TT RS 8J A/C blower not working. Code 01273
GBXRS
Australia
C?ID=240134 (NRRT)
I'm new to the forum & VCDS so please forgive any dumb questions.
I did try searching but I couldn't find anything relevant to my problem.
2010 TT RS 8J. It's an Australia delivered car.
My A/c stopped working. The blower fan does not come on.
In Ross-tech VCDS it shows code 01273.
I checked all the fuses in the engine bay, in the cabin and in the rear trunk area. All fuses are good.
I haven't checked any relays (don't know what to check).
I have checked at the blower motor and there is no short to earth and there is no power at the plug on the harness.
At the control panel the LED's on each control knob are on but the blower motor does not run.
What should I check next?
Is there a relay that I should check?
I did an Auto-scan. Here are the results:
Windows Based VAG/VAS Emulator
VCDS Version: Release 14.10.2(x64) Data version: 20150311
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,29,June,2015,18:24:21:35289
VIN: TRUZZZ8J0B1900043 License Plate:
Mileage: 24470km-15204mi Repair Order:
Chassis Type: 8J (8P0)
Scan: 01 03 08 09 10 14 15 16 17 19 20 22 25 2E 37 42 44 46 47 4C
52 55 56 61 77
VIN: TRUZZZ8J0B1900043 Mileage: 24470km-15204miles
Self-Diagnosis Log
Page 2
Address 01: Engine (CEP) Labels: 07K-907-404-CEP.clb
Part No SW: 8J0 907 404 F HW: 8J0 907 404
Component: 2.5l R5/4V TFSI 0010
Revision: F4H05--- Serial number: AUX7Z0J4FNH067
Coding: 0113000C180F0160
Shop #: WSC 01236 785 00200
VCID: 306F2ED8A3AA8AA1DEF-8065
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Mileage: 23992 km
Date: 2015.06.15
Time: 09:39:26
RPM: 741 /min
Load: 14.9 %
Temperature: 98.0°C
Temperature: 50.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0010 0000
Self-Diagnosis Log
Page 3
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 HW: 8J0 614 517 C
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0618391
VCID: 69D983BC40F03B69D91-803C
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 BA HW: 8J0 820 043 BA
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001152826
Coding: 1573957
VCID: 66C3888051EE1411F43-8033
01273 - Fresh Air Blower (V2)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 138
Mileage: 24476 km
Date: 2015.06.26
Time: 13:35:56
Temperature: 26.0°C
(no units): 55.0
(no units): 224.0
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 H HW: 8P0 907 063 H
Component: BCM PQ35 H 106 0615
Revision: 00106 AD
Coding: 4E000B2FA0051A202070C0E82180084C507658AA3120D928DC080E440045
Shop #: WSC 01236 758 00200
VCID: 397913FCB0D04BE9691-806C
Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00FD10
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02492C
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93641013419135
Coding: 00000B
VCID: 428B7410DD06083138B-8017
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8J0 910 376 E HW: 8J0 907 376 E
Component: J250 Raddaempfung 0110
Revision: --H22--- Serial number: 190DPH 0110378
Coding: 0000072
VCID: 31692BDCA8A083A9D11-8064
Self-Diagnosis Log
Page 5
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -r Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K004FE2L
Coding: 0011634
VCID: 79F9D3FC30508BE9291-802C
Subsystem 1 - Serial number: 6332DRB40B6E0CB1
Subsystem 2 - Serial number: 6342DRB40B6E0BA3$
Subsystem 3 - Serial number: 63747RB4058B1309K
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004041
VCID: 46836800312E3411143-8013
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 930 S HW: 8J0 920 930 S
Component: KOMBIINSTR. VDO H01 0580
Revision: D0H01002 Serial number: 2244J002000023
Coding: 0117728
Shop #: WSC 20460 822 999999
VCID: 3C770AE87FE27EC1727-8069
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H33 0302
Revision: H33 Serial number: 210510F2000185
Coding: E9BB1F0650065204004101
Self-Diagnosis Log
Page 6
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8J0 857 511 G HW: 8J0 857 511 G
Component: FLA H03 0004
Revision: AA002001
Coding: 02028D64747464545425363E
VCID: 346722C897B2B681BA7-8061
Address 22: AWD Labels: Redir Fail!
Part No SW: 2K0 907 554 HW: 2K0 907 554
Component: Haldex 4Motion 5003
Coding: 0000005
VCID: 6BD5F9B44A0C2979ABD-803E
Revision: D0H01002 Serial number: AUX7Z0J4FNH067
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 74E7E2C8D732F6817A7-8021
Self-Diagnosis Log
Page 7
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
Component: RNS-E PU EU H04 0200
Revision: 0000010S Serial number: AUZBZ7KD400450
Coding: 0610725
Shop #: WSC 20460 822 173925
VCID: 2B5539B48A8CE979EBD-807E
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J8 959 801 J HW: 8J8 959 801 J
Component: Tuer-SG H04 0101
Coding: 0000605
Shop #: WSC 20460 822 13273
VCID: 44877208071206010A7-8011
Part No: 8J0 909 144 J
Component: EPS_ZFLS Kl. 239 3001
Revision: 00H17000
VCID: 377D15C446C45D999F5-8062
Address 47: Sound System (J525) Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 F HW: 8J0 035 223 F
Component: Audi TT Amp5K H05 0170
Revision: -------- Serial number: BP208309190387
Coding: 070101060002
ASAM Dataset: EV_AudioAmpli5ChannBNO1 003011
ROD: EV_AudioAmpli5ChannBNO1.rod
VCID: 275DC5845E64CD190F5-8072
Self-Diagnosis Log
Page 8
Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
Part No SW: 8J0 907 274 C HW: 4F0 907 274
Component: J793 RKA+ H02 0190
Revision: 00000813 Serial number: 00008130113299
Coding: 0604100
VCID: 326B24D0ADA6B8B1A8B-8067
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8J8 959 802 H HW: 8J8 959 802 H
Coding: 0000605
VCID: 43857114021C013933D-8016
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0060
Coding: 0000025
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0610725
Self-Diagnosis Log
Page 9
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H33 0302
Coding: 0302015A
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005205469
Coding: 0011422
VCID: 74E7E2C81732F6817A7-8021
End-------------------------(Elapsed Time: 06:55)--------------------------
GBXRS
Australia
C?ID=240134 (NRRT)
Thanks for the fast response Uwe.
Problem fixed. Stupid mistake.
I found I had all the wiring & fuse info so I worked my way through that. I started at the fuse box in the engine bay and read the fuse locations. Oops I had pulled fuse 1-12 Fresh Air Blower control unit out to look at it and put it back into location 1-11 (which should be vacant)
Blower now works fine.
I note your suggesting on posting autoscans using copy rather than print. I'll do that in future.
Thanks, Greg
