Audi S3 Sportback 2021 model - LED side light variance
fastlanetuningschweiz
Switzerland
C?ID=516731
Hi All,
I have a European spec S3 2021 model with LED lights. Below the main light is 10 little bars or tabs. The right side (passenger side) was replaced. When it lights up all 10 LED bars / tabs are lit. The left side has just 6 lit in the form of a double L shape. I will attach photo.
I scanned with VCDS... no real glaring errors. I tried adaption but it keeps rejecting the workshop codes (which I cannot change). I am running 22.9 with the HEXNet VCDS adapter. Image of the lights here: https://ibb.co/rpYqDBC
Workshop Code: 210 01369 040505
VIN: WAUZZZGY3MA127318   License Plate:
Chassis Type: GY-AU38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 4B 52 5F 6C
          75 82 A5 A9 BB BC D6 D7 DE 811E 811F 8120 8121 C002 C003
Address 01: Engine (J623-DNFB)       Labels: None
   Part No SW: 8Y0 906 259     HW: 06K 907 425 N
   Component: R4 2.0l TFSI  H08 0004
   CVN: 0653DC88
   Coding: 0A2540322466050B300C0000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0208Y0906259 001007
   ROD: EV_ECM20TFS0208Y0906259_AU38.rod
   VCID: 55FCEE3375F6BE23E45-8100
   VINID: 9D196AAAA5E90DD4410870C120C41F2A28
   Part No SW: 0GC 906 557     HW: 0GC 300 012 H
   Component: GSG DQ381     H06 3562
   CVN: 6CC06634
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062.rod
   VCID: 7AA69D8FBC28B15BA97-812E
   Subsystem 1 - Part No SW: 5WA 713 033 AN    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20210506000067018591
   Subsystem 2 - Part No SW: 8Y0 713 059 D    HW: 8Y0 713 059 D
   Component: ZSB_SB_mono    H07 0152
   Serial number: 01S19.04.21007500031
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810500002925266
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 5WA 614 517 BJ    HW: 5WA 614 517 N
   Component: ESC           H13 0131
   Serial number: 61311000000004  CVN: 4FE1A743
   Coding: 36006CA556226A73527A680116CB60064DB258505A89030821FC3851018E7100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013055
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 1174DA23819E920378D-8144 SFD
16401 - Tire Pressure Warning
          C102D 00 [032] - -
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 C    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003.rod
   VCID: 54FA13377E0CA72B13B-8100
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 007 J    HW: 5WA 907 007 J
   Component: AC Automat    H30 3130
   Coding: 006000010011320100100000111011010000012100100200000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001098
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 4ECE015F5020CDFB25F-811A
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu      H05 0010
   Serial number: AAB0803F00PAG0MUFU04
   Front A/C control head:
   Subsystem 3 - Part No SW: 8Y0 820 043 A    HW: 8Y0 820 043 A
   Component: AU38X KVA      H05 0021
   Serial number: 15 S14.05.2100930433
   Interior temperature sensor:
   Subsystem 4 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001280421191716512
   Part No SW: 5WA 937 086 G    HW: 5WA 937 086 G
   Component: BCM 37W BOSCH 018 0159
   Serial number: BXJ53F130521940
   ASAM Dataset: EV_BCM37w 006001
   ROD: EV_BCM37w_006_VW38.rod
   VCID: 55FCEE3375F6BE23E45-8100 SFD
   Subsystem 1 - Part No SW: 8Y1 955 119 A    HW: 8Y1 955 119
   Component: J400FRWISCH    067 0090
   Serial number: 907453F0302109103315
   Component: G397_RLFSS     H06 0004
   Serial number: 20396695X81A955555B0
   Subsystem 3 - Part No SW: 4K1 941 501 K    HW: 4K1 941 501 K
   Component: E1 - LTM       H05 0010
   Serial number: 92160UBS00108    10S
   Steering Column Switch:
   Subsystem 4 - Part No SW: 82A 953 521 GF    HW: 5Q1 953 549 D
   Serial number: 00000013052120241331
   left tail lamp 1:
   Subsystem 5 - Part No SW: 8Y0 945 423     HW: 8Y0 945 423
   Component: SHL_li1        H06 0005
   Serial number: 0021355409L1332143BC
   left tail lamp 2:
   Subsystem 6 - Part No SW: 8Y0 945 429     HW: 8Y0 945 429
   Component: SHL_li2        H06 0005
   Serial number: 0021352607L13821B056
   Right rear tail lamp 1:
   Subsystem 7 - Part No SW: 8Y0 945 424     HW: 8Y0 945 424
   Component: SHL_re1        H06 0005
   Serial number: 0021363909R138215C82
   Right rear tail lamp 2:
   Subsystem 8 - Part No SW: 8Y0 945 430     HW: 8Y0 945 430
   Component: SHL_re2        H06 0005
   Serial number: 0021361407R104212D82
   Part No SW: 5WA 919 298 A    HW: 5WA 919 298
   Component: PLA 12K Kanal H04 0230
   Serial number: 000012052194560
   Coding: 8202022013
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
1080304 - Parking Sensor(s); Rear
          B107B F0 [032] - Function Limitation due to External Factors
1113328 - Parking Sensor(s); Front
          B10FC F0 [032] - Function Limitation due to External Factors
          [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
1114112 - Tone Output for Driver Assist Systems
          B1AE2 00 [032] - -
13959168 - Parking Sensor(s); Rear
          [Geber für Einparkhilfe - Schmutz bzw. Eisbildung hinten]
13959169 - Parking Sensor(s); Front
          [Geber für Einparkhilfe - Schmutz bzw. Eisbildung vorn]
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Coding: 0E0B007F4071604522474000000000C9B64020000000000000000000000000
   VCID: 4DCC06535D26F6E35C5-8118
No ASAM data for: "Unknown" (AU38)
1396 - ROD - Unknown Error Code
          - 00 [032]
1538 - ROD - Unknown Error Code
          - 00 [032]
209054 - ROD - Unknown Error Code
          - 00 [032]
0578 - ROD - Unknown Error Code
          - 00 [032]
0790 - ROD - Unknown Error Code
          - 00 [032]
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 J    HW: 5WA 959 655 J
   Component: AirbagVW40    007 0636
   Serial number: 000000003C0J0R7
   Coding: 88CC008000CCC000000000000000000091540000205400004000F670001300C5
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 5EEEF11F00C07D7BB5F-810A SFD
   Subsystem 1 - Part No SW: -----------    HW: 480 401 805 21
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A0C4D3CC94429
   Subsystem 2 - Part No SW: -----------    HW: 480 401 805 21
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A0C4D3CC6A6AN
   Subsystem 3 - Part No SW: -----------    HW: 480 001 605 21
   Serial number: 35700000000EE260D45U
   Subsystem 4 - Part No SW: -----------    HW: 480 001 605 21
   Serial number: 3580000000045250D45B
   Subsystem 5 - Part No SW: -----------    HW: 480 400 605 21
   Component: FrontSensor_D  003 614A
   Serial number: 35500019CC4A45A2B7AO
   Subsystem 6 - Part No SW: -----------    HW: 480 400 605 21
   Component: FrontSensor_P  003 614A
   Serial number: 35600019CC4A45A578AP
   Part No SW: 8Y0 920 700 A    HW: 8Y0 920 700 A
   Component: KOMBI         H03 1900
   Coding: 84A516426B8C00080080E3402000000808000000
   ASAM Dataset: EV_DashBoardVDDMQB37W 003032
   ROD: EV_DashBoardVDDMQB37W_003_VW41.rod
   VCID: 343A73B7DECC872B33B-8160 SFD
   Part No HW: 5WA 907 530 C
   Component: GW2020 High   752
   Revision: --------    Serial number: 771049050021137
   Coding: 0000808D0F00000000000000012101125101210102000100030100000001010000000000000000000000000000000000
   GVL: 3D080000020840CC80008002C8000040040040020040000002000000000000C4
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 1679367405
   Subsystem 3 - Part No SW: 83A 951 523 J    HW: 83A 951 523 J
   Component: J453 MFL       H07 0004
   Serial number: 20210224191250 32133
   Subsystem 4 - Part No SW: 8Y0 419 508     HW: 8Y0 419 508
   Component: J IEEHOD1ZONE  250 0260
   Serial number: 00000000230200242715
   Part No SW: 5WA 909 059 H    HW: 3Q0 909 059 B
   Component: EBKV          H06 0112
   Serial number: BPA085190521013
   Coding: 5003C5009600007BEFBDF7DE000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 014027
   ROD: EV_BrakeBoostG2BoschVW37W_014.rod
107024 - Transmission Control Module
          U14E4 00 [032] - Received Malfunction Value
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 21000139355003
   Coding: 8800000000000000
   Shop #: WSC 00000 790 03039
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 323675AF24D8891B217-8166
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 E    HW: 2Q0 907 686 E
   Component: HRE_Master    H25 0284
   Serial number: 00000575606884
   Coding: 565545D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
   ROD: EV_HREntryHellaGen3Mstr.rod
   VCID: 3C2A5B97F69C4F6BFBB-8168
   Subsystem 1 - Part No SW: 2Q0 907 685 E    HW: 2Q0 907 685 E
   Component: HRE_Slave      H25 0284
   Serial number: 00000575204002
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS003 0330
   Serial number: YE007UEJ0229C
   Coding: 001E8B004000000000001000
   Shop #: WSC 00000 790 03052
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 49C43243A94EEAC370D-811C
   Part No SW: 5WA 907 145 G    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  502 1040
   Serial number: 00854275
   Coding: 0000000000000001000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   Part No SW: 5WA 907 338     HW: 5WA 907 338
   Component: FCM2020 Low   009 1372
   Serial number: 210151221194279
   Coding: 00000000090025F202202B13020003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 002010
   ROD: EV_MultiModulContiVW38X_002_VW38.rod
   VCID: 0B48C84BE3B2B8D3821-815E SFD
Address 52: Door Elect, Pass. (J387)       Labels: Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS003 0330
   Serial number: YE007UDD23307
   VCID: 48C23747B24413CB6F3-811C
   Part No SW: 8Y0 035 043 H    HW: 8Y0 035 043
   Component: MU-TH-ND-EU   042 3458
   Serial number: GRO-63324.05.21
   Coding: 13801000004200000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU27.rod
   VCID: 38224787C2A4634B1F3-816C SFD
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8Y0 919 605     HW: 8Y0 919 605
   Component: DU AU38x High  H40 0138
   Serial number: MA19X2AE0928527
   Compact disc data bank:
   Component: Gracenote2     1007
   Volume Control 1:
   Subsystem 4 - Part No SW: 8Y0 919 616     HW: 8Y0 919 616
   Component: Sensoric LSR   H31 0131
   Serial number: 10S07.05.21007400136
   Media socket:
2562 - Navigation System
          B126C F0 [009] - Navigation Database Faulty
                    Reset counter: 121
                    Mileage: 14359 km
                    Date: 2022.09.14
                    Time: 11:45:40
                    Voltage terminal 30: 12.0 V
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 5WA 980 556 B    HW: 5WA 980 556 B
   Component: RV eCompact   H26 0254
   Serial number: FCLK20080421000
   Coding: 01031000842000
   ASAM Dataset: EV_CamSysRVCCompaFicos 009020
   ROD: EV_CamSysRVCCompaFicos_009.rod
   VCID: 50F21F274A14DB0B373-8104
   Part No SW: 8Y0 035 282 A    HW: 8Y0 035 282 A
   Component: OCU3HMQB37W   H06 0030
   Serial number: 0000000105VIYK3
   Coding: 013801109FE928A590254600315F2607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002.rod
   VCID: 363E49BFC8B0953B0DF-8162 SFD
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 8Y1 919 617     HW: 8Y1 919 617
   Component: HeadupDisplay H16 2048
   Coding: 4700F0
   ASAM Dataset: EV_HeadUpDisplMQB37W 001018
   ROD: EV_HeadUpDisplMQB37W.rod
   VCID: 0358E06BCBE2F093FA1-8156
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H06 3129
   Serial number: E57830711211320
   Coding: 00040888216CC040109E44001020008000430000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_AU38.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8Y0 907 159     HW: 81A 907 159 A
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 210127200135
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS005 0330
   Serial number: YE007UDC31887
   Coding: 000E89004000000000001000
   VCID: 4BC8084BA332F8D3421-811E
   Component: TSG HBFS005 0330
   Serial number: YE007UDB02785
   Part No SW: 4K0 941 591 BS    HW: 4K0 941 591 B
   Component: LMS_MQB       H11 0044
   VCID: 0154EA63D1FEE283E8D-8154
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800080
   VCID: 231880EB6B221093DA1-8176
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002.rod
   VCID: 47C0347BBF5A1CB3669-8112
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----(Elapsed Time: 03:56, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
EuroX
Northern NJ USA
C?ID=208579
Its under warranty so take it to the dealer.
  • Agree
Reactions: JMR
Switzerland
C?ID=516731
Guys the car is not in the USA, its in Switzerland, the land of cheese and chocolate. Over here damage to the headlights that require replacement - is not covered under warranty, they are considered consumables like tyres. So just take it to the dealer because its under warranty is not the solution over here. Also - we seem to be glossing over the fact that VCDS 22.9 gets rejected whenever any attempt at basic settings is attempted or adaptations. It does not work. I assume its because the vehicle is too new? Looking at external sources, it appears that 10 X LEDS is fully functioning and 2 X L's is Not Functioning Good (NFG)... heres the pictures:
Press release - Audi S3 Sportback 2021
So it appears the left side is the problem not the right side. (drivers side left) Is this a coding feature or as Uwe says - just not effing working properly?
Physical damage I can understand, but this looks like a defect, not damage.
SFD....
EuroX
Northern NJ USA
C?ID=208579
SFD....
Correct but SFD is only related to USER trying to access/change/manipulate data/information. SFD authorization is assigned to each user id and geko id by dealer extranet admin for use with ODIS. In this case vehicle most likely has diagnostic firewall and needs SFD to perform any sort of learning functions.
It would be a good habit to get into to maintain 12.5V or higher during diagnostics also. (connect a battery charger, 10-20 amps while ignition is "ON".
I would still take it to the dealer and get their official opinion. (?)
Westbury, UK
Also worth asking @fastlanetuningschweiz if he had the bonnet/hood open to disable any diagnostic firewall when trying to make changes?
Switzerland
C?ID=516731
Yes the hood was open, was only on a preliminary scan to see what was going on and if it was adaptable, in between the engine was running to keep the voltage higher. Normally Id connect a charger of course for extended duration scans etc. Im going to have a look at it with ODIS today and see what comes back.
AINils
Germany (AIB)
C?ID=56975
Did you change light control on right side also? Or just head light without control module?
Switzerland
C?ID=516731
So I made an attempt with ODIS and a SVM / GEKO connection. 2 things became very apparent.
1. Need VAS 6064 - the newest VCI - it will not program without it. I have only the VAS 5054a.
2. Do not trust the company VXDAS, they offer one time login for such purposes but the second the tech left the computer ODIS asked for the login again in the middle of a diagnostics session. No second session created, no change of vehicle, still on the same job.
There was no fault found in the lighting system, which leads me to believe that Uwe and crew were correct at the start - its a faulty light itself. In any case this thing has been kicked over to Audi to deal with, Ive wasted enough time on the stupid thing. Thanks everyone for your help I hope the feedback provided helps people. SFD is a bitch but the bigger problem is the requirement for the newest VCI... wont be getting around that any time soon its just too expensive.
  • Informative
