- Aug 22, 2022
- 3
- 0
- Houston, TX, USA
- C?ID=448943
2012 Q7 3.0 TDI
Getting request out of range while coding injectors.
We have verified not getting I for 1 mixed up.
We have changed the workshop codes to random numbers.
Update firmware to latest version.
Updated software to latest version.
One of 6 codes actually works on any of the 6 channels. (7Z1ECEE)
Any help is greatly appreciated.
See Autoscan below:
See Autoscan below:
Tuesday,23,August,2022,19:38:16:04121
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WA1WMAFE8CD004392 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
56 5F 62 69 6C 6D 6F 72 76
VIN: WA1WMAFE8CD004392 Mileage: 178490km-110908miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI FSA X18 0009
Revision: 54X18--- Serial number: CVN: 5B6F114CD45710C138D3FF82
Coding: 2A2A4012253600050000
ASAM Dataset: EV_ECM30TDI0114L2910401 002008
ROD: EV_ECM30TDI0114L2910401_002.rod
VCID: 619FAC3C81C8AB93A01-8034
VINID: 9D10677515952135000040C908CB47BB8E
5211 - Fuel Rail/System Pressure
P0087 00 [237] - Too Low
Mileage: 178490 km
Date: 2022.08.22
Time: 21:25:21
Engine RPM: 2018.00 /min
Normed load value: 99.6 %
Vehicle speed: 44 km/h
Coolant temperature: 73 °C
Intake air temperature: 35 °C
Voltage terminal 30: 13.700 V
Fuel temperature: 38.0 °C
Mean injection quantity: 66.09 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high-pressure: actual value: 1302600 hPa
High fuel pressure: specified value: 1604700 hPa
Pressure control valve adaptation factor: 1.0654
Fuel level: 37.00 l
5212 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Mileage: 178490 km
Date: 2022.08.22
Time: 21:26:23
Engine RPM: 3678.00 /min
Normed load value: 95.7 %
Vehicle speed: 28 km/h
Coolant temperature: 78 °C
Intake air temperature: 36 °C
Voltage terminal 30: 13.040 V
Fuel temperature: 37.1 °C
Mean injection quantity: 47.06 mg/stroke
Fuel high-pressure: actual value: 1375200 hPa
High fuel pressure: specified value: 1750700 hPa
Fuel level: 37.00 l
4875 - Coolant Pump 2
P261A 00 [175] - Open circuit
[Coolant Pump "B" Control Circuit/Open]
Mileage: 178490 km
Date: 2022.08.22
Time: 21:23:29
Engine RPM: 0.00 /min
Coolant temperature: 65 °C
Intake air temperature: 39 °C
Voltage terminal 30: 11.580 V
Coolant temperature at radiator outlet: actual value: 35.9 °C
Bypass valve for EGR cooler: status-Bits 0-7: 1
EGR cooling function: status-Bits 0-7: 18
exh.gas recirc. (EGR) cooler pump: specified value: 80.00 %
Temp sensor for EGR after cooler: raw value: 1000.0 °C
Exhaust gas temperature sensor 1: 79.7 °C
Readiness: 1 2 0 1 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 3408
Serial number: CVN: 44BD1086
Coding: 001378
Shop #: WSC 11906 004 1048576
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 3C213D4846EAA67BD37-8068
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099473
Shop #: WSC 27483 002 1048576
VCID: 34311568623A6E3B1B7-8060
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:06:56
Count: 65
Count: 8194
Count: 42240
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H07 0200
Revision: 00H07000 Serial number: 10603501910040
Coding: 0000135
VCID: 2517F82CD9E007B39C9-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
00193 - Rear Right Door Handle Touch Sensor (G418)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 134
Mileage: 158745 km
Date: 2021.11.05
Time: 16:07:51
00191 - Passenger's Door Handle Touch Sensor (G416)
Reset counter: 134
Mileage: 158745 km
Date: 2021.11.05
Time: 16:07:52
00230 - Transmission Park Selector Switch (F305)
Fault Status: 00101010
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:08:17
Reset counter: 174
Mileage: 178461 km
Date: 2022.08.04
Time: 20:49:44
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AJ
Revision: 00---026 Serial number: 00000000299782
Coding: 0004A036
Shop #: WSC 31414 790 00001
VCID: 2517F82CD5E007B39C9-8070
Subsystem 1 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0015396407
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Serial number: 0015397645
Coding: 070000
01273 - Fresh Air Blower (V2)
Fault Status: 01101010
Reset counter: 135
Mileage: 178491 km
Date: 2022.08.22
Time: 21:33:40
Temperature: 27.0°C
(no units): 186.0
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:07:01
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133123
VCID: 6E85C7004C9604EB2D3-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Fault Status: 00100111
Reset counter: 174
Mileage: 178460 km
Date: 2022.08.04
Time: 14:45:00
Fault Status: 00111010
Reset counter: 174
Mileage: 178460 km
Date: 2022.08.04
Time: 14:45:00
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09WKL3
Coding: 0014131
VCID: 2B030E14BF0431C34AD-807E
Subsystem 1 - Part No: 4L0 959 339 B
Component: BF-Gewichtsens. H04 0040
Subsystem 2 - Serial number: 6332QSME7B600E44L
Subsystem 3 - Serial number: 6342QSME776500528
Subsystem 4 - Serial number: 6352QSME7B601F76U
Subsystem 5 - Serial number: 6362QSME7E601266K
Subsystem 6 - Serial number: 63734SME3A5F307CD
Subsystem 7 - Serial number: 63834SME09604F564
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H07000 Serial number: 90025112660223
Coding: 0012142
VCID: 2809F118AEF21ADBA7F-807C
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 984 R HW: 4L0 920 984 R
Component: KOMBIINSTR. H22 0411
Revision: 00000000 Serial number: LMZ50Y3AC
Coding: 8BD664040900CF05020205
VCID: 42DD43B0248ED08B99B-8016
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:06:57
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0057
Revision: MB600036 Serial number: 3600M119260097
Coding: 00C303
VCID: 3FDB4A44577CBD63F65-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790746679
Fault Frequency: 242
Reset counter: 174
Mileage: 158745 km
Date: 2021.11.05
Time: 16:07:02
Bin. Bits: 10111
Voltage: 11.00 V
Count: 7
02256 - Quiescent Current
Fault Status: 00100001
Fault Frequency: 139
Reset counter: 174
Mileage: 158779 km
Date: 2021.11.05
Time: 23:26:00
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:06:57
Bin. Bits: 10111
Voltage: 11.50 V
Count: 7
Bin. Bits: 10011
Time: 25.40 s
00384 - Optical Databus
Fault Status: 00101011
Reset counter: 174
Mileage: 178461 km
Date: 2022.08.04
Time: 14:40:48
Bin. Bits: 00000
Voltage: 11.50 V
Count: 19
Bin. Bits: 11000
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000030215087
Coding: 0000006
VCID: 6889B1186E72DADB67F-803C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 134
Mileage: 158753 km
Date: 2021.11.05
Time: 18:12:48
00003 - Control Module
Fault Status: 00100011
Mileage: 160639 km
Date: 2021.11.27
Time: 15:38:13
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000014945565
Coding: 00581B00000011110000
VCID: 323D1370942E600B09B-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E0507008C1644EB6D3-807A
Subsystem 3 - Serial number: 5F28.09.1100H010003C914269ÿ
Subsystem 4 - Serial number: 914269ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000015971538
Coding: 011F57205E40440004
VCID: 48C9519802B2FADB47F-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H11 0120
Revision: 0120 --- Serial number: 01582941610000
Coding: 3569693
VCID: 382921587E528A5B37F-806C
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:06:56
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0160
Revision: CH003000 Serial number: 00000000015049
Coding: 030000
Shop #: WSC 43296 001 1048576
VCID: 290FF41CB9F823D3B81-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190129018
Coding: 0758477
VCID: 2313E634D7D4F983F2D-8076
Fault Status: 00101101
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:06:57
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 11.70 V
Temperature: 25.0°C
(no units): 0.0
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:06:56
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 11.70 V
Temperature: 25.0°C
(no units): 0.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000097801
Coding: 0012001
VCID: 5EE597C0BC36946B9D3-800A
Reset counter: 175
Mileage: 178460 km
Date: 2022.08.03
Time: 17:06:00
Voltage: 11.600 V
Temperature: 25.0°C
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000015919707
VCID: 47CB52A40FACF5A34E5-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:06:57
Component: Radio U SIRIU H53 0133
Revision: AB001007 Serial number: 156J/0B7561156
Coding: 020007010000000000
VCID: 2411E528DEDAFEBB8B7-8070
Reset counter: 175
Mileage: 178484 km
Date: 2022.08.22
Time: 19:59:35
Bin. Bits: 00000000 00001000
Part No SW: 4L2 035 746 D HW: 4L2 035 746
Component: H-BNT-NA H42 0738
Revision: -------- Serial number: 097J30B7504773
Coding: 180200060004E3EF51002345EF632003140000000100000000
VCID: 2F3B1A04871C4DE3665-807A
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130J70BS035067
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000001927217
Component: CD-Database 3371
Reset counter: 175
Mileage: 178484 km
Date: 2022.08.22
Time: 19:59:35
Bin. Bits: 00010000 00000000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000016059206
Coding: 010E57204040230004
VCID: 46D55FA008A6ECABB53-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000157628425
Coding: 0200000000000000
VCID: 313F1C7C91285B13701-8064
Reset counter: 175
Mileage: 178461 km
Date: 2022.08.03
Time: 17:06:57
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H05--- Serial number: 525PA8-J19433V
Coding: 1021201
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81CD087A8AF6FB037-8038
Subsystem 3 - Serial number: RD15.10.11--H57001001A0183ÿ
Subsystem 4 - Serial number: 1A0183ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H07 0080
Revision: AAH07080 Serial number: 120648908-----
Coding: 0003595
VCID: 2615FF20A4E60CAB953-8072
Component: J_245_EE16_SKB10H11 0220
Component: J_394_EE16_SKB10H11 0220
Component: J_392_EE16_SKB10H11 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000016059203
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H03 0100
Revision: 00H03000 Serial number: 37361124103736
Coding: 0231266
VCID: 2C010D08BA0A36FB437-8078
End----(Elapsed Time: 02:23, VBatt start/end: 11.9V/11.7V. VIgn 11.8V)-----
