ABS Control module lost coding - 2012 VW GOLF 6 GTI
ChrisdraggerS3
Jamaica
C?ID=426264
Greetings everyone
I need your help. I I just changed a faulty ABS unit. However the ABS module has lost its code. I recovered the code from the faulty unit and input it into the new system. However, it was rejected.
Can anyone assist and provide me with the correct code for this ABS Module?
Westbury, UK
Please post an Auto-Scan which is full and unedited, ABS coding is vehicle and configuration dependent so we need the full details.
Are you 100% sure that the replacement ABS module is suitable for the vehicle?
etz2k
C?ID=69430
Please post also infos and coding of the old ABS module, because that might help alot if your new unit is a slightly different ABS and the coding must be adapted.
ChrisdraggerS3
Jamaica
C?ID=426264
Please see scan below with new ABS installed
Saturday,27,August,2022,19:03:13:29807
VIN: WVWZZZ1KZCW079605   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: WVWZZZ1KZCW079605   Mileage: 103100km-64063miles
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115 A    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH18---    Serial number:
   Coding: 040300101C070060
   Shop #: WSC 00642 210 45725
   VCID: 2809F301FEF45DBBA7F-807C
   VINID: 9E69EAAAA05BA939C01C9180142512580A
Readiness: 1110 0101
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 3514
   Revision: 06454104    Serial number: 00002003130284
   Shop #: WSC 04940 001 00001
   VCID: 270BF03DF3EA52C3AE5-8072
   Revision: 00H31001
   VCID: 76B5ED7968C07B4BE53-8022
                    Reset counter: 88
                    Date: 2017.01.17
                    Time: 00:22:60
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 44032
                    Fault Status: 01100101
                    Reset counter: 88
                    Mileage: 103101 km
                    Date: 2017.01.17
                    Time: 00:22:59
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 279
                    Count: 44032
                    Count: 512
                    Reset counter: 88
                    Mileage: 103101 km
                    Date: 2017.01.17
                    Time: 00:22:59
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 295
                    Count: 44032
                    Count: 512
                    Reset counter: 88
                    Mileage: 103101 km
                    Date: 2017.01.17
                    Time: 00:22:59
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 270
                    Count: 44032
                    Count: 512
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0000014002
   Shop #: WSC 12345 123 61029
   VCID: 00598BA13A8445FBCFF-8054
Address 09: Cent. Elect.
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA8H4BF
   Coding: 00003958
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 313F1E65C1AE1C73701-8064
   Serial number: 3572MSME7F120142ZZZP
   Serial number: 3582MSME04140442ZZZD
   Serial number: 3512QSME603B0A06ZZZR
   Serial number: 3522QSME58111D40ZZZP
   Part No SW: 5K0 953 507 AF    HW: 5K0 953 549 A
   Revision: --------    Serial number:  90440KGR0008T
   Coding: 1892040000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 74B1D7717E3C695BDB7-8020
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H08 0010
   Serial number: 0069294
   Coding: 830000
   Part No SW: 5K6 920 972     HW: 5K6 920 972
   Coding: 570C00
   VCID: 73B3D46D7B326E63C2D-8026
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 240711F2001465
   Coding: 350001
   VCID: 35372A75354630532C9-8060
01304 - Radio
                    Reset counter: 129
                    Mileage: 103101 km
                    Date: 2017.01.17
                    Time: 00:20:53
   VCID: 6A8DC9092CF8AFAB71B-803E
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2118
   Coding: 0000628
   Shop #: WSC 11111 111 45799
   VCID: 313F1E65CD2E1C73701-8064
00120 - Outside Warning Light/Door exit Light Driver Side
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 34311771323C295B1B7-8060
Address 46: Central Conv.
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0000628
   VCID: 323D1169C828276B09B-8066
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1443100
   Shop #: WSC 12345 111 45725
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
Address 56: Radio
End----------(Elapsed Time: 01:15, VBatt start/end: 12.4V/12.4V)-----------
ChrisdraggerS3
Jamaica
C?ID=426264
Also Please see scan from March 2021 when the ABS module was functioning. This is the code (highlighted in red below) which was copied and pasted into the new module. However this was rejected
Saturday,13,March,2021,13:23:58:29807
VIN: WVWZZZ1KZCW079605   Mileage: 81720km-50778miles
   VCID: 2809F301FEF45DBBE73-807C
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal
                    Mileage: 81725 km
                    Date: 2015.08.04
                    Time: 17:20:56
                    RPM: 273 /min
                    Load: 57.6 %
                    Temperature: 80.0°C
                    Temperature: 60.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.303 V
   VCID: 270BF03DF3EA52C3EE9-8072
   Revision: 00H31001
  Coding: 163B600D09298003681106E4901E0181310800
   VCID: 7BA3FC4D53E22623DA1-802E
   Revision: 00001003
   Coding: 0000014002
   VCID: 00598BA13A8445FB8F3-8054
   Coding: 00003958
   VCID: 313F1E65C1AE1C7330D-8064
   Coding: 1892040000
   VCID: 74B1D7717E3C695B9BB-8020
   Coding: 830000
   Coding: 470C00
   VCID: 73B3D46D7B326E63821-8026
   Coding: 350001
   VCID: 35372A75354630536C5-8060
01304 - Radio
                    Fault Frequency: 8
                    Reset counter: 151
                    Mileage: 81721 km
                    Date: 2015.08.04
                    Time: 12:58:58
   VCID: 6A8DC9092CF8AFAB317-803E
   Coding: 0000628
   VCID: 313F1E65CD2E1C7330D-8064
   Revision: 00H20000
   VCID: 34311771323C295B5BB-8060
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.7 V
                        PD
                    Temperature: 37.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Coding: 0000628
   VCID: 323D1169C828276B497-8066
   Coding: 1443100
   Shop #: WSC 06370 637 03013
   Coding: 00000022
   Coding: 00000022
Address 56: Radio
End----------(Elapsed Time: 00:51, VBatt start/end: 12.7V/12.7V)-----------
etz2k
C?ID=69430
Your "new" ABS with SW:0108 (-BE) is from a older car (MJ'11) and this doesn't support the 2-stage ESC-OFF function (which is only availabled with SW:0121 and higher [MJ'12+]).
Use this coding 163B600D09290003681106E4901E0081310800 , if you want only the ASR-OFF function with the ESC button
or this 163B600D09290003681106E4901E0081390800 , if you want only the ESC-OFF function.
ChrisdraggerS3
Jamaica
C?ID=426264
Hello friends I've try the both codes and it's still rejected
  • Informative
Reactions: JMR
JMR
Romania
C?ID=432218
with vacuum sensor as suggested by vis4vag though i'd take @etz2k codings anyday
113B200D09290003881104E4901E0041310000
JMR
Romania
C?ID=432218
are you copy/pasting or input manually ? i'd sugest you copy/paste for accuracy !!!
etz2k
C?ID=69430
113B200D09290003881104E4901E0041310000uk
I will take a look what's wrong later today. If there is a org. coding the new should be very close to it and with vis4vag its to different.
The use of a older ABS than the org. is often not a good idea.
ChrisdraggerS3
Jamaica
C?ID=426264
Thank u I appreciate it
etz2k
C?ID=69430
Sorry, i can't find any fault in the coding.
Here is a example of an german GTI'11 and only some vin-bytes (byte 5, 7, 9, 11, 13), the brake booster (byte 0 & 8, because LHD=10" and RHD=7"/8" brake booster) and LHD/RHD selection (byte 15/ bit6&7) is different . I don't believe the coding is the problem.
Adresse 03: Bremsenelektronik (J104) Labeldatei: PCI\1K0-907-379-60EC1F.clb
Teilenummer SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Bauteil: ESP MK60EC1 H31 0108
Revision: 00H31001
Codierung: 143B600D09220003280C06EB901E0041310800
I had the case on a A3'11 with the -BE, that it need the SA:40304 to unlock the adaption channels, but i had no problem to insert a coding.
If you insert the coding and click OK, a message "... rejected ..." appears?
Can you flash the -BE firmware to a newer version (-BJ or -BL)?
cristo_844
Portugal
C?ID=412536
the coding is rejected or reverts back to 00 after cycling the ignition?
