- May 4, 2022
- 34
- 9
- Newcastle, Australia
- C?ID=514991
Hi, I have a fault code which clears then reappears shortly after.
Vehicle is a 2014 Bitdi 400 single cab tray back amarok. It is a 4wd with low range not a full time (4motion). I'm not sure if the AWD should be enabled? as it is techically not AWD?
Brake lights work so I dont believe there is a problem with the switch controlling the brake lights (all 3 work) the two rear are LED, the high level .
Code clears then reappears. brings up the flashing glow plug MIL.
Without the DTC the cruise control works. Once the code registers the cruise stops working.
The codes doesnt seem to have any effect on anything else other than the cruise control.
Any help appreciated
Friday,09,September,2022,08:12:46:14227
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Dealer/Shop Name: Don1
VIN: WV1ZZZ2HZDA063068 License Plate:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 10 15 17 19 22 25 32 56 69 77
VIN: WV1ZZZ2HZDA063068 Mileage: 163630km-101674miles
22-AWD -- Status: Not registered 0001
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-CNEA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 012 AD HW: 03L 907 309 AC
Component: R4 2.0l BTD H24 9977
Revision: 74H24--- Serial number: 00000000000000 CVN: F4CE46750000000000000000
Coding: 0159401A231600080001
Shop #: WSC 56885 003 1048576
ASAM Dataset: EV_ECM20BTD01103L906012AD 004006
ROD: EV_ECM20BTD01103L906012AD_004.rod
VCID: 6695B80C28E4B40B7DF-8032
VINID: 9E606AAAA098A94440183006201C6AFD68
2644 - Brake Switch (F)
P0571 00 [175] - Implausible Signal
Mileage: 163628 km
Date: 2022.09.09
Time: 06:06:14
Engine RPM: 840.00 /min
Normed load value: 32.2 %
Vehicle speed: 2 km/h
Coolant temperature: 44 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.000 V
Requested transmission torque: 1000.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 6
selected gear-Bits 0-7: 1
Transmission torque intervention status-Bits 0-7: 0
Calculated reducing transmission intervention torque: 1000.0 Nm
Readiness: 0110 0000
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 L HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0110
Revision: 00H44001
Coding: C07324B6919A039824A289A9AF5890
VCID: 392F2370095AEBF3E0D-806C
Reset counter: 9
Mileage: 163635 km
Date: 2017.01.30
Time: 20:17:21
Count: 16384
Count: 4097
Count: 148
Count: 252
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 2H0 907 047 E HW: 2H0 907 047 E
Component: Climatic-T5 H20 0505
Revision: 00001008
Coding: 0000000002
Shop #: WSC 07456 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 2A0D0C3CFC7C506B997-807E
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 M HW: 6R7 937 087 M
Component: PQ25 BCM H30 0555
Revision: -1------ Serial number: --------------
Coding: 600000B80C210000002808D02C4B80C5008041DE60020000300000000003
Shop #: WSC 66669 333 66662
VCID: 4EC560ACA0D45C4B25F-801A
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3323
Coding: 050000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3323
Coding: 050000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0610207
Coding: 020000
03301 - Response Closing Status of Drivers Door
Reset counter: 49
Mileage: 163630 km
Date: 2017.01.30
Time: 06:11:52
03302 - Response Closing Status of Passenger's Door
Reset counter: 49
Mileage: 163630 km
Date: 2017.01.30
Time: 06:11:52
Address 10: Park/Steer Assist
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00H H06 0013
Revision: -------- Serial number: 003HN005V5RP
Coding: 000000000000000000000000000000003048
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 333311582BB611A32A1-8066
Serial number: 3495RRB400C50GQ65H27
Serial number: 3505RRB400C50GQ6K1JF
Serial number: 3555YRB401A50FMC9HQ$
Serial number: 3565YRB401450FFIJHDU
Part No SW: 2H0 920 861 C HW: 2H0 920 861 C
Component: KOMBI H05 0605
Coding: 170A00
VCID: 270BF508EF6E6D03869-8072
Part No SW: 6N0 909 901 HW: 6R7 937 087 M
Component: GW-K-CAN TP20 H30 0555
Revision: -1------
Coding: 552260
VCID: 70B9DE541AA06ABB173-8024
Reset counter: 9
Mileage: 163628 km
Date: 2017.01.30
Time: 03:10:10
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 C HW: 2H0 927 755 C
Component: SG offroad VTG 0155
Revision: 00H07000 Serial number: T33YC08032HCM8
Coding: 0000013
VCID: 30391E54D6202ABB573-8064
Component: IMMO H05 0605
VCID: 6A8DCC3C3CFC906B597-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 13.05.13 00
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2C010A24F6884E5B6BB-8078
Part No SW: 5K0 035 156 A HW: 5K0 035 156 A
Component: Radio H52 0107
Revision: R0000000 Serial number: VWZAZ1N6138198
Coding: 0500020001
VCID: 2517FF0095E27F13B45-8070
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030480654
Coding: 0100000100000000
VCID: 30391E54DA202ABB573-8064
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664629820
Coding: 0200010001010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2D3C7C0CDCE0EBE97-806E
9458195 - Control Module for Cellular Telephone
B1052 13 [008] - Open Circuit
[Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
Reset counter: 49
End----------(Elapsed Time: 01:07, VBatt start/end: 14.2V/14.1V)-----------
