VW Polo 1.2 110 Hp CJZD 2014 error Code 1048833 AC problems
Lkmlkm8383
Denmark
Hello
I am getting a error code 1048833 on VCDS the AC starts lacking cold air on highway and hot weather. The car has been to all sorts of specialist and the AC system is good condition and everything is up to date. But since this error code on says that the engine shouts the AC of with any further specification it’s a big headache and I don’t quite know where to go to so I was hoping some here had a similar problem.
Thx in advance !
Lkmlkm8383
Denmark
Fredag,19,August,2022,20:08:16:55653
VCDS version: NEZ 22.3.1 - Kører på Windows 10 x64
www.vcds.dk
adresse 08: Klimaanlæg Forklaringsfil: NEZ\6C0-907-044.clb
Styreenhed reservedelsnr. : 6C0 907 044 A HW: 6C0 907 044 A
Komponent og/eller version : Climatronic H02 0102
Software kodning : 200000001001100001
Forhandlernummer : WSC 00788 648 00255
ASAM datasæt : EV_ACClimaValeoPQ26 003001 (VW26)
ROD: EV_ACClimaValeoPQ26.rod
VCID: 220822833516949FFB-8076
1 fejl fundet:
1048833 - Funktionsindskrænkning pga. kompressorfrakobling via motor
B10F0 00 [012] - -
Periodisk - Bekræftet - Testet siden sletning af hukommelse
Fryserammedata:
Fejl status : 00000001
Fejlprioritet: 6
Fejlhyppighed: 19
Nulstiltæller: 234
Kørestrækning: 127993 km
Dato: 2022.08.12
Tid: 10:24:40
Kl. 30 spænding: 12.9 V
Betingelse for kompressorfrakobling: Afbrydelse fra motorstyreenhed via CAN (T > 15 sek.)
Lkmlkm8383
Denmark
Fredag,19,August,2022,20:12:11:55653
VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
VCDS version: NEZ 22.3.1.6  HEX-NET CB: 0.4615.4
Dataversion: 20220501 DS338.0
www.vcds.dk
Stelnummer: WVWZZZ6RZFY030092   Indreg.nr.:
Modeltype: 6R-VW26 (6C0)
Søgning: 01 03 08 09 10 13 14 15 17 19 44 5F
Stelnummer: WVWZZZ6RZFY030092   Kørestrækning: 128362km
01-Motor -- Status: Fejlfunktion 0010
03-ABS bremser -- Status: Ok 0000
08-Klimaanlæg -- Status: Fejlfunktion 0010
09-Centralelektr. BCM1 -- Status: Ok 0000
10-Park.assist. -- Status: Ok 0000
13-Afstandsreg. 1 -- Status: Ok 0000
14-Affjedringselektr. -- Status: Ok 0000
15-Airbags -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
19-CAN Gateway -- Status: Ok 0000
44-Servostyring -- Status: Ok 0000
5F-Informationselek. -- Status: Fejlfunktion 0010
Styreenhed  01: Motor (J623-CJZD)     Forklaringsfil:. NEZ\04E-907-309-V1.clb
   Styreenhedsnr: SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Komponent    : R4 1.2l TFS   H21 9315
   Revision    : R5H21---    CVN: 399C2D98
   Kodning    : 01190032234411080000
   Forhandler    : WSC 00046 000 00000
   ASAM datasæt    : EV_ECM12TFS01104E906027BC 001010
   ROD: EV_ECM12TFS01104E906027BC.rod
   VCID: 66807E9399BEA8BF57-8032
   VINID: 9E69EAAAA1A2A96A400C000908EB50844D
   Betjeningsenhed midterkonsol 1:
3 fejlkoder fundet:
10203 - Forbrændingsudsættere registreret
          P0300 00 [096] - -
          Periodisk - Ikke bekræftet - Testet siden sletning af hukommelse
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Kørestrækning: 128232 km
                    Dato: 2022.08.15
                    Tid: 13:18:03
                    Motoromdrejningstal: 1008.00 /min
                    Normeret belastningsværdi: 76.1 %
                    Kørehastighed: 0 km/t
                    Kølevæsketemperatur: 36 °C
                    Indsugningsluft temperatur: 28 °C
                    Barometerstand lufttryk: 1000 mbar
                    Kl. 30 spænding: 12.510 V
                    Nulstillingstæller for EOBD: 31
                    Lambdasonde B1-S1: foreskr. værdi: 1.0000
                    Lambdasonde B1-S2: indre modstand grænseværdi: 700 Ohm
                    Langvarig tilpasning af blandingsforhold B1: i tomgang: -0.94 %
10593 - Cylinder 3
          P0303 00 [096] - Forbrændingsudsættere registreret
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Dato: 2022.08.15
                    Tid: 13:18:45
                    Motoromdrejningstal: 750.50 /min
                    Normeret belastningsværdi: 39.6 %
                    Kølevæsketemperatur: 45 °C
                    Kl. 30 spænding: 12.533 V
                    Udsætterdetektering reference moment: 10.118 %
                    Udsætter sumtæller: 195
                    Tæller: ikke realistiske korttidsadap.: udsætterreg.: 0
10594 - Cylinder 4
          P0304 00 [096] - Forbrændingsudsættere registreret
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Dato: 2022.08.15
                    Tid: 13:18:45
Styreenhed  03: ABS bremser (J104)     Forklaringsfil: NEZ\6R0-907-37x-ESP90.clb
   Styreenhedsnr: SW: 6C0 907 379 H    HW: 6C0 907 379 B
   Komponent    : ESP9.0i       H01 0003
   Serienummer    : 08505826140805
   Kodning    : 21DD48854B2633C00914307200538412D2CC900C0005C7FB8F00
   Forhandler    : WSC 00788 648 00255
   ASAM datasæt    : EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3424D4DB9FE20A2F19-8060
Ingen fejlkoder fundet.
Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil:| NEZ\6C0-907-044.clb
   Styreenhedsnr: SW: 6C0 907 044 A    HW: 6C0 907 044 A
   Komponent    : Climatronic   H02 0102
   Serienummer    :  1404102A-0434
   Kodning    : 200000001001100001
1 fejl fundet:
          B10F0 00 [012] - -
             Fryserammedata:
                    Fejlprioritet: 6
                    Fejlhyppighed: 19
                    Nulstiltæller: 234
                    Dato: 2022.08.12
                    Tid: 10:24:40
Styreenhed  09: Centralelektr. BCM1 (J519)     Forklaringsfil:| NEZ\6C0-937-089-V1.clb
   Styreenhedsnr: SW: 6C0 937 089     HW: 6C0 937 089
   Komponent    : BCM PQ26 Hi4R H06 0030
   Serienummer    : 007128013179
   Kodning    : 0000085042530AFB4F844000402F07D800005B0253010000000000000000
   ASAM datasæt    : EV_BCMA0 004001
   ROD: EV_MQBA0.rod
   VCID: 6D9201BFBC489BE716-8038
   Regn- og lyssensor:
   Undersystem 1 - Styreenhedsnr: SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Forklaringsfil: NEZ\5Q0-955-547.CLB
   Komponent    : RLHS  037 0059
   Serienummer    : S2Y14M04D01H18M47S34
   Kodning    : 0038DD
   Dørstyreenhed: førerside:
   Undersystem 2 - Styreenhedsnr: SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Forklaringsfil: NEZ\6R0-959-801-V2.CLB
   Komponent    : J386__TSG_FT  003 8612
   Serienummer    : KU0KU019031440785489
   Kodning    : 0400A0
   Dørstyreenhed i passagerside foran:
   Undersystem 3 - Styreenhedsnr: SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Forklaringsfil: NEZ\6R0-959-802-V2.CLB
   Komponent    : J387__TSG_BT  003 8612
   Serienummer    : KU0KU007041440971340
   Kodning    : 1400A0
   Dørstyreenhed i førerside bagved:
   Undersystem 4 - Styreenhedsnr: SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Komponent    : J388__TSG_HL  003 8610
   Serienummer    : KU0KU024031440833718
   Kodning    : 0400A0
   Dørstyreenhed i passagerside bagved:
   Undersystem 5 - Styreenhedsnr: SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Komponent    : J389__TSG_HR  003 8610
   Serienummer    : KU0KU020031440795585
   Kodning    : 1400A0
Styreenhed  10: Park.assist. (J791)     Forklaringsfil:| NEZ\5Q0-919-294.clb
   Styreenhedsnr: SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Komponent    : PARKHILFE 8K  H03 0142
   Revision    : --------    Serienummer    : 39331409800491
   Kodning    : 0011051001
   ASAM datasæt    : EV_EPHVA18AU3700000 002024
   VCID: 3E30F6F3A1AED07FFF-806A
Styreenhed  13: Afstandsreg. 1 (J428)     Forklaringsfil:| NEZ\5Q0-907-572-V1.clb
   Styreenhedsnr: SW: 5Q0 907 572 E    HW: 5Q0 907 572 B
   Komponent    : ACC Bosch MQB H04 X312
   Serienummer    : 20031476510934
   Kodning    : 00000000FE0739
   Forhandler    : WSC 00046 123 12345
   ASAM datasæt    : EV_ACCMRRBoschVW372 001015
   VCID: 393AE5EFB880F747CA-806C
Styreenhed  14: Affjedringselektr. (J250)     Forklaringsfil:. NEZ\6C0-907-359.clb
   Styreenhedsnr: SW: 6C0 907 359     HW: 6C0 907 359
   Komponent    : DAEMPFUNGS-SG H04 0007
   Serienummer    : 20031402000086
   Kodning    : 80
   ASAM datasæt    : EV_SwitcDampeContiTemic 001004
   ROD: EV_SwitcDampeContiTemic.rod
   VCID: 6A980AA38DA68CDF73-803E
Styreenhed  15: Airbags (J234)     Forklaringsfil:* NEZ\6C0-959-655.clb
   Styreenhedsnr: SW: 6C0 959 655 B    HW: 6C0 959 655 B
   Komponent    : VW20Airbag01B 001 0330
   Revision    : --------    Serienummer    : 003LN001G7B$
   Kodning    : 88CCC000000000005C0000CA000800000000
   Forhandler    : WSC 60080 001 1048576
   ASAM datasæt    : EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3228D2C365F6041F0B-8066
   Crashsensor til sideairbag i førerside:
   Undersystem 1 - Styreenhedsnr: SW: -----------    HW: 410 820 903 14
   Komponent    : SideSensor_Df  151 0800
   Serienummer    : 3575H00B3135C2E1C3FX
   Kodning    : 2D2D2D
   Crashsensor til sideairbag i passagerside:
   Undersystem 2 - Styreenhedsnr: SW: -----------    HW: 410 822 003 14
   Komponent    : SideSensor_Pf  151 0800
   Serienummer    : 3585H00C112E61A3A2FT
   Kodning    : 2D2D2D
   Crashsensor til sideairbag bagi i førerside:
   Undersystem 3 - Styreenhedsnr: SW: -----------    HW: 442 150 304 14
   Komponent    : SideSensor_Dr  1CA 0148
   Serienummer    : 3517A00A71534AC1F3DO
   Kodning    : 2D2D2D
   Crashsensor til sideairbag bagi i passagerside:
   Undersystem 4 - Styreenhedsnr: SW: -----------    HW: 442 150 304 14
   Komponent    : SideSensor_Pr  1CA 0148
   Serienummer    : 3527A00A71534AC4C2FQ
   Kodning    : 2D2D2D
Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\5G0-920-XXX-17.clb-SRI3
   Styreenhedsnr: SW: 6C0 920 740 A    HW: 6C0 920 740 A
   Komponent    : KOMBI         211 0260
   Kodning    : 072409003580000800882A011000000000000000
   ASAM datasæt    : EV_DashBoardVDDMQBAB 009036
   VCID: 200C288B3B1A868FED-8074
Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:| NEZ\6C0-909-901-V1.clb
   Styreenhedsnr: SW: 6C0 909 901     HW: 6C0 937 089
   Komponent    : GW MQB A0     H06 0030
   Revision    : --------    Serienummer    : 007128013179
   Kodning    : 030100046F0A560071000000800000010001000000000000000000000000
   Forhandler    : WSC 131071 1023 2097151
   GVL: 01443C00000000004000800000004C0000000000000000000000000000000000
   ASAM datasæt    : EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 6582799F64B8A3A75E-8030
   Styreenhed til multifunktionsrat:
   Undersystem 1 - Styreenhedsnr: SW: 6C0 959 442 B    HW: 6C0 959 442 B  Forklaringsfil: NEZ\3C8-959-537.CLB
   Komponent    : E221__MFL-TAT  H03 0015
   Serienummer    : 12003020140000000102
   Kodning    : 2C0000
   Styreenhed til batteriovervågning:
   Undersystem 2 - Styreenhedsnr: SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Komponent    : J367-BDM  H08 0223
   Serienummer    : 61085A39542821997848
Styreenhed  44: Servostyring (J792)     Forklaringsfil:| NEZ\6Rx-909-144-V2.clb
   Styreenhedsnr: SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Komponent    : EPS_TRW_ALow  312 3211
   Serienummer    : PE4L0330
   Kodning    : 0007
   ASAM datasæt    : EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
Styreenhed  5F: Informationselek. (J794)     Forklaringsfil:| NEZ\5G0-035-MIB-ENT1.clb
   Styreenhedsnr: SW: 6C0 035 869     HW: 6C0 035 869
   Komponent    : MU-E--ER      640 5997
   Serienummer    : 31031400010656
   Kodning    : 02620000BE00000041110001000000001F0000840000010000
   ASAM datasæt    : EV_MUEnt4CLGE 001030
   ROD: EV_MUEnt4CLGE_VW26.rod
   VCID: 689C70AB93AABECF65-803C
2 fejlkoder fundet:
0002 - Radioantenne 1
          B1119 11 [008] - Kortslutning til stel
             Fryserammedata:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 236
                    Kørestrækning: 128303 km
                    Dato: 2022.08.16
                    Tid: 22:41:35
                    Kl. 30 spænding: 13.4 V
                    Status antenne 1 til radio-Antennestrøm: 0 mA
                    Status antenne 1 til radio-Forbindelse mellem radio og antenneforstærker: Kortslutning
                    Status antenne 1 til radio-Forbindelse mellem antenneforstærker og antenne: Ikke tilgængelig
                    Status antenne 1 til radio-Modtagelsesniveau antenne 1: 40 dBµV
0004 - Radioantenne 2
          B111A 11 [008] - Kortslutning til stel
             Fryserammedata:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 236
                    Dato: 2022.08.16
                    Tid: 22:41:35
                    Status antenne 2 til radio-Antennestrøm: 0 mA
                    Status antenne 2 til radio-Forbindelse mellem radio og antenneforstærker: Kortslutning
                    Status antenne 2 til radio-Forbindelse mellem antenneforstærker og antenne: Ikke tilgængelig
                    Status antenne 2 til radio-Modtagelsesniveau antenne 2: 13 dBµV
Slutning------(Forløbet tid: 00:54, VBat. start/slut: 12.2V/12.1V)--------
JMR
Romania
C?ID=432218
Polofan
Denmark
C?ID=270984
Look Here
