- Apr 26, 2022
- 31
- 12
- Switzerland
- C?ID=516731
Hi All,
I have a European spec S3 2021 model with LED lights. Below the main light is 10 little bars or tabs. The right side (passenger side) was replaced. When it lights up all 10 LED bars / tabs are lit. The left side has just 6 lit in the form of a double L shape. I will attach photo.
I scanned with VCDS... no real glaring errors. I tried adaption but it keeps rejecting the workshop codes (which I cannot change). I am running 22.9 with the HEXNet VCDS adapter. Image of the lights here: https://ibb.co/rpYqDBC
Workshop Code: 210 01369 040505
VIN: WAUZZZGY3MA127318 License Plate:
Chassis Type: GY-AU38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 4B 52 5F 6C
75 82 A5 A9 BB BC D6 D7 DE 811E 811F 8120 8121 C002 C003
82-Head Up Display -- Status: OK 0000
811E-Burglary Protection FL -- Status: OK 0000
811F-Burglary Protection FR -- Status: OK 0000
8120-Burglary Protection RL -- Status: OK 0000
8121-Burglary Protection RR -- Status: OK 0000
Address 01: Engine (J623-DNFB) Labels: None
Part No SW: 8Y0 906 259 HW: 06K 907 425 N
Component: R4 2.0l TFSI H08 0004
CVN: 0653DC88
Coding: 0A2540322466050B300C0000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0208Y0906259 001007
ROD: EV_ECM20TFS0208Y0906259_AU38.rod
VCID: 55FCEE3375F6BE23E45-8100
VINID: 9D196AAAA5E90DD4410870C120C41F2A28
Part No SW: 0GC 906 557 HW: 0GC 300 012 H
Component: GSG DQ381 H06 3562
CVN: 6CC06634
ASAM Dataset: EV_TCMDQ381062 001001
ROD: EV_TCMDQ381062.rod
VCID: 7AA69D8FBC28B15BA97-812E
Subsystem 1 - Part No SW: 5WA 713 033 AN HW: 610 5
Component: ZSB_SB_AUTO H08 1034
Serial number: 20210506000067018591
Subsystem 2 - Part No SW: 8Y0 713 059 D HW: 8Y0 713 059 D
Component: ZSB_SB_mono H07 0152
Serial number: 01S19.04.21007500031
Subsystem 3 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810500002925266
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 5WA 614 517 BJ HW: 5WA 614 517 N
Component: ESC H13 0131
Serial number: 61311000000004 CVN: 4FE1A743
Coding: 36006CA556226A73527A680116CB60064DB258505A89030821FC3851018E7100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013055
ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
VCID: 1174DA23819E920378D-8144 SFD
16401 - Tire Pressure Warning
C102D 00 [032] - -
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 C HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0706
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w_003.rod
VCID: 54FA13377E0CA72B13B-8100
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 007 J HW: 5WA 907 007 J
Component: AC Automat H30 3130
Coding: 006000010011320100100000111011010000012100100200000000000000
ASAM Dataset: EV_ACClimaPREVW38X 001098
ROD: EV_ACClimaPREVW38X_VW38.rod
VCID: 4ECE015F5020CDFB25F-811A
Air quality sensor:
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H05 0010
Serial number: AAB0803F00PAG0MUFU04
Front A/C control head:
Subsystem 3 - Part No SW: 8Y0 820 043 A HW: 8Y0 820 043 A
Component: AU38X KVA H05 0021
Serial number: 15 S14.05.2100930433
Interior temperature sensor:
Subsystem 4 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001280421191716512
Part No SW: 5WA 937 086 G HW: 5WA 937 086 G
Component: BCM 37W BOSCH 018 0159
Serial number: BXJ53F130521940
ASAM Dataset: EV_BCM37w 006001
ROD: EV_BCM37w_006_VW38.rod
VCID: 55FCEE3375F6BE23E45-8100 SFD
Wiper motor control module:
Subsystem 1 - Part No SW: 8Y1 955 119 A HW: 8Y1 955 119
Component: J400FRWISCH 067 0090
Serial number: 907453F0302109103315
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 20396695X81A955555B0
Subsystem 3 - Part No SW: 4K1 941 501 K HW: 4K1 941 501 K
Component: E1 - LTM H05 0010
Serial number: 92160UBS00108 10S
Steering Column Switch:
Subsystem 4 - Part No SW: 82A 953 521 GF HW: 5Q1 953 549 D
Component: J527 SMLS MQB 005 0080
Serial number: 00000013052120241331
left tail lamp 1:
Subsystem 5 - Part No SW: 8Y0 945 423 HW: 8Y0 945 423
Component: SHL_li1 H06 0005
Serial number: 0021355409L1332143BC
left tail lamp 2:
Subsystem 6 - Part No SW: 8Y0 945 429 HW: 8Y0 945 429
Component: SHL_li2 H06 0005
Serial number: 0021352607L13821B056
Right rear tail lamp 1:
Subsystem 7 - Part No SW: 8Y0 945 424 HW: 8Y0 945 424
Component: SHL_re1 H06 0005
Serial number: 0021363909R138215C82
Right rear tail lamp 2:
Subsystem 8 - Part No SW: 8Y0 945 430 HW: 8Y0 945 430
Component: SHL_re2 H06 0005
Serial number: 0021361407R104212D82
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 298 A HW: 5WA 919 298
Component: PLA 12K Kanal H04 0230
Serial number: 000012052194560
Coding: 8202022013
ASAM Dataset: EV_EPHBO2CVW3800000 002028
ROD: EV_EPHBO2CVW3800000_VW38.rod
1080304 - Parking Sensor(s); Rear
B107B F0 [032] - Function Limitation due to External Factors
1113328 - Parking Sensor(s); Front
B10FC F0 [032] - Function Limitation due to External Factors
[Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
1114112 - Tone Output for Driver Assist Systems
B1AE2 00 [032] - -
13959168 - Parking Sensor(s); Rear
[Geber für Einparkhilfe - Schmutz bzw. Eisbildung hinten]
13959169 - Parking Sensor(s); Front
[Geber für Einparkhilfe - Schmutz bzw. Eisbildung vorn]
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 5WA 907 572 B HW: 5WA 907 572
Component: ACC Bosch MQB H20 0395
Coding: 0E0B007F4071604522474000000000C9B64020000000000000000000000000
VCID: 4DCC06535D26F6E35C5-8118
No ASAM data for: "Unknown" (AU38)
1396 - ROD - Unknown Error Code
- 00 [032]
1538 - ROD - Unknown Error Code
- 00 [032]
209054 - ROD - Unknown Error Code
- 00 [032]
0578 - ROD - Unknown Error Code
- 00 [032]
0790 - ROD - Unknown Error Code
- 00 [032]
Address 15: Airbags (J234) Labels:* 5WA-959-655.clb
Part No SW: 5WA 959 655 J HW: 5WA 959 655 J
Component: AirbagVW40 007 0636
Serial number: 000000003C0J0R7
Coding: 88CC008000CCC000000000000000000091540000205400004000F670001300C5
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: 5EEEF11F00C07D7BB5F-810A SFD
Subsystem 1 - Part No SW: ----------- HW: 480 401 805 21
Component: SideSensor_Dr 003 6149
Serial number: 3510001A0C4D3CC94429
Subsystem 2 - Part No SW: ----------- HW: 480 401 805 21
Component: SideSensor_Pr 003 6149
Serial number: 3520001A0C4D3CC6A6AN
Subsystem 3 - Part No SW: ----------- HW: 480 001 605 21
Serial number: 35700000000EE260D45U
Subsystem 4 - Part No SW: ----------- HW: 480 001 605 21
Serial number: 3580000000045250D45B
Subsystem 5 - Part No SW: ----------- HW: 480 400 605 21
Component: FrontSensor_D 003 614A
Serial number: 35500019CC4A45A2B7AO
Subsystem 6 - Part No SW: ----------- HW: 480 400 605 21
Component: FrontSensor_P 003 614A
Serial number: 35600019CC4A45A578AP
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8Y0 920 700 A HW: 8Y0 920 700 A
Component: KOMBI H03 1900
Coding: 84A516426B8C00080080E3402000000808000000
ASAM Dataset: EV_DashBoardVDDMQB37W 003032
ROD: EV_DashBoardVDDMQB37W_003_VW41.rod
VCID: 343A73B7DECC872B33B-8160 SFD
Part No HW: 5WA 907 530 C
Component: GW2020 High 752
Revision: -------- Serial number: 771049050021137
Coding: 0000808D0F00000000000000012101125101210102000100030100000001010000000000000000000000000000000000
GVL: 3D080000020840CC80008002C8000040040040020040000002000000000000C4
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 1679367405
Subsystem 3 - Part No SW: 83A 951 523 J HW: 83A 951 523 J
Component: J453 MFL H07 0004
Serial number: 20210224191250 32133
Subsystem 4 - Part No SW: 8Y0 419 508 HW: 8Y0 419 508
Component: J IEEHOD1ZONE 250 0260
Serial number: 00000000230200242715
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 H HW: 3Q0 909 059 B
Component: EBKV H06 0112
Serial number: BPA085190521013
Coding: 5003C5009600007BEFBDF7DE000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 014027
ROD: EV_BrakeBoostG2BoschVW37W_014.rod
107024 - Transmission Control Module
U14E4 00 [032] - Received Malfunction Value
[Scl_Getriebe_11_GE_Fahrstufe_Error]
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 21000139355003
Coding: 8800000000000000
Shop #: WSC 00000 790 03039
ASAM Dataset: EV_ELVMarqMQBA0 002004
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 323675AF24D8891B217-8166
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 E HW: 2Q0 907 686 E
Component: HRE_Master H25 0284
Serial number: 00000575606884
Coding: 565545D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
ROD: EV_HREntryHellaGen3Mstr.rod
VCID: 3C2A5B97F69C4F6BFBB-8168
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 E HW: 2Q0 907 685 E
Component: HRE_Slave H25 0284
Serial number: 00000575204002
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS003 0330
Serial number: YE007UEJ0229C
Coding: 001E8B004000000000001000
Shop #: WSC 00000 790 03052
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 49C43243A94EEAC370D-811C
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 00854275
Coding: 0000000000000001000102010100010000000101010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 HW: 5WA 907 338
Component: FCM2020 Low 009 1372
Serial number: 210151221194279
Coding: 00000000090025F202202B13020003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 002010
ROD: EV_MultiModulContiVW38X_002_VW38.rod
VCID: 0B48C84BE3B2B8D3821-815E SFD
Address 52: Door Elect, Pass. (J387) Labels: Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS003 0330
Serial number: YE007UDD23307
VCID: 48C23747B24413CB6F3-811C
Part No SW: 8Y0 035 043 H HW: 8Y0 035 043
Component: MU-TH-ND-EU 042 3458
Serial number: GRO-63324.05.21
Coding: 13801000004200000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU27.rod
VCID: 38224787C2A4634B1F3-816C SFD
Multimedia System 1:
Subsystem 1 - Part No SW: 8Y0 919 605 HW: 8Y0 919 605
Component: DU AU38x High H40 0138
Serial number: MA19X2AE0928527
Data carrier:
Compact disc data bank:
Component: Gracenote2 1007
Volume Control 1:
Subsystem 4 - Part No SW: 8Y0 919 616 HW: 8Y0 919 616
Component: Sensoric LSR H31 0131
Serial number: 10S07.05.21007400136
Media socket:
2562 - Navigation System
B126C F0 [009] - Navigation Database Faulty
Reset counter: 121
Mileage: 14359 km
Date: 2022.09.14
Time: 11:45:40
Voltage terminal 30: 12.0 V
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 5WA 980 556 B HW: 5WA 980 556 B
Component: RV eCompact H26 0254
Serial number: FCLK20080421000
Coding: 01031000842000
ASAM Dataset: EV_CamSysRVCCompaFicos 009020
ROD: EV_CamSysRVCCompaFicos_009.rod
VCID: 50F21F274A14DB0B373-8104
Address 75: Telematics (J949) Labels:* None
Part No SW: 8Y0 035 282 A HW: 8Y0 035 282 A
Component: OCU3HMQB37W H06 0030
Serial number: 0000000105VIYK3
Coding: 013801109FE928A590254600315F2607
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002.rod
VCID: 363E49BFC8B0953B0DF-8162 SFD
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 8Y1 919 617 HW: 8Y1 919 617
Component: HeadupDisplay H16 2048
Coding: 4700F0
ASAM Dataset: EV_HeadUpDisplMQB37W 001018
ROD: EV_HeadUpDisplMQB37W.rod
VCID: 0358E06BCBE2F093FA1-8156
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 A HW: 5WA 980 653
Component: MQB MFK 3.0 H06 3129
Serial number: E57830711211320
Coding: 00040888216CC040109E44001020008000430000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_AU38.rod
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8Y0 907 159 HW: 81A 907 159 A
Component: SAS-GEN 2.5 H08 0001
Serial number: 210127200135
Part No SW: 5Q0 959 595 K HW: 8W1 959 595 D
Component: TSG HFS005 0330
Serial number: YE007UDC31887
Coding: 000E89004000000000001000
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
VCID: 4BC8084BA332F8D3421-811E
Component: TSG HBFS005 0330
Serial number: YE007UDB02785
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
Part No SW: 4K0 941 591 BS HW: 4K0 941 591 B
Component: LMS_MQB H11 0044
VCID: 0154EA63D1FEE283E8D-8154
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Coding: 800080
ROD: EV_Charg1MobilDevicAU651.rod
VCID: 231880EB6B221093DA1-8176
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 B HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w_002.rod
VCID: 47C0347BBF5A1CB3669-8112
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w_002.rod
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 002013
End----(Elapsed Time: 03:56, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
