2019 VW GTI ECU REFLASH TO BLANK
Dkoz
Missouri, USA
C?ID=401945
Hey ..
Is anyone aware of a way a 2019 GTI ECU #( 06K907425J ) can be refreshed to technically be considered a " blank slate ". My ECU was fried along with the body control module due to Lighting, I was able to get another ecu under the assumption is was blank but turned out its got a Vin number written to it along with immobilizer data. The Dealership didn't think they would be able to reprogram a used ECU to match the car. Or is the only way forward to just bite the bullet and order a New ECM from the dealer ?
2kaa52
C?ID=319193
Match a used ecu to your car isnt a Problem. If your vw dealer cant/will do it,go to other dealer.
Set a used ecu to virgin state isnt needed.
DrPeter
16.4905° S, 151.7375° W
Hi there...
I am a little late to the party... :p
If you still need help with that dealer, see if they are willing to create a Technical Assistance (VTA) ticket and call the Volkswagen Technical Helpline to see if they can get any assistance with the matching of a used ECM. if they do not what that is, then I agree with 2kaa52, get a new dealer!!!
Hope this helps,
drpeter
Dkoz
Missouri, USA
C?ID=401945
I have an Update. I was able to get the Used ECM programed via third party and not the dealer. We were able to get the car to crank now, component protection taken care of. I believe when it was programmed, the coding currently in the software is incorrect. When attempting to start the car , I've been monitoring certain sensors and when cranking, and one that seems off is the Camshaft position sensor. I'm not seeing any camshaft RPMs. I've checked the wiring and replaced the sensor with a new OEM one with nothing changing. Im hoping someone with more knowledge then me can double check the coding. The only two items that were replaced and reprogrammed so far was the ECM and the Body Control module. It is a 2019 GTI that's a 6 speed manual.
Friday,23,September,2022,12:52:27:04766
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4615.4
VIN: 3VW5T7AU2KM014955   License Plate:
Mileage: 16908km-10506mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F 75
          A9 D6 D7
VIN: 3VW5T7AU2KM014955   Mileage: 16908km-10506miles
29-Left Light -- Status: Malfunction 0010
32-Differential Locks -- Status: Cannot be reached 0100
39-Right Light -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 0100
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: 2.0l R4 TFSI  H13 1312
   Revision: --H13---
   Coding: 091900122424002F1000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C341C95B779396BDF-8068
31373 - Actuator for Engine Temperature Regulation
          U0615 00 [039] - No Communication
                    Mileage: 16908 km
                    Engine RPM: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 16 ∞C
                    Intake air temperature: 18 ∞C
                    Voltage terminal 30: 11.660 V
                    Engine: operating status: ES
                    Engine temp. management actuator: raw value: 0
                    Engine temperature management actuator: stop open: 145
                    Engine temperature management actuator: after-run stop: 3948
                    RVC_SP: 88.75 ∞
                    RVC_AV: 0.00 ∞
                    RVCPWM: -100.000 %
23096 - Intake Air Temp. Sensor (G42)
          P0113 00 [038] - Signal too High
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:25
                    Coolant temperature: 27 ∞C
                    Intake air temperature: -40 ∞C
                    Voltage terminal 30: 12.832 V
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 255 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 0.390625 %
                    FUP_H_SAE: 17140.0 kPa
15373 - Sensor Reference Voltage A
          P0642 00 [038] - Voltage too Low
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:24
                    T_AST_SAE: 0 s
                    FUP_H_SAE: 17150.0 kPa
22055 - No Communications with Power Steering Control Module
          U0131 00 [039] - -
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:24
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 25.0 ∞C
                    Time since engine start: 0.0 s
                    T_ES: 277 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    T_AST_SAE: 0 s
16470 - Throttle Position Sensor (G69)
          P0121 00 [039] - Implausible Signal
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:24
                    T_AST_SAE: 0 s
15338 - Throttle Position Sensor (G69)
          P0122 00 [167] - Signal too Low
                    Mileage: 16908 km
                    Intake air temperature: 19 ∞C
                    Voltage terminal 30: 11.406 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 98 kPa
                    FAC_TPS_1_SAE: 0.000000 %
                    FUP_H_SAE: 29960.0 kPa
Readiness: 1110 1101
   Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
   Component: ESC           H45 0108
   Revision: 00000000    Serial number: 50149000000439
   Coding: 01FA6BA1502109704080020560C86880D60A90024006163610435051D0894B0B0000000012121212B835351919323200
   Shop #: WSC 00066 790 00154
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 0444A4758F0981ABE7-8050
9 Faults Found:
0039 - Front Left Wheel Speed Sensor
          C101A 4A [008] - Incorrect component(s) installed
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
0166 - Steering angle sensor
          B1168 31 [137] - No Signal
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:34
8238 - Databus
          U1121 00 [137] - Missing Message
          [FCAN: LH_EPS_01 message is not received]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:34
8242 - Databus
          [FCAN: LH_EPS_03 message is not received]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:34
8274 - Databus
          [FCAN: MO_Fahrpedalgradient signal is invalid]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:16
8286 - Databus
          [FCAN: MO_Timeout_ESP signal is invalid]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:16
8330 - Databus
          [FCAN: MO_QBit_Fahrpedalrohwert signal is invalid]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:16
8331 - Databus
          [FCAN: Quersperre_03 message is not received]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:34
16418 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:43
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0502639019
   Coding: 132C0C0623
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43C66769CA8746939E-8016
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 176
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: OFF
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: OFF
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Park selector lever position: Not engaged and not locked
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 3.088 V
                    Vehicle speed: Initialization
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12717828 - Databus
          [Message SAD_01 missing]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:19
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    ZAT_pressed: OFF
                    Park selector lever position: Timeout
                    Control Module Voltage: 12.882 V
                    Vehicle speed: 0.0 km/h
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12786207 - Databus
          [Message ESP_21 invalid Qbit received]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:15
                    ZAT_pressed: OFF
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 11.493 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110000000000000010004
   Shop #: WSC 00066 790 00392
   VCID: 4CD44C55E7D989EB6F-8018
          B10CD 00 [008] - -
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:10:19
                    Voltage terminal 30: 11.3 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: J53F0610210524
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7CB4DC95F7F9F96B9F-8028
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    181127  043 0551
   Serial number: 97022066181208021022
8458 - Bulb for Right DRL
          B121E 15 [009] - Open or Short to Plus
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:43
8202 - Bulb for Left DRL
          B121D 15 [009] - Open or Short to Plus
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:43
206085 - Remote Control
          B1311 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:40
525056 - Production Mode Active
          U1103 00 [009] - -
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:40
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 2D00008101FFC728949C810500401600000000000000000004
   VCID: 44C46475CF8941ABA7-8010
8 Faults Found:
0837 - Databus
          [FAULT_ESP_QBIT_V_SIGNAL_INIT_OR_ERROR_VALUE]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:16
                    Control Module temperature: 25 ∞C
                    Voltage terminal 15: 11.5 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
                    Status_ACC_System: ACC_Init
0863 - Databus
          [FAULT_ESP_QBIT_WEGIMPULS]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:17
                    Voltage terminal 15: 11.6 V
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:47
                    Control Module temperature: 49 ∞C
                    Voltage terminal 15: 12.8 V
0815 - Databus
          [FAULT_ESP_WEGIMPULS_HL_ERROR]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:16
2058 - Databus
          [FAULT_GP_INVALID]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:47
2177 - Databus
          [FAULT_SMLS_CONTROL_UNIT_OBSOLETE_DATA]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:47
1031 - Databus
          [FAULT_TIMEOUT_LWI_01]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:47
2126 - Databus
          [FAULT_TSK_ROAD_SLOPE_FAIL]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:18
   Serial number: 003GCR0AYFYM
   VCID: 47DE7379FEBF6AB342-8012
   Serial number: IBH00000000000AW1YF9
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 312 18
   Serial number: 357000000008474D663N
   Subsystem 3 - Part No SW: -----------    HW: 480 000 712 18
   Serial number: 358000000002EB98763X
   Subsystem 4 - Part No SW: -----------    HW: 480 402 209 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001B72D82C85B2FK
   Subsystem 5 - Part No SW: -----------    HW: 480 402 209 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001B92E18365139/
   Subsystem 6 - Part No SW: -----------    HW: 480 401 401 19
   Serial number: 3550001322B805A4223N
   Subsystem 7 - Part No SW: -----------    HW: 480 401 401 19
   Component: FrontSensor_P  004 6149
   Serial number: 35600011A2B805A182D0
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:33
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 0BAD0912A988CF0502886A095000000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2F2E3BD9760FD2F36A-807A
16776978 - Databus
          [LH_EPS_01 keine Kommunikation]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:53
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [008] - -
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:14
9603840 - Incorrect Key Programming for Remote Control
          B128B 00 [009] - -
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 17:21:11
   Serial number: 26011900840266
   Coding: 0101000830085900FB00002B080F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E90E6DDB1859BFB21-803A
   Generator:
   Component: 0-00-03-07-1f
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002804980068476
   Coding: 28FFFF
131602 - Power Steering Control Module
          U101D 00 [009] - No Communication
          [Timeout Knoten 0x12 / 44 - Steuerger‰t f¸r Lenkhilfe]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:57
                    Terminal 30 power supply: 12.8 V
                    Terminal 15: On
131614 - Differential Lock Control Module
          U1040 00 [009] - No communication
          [Timeout Knoten 0x1E / 32 - Steuerger‰t f¸r Quersperren]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:57
                    Terminal 15: On
66050 - Data Bus for Suspension
          U10AC 00 [008] - No Communications
          [Globaler Timeout CAN-Fahrwerk]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:18:07
                    Terminal 30 power supply: 13.1 V
                    Terminal 15: OFF
65794 - Data Bus for Suspension
          U10AE 00 [009] - 1-Wire Mode
          [Eindrahtfehler CAN-Fahrwerk]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:57
                    Terminal 15: On
66567 - Local Databus
          U1030 00 [009] - Electrical Malfunction
          [LIN#1 (LIN-Energie) elektrischer Fehler]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:14:59
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          U1011 00 [009] - Voltage too Low
          [Supply voltage - lower limit exceeded]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 01:31:41
0036 - Terminal 15
          U1405 00 [009] - Implausible signal
          [Clamp 15 implausible signal]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 01:30:14
0327 - Bulb for DRL and Parking Light
          C123A 15 [009] - Open or Short to Plus
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 01:30:16
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000398113015
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A3DA1603BC4037C-8064
12666370 - Databus
          [Timeout Message ESP_10]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:06
                    Result lock conditions: invalid
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Lock sensor: Not operated
                    Unlock sensor: operated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: OFF
                    Clamp 15: OFF
                    Clamp 15 Status: valid
                    Remote Start: not active
                    Driver door: For
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c timeout
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    Signature IMS OK: No
                    IMS responded: No
                    Positive authentification in current KL15 cycle: No
                    Lifestate: Immobilizer download obtained
                    Learn mode: Adapted
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 655.35 km/h
                    UBat internal: 11.1 V
                    UMotorBridge: 6.1 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition met
                    Lock condition clamp 15: Condition met
                    Lock condition E2E clamp status: Condition met
                    Lock condition timeout clamp status: Condition met
                    Lock condition vehicle speed: Condition not met
                    Lock condition E2E vehicle speed: Condition not met
                    Lock condition timeout vehicle speed: Condition not met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition met
                    Lock condition selector lever position parking: Condition met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition not met
                    Lock condition E2E distance pulse: Condition not met
                    Lock condition difference distance pulse: Condition not met
12666379 - Databus
          [Timeout Message ESP_21]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:05
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: OFF
                    Clamp 15: OFF
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UBat internal: 11.2 V
                    UMotorBridge: 6.1 V
13637378 - Databus
          [Errorvalue ESP_Wegimpulse]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:16
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    I2C state esp 10: i2c cnd false
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: Yes
                    Signature IMS OK: Yes
                    IMS responded: Yes
                    Learn mode: Adapted
                    Vehicle speed: 0.00 km/h
                    UBat internal: 11.0 V
                    UMotorBridge: 6.0 V
                    Lock condition clamp S: Condition not met
                    Lock condition clamp 15: Condition not met
                    Lock condition E2E clamp status: Condition not met
                    Lock condition timeout distance pulse: Condition met
                    Lock condition E2E distance pulse: Condition met
Address 32: Differential Locks
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
0001 - Internal Control Module Memory Check Sum Error
          B2000 00 [009] - -
          [ECU defect (ADC)]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 01:31:41
0036 - Terminal 15
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 01:30:14
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 01:30:16
   Serial number: 0505682336
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D321191AC633063E8-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0504523035
   Coding: 010111
119301 - Databus
          [SMLS ECU Gateway_72::SMLS_01_alt no signal/no communication]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:05
337280 - Databus
          [EPS ECU LWI_01 - no signal/no communication]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:05
337760 - Databus
          [ESP_10::ESP_QBit_Wegimpuls_VL - Ersatz_Init_oder_Fehlerwert]
                    Reset counter: 176
                    Mileage: 16908 km
                    Date: 2022.06.22
                    Time: 00:00:15
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42035900601323
   Coding: 003E13200000040000000000
   Shop #: WSC 01383 790 50316
   VCID: 4FEE5B5916CFB2F30A-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001688023
   Coding: 011000
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:14
Address 44: Steering Assist
   Component: FCM MQB Low   002 0345
   Serial number: 03021900841199
   Coding: 000000050900210A01110F00030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 352209B19453E82320-8060
13705478 - Databus
          [RLS_01 data bus missing message]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:12
13705483 - Databus
          [SMLS_01 data bus missing message]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:12
13705474 - Databus
          [LWI_01 data bus missing message]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:12
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038902703717
   VCID: 4ED0465D11C5BBFB01-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001665325
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     724 0890
   Coding: 02731000BE00000041220001001808009F0503D40120050002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2E1026DD7105DBFB61-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  252 8130
   Serial number: VWZ6ZMW0415401
   Component: OCULowMQBUS   009 0570
   ROD: EV_OCULowMQB.rod
0038 - Databus
          [CAN TO Sliding sunroof ECU]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:16
12718848 - Databus
          [CAN TO Steering angle module]
                    Reset counter: 136
                    Mileage: 16908 km
                    Date: 2022.06.20
                    Time: 05:15:16
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 181119201080
   VCID: 322832AD653DFF1B05-8066
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393A0581B84B0C43C4-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----(Elapsed Time: 01:29, VBatt start/end: 11.5V/11.4V. VIgn 11.5V)-----
I don't suppose you have a scan from this car with the data from the original ECU...?
Dkoz
Missouri, USA
C?ID=401945
No , The original ECU is completely dead . Im sure that lighting bolt did a number of things on it.
Dkoz
Missouri, USA
C?ID=401945
The story with this car is it was struck by lighting, the ECM and body control were the two items that wouldn't appear on a full system check to see what modules were present. After the lighting , ignition would turn on along with radio, cluster, headlights, but when attempting to start the car you would get no response.
JMR
Romania
C?ID=432218
This here error bothers me...it is possible that one of your many sensors/actuators has been also fried somehow and keeps your car ecu in some sort of electrical malfunction. I would suggest you use my method to figure out which sensor/actuator in short circuited.
