- Sep 10, 2022
- 8
- 4
- Bellingham, WA, USA
- C?ID=522163
Hi everyone, I've been bringing a 2010 2.0t Passat back from the dead, and the whole thing is just about sorted. There is a nagging issue with a cold start misfire, and I'm hoping that the folks who are more knowledgeable about what to look for, and when, can lend a hand. This is cross posted from the Vortex forum, and here is the original post below:
The issue first presented itself the morning after a longer than usual drive. Upon starting from dead cold, the engine would not stay running on it's own initially, would stutter, and then stall. If I proceeded to open up the throttle a bit, it would run (somewhat unhappily, but it would run). The odd behavior is that it would only do this for a short time, less than a few minutes, and then basically flatten right out into a happy idle. It would not gradually improve, it was as if there was an on/off switch to the issue. One second it would not idle, the next, fine.
Ambient temps in the high 50's Fahrenheit, and the issue seems to cease when the coolant temp reaches 50 Celsius, but I don't know the delay on the sampling.
The issue only happens when the engine is completely cold, and only for those first few minutes. No CEL present.
In my time of ownership, I've done what I can to take care of the usual 2.0tsi issues. Here is what I have done/replaced:
In my time of ownership, as I do with most cars, I've gone through the engine bay for the details;
This morning, the engine idled fine from cold (1200 rpm), but then when settling down to ~700 or so, the engine began logging tons of misfires, with a flashing CEL, but again, as above, after a short time, calmed down and drove as normal during and after several shut downs/restarts.
I'm fairly mechanically inclined, and can typically troubleshoot my own issues. I know that one of the big three (fuel, air, spark) is not happening in the right quantity, or at the right time. Without a more descriptive diagnostic code, I'm a little lost. It nearly seems as if there is a component that doesn't know that it has failed, so the system isn't seeing the trigger for the CEL.
Any inputs on where I should start? I realize I have this incredible tool in VCDS, but at this point, having looked at some of my logs, I very honestly don't know what to be tracking to hunt this down.
Some of the measuring blocks I've been logging (not all inclusive):
Any assistance would be appreciated, I am a VCDS rookie, but love the tool. I also very much enjoy this car and would like to sort it out completely. The diagnostic on this is specifically difficult as it only happens at dead cold, and that is only in the morning while I am trying to get my kiddo to daycare.
I am wondering if there is a block to view if the injectors are drowning the cylinders in fuel due to leakage, but I am not sure how to verify short of replacing the injectors. I am sure there is a better way to measure air/fuel ratio, but again, not sure which block to use. Fuel mileage does not seem to be suffering, 25-29 average depending on amount of highway trips. So leaky injectors seem unlikely.
Present me:
I had a user suggest that the MAF could be the issue, so I did a bit of digging to see how I could best test this with VCDS, and my follow up post was this:
Bringing some data back to this, I logged a cold start this morning coupled with a short drive around the block, and I noticed something interesting with the idle adaptation (or lack there of):
As I understand it, there should be some short term fuel trimming happening in group 32.
You can also see that when the O2 sensor comes online into closed loop, the lambda control is pegged at 25%. Eventually, the mapping calms down:
But something does seem odd with the start up behavior.
I logged a WOT run (short one) to see about MAF behavior, and here is the readout:
Seems like this is within normal spec, but any input is appreciated on that front.
With no adaption happening at idle, it would seem that the MAF could be the culprit, but there is certainly a challenge here with information overload.
Present me again:
Here is the autoscan:
Any help would be greatly appreciated. I believe I understand what the data is telling me, but what I don't really have a great grasp on, is why it is behaving the way it is.
Logically, if I get the gist of what I've read, is that if the lambda control is pegged at 25%, it is essentially telling me that it is seeing the leanest possible condition and doing what it can to compensate to the limit of its threshold (25%). But what I don't think I know what to look at is the corresponding values to see why, or if it is even effectively changing the map.
I do understand that air flow meters, MAF/AFM/etc, have a habit of going bad without them really knowing that they are broken. But they are not inexpensive, and it would be helpful to see if I can trouble shoot a bit further to gain some confidence.
I've also done the O2 sensor test (block 34?) and VCDS calls the sensor OK.
Long first post, but if I've learned anything by lurking on here, y'all would much rather have as much information as possible!
Really appreciate any help!
- Carbon cleaning (walnut shells)
- Coils (OEM)
- Plugs (OEM)
- Oil change
- Injector cleaner (not my magic bullet, but I had some laying around)
- MAF cleaned
- Checked/repaired any vacuum lines
- Replaced air filter
- Checked all host clamps/fitments
- Verified all electrical connections are solid
- Misfire count
- Misfire count/cylinder
- Throttle plate angle
- Fuel rail pressure expected
- Fuel rail pressure actual
- Fuel pump duty cycle
- Engine RPM
- Timing
- Coolant temp
- Ambient temp
- Fuel trim (block 32? I can't recall, but it's a percentage value)
Present me:
Present me again:
Saturday,10,September,2022,08:27:35:52859
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WVWXK7ANXAE065373 License Plate:
Mileage: 301990km-187647mi Repair Order:
Chassis Type: AN-VW46 (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 53 56 62 65
6D 72 77
VIN: WVWXK7ANXAE065373 Mileage: 301990km-187647miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 DA HW: 06J 906 026 DA
Component: MED17.5 TFSI 2,0 6987
Revision: AAH11--- Serial number: VWZCZ000000000
Coding: 0404010A1C070160
Shop #: WSC 03189 444 12565
VCID: 6C81C9FD6A8710DB037-8038
VINID: 9E69E86C745EA115401850C70CB79A0901
P0300 - 000 -
Mileage: 301991 km
Date: 2017.01.31
Time: 08:13:01
RPM: 955 /min
Load: 41.6 %
Temperature: 21.0∞C
Temperature: 16.0∞C
Absolute Pres.: 1000.0 mbar
000769 - Cylinder 1
P0301 - 000 - Misfire Detected
Mileage: 301991 km
Date: 2017.01.31
Time: 08:13:34
RPM: 951 /min
Load: 39.2 %
Temperature: 28.0∞C
Temperature: 16.0∞C
000771 - Cylinder 3
P0303 - 000 - Misfire Detected
Mileage: 301991 km
Date: 2017.01.31
Time: 08:13:34
RPM: 951 /min
Load: 39.2 %
Temperature: 28.0∞C
Temperature: 16.0∞C
000772 - Cylinder 4
P0304 - 000 - Misfire Detected
Mileage: 301991 km
Date: 2017.01.31
Time: 08:13:34
RPM: 951 /min
Load: 39.2 %
Temperature: 28.0∞C
Temperature: 16.0∞C
000770 - Cylinder 2
P0302 - 000 - Misfire Detected
Mileage: 301991 km
Date: 2017.01.31
Time: 08:13:34
RPM: 951 /min
Load: 39.2 %
Temperature: 28.0∞C
Temperature: 16.0∞C
Readiness: 0110 0101
Part No SW: 02E 300 053 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2106
Revision: 51112 Serial number: 00000910151439
Shop #: WSC 05311 000 00000
VCID: 1373B20117796F2362D-8046
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000795814227
Coding: 0000380
VCID: 629DA7C5984356ABB9B-8036
Fault Status: 00101101
Reset counter: 135
Mileage: 301991 km
Date: 2017.01.31
Time: 20:06:01
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011111
Count: 217
Hex Value: 0x0000
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 05311 115 00000
ROD: EV_ClimaBasis_VW46.rod
VCID: 75B7EC99354DD113EC9-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000003432383
Coding: 158C8F0340041A00470000000F00000000285D435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 3333128177398F2302D-8066
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 150909 006 0208
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 H HW: 5N0 959 655 H
Component: J234__01T VW10 HI 1916
Revision: 20013000 Serial number: 003E1PMDEV82
Coding: 0012628
VCID: 42DD4745388336AB99B-8016
Subsystem 1 - Part No: 3C0 959 339 D
Component: BF-Gewichtsens. 001 0002
Subsystem 2 - Serial number: 00000000004VMU
Subsystem 3 - Serial number: 0025.09.090000100000640013ˇÜ63
Subsystem 4 - Serial number: 640013ˇÜ6332MTS636642679 ˇÜ63
Subsystem 5 - Serial number: 42679 ˇÜ6342MTS648662769 ˇÜ63
Subsystem 6 - Serial number: 62769 ˇÜ6351HTS6P1AA66KR ˇÜ63
Subsystem 7 - Serial number: A66KR ˇÜ6361HTS6EVKV19KR ˇÜ63
Subsystem 8 - Serial number: V19KR ˇÜ63727TS6201166KJ ˇÜ63
Subsystem 9 - Serial number: 166KJ ˇÜ63827TS62M2266KR ˇ
Subsystem 10 - Serial number: 266KR ˇ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0122
Revision: FF010E35 Serial number: 20091020100472
Coding: 198A270002
ASAM Dataset: EV_VW360SteerWheelUDS A03002
VCID: 6FBBDEF15711EBC3265-803A
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Part No SW: 3C0 920 972 L HW: 3C0 920 972 L
Component: KOMBI H03 0305
Coding: 261F00
Shop #: WSC 05314 115 12345
VCID: 2F3B1EF19791ABC3665-807A
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0170
Revision: H13 Serial number: 3420P09A240188
Coding: FD807F07021612002002
Shop #: WSC 05314 000 00000
VCID: 2F3B1EF19B11ABC3665-807A
Fault Frequency: 15
Reset counter: 4
Mileage: 298997 km
03272 - Control Module for Audio Interface
Reset counter: 7
Mileage: 299593 km
Part No SW: 3C8 919 965 HW: 3C8 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1614128T10PD02
Coding: 0000002
VCID: 75B7EC9939CDD113EC9-8020
Part No SW: 3C0 959 433 AP HW: 3C0 959 433 AP
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
VCID: 78A9E5AD2EDFAC7BF7F-802C
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 2E: Media Player 3
Part No SW: 1K0 959 701 AR HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1501
Revision: 72009005 Serial number: 00000628599013
Coding: 0001205
VCID: 7EA5F3B50CFB924BBD3-802A
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.148 0703
Revision: 1AH03256 Serial number: 00092500351602
Coding: 0000258
VCID: 3A2D3FA550537E6BC1B-806E
Component: KSG PQ46 RDK 052 0412
Coding: 1A900E80D1030E362004141CF08A0F0E085801
Shop #: WSC 05311 123 12345
Part No SW: 1K0 959 702 AR HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1501
Revision: 72009005 Serial number: 00000752399013
Coding: 0001204
VCID: 7F5B0EB10BF19B43B65-802A
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000058156
Coding: 0000057
VCID: 2C0109FDAA07D0DB437-8078
Reset counter: 189
Mileage: 298999 km
Date: 2017.01.31
Time: 00:07:60
Voltage: 8.20 V
Count: 50
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5614
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 16000400040005
Shop #: WSC 127395 840 08317
VCID: 46D55B5518AB0A8BB53-8012
00856 - Radio Antenna
Fault Status: 00111011
Reset counter: 221
Mileage: 27780 km
Date: 2012.12.23
Time: 07:30:09
Fault Status: 00101110
Reset counter: 6
Reset counter: 37
Mileage: 300737 km
Date: 2017.01.31
Time: 06:47:47
Part No SW: 1K0 959 703 AD HW: 1K0 959 795 P
Component: J388 TUER-SG HL 0307
Revision: 42004101 Serial number: 00000001113587
Coding: 0001168
VCID: 72BDD78548A3C62BC9B-8026
Component: RDK 0453
Coding: 0100101
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 G HW: 3C9 827 383 G
Component: J605 HECKDECKEL 0730
Revision: 00H27001
VCID: 35372C99794D91132C9-8060
Subsystem 1 - Part No: 3C9 827 384 G
Component: J756 HECKDECKEL 0730
Subsystem 2 - Serial number: 0900H27001001B0171ˇ
00317 - Rear Lid Control Module (J605)
Reset counter: 127
Mileage: 288653 km
Date: 2015.11.10
Time: 22:42:01
03047 - Motor (in Trunk/Hatch control module) (V375)
Fault Status: 00101011
Fault Frequency: 26
Reset counter: 114
Mileage: 296902 km
Date: 2016.04.13
Time: 03:23:52
Part No SW: 1K0 959 704 AD HW: 1K0 959 794 P
Component: J389 TUER-SG HR 0307
Revision: 42004101 Serial number: 00000001098186
Coding: 0001168
VCID: 73B3D28137B9CF23C2D-8026
Address 77: Telephone
End----------(Elapsed Time: 02:08, VBatt start/end: 14.4V/14.3V)-----------
