
@ EuroX
Yep. Car was there all day on the 13th.
You have come to same conclusion as I. I wanted to post the work order to confirm my suspicions. Incompetence or predatory business behavior.... ?? Either way unacceptable.
Should have taken ~ hr for the work with ODIS and subscription
IMHO.
EuroX
Northern NJ USA
C?ID=208579
I will try to get you sorted out on my end hang tight.
Samanna
Maryland, USA
C?ID=24006
I wanted to update and close this post out-
This ECU problem has been resolved. Both the replacement Simos 8.2 ECU and the failing ECU that was reading barometric pressure incorrectly was sent to @Jetta 97. He was able to do data transfer from bad to good ECU in quick fashion. The used replacement box was plug n play upon its return to me. No baro codes and car is running great. Thanks to all that helped in the replies and to Jetta 97 for completing the work!
