Audi A6 2018 Preheater problem
fridaforsbilservice
Sweden
C?ID=21915 (NRRT)
Hello! We have changed the pre heater and whit the VCDS have we take the old Code and put it in the other Pre heater that is from another car. but now the heater dont work and there is fault codes on it becuese its from another car. i think the software isnt the same
the old one had in the car
Standheizung H26 0280
the old one from the oher car has
standheizung H26 0290
how to fix this problem?
i did an auto-scan:
Wednesday,17,August,2022,12:13:05:20017
VCDS Version: 22.3.1.1 (x64)
Data version: 20220401 DS337.0
VIN: WAUZZZ4GXJN051726   License Plate: YWE895
Mileage: 118703km-73758mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 28 34 3B 3C 42 44 46 52
          53 55 5F 62 69 6C 6D 72 85 8B 8E 8F 90 AC 47
VIN: WAUZZZ4GXJN051726   Mileage: 118703km-73758miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CZVA)       Labels: Redir Fail!
   Part No SW: 4G2 907 311 B    HW: 4G2 907 311 A
   Component: 3.0TDI MD1    H25 0005
   Revision: C4H25---    CVN: 64479CD4C19C7771B866C2ADB866C2AD
   Coding: 3225401A057609030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G2907311B 001009
   ROD: EV_ECM30TDI0114G2907311B.rod
   VCID: 24431AE92F95CEAF8E-8070
   VINID: 9D196AAAA117A1A7801411C2181E1BDA9F
5461 - Ignition Switch; ON Position
          P2533 00 [096] - Short to Plus
                    Mileage: 115596 km
                    Engine RPM: 125.50 /min
                    Coolant temperature: 83 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 9.540 V
                    Unlearning counter according OBD: 13
                    Limitation: torque: 1000.0 Nm
                    Engine torque: 0.0 Nm
                    Generator: load signal: 0.00 %
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 118703 km
                    Engine RPM: 0.00 /min
                    Coolant temperature: 33 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 11.300 V
                    selected gear-Bits 0-7: 0
   Part No SW: 4G0 927 166 L    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H06 0006
   Revision: --H06---    CVN: 00009FD1
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 3667D0A189094C3F20-8062
20361 - No Communication with Cruise Control Module
          U0104 00 [039] - -
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
                    Engine RPM: 0 /min
                    Transmission input speed: 0 /min
                    Engine torque: 920 Nm
                    ATF temperature: 28 °C
                    Accelerator pedal position: 0.0 %
                    Clutch status: Beide Kupplungen offen
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 27A6DE4DE4657BB2BB00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 418DB37DD0C7FB8785-8014
10240 - Function Restricted due to Missing Message(s)
          U1111 00 [047] - -
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 20
                    Bit Info 4: 1F
                    Uz: 91
10752 - Function Restricted due to Missing Message(s)
          U1111 00 [047] - -
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 20
                    Bit Info 4: 1F
                    Uz: 91
   Part No SW: 4H0 907 064 HP    HW: 4H0 907 064 HP
   Component: BCM2 2.0      H61 0825
   Coding: 05A96F4E000000000000
   VCID: 7EF70881E9B9447FB8-802A
   Serial number: 3217000188604007
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 12101700040599
   Coding: 361211B82D0000
   VCID: 63C159F56A1B8997B7-8036
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001788384502
   Coding: 0105C01440349FE2C901408300001800CF9C67082E08020100000894E10017020040003D030000
   VCID: 74E32AA9D7F51E2FDE-8020
   Component: WWS57X 170902  H38 0080
   Serial number:         170908123616
   Coding: 0045F7
   Serial number: 20519203X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 29 09 2017  00000350
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 854152D800PAG0MUFU03
02069 - Front Parking Aid Sensors
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
01319 - Control Module for Distance Control (J428)
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:45
Address 13: Auto Dist. Reg
   Component: Airbag10.43   H83 0098
   Revision: --------    Serial number: 003P100EWDHJ
   Coding: 30333130313730323539554A304C34473053
   VCID: 3B71C195B22B9157DF-806E
   Serial number: 3575HRB400C5BEA66HPD
   Serial number: 3585HRB40105BEA6BPPG
   Serial number: 3515JRB400I5BLHCP1LY
   Serial number: 3525JRB40105BMPCJA2B
   Serial number: 3554VRB405B52EI898SQ
   Serial number: 3564VRB405D52EI8NOQE
1050368 - Databus
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:41
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QJ60009Y
   Coding: 0000DD
   VCID: 3779DDA58603B5373B-8062
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 28 06 2017  D0041418
   Part No SW: 4G9 920 951 L    HW: 4G9 920 951 L
   Component: TDieRdwAccNv  H17 0225
   Revision: 18001312    Serial number: 658270917592062
   Coding: 138625081F5100080B0600
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 3A7FC491BD11A85FC4-806E
16776960 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:41
16776961 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:41
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 J    HW: 4H0 265 105 J
   Component: Standheizung  H28 0290
   Revision: 88008008    Serial number: 00000000000000
   Coding: 5D3F01
   Shop #: WSC 00001 785 00200
   VCID: 295D0BDD40B713C7BD-807C
02084 - Component Protection
                    Fault Status: 01100101
                    Temperature: 19.0°C
                    Temperature: 143.0°C
                    Voltage: 11.90 V
                    Temperature: -50.0°C
                        No
                    Mileage: 118703 km
                    Date: 2022.08.17
                    Time: 11:27:17
                    Temperature: 25.0°C
                    Temperature: 23.0°C
                    Voltage: 12.10 V
                    Temperature: 24.0°C
                        No
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002751266
   Coding: C0CD078118
   GVL: FD8FD844DCA5600F40040800
   ASAM Dataset: EV_GatewPkoUDS 002011
   VCID: 408BB679DBCDF28F8A-8014
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 0806485404
   Voltage stabilizer:
   Serial number: 170715000000000003CD
4365 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
                    Voltage terminal 30: 11.3 V
                    Voltage terminal 15: 11.2 V
                    Control Module temperature: 24 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
6654 - Automatic distance regulation 2
          U1071 00 [009] - No communication
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:42
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 11.6 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U1101 00 [009] - Active
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.17
                    Time: 10:55:35
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 11.4 V
                    Control Module temperature: 22 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0113
   Serial number: 11101700041092
   Coding: 21
   VCID: 3E77C881A139847FF8-806A
   Coding: 008003
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F69E5C576537DF763-807A
0002 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
          C10C8 00 [009] - -
                    Reset counter: 106
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820EB6VN
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0456908343
   Coding: 040321
   VCID: 397DDB9DB817A347CD-806C
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0456134841
   Coding: 040321
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F16015C00628002080013
   VCID: 4585A76DCCEFD7A7B9-8010
   Component: RCevo         H55 0202
   Revision: 00000002    Serial number: 0000190844
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   Revision: 00002001    Serial number: 0457715603
   Coding: 013A0E20A0B93095C32009842E010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 2 - Part No: 1K0 951 605 F
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H04 0005
   Serial number: 0000FST001T4TG700000
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00037901416
   Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H04 0005
   Serial number: 0000FST001T4TVM00000
   Coding: 801F00
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.17
                    Time: 11:37:00
   Component: TSG BF        H03 0511
   Coding: 011F16015E00628002080002
   VCID: 4687A061F1E9DCBFB0-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002325369
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 326FECB16561501F0C-8066
327936 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
                    Voltage terminal 30: 11.4 V
                    Internal Fault ID: 86
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Coding: 04FA02202A170200
   VCID: 3463EAA99F755E2F1E-8060
   Coding: E01F00
   Coding: E01F00
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 044 J    HW: 4G1 035 044 D
   Component: MU-H-LN-EU    054 0910
   Serial number: A734I0HS024441
   Coding: 017542010000000013110002000A00332F000AE5F1700100DF
   Shop #: WSC 48111 002 1048576
   VCID: 264700E159A93CBF90-8072
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9HY808Z2W
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349QJ900072
   Compact disc data bank:
   Component: Gracenote2  --- 1016
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:31:03
                    Voltage terminal 30: 12.0 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:31:03
   Component: TSG HL        H03 0511
   Coding: 010F14004000628002080002
   VCID: 499DAB5DE0F733C75D-801C
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H20 0160
   Revision: 7B001003    Serial number: 0457571141
   Coding: 0100000202000000
   VCID: 3361E9B59A7B591707-8066
655882 - Bulb for Brake Light on Trailer
          C10F3 15 [008] - Open or Short to Plus
                    Reset counter: 129
                    Mileage: 117435 km
                    Date: 2022.07.25
                    Time: 20:47:12
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [008] - Open or Short to Plus
                    Reset counter: 129
                    Mileage: 117435 km
                    Date: 2022.07.25
                    Time: 20:47:12
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 0275000103002007000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
   VCID: 78FB1E99C39D7A4FF2-802C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0152
   Revision: 14005001    Serial number: 277700735
   Coding: 093205C031
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0511
   Component: DPC-SG        H28 0081
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C53F2C9474506EF46-8078
0001 - Front Heater for Lane-Holding Assist
          C1101 15 [008] - Open or Short to Plus
                    Fault Frequency: 29
                    Reset counter: 146
                    Mileage: 110441 km
                    Date: 2022.04.17
                    Time: 11:41:19
                    Outside temperature: -41.5 °C
                    Voltage terminal 15: 12.9 V
                    Control Module temperature: 50.0 °C
0724 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:41
                    Outside temperature: -37.5 °C
                    Control Module temperature: 25.0 °C
Address 8B: Adaptive Cruise 2
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002450509177
   Coding: 04C0BA1C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0046 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
                    Outside temperature: 25.0 °C
                    Control Module temperature: 0.0 °C
0173 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:40
                    Voltage terminal 15: 11.8 V
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 316DE3BD60676B0775-8064
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:41
12583693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:41
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:41
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 118703 km
                    Date: 2022.08.16
                    Time: 15:30:41
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 172280996
   ROD: EV_RDCMA00100.rod
   Part No SW: 4G5 035 223 E    HW: 4G5 035 223
   Component: MIB2_amp_P    H03 0440
   Serial number: 00000000093920
   Coding: 01758208018AF02A5A0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
End-------------------------(Elapsed Time: 06:56)--------------------------
Ah yes, CP, the bane of every DIY'er !
Special Notes​
  • At the present time the Component Protection can only be learned/disabled using the Factory Tool in Combination with an online Connection. Every Audi Dealer/Service should be able to perform this Procedure.
