- Feb 27, 2015
- 68
- 64
- Central FL
- C?ID=148074
2010 GTI in excellent shape with 63k on the clock. CEL is on for the 012425 code. Any pointers on how to determine if the fuel pump control module or the lift pump is causing this code? I cleared it the other day but it came back. The 050217 code did not. The car is running fine and hasn't shown any symptoms of a failing module or pump. When I go to group 106 in MB the actual and requested pressures seem to be fine. The code comes back after a day or so of driving. The duty cycle of the pump was 69-70% at idle when the car first came in. I replaced the fuel filter and the duty cycle dropped to an acceptable 53%. Before I replace the pump and control module I was wondering if anyone has any pointers. I called the dealer to get a price on the pump and ask if there were any TSBs associated with it and was told no. I don't think the parts guy even looked into it.
Thanks in advance,
Josh
Thanks in advance,
Josh
Chassis Type: AJ (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 65 77
VIN: WVWEV7AJ0AW424994 Mileage: 101760km-63230miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AM HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH17--- Serial number:
Coding: 0403010A18070160
VCID: 71E3CD8D68D8AFA9911-8024
012425 - Signal Line for Fuel Pump Electronics
P3089 - 000 - Electrical Malfunction - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 9
Mileage: 101669 km
Date: 2015.06.20
Time: 04:10:42
RPM: 697 /min
Load: 36.5 %
Speed: 5.0 km/h
Temperature: 57.0°C
Temperature: 36.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
050217 - Implausible Data Received from Steering Column Control Module
U0429 - 000 - - Intermittent
Mileage: 101567 km
Date: 2015.06.16
Time: 19:56:43
Temperature: 90.0°C
Temperature: 51.0°C
Voltage: 12.319 V
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492400FE881406ED921D0041300800
VCID: 78F5F0A9CBA2FEE156F-802D
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW32.rod
VCID: 75EBF99DD4B083894D9-8020
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AF
Coding: 6D180A1A90272A0480080081600005C441010086534D8D60648020200000
Shop #: WSC 05232 444 54327
VCID: 356B399D9C30C3898D9-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 06051 23 0512
Coding: 009795
Fault Status: 00101010
Fault Frequency: 81
Reset counter: 108
Mileage: 98437 km
Date: 2015.04.15
Time: 17:15:14
Voltage: 13.90 V
Term 50 Off
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R009RPL
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: 397335ADB82827E9691-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--000558DU00
Serial number: 3572MSME13313153ZZZD
Serial number: 3582MSME78351353ZZZT
Serial number: 3512QSME1C4C5D19ZZZ5
Serial number: 3522QSME06575C01ZZZS
Serial number: 35527SME0F0A0822ZZZD
Serial number: 35627SME401A0822ZZZ4
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78F5F0A90BA2FEE156F-802D
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Coding: 270F00
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 050510F1003792
Coding: E9801F07001612000000
VCID: 69D3A5ED40085769D91-803C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R8XFG06
Coding: 0000002
VCID: 7EF9E6B12986C0D11C3-802B
Component: IMMO H03 0305
VCID: 6AD1DAE18D0E5C71D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7668050191
VCID: 2649EED15196B811343-8073
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2111
Coding: 0001076
VCID: 31630D8DA858EFA9D11-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 32610281AD5ED4B1A8B-8067
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H13 0044
Revision: -----26S Serial number: VWZ4Z7K3113738
Coding: 0100040004
Shop #: WSC 05232 444 100092
VCID: 61C3BDCD78381F29011-8034
Reset counter: 54
Mileage: 62222 km
Date: 2013.04.10
Time: 12:46:04
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018705
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 000 000 000 00
Component: Telefon H00 6900
Revision: 00000000 Serial number: 000000AA000000
Coding: 003420
VCID: 2A511AE1458E9C7110B-807F
01524 - Antenna for Telephone
Reset counter: 234
Mileage: 62222 km
Date: 2013.04.10
Time: 12:46:55
02791 - Telephone baseplate (R126)
Reset counter: 234
Mileage: 62222 km
Date: 2013.04.10
Time: 12:46:55
