Problem changing rear brakes
MACH999
Taunton, UK
C?ID=513798
I have followed the instructions for putting the EPB into service mode to change the rear disk and pads, which should have been straightforward - but not so in my case!
First I ran a full scan of my car and cleared several fault codes relating to apparent intermittent issues with electric windows and door locking - neither of which have been causing me any concern. I then cycled the EPB on and off a couple of times to check that it WAS releasing manually as required, then I proceeded with the instruction to "Start Lining Change Mode" - but when I clicked "Go" I got the message "Aborted Due To Malfunction" which was quickly replaced by "Not Running".
Consequently I am unable to replace the rear disks and pads as planned.
Prior to me starting work, the brakes were working perfectly, but as the rear disks are badly pitted, I thought it would be best to repalce them prior to the MOT in 3 weeks, as they had been an advisory point on the car's MOT when we bought it last year.
Before starting work, I placed blocks in front of the front wheels and engaf=ged reverse gear, to prevent movement when the EPB disengaged. Could this somehow be to blame?
I have tried going through the Start and end lining change procedures but each is followed by the error messages above. I am now stuck. Please can anyone advise?
Friday,19,August,2022,11:13:38:06421
VIN: WVGZZZ5NZHW321351   License Plate: DT16 HLU
Mileage: 65748km-40853mi   Repair Order: unable to proceed
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 52 55 5F A5 BB BC
          CA D6 D7
VIN: WVGZZZ5NZHW321351   Mileage: 65748km-40853miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HQ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3022
   Revision: B4H24---    CVN: 2526BD574C6C0C4B
   Coding: 0119001203441D082000
   ASAM Dataset: EV_ECM20TDI01104L906026HQ 004002
   ROD: EV_ECM20TDI01104L906026GQ_004.rod
   VCID: 00598E766A82925BCFF-8054
   VINID: 9E65EAAAA15EA989C30810C504C16E8440
28252 - Coolant Pump 3
          P26FA 00 [032] - Air in System
28991 - No Communications with NOX Sensor 1
          U029D 00 [032] - -
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 61886000001548
   Coding: 0AEE929A34220B6D477A060562C44950492CD0E2604692713460F078C0224200002E64121A03102F35351919323200
   VCID: 76B5E8AE3846ACEBE53-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 K    HW: 5NA 907 044 K
   Component: AC Automat    H35 4003
   Revision: 20K08000    Serial number: 00000B00171677
   Coding: 00120124202110011105100000101022
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   VCID: 47CB556A0F2C65634E5-8012
   Rear A/C control head:
   Subsystem 1 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001619400702
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B0D8A177CEDA3B65-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160603  033 0372
   Serial number: 00000001605310303651
   Component: RLHS  037 0059
   Serial number: S3Y16M06D30H18M50S37
   Coding: 00A8DD
   Serial number: 000000000ZY1615210CG
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035818364
   Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 002005167478000
   Coding: 0071051801
   ASAM Dataset: EV_EPHBO18VW3260000 007015
   ROD: EV_EPHBO18VW3260000_SK37.rod
   VCID: 372B25AA7FCC15E33E5-8062
   Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0155
   Coding: 2A01404158FF8728749C8065104085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001010
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 392F239249D80393C81-806C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR1XTSZQ
   Coding: 98CCC0C00C0000005C5400CF008800000065
   VCID: 1079BE363AE2E2DB5FF-8044
   Left seat belt tensioner:
   Serial number: 5NC857705C0181Q01628
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5NC857706C0182Q01286
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 107 16
   Serial number: 357000000002493C6C1L
   Subsystem 4 - Part No SW: -----------    HW: 480 000 107 16
   Serial number: 358000000004F6D86C1
   Subsystem 5 - Part No SW: -----------    HW: 480 400 607 16
   Serial number: 35100019F213E8D1E55E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 607 16
   Serial number: 3520001AD21816E4C163
   Subsystem 7 - Part No SW: -----------    HW: 480 401 407 16
   Serial number: 3550001C9213E8D43603
   Subsystem 8 - Part No SW: -----------    HW: 480 400 407 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001BD2134BB592FE
   Subsystem 9 - Part No SW: -----------    HW: 480 400 407 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001BD2134BB592AA
   Subsystem 10 - Part No SW: -----------    HW: 480 400 407 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001BD2134BB5C1A4
   Subsystem 11 - Part No SW: -----------    HW: 480 000 807 16
   Serial number: I0M00000000132608C1U
   Subsystem 12 - Part No SW: -----------    HW: 480 000 807 16
   Serial number: I0N000000004FCBC7C1T
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160708401181
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DF4B7221085B53801-8014
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         405 2153
   Coding: 27A401006F84260001886A031401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 30061610800273
   Coding: 030100041F087300FB00025E080F00010001050000000000000000000000
   GVL: 01543C0000000000408C90000000480010000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1FA86066AF6BB937-8028
   Generator:
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 1821608503301031AT1B
   Coding: 2C0000
   Serial number: 0195660704
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH07 0014
   VCID: 45D75F6235207773BC9-8010
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 210616EFK14551
   Coding: 003F0220D001048000001000
   VCID: 43D3417A3B14494392D-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 1107
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 190616EFI29887
   Coding: 003F0020DE01048000001000
   VCID: 42DD447E240E404B99B-8016
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0051
   Coding: 089E00104B200201
   ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0764
   Coding: 02730601FF00000051110101008808001F0100E6012000008F
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313F1BB291A8CBD3701-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL021GN
   Subsystem 2 - Part No SW: 5NA 919 866 CH    HW: -----------
   Component: ECE1 2023  --- 1910
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 05071611P11683
   Coding: 0003070600000401000213448040A10094000E200040
   VCID: 3A2D3C9E4CDE088BC1B-806E
   Serial number: 280616BFP04401
   Coding: 002A00200100048000001000
   Serial number: 280616BFR0266B
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 308040732602
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C82E18060CEB053-8042
   Component: LED1R         H09 0003
End----(Elapsed Time: 01:44, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Why do we need a new thread when you already have one open about this?
Please carry on in your original thread.
