09 GTI DSG - Group 06x Error: Not Available - no drive, flashing PRNDS
Bluestreak
HSV, AL, USA
C?ID=525823
Hi All,
Daughters car, 2009 GTI DSG, 82k miles, dealer maintained, very gently driven car, never been so much as scratched. Car lost all drive with no noises, no warning. It has two gears now, Park, and all else are Neutral.
Went through the Ross-Tech guide which advises resetting the mechatronic. Followed it precisely about a dozen times now in VCDS. When I get to Group 060, I get Error: Not Available. If I clear the codes, shut the car off, restart the car, I get a flashing PRNDS and Error: Not Available, again.
I decided to retry by not starting the car.
I can clear the codes, turn the car back to "on" but *not* running, and when I go to 060 I see activity rolling through 5 0 3 0 to 11 0 3 0 to 13 0 3 0, but no functionality on the ON/OFF/Next button. Then when I start the car, I get a flashing PRNDS and Error: Not Available, again.
I've no problem attempting a mechatronic swap, but I'd like to know I've got the right issue.
Codes are P1707-005 Interference in Mechatronic Unit
and P2711-004 Unexpected/Implausible Gear Disengagement.
Westbury, UK
It would help a lot if you post an Auto-Scan so we can see the fault codes and the details of the hardware and software in this GTI.
Bluestreak
HSV, AL, USA
C?ID=525823
Self-Diagnosis Log
Thursday,11,August,2022,09:40:27:41186
Page 2
VIN: WVWHV71K89W069476 License Plate:
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
 Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
 Component: 2.0l R4/4V TFSI 0030
 Revision: AAH03--- Serial number: VWX7Z0H63NH8PP
 Coding: 0403010A1C070160
 Shop #: WSC 01279 785 00200
 VCID: 698FB0619573EC63781-803C
 VINID: 9E69D898705B2099C01891071850B91309
005668 - MIL Request Signal Active (Check TCM for errors too!)
 P1624 - 000 -
 Mileage: 133183 km
 Time: 09:24:08
 RPM: 1174 /min
 Load: 44.3 %
 Temperature: 33.0°C
 Temperature: 25.0°C
 Absolute Pres.: 990.0 mbar
 Voltage: 13.716 V
Readiness: 0110 0101
Self-Diagnosis Log
Page 3
 Part No SW: 02E 300 051 C HW: 02E 927 770 AJ
 Component: GSG DSG AG6 431 1815
 Revision: 04843012 Serial number: 00000807011040
 VCID: 1373B289E77F86B362D-8046
18115 - Interference in Mechatronic Module
 P1707 - 005 - - Intermittent - MIL ON
 Fault Status: 10100101
 Fault Frequency: 255
 Mileage: 133183 km
19143 - Unexpected / Implausible Mechanical Gear Disengagement
 P2711 - 004 - - Intermittent - MIL ON
 Fault Status: 10100100
 Mileage: 133183 km
------------------------------------------------------------------------------- Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
 Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
 Component: ESP MK60EC1 H45 0107
 Revision: 00H45001
 Coding: 113B600D49280003880F06EB921F0041B100
 Shop #: WSC 03200 002 1048576
 VCID: 00598DC58A090D2BCFF-8054
No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl
 Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
 Component: Climatic PQ35 142 1212
 Revision: 00142032 Serial number: 00000000000000
 VCID: 78A9E525DED945EBF7F-802C
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
 Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
 Revision: 00H54000 Serial number: 00000008636580
 Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
 Shop #: WSC 00000 785 00200
 VCID: 33331209873F66B302D-8066
 Component: Wischer 080708 021 0501
 Coding: 00038805
No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl
 Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
 Component: 6K AIRBAG VW8R 034 8000
 Revision: 05034000 Serial number: 003B6D0BKDKB
 Coding: 0013899
 VCID: 6C81C9759A81F94B037-8038
 Subsystem 1 - Part No: 1K0 959 339 G
 Component: BF-Gewichtsens. 007 0007
 Subsystem 2 - Serial number: 6332MSME38763835E
 Subsystem 3 - Serial number: 6342MSME3E224A5DP
 Subsystem 4 - Serial number: 6352QSME75770A01E
 Subsystem 5 - Serial number: 6362QSME6A273377N
 Subsystem 6 - Serial number: 63727SME173B0F4CD
 Subsystem 7 - Serial number: 63827SME17454047-
Self-Diagnosis Log
Page 5
 Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
 Component: J0527 051 0101
 Coding: 0012122
 Component: E0221 002 0010
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
 Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
 Component: KOMBIINSTRUMENT VDD 2416
 Revision: V0003000 Serial number: VWX7Z0H63NH8PP
 Coding: 0007203
 Shop #: WSC 07111 444 11096
 VCID: 392F2021A5539CE3C81-806C
No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
 Part No SW: 1K0 907 530 Q HW: 1K0 907 951
 Component: J533__Gateway H16 0202
 Revision: H16 Serial number: 2700K087070208
 Coding: ED817F074002120002
 VCID: 35372C11894B78832C9-8060
Self-Diagnosis Log
Page 6
 Component: IMMO VDD 2416
No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
 Part No SW: 5N0 035 342 A HW: 5N0 035 342 A
 Component: SG EXT.PLAYER H13 0062
 Revision: A1001003 Serial number: 7667014509
 VCID: 2517FC5135EB08039C9-8070
No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
 Part No SW: 3C0 035 684 HW: 3C0 035 684
 Component: RNS-MID H17 0210
 Revision: AB001001 Serial number: VWZ6Z7H9207052
 Coding: 040004000400001200
 Shop #: WSC 01316 785 00200
 VCID: 6099AD456A49AD2BAFF-8034
No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: None
 Part No SW: 1K0 959 701 AK HW: 1K0 959 701 AK
 Component: Tuer-SG 006 1203
 Coding: 0001205
 VCID: 77ABE619D3C74A93FE5-8022
00105 - Signal Central Locking SAVE/LOCK Drivers Side
 008 - Implausible Signal - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 7
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
 Part No: 1K1 909 144 M
 Component: EPS_ZFLS Kl.074 H08 1901
 Shop #: WSC 00000 028 00001
No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
 Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
 Component: KSG PQ35 RDK 052 0221
 Revision: 00052000 Serial number: 00000000000000
 Coding: 139006885103281B0904058FB0080F0488DC00
 VCID: 045181D59211110BEB7-8050
No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
 Part No SW: 1K0 959 702 AK HW: 1K0 959 702 AK
 Coding: 0001204
No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl
 Part No: 1T0 907 357
 Component: Dynamische LWR 0003
 Coding: 0000003
 VCID: 74B1D115C2B1218BDB7-8020
Self-Diagnosis Log
Page 8
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
 Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
 Component: Tuer-SG 006 1302
 Coding: 0001168
 Shop #: WSC 01279 785 1012552
 VCID: 382925259E5985EB37F-806C
No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
 Component: RDK 0450
 Coding: 0100101
No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
 Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
 Component: Tuer-SG 006 1305
 Coding: 0001168
End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)----
Bluestreak
HSV, AL, USA
C?ID=525823
Edited because first time I accidentally posted data from previous post:
And here is another, after several clearings, and then a warm up. The voltage at the end is interesting on both of those. What's the expected voltage?
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 22.3.1(x64) Data version: 20220407 DS337.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,17,August,2022,11:10:30:41186
Mileage: 133180km-82754mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 65
 72
VIN: WVWHV71K89W069476 Mileage: 133180km-82754miles
Self-Diagnosis Log
Page 2
 P1624 - 000 - - Intermittent
 Mileage: 133183 km
 Time: 09:24:08
 RPM: 1174 /min
 Load: 44.3 %
 Temperature: 33.0°C
 Temperature: 25.0°C
 Voltage: 13.716 V
Self-Diagnosis Log
Page 3
 P2711 - 005 - - Intermittent
 Fault Status: 00100101
 Mileage: 133183 km
 Revision: 00H45001
Self-Diagnosis Log
Page 4
 Coding: 00038805
 Coding: 0013899
Self-Diagnosis Log
Page 5
 Coding: 0012122
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
 Coding: 0007203
No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Self-Diagnosis Log
Page 6
 Coding: 0001205
No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Self-Diagnosis Log
Page 7
 Coding: 0001204
 Coding: 0000003
No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Self-Diagnosis Log
Page 8
 Coding: 0001168
 Component: RDK 0450
 Coding: 0100101
 Coding: 0001168
End----(Elapsed Time: 01:22, VBatt start/end: 12.2V/12.0V. VIgn 12.0V)-----
EuroX
Northern NJ USA
C?ID=208579
please post adaption values from TCM for clutches.
Bluestreak
HSV, AL, USA
C?ID=525823
Is this what you're referring to?
                Address 02: Auto Trans  (02E 300 051 C)
16:25:37 Group 063
16:25:50 Group 064
16:25:59 Group 065
  0.00 bar
  0.00 bar
  0.00 bar
  0.00 bar
16:26:07 Group 066
     00001
     00001
     00000
     00000
16:26:17 Group 067
  0.270 A
  0.250 A
  N/A
  N/A
16:26:26 Group 068
  0.210 A
  0.210 A
  N/A
  N/A
16:26:35 Group 069
16:26:42 Group 070
  20
  20
  N/A
  N/A
Bluestreak
HSV, AL, USA
C?ID=525823
060, 061, 062 are Error: Not Available
Bluestreak
HSV, AL, USA
C?ID=525823
When I search the VW OEM parts sites, they show dozens of different "mechatron" units possible for her car. One dealer has advised my VIN should be using
02E-325-025-AT-Z32
and also advised that it is on national backorder with no visibility. Is there anyone here that can confirm that PN for my VIN
WVWHV71K89W069476
