2012 Passat TDI - P2459, P0101, P00AF, P1741
Eightpin
Northern VA, USA
C?ID=527706
I was originally concerned with a rougher idle and then the CEL showed up last week. A general scan showed the P2459 codes. Decided to purchase the VCDS scanner for more information, and other items showed up that I wasn't expecting.
My original plan for the P2459 code was the either clear the pipes from the sensor or replace the G450/G451 sensor and then see if that addressed the problem.
I was surprised to see the P01001 codes, as the MAF was recently replaced. I am guessing there was a computer reset I need to do, however, I am not sure of if (a) that is needed or (b) what steps to perform to do that computer reset.
Now the two new codes, The suggestion for the P1741 is to perform a computer reset. I will go ahead with that, however I wanted to verify if that was the proper course of action or not. I have no approach yet for the turbo code (P00AF), as I don't have a vacuum press to check that is functioning. Would love any suggestions there as well.
Really impressed with this VCDS application and after reviewing this board, I am eve more impressed with the community. I am hoping to tap into this talent for some advice.
TIA
Tuesday,30,August,2022,15:46:35:56166
VIN: 1VWCN7A37CC055657   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCN7A37CC055657   Mileage: 236460km-146929miles
   Component: R4 2.0l TDI   H21 9982
   Revision: 71H21---    Serial number:                CVN: D240C61FD45710C1
   Coding: 001D0012042400008000
   Shop #: WSC 09460 444 00000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B233A1483E816B3DAD-806E
   VINID: 0669D37874431D34C01451851CFE2D0DDF
4795 - Mass Air Flow Sensor (G70)
          P0101 00 [096] - Implausible Signal
13011 - Actuator Module for Turbocharger 1
          P00AF 00 [101] - Stuck
                    Mileage: 236439 km
                    Date: 2022.08.30
                    Time: 14:02:09
                    Engine RPM: 830.50 /min
                    Normed load value: 36.1 %
                    Coolant temperature: 99 ∞C
                    Intake air temperature: 55 ∞C
                    Voltage terminal 30: 12.980 V
                    Charge air pressure: specified value: 1013 hPa
                    Charge air pressure actuator: acknowledgment: 48.02 %
                    Charge Pressure Actuator: activation: 46.52 %
8863 - Diesel Particulate Filter
          P2459 00 [237] - Regeneration Frequency
                    Mileage: 236255 km
                    Date: 2022.08.25
                    Time: 16:38:12
                    Engine RPM: 1170.00 /min
                    Normed load value: 69.0 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 98 ∞C
                    Intake air temperature: 50 ∞C
                    Voltage terminal 30: 13.200 V
                    Exhaust gas jet volume in particle filter: 115.2 m≥/h
                    Particle filter: difference pressure: 114 hPa
                    Particle filter: soot mass measured: 22.36 g
                    Particle filter: soot mass calculated: 22.35 g
                    Particle filter: differential pressure: dynamic offset: -39 hPa
                    Exhaust gas temperature sensor 3: 302.2 ∞C
                    Exhaust gas temperature sensor 4: 232.1 ∞C
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9435
   Revision: 05551213    Serial number: 00001111190972
   Shop #: WSC 10305 003 1048576
   VCID: 2615FB6064EABB5B953-8072
18149 - Clutch Pressure Adaptation
            P1741 - 002 - Limit Reached
                    Fault Status: 01100010
                    Reset counter: 2
                    Mileage: 236442 km
                    Date: 2017.01.20
                    Time: 14:36:55
   Revision: 00H31001
   Coding: C54BC0F5492700FFA31103E992200042A71000
   Shop #: WSC 09003 957 00200
   VCID: 7DA7F40CDDFCD883A49-8028
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0161452723
   Coding: 130C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 34311128AEB6D9CB1B7-8060
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001012
   VCID: 1C61D9882626718B337-8048
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0164
   Revision: BL121001
   Coding: 6F200E1B982B08D408880201360085480071008645A005F0648060009C70
   VCID: 74B1D128EEB699CBDB7-8020
   Component: RLS 020212 05  54  0403
   Coding: 22300A
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM01669+
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBDE448710BA13265-803A
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000B6RB0P
   Coding: 303047
   Serial number: 3572MSME47527449ZZZZ
   Serial number: 3582MSME5B457166ZZZ$
   Serial number: 3516KSME76412C16ZZZS
   Serial number: 3526KSME751D2216ZZZR
   Serial number: 3556LSME164E5111ZZZR
   Serial number: 3566LSME6A0F4F11ZZZ4
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110622301645
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7F40CDD7CD883A49-8028
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 C    HW: 561 920 970 C
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 1A6DDF902C120FBB21B-804E
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 25011201290734
   Coding: 461000
   VCID: 3D27340C9D7C1883E49-8068
   Component: IMMO          H07 0507
   Coding: 000007
   VCID: 6A8DCF50BCF25F3B71B-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000280681001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E050340409AF31B6D3-807A
   Revision: A1001003    Serial number: 7661225673
   VCID: 290FF05C79F49423B81-807C
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000021879398
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 6099AD784A4E156BAFF-8034
   Part No SW: 3C0 035 684 J    HW: 3C8 035 684 E
   Component: RNS-MID       H61 4366
   Revision: AB001001    Serial number: VWZ6Z7M7022143
   Coding: 04090002010000A6000B
   VCID: 2A0D0F507CF29F3BB1B-807E
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0003653224
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 290    3301
   Revision: 00H22000
   VCID: 35372C2CA94CC0C32C9-8060
   Part No SW: 5C6 035 456     HW: 5C6 035 456
   Component: KonzernAmp10K H07 0468
   Revision: --------    Serial number: EAA083A0000738
   ROD: EV_AudioVerst10KanalSTT3_VW36.rod
   VCID: 6597BC6C55EC70435C9-8030
   Component: EZE_2         H40 1623
   Coding: 01030108
   VCID: 6FBBDE448790BA13265-803A
   Serial number: 53388786011133302064
   Coding: 181100
   Component: Analoguhr  008 0004
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0003767998
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D67D48C3D3C7883C49-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661318744
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270BF6646F60A253AE5-8072
End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
Eightpin
Northern VA, USA
C?ID=527706
Here is the new scan... now it is completely different, but the MAF code is still there (causing a CHECK ENGINE LIGHT)
I did replace the Timing Belt and performed a DSG Service (where the battery was disconnected). I am guessing the Door/Break faults are due to the battery reset... but the MAF code still there is confusing.
Wednesday,14,September,2022,17:19:58:56166
Mileage: 236760km-147115mi   Repair Order:
          52 56 62 72 77
VIN: 1VWCN7A37CC055657   Mileage: 236760km-147115miles
                    Mileage: 236632 km
                    Date: 2022.09.07
                    Time: 18:05:37
                    Engine RPM: 1949.00 /min
                    Normed load value: 19.6 %
                    Vehicle speed: 36 km/h
                    Coolant temperature: 46 ∞C
                    Intake air temperature: 34 ∞C
                    Voltage terminal 30: 14.140 V
                    Exhaust gas jet volume in particle filter: 231.3 m≥/h
                    Particle filter: difference pressure: 229 hPa
                    Particle filter: soot mass measured: 23.26 g
                    Particle filter: soot mass calculated: 23.26 g
                    Particle filter: differential pressure: dynamic offset: -5 hPa
                    Exhaust gas temperature sensor 3: 146.8 ∞C
                    Exhaust gas temperature sensor 4: 73.3 ∞C
   Revision: 00H31001
                    Reset counter: 247
                    Mileage: 236553 km
                    Date: 2017.01.24
                    Time: 14:26:01
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 49664
                    Count: 1
   Coding: 130C0C
   Revision: 00001001
   Coding: 0010001012
   Revision: BL121001
   Coding: 22300A
   Coding: 00003548
   Coding: 303047
   Coding: 000A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
   Coding: 000007
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 246
                    Mileage: 236553 km
                    Date: 2022.09.03
                    Time: 14:26:01
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 206
                    Mileage: 236553 km
                    Date: 2022.09.03
                    Time: 14:26:01
   Revision: 00H22000
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 206
                    Mileage: 236553 km
                    Date: 2022.09.03
                    Time: 14:26:01
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:22, VBatt start/end: 13.1V/13.1V)-----------
Eightpin
Northern VA, USA
C?ID=527706
I meant to say the DPF returned......... and this is all I found
18891/P2459/009305 - Diesel Particulate Filer: Regeneration Frequency​
Possible Symptoms​
  • MIL on
Possible Causes​
  • Heavy loads on engine (towing)
  • Short trips in cold weather
  • Faulty Exhaust Pressure Sensors (G450/G451)
Possible Solutions​
  • Change driving habits.
  • Inspect Exhaust Pressure Sensors (G450/G451) as per factory repair manual.
Special Notes​
  • Depending on driving habits, soot can build up quickly in the DPF, thus requiring more frequent regenerations than normal.
  • With CBEA and CJAA engines, the factory documentation may show the wrong part location for the Exhaust Pressure Sensor 1 (G450). This sensor is in a foil pouch just behind the oil cap.
Look in the menus and see if a "service regeneration" or "regeneration whilst standing" is listed, do the appropriate loggin and then the regen. At 22g it should fire up and clean itself after about half an hour, it needs a decent tank of fuel sometimes, depends on the car.
Reactions: JMR
