- Feb 25, 2014
- 2,879
- 4,656
- Garrettsville, OH
- C?ID=25607
After a push-button start, you don't need a key present in a Phaeton to keep driving. It won't tell you a thing until next time you try to start it. I knew this, but never really thought about it much until today. Today I was distracted while loading some things in the car, and drove to a gas station to fill up... turns out I left my key at home. And of course nobody's answering their phones at home, so I had a four mile walk-of-shame to retrieve it. That sucked.
My car appears to be Immo 4a/KESSY. Jack@EPE retrieved my PIN for me some time ago; I can confirm it works. I've verified successful Security Access to 05-Acc/Start Auth. I've done business with Mark at sidewinderkey.com before, and intended to order a new key from him, but his page makes it sound like Phaeton and Touareg keys are extremely magic in some way and he apparently won't even attempt to cut one.
Questions:
1) Is the dealer truly the only source for these keys? I'll go there if needed, just trying to figure out why they're so unique.
2) Should the regular Immo 4a procedure in RT's Wiki work for me?
3) Does anyone know a reason why the plastic "emergency" key 3D0 837 216 wouldn't work? PL24 grays it out for my car. That would be perfect to hide somewhere on the car.
4) If I get a key with a remote, does matching it to KESSY also handle the remote functions? Used to this being in 46-Central Conv. on my Passat, but I don't see a way to do that here.
Jason
Obligatory Auto-Scan:
Questions:
Jason
Sunday,28,June,2015,19:51:17:21122
VCDS Version: 15.6.0.0 (x64)
Data version: 20150604
VIN: WVWAK03D868005728 License Plate: 2006PHAETON
Mileage: 140410km-87246mi Repair Order: IMMO-Q
Chassis Type: 3D (JY2 - My 2006 VW Phaeton)
Scan: 01 02 03 05 06 07 08 09 11 15 16 17 19 28 29 34 36 37 38 39
46 47 65 68 71 76
VIN: WVWAK03D868005728 Mileage: 140410km-87246miles
Address 01: Engine Labels: 07C-906-018-BAP1.lbl
Part No SW: 07C 906 018 AJ HW: 000 000 000 00
Component: D1-6.0L-AT-LEV2 G ª8188
Revision: --H01--- Serial number: VWZ3Z0F7470400
Coding: 0000173
Shop #: WSC 03738 444 38140
VCID: 6D9208DC75C37C5728-5184
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold - Intermittent - MIL ON
Fault Status: 10100010
Fault Frequency: 16
Mileage: 136159 km
RPM: 2140 /min
Load: 35.7 %
Speed: 115.0 km/h
Temperature: 96.0°C
Temperature: 36.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.208 V
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Mileage: 136385 km
RPM: 1693 /min
Load: 18.8 %
Temperature: 89.0°C
Temperature: 43.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.938 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 140411 km
Temperature: 67.0°C
Temperature: 68.0°C
Voltage: 11.811 V
Address 02: Auto Trans Labels: 3D0-927-156.lbl
Part No: 3D0 927 156 AB
Component: AG5 01L 6.0lW12 USA 1010
Coding: 0000002
VCID: 689C79C85A21597F5B-5184
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H33 0047
Coding: 0008397
Shop #: WSC 01065 000 00000
VCID: 6B9606C44BD7726736-5184
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 C HW: 5WK 484 97
Component: G1 Kessy 6700
Revision: 67006015 Serial number: VWZ3Z0F7470400
Coding: 0213228
VCID: 271E3AF497BF960792-5184
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 1940
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1720
Coding: 0000003
VCID: 77BE2AB4079FC687C2-5184
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3D0 035 008 QX
Component: ZAB COCKPIT 9923
Coding: 0500305
Shop #: WSC 03207 444 84420
VCID: 004C41685251813FF3-5184
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 J
Component: Climatronic D1 2031
Coding: 0000002
VCID: 250230FCEDB38417A0-5184
00716 - Air recirculation Flap Positioning Motor (V113)
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000003
VCID: 2F2ED2D4BF4FCE475A-5184
Address 11: Engine II Labels: 07C-906-018-BAP2.lbl
Coding: 0000173
012953 - Catalyst System; Bank 4
P3299 - 002 - Efficiency Below Threshold - MIL ON
Fault Status: 11100010
Fault Frequency: 17
Mileage: 136129 km
RPM: 2183 /min
Load: 42.7 %
Speed: 117.0 km/h
Temperature: 100.0°C
Temperature: 38.0°C
Voltage: 13.081 V
012952 - Catalyst System; Bank 3
P3298 - 002 - Efficiency Below Threshold - MIL ON
Fault Frequency: 15
Mileage: 136325 km
RPM: 2112 /min
Load: 37.6 %
Speed: 112.0 km/h
Temperature: 104.0°C
Temperature: 39.0°C
Voltage: 12.700 V
Mileage: 136385 km
RPM: 1671 /min
Load: 17.6 %
Temperature: 89.0°C
Temperature: 45.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.684 V
000013 - Camshaft Positioner (Bank 2 Exhaust)
P000D - 008 - Slow Response - Intermittent
Mileage: 137072 km
RPM: 2075 /min
Load: 14.5 %
Speed: 112.0 km/h
Temperature: 95.0°C
Temperature: 26.0°C
Voltage: 13.208 V
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 04 Airbag 8.4E++H01 0554
Revision: BB38727 Serial number: 0006635<
Coding: 0012340
VCID: 281C39C89AA1997F9B-5184
Subsystem 1 - Part No: 3D0 959 339
Component: BF-Gewichtsens. 006 0005
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 E
Component: Lenksäulenmodul 3401
Coding: 0000232
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No: 3D0 920 982 B
Component: KOMBIINSTRUMENT RB8 0521
Coding: 0005221
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70AC11A862F191BF03-5184
Address 28: HVAC, Rear Labels: 3D0-919-158.lbl
Part No: 3D0 919 158 F
Component: Klima-Bedienteil D1 0117
VCID: 2E10CFD0B845C74F51-5184
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000001
VCID: 668077F050354F0F69-5160
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005531
Shop #: WSC 53212 053 999999
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1720
Coding: 0000004
VCID: 6FAE12D47FCF8E471A-5184
Address 37: Navigation Labels: 3D0-919-887.lbl
Part No: 3D0 919 887 F
Component: NAVIGATION 9968
Coding: 0400000
VCID: 373EEAB4471F068702-5184
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 C
Component: Dachmodul 0708
Coding: 0000015
VCID: 23062EE4E3877A27CE-5184
00220 - Connection to Sunroof
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000001
VCID: 679E7AF4573F560752-5184
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: X3 HSG 0102
Coding: 0000040
Shop #: WSC 03325 444 13946
VCID: 3326DEA45367EAA73E-4B3C
Subsystem 1 - Part No: 3D1 959 701 L
Component: Tuersteuergeraet FS 6001
Subsystem 2 - Part No: 3D1 959 702 L
Component: Tuersteuergeraet BF 6001
Subsystem 3 - Part No: 3D0 959 703 K
Component: Tuersteuergeraet HL 6001
Subsystem 4 - Part No: 3D0 959 704 K
Component: Tuersteuergeraet HR 6001
Subsystem 5 - Part No: 3D0 909 610 C
Component: 3L HDSG 2330
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3D0 035 466 A
Component: 12K-AUDIOVERST 0118
VCID: 200C21E8F291613FD3-5184
Address 65: Tire Pressure Labels: None
Part No: 3D0 907 273 G
Component: Reifendruckueberw. 0026
Coding: 0411224
VCID: 2A18C3C084ADAB6F8D-5184
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V1.clb
Part No: 3D1 955 119 A
Component: Front Wiper 2005
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 24042DF8E6897D1FB7-5184
Address 76: Park Assist Labels: None
Part No: 3D0 919 283 D
Component: 03 Einparkhilfe 0907
VCID: 2B16C6C48B57B26776-5184
End-------------------------(Elapsed Time: 04:23)--------------------------
