VW Multivan 08.2020. Would like to purchase...?
State-808
C?ID=522224
Hi All,
My first post in Anger, (figure of speech) I'm looking at buying this 2020 Multivan.
Everthing looks good except the AutoScan (see below)
Here are the fault codes
But what worries me is the.
1548 - Function Restriction
B2008 F0 [009] - due to Over-Temp Protection
This indicates to me that the Van was pushed so hard that it had to go into Protection mode.
I would appreciate your feedback...
Regards
State-808
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 15 17 18 19 44 55 5F 65 69 75 D6 D7
VIN: WV2ZZZ7HZLH070580   Mileage: 24370km-15142miles
Address 01: Engine (J623-CXFA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 LE    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9971
   Revision: 23301001
   Coding: 0019401C4334050800000000000000000000000000000000
   Shop #: WSC 14343 004 1048576
   ASAM Dataset: EV_ECM20TDI03004L906056LE 005008
   ROD: EV_ECM20TDI03004L906056LE_005.rod
   VCID: 7BA2F55AB3661B339AD-802E
   VINID: 9E60AAAAA1D8A9C6001C0148007974ECEF
27277 - System Voltage
          P0562 00 [032] - Too Low
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LB 614 517 A    HW: 7LB 614 517
   Component: ESC_base      H01 0700
   Serial number: 08501238200313
   Coding: 10552452484EE685085924AC12666726382020B8
   Shop #: WSC 00012 790 00047
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
   VCID: 3E243C4EE0F4CE1BFD3-806A
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 7LA 907 040 A    HW: 7LA 907 040 A
   Component: Climatronic   H01 0502
   Coding: 0030100008102100010009005040010500000000000B1101A08000000000
   Shop #: WSC 00012 790 00111
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: EV_AirCondiBHTCT6PA.rod
   VCID: 392E2F52F9DAE923C81-806C
   Rear A/C control head:
   Subsystem 1 - Part No SW: 7LA 907 049 F    HW: 7LA 907 049 F
   Component: E857  H02 0301
   Serial number: 00002080220121706605
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0936
   Serial number: 01102015400678
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205_VW26.rod
   VCID: 74B0DE669E38544BDB7-8020
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: SBY20M05D07H03M42S28
   Coding: 02B8DD
   Driver door control module:
   Subsystem 2 - Part No SW: 7L2 959 405 B    HW: 7L2 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000039555350
   Coding: 130007
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L2 959 406 B    HW: 7L2 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000039535439
   Coding: 090007
   Subsystem 4 - Part No SW: 2N0 951 173     HW: 2N0 951 173
   Component: Sensor, DWA  015 0316
   Serial number: 000000000ZY201151ZM4
   Serial number: 00000000000016410564
609292 - Child Safety / Anti Car-Jacking for Sliding Door; Rear Pass. Side
          B1A75 F0 [008] - Elect. Malfunction
                    Reset counter: 29
                    Mileage: 16839 km
                    Date: 2021.12.09
                    Time: 13:22:47
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057620134
   Coding: 0271161141
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 55F683E275822D43CC9-8000
   Part No SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
   Component: VW22Airbag    015 0506
   Revision: --------
   Coding: 88CCC00000000000400000CF000C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 005882B6DA8078EBCFF-8054
   Subsystem 1 - Part No SW: -----------    HW: 442 060 705 20
   Serial number: 3577Y20B734E2703A3F8
   Subsystem 2 - Part No SW: -----------    HW: 442 060 705 20
   Serial number: 3587Y209935C7573D0BE
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI3
   Part No SW: 7LA 920 320     HW: 7LA 920 320
   Component: KOMBI         503 4193
   Coding: 04A4088028800008010862040001000800601E02
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_AU27.rod
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 18369 km
                    Date: 2022.02.04
                    Time: 17:35:31
16711681 - Ethernet Databus
          U11C4 00 [008] - No Communications
                    Fault Frequency: 15
                    Reset counter: 16
                    Mileage: 16832 km
                    Date: 2021.12.07
                    Time: 18:37:48
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 5WA 963 271 A    HW: 5WA 963 271 A
   Component: STH-VW37x     006 0010
   Serial number: 000000000000012
   Coding: 3143221854121512DCE519
   ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
   ROD: EV_AuxilHeateWOSVW38X_001.rod
   VCID: 4ACC609EAC3C72BB51B-801E
0036 - Fuel Level too Low
          P1250 00 [096] - -
0388 - Flame-Out
          B138A F0 [096] - During Reserve Tank Level
          [FLAME OUT DURING FUEL LEVEL LOW]
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 28032010520898
   Coding: 030100344F05730400000208000F00010001070000000000000000000000
   GVL: 014C3C0000000000C00010008004480000000000000000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 70B8D276EA20686B3FF-8024
   Generator:
   Component: 4-00-11-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 E    HW: 3G0 959 442 E  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036078203832
   Coding: 281C00
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 77343301002003100F5A
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0306
   Shop #: WSC 00012 790 00155
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: EV_SteerAssisMNB.rod
   VCID: 45D653A285229DC3BC9-8010
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 0C8A020009210003
   ROD: EV_HeadlRegulAFSMQBMAX_SE25.rod
   VCID: 41DE47B2910AB1E3801-8014
   Part No SW: 3G5 035 816     HW: 3G5 035 816
   Component: MU-O-ND-EU    H12 0156
   Serial number: VWZAZ2X0576984
   Coding: 64600000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_VN46.rod
   VCID: 6694B42ED8E4B6DB553-8032
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2     H61 9214
   Serial number: VWZ6ZJX1602970
   Subsystem 2 - Part No: V03 959 806 MG
   Component: EU 2019/04     1004
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Fault Frequency: 48
                    Reset counter: 35
                    Mileage: 16904 km
                    Date: 2021.12.13
                    Time: 13:21:41
                    Voltage terminal 30: 14.7 V
          B201A 00 [009] - -
                    Mileage: 16832 km
                    Date: 2021.12.07
                    Time: 15:32:00
                    Voltage terminal 30: Write only channel V
                    module_name: Write only channel
          [Function restriction due to excessive-temperature protection (power stages)]
                    Mileage: 18695 km
                    Date: 2022.02.25
                    Time: 17:56:30
                    Voltage terminal 30: 12.4 V
                    Up-to-date: Not available
                    min.value: Not available
                    max.value: Not available
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H05 0010
   Serial number: 40000000389365
   ROD: EV_RDKBERU30_VW41.rod
   VCID: 3634246EC8C4065B253-8062
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005483
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 6B82C51AC3068BB30AD-803E
   Part No SW: 5WA 035 284     HW: 5WA 035 284
   Component: OCUGen3High   H20 0088
   Serial number: 0000000001VIHJ5
   Coding: 06462000196898009005460160400607
   ASAM Dataset: EV_OCUGen3High 002115
   ROD: EV_OCUGen3High_002_VW27.rod
   VCID: 03528DBACB9663F3D2D-8056
2566 - GPS Antenna
          B1054 13 [008] - Open Circuit
          [GPS-Antenna - Interruption]
                    Reset counter: 38
                    Voltage terminal 30: 12.5 V
1190912 - Ethernet Databus Branch 1
          U122C 00 [008] - No Communication
                    Fault Frequency: 17
                    Reset counter: 27
                    Mileage: 16832 km
                    Date: 2021.12.07
                    Time: 18:37:48
                    Ethernet counter checksum error: branch 1: 0
                    Ethernet counter connection interruptions: branch 1: 1
0081 - Databus
          [Ethernet Databus missing message - Infotainment Unit]
                    Fault Frequency: 23
                    Reset counter: 27
                    Mileage: 16832 km
                    Date: 2021.12.07
                    Time: 18:37:45
                    Voltage terminal 30: 14.4 V
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 619EA73231CAD1E3A01-8034
   Component: LED1R         H08 9002
End----(Elapsed Time: 01:21, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Mileage looks good, matches with the DSP (via erWin). The over-temp code is stored in the infotainment, certainly not unexpected and certainly not something I would worry about - especially since it only occurred once. The B201A DTC is more interesting and implies an incomplete update for the MIB. I don't see anything obvious from a diagnostic side speaking against a purchase.
AINils
Germany (AIB)
C?ID=56975
MIB has ancient FW, this crap should be fixed in VW workshop as a lot of Main unit (PCC Vendor like this) don't survive the update to newest 0309 Version. So it should be done in workshop to change Main unit if update kills that crap. Update is 2 Stage one, with duration of 90-120min.
The other things are like sebastian wrote
State-808
C?ID=522224
Thanks for the feedback Sebastian & AINils.
Query @ Sebastian, "matches with the DSP (via erWin)" what is that? is that something I can also check???
Query @ AINils, "Update is 2 Stage one, with duration of 90-120min." is that something I would have to pay for?
When yes how much? (estimate)
I'm already feeling good about my new HEX-V2 purchase...
Sebastian
Magdeburg, Germany
HN0-nnnnnn
DSP = Digital(er) Service Plan, which can be queried via https://erwin.volkswagen.de
As for the MIB update, no dealer will touch that on a car they sell prior to the sale because nobody pays for the time. Once the car is sold and there is possibly a used car warranty or an existing warranty extension which will pay for the work if needed. That said, unless there is a specific claim/issue it may not be easy to have them update it just as a courtesy. So while Nils has a point, especially that some of these won't survive the update, it isn't as clear cut as to who and what and how much.
State-808
C?ID=522224
Thanks...:thanks:
AINils
Germany (AIB)
C?ID=56975
Agree with Sebastian statement, but you`re lucky guy if car has warranty. MIB3 has a lot of bugs and random restart as reason is enough for update. So after buying car, you should claim warranty and force update at dealer
