Audi A3 1.4L CPTA wont start, multiple faults stored, TCM lost communication
mpauto
C?ID=490545
Hi everyone, i have a 2014 audi a3 1.4L CPTA 7 Speed 0AM transmission with that has a intermittent issue. Sometimes when coming to the car it wont shift into gears, there is fault stored saying lost communication with TCM. The P symbol on the shifter flashes. There is also warning on the dash for TPMS, EPC and stability control. Then sometimes it starts and drives fine. here are the faults recorded has anyone seen anything similar before?
Wednesday,17,August,2022,16:48:36:46293
VCDS Version: 22.3.1.4 (x64)  HEX-NET2 CB: 0.4615.4
Dealer/Shop Name: MP Auto Repairs
VIN: WAUZZZ8V9E1037080   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F 6C
VIN: WAUZZZ8V9E1037080   Mileage: 216886km-134766miles
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
   Component: 1,4l R4 TSI   H02 6189
   Revision: WKH02---    CVN: 21292CE9
   Coding: 02250032232401082000
   Shop #: WSC 59050 001 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016AD 002008
   ROD: EV_ECM14TFS01104E906016AD.rod
   VCID: 649AC57F5ED0F27B4B7-8030
   VINID: 9D196AAAA2262550400C70080024D93F07
17158 - Databus
                    Mileage: 216884 km
                    Date: 2022.08.14
                    Time: 23:36:37
                    Engine RPM: 0.00 /min
                    Coolant temperature: 86 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 12.203 V
                    Mass flow through throttle valve: 0.0 kg/h
                    Mean injection time: 0.000 ms
                    Engine operating condition: Idle
          U0428 00 [032] - -
                    Mileage: 216884 km
                    Date: 2022.08.15
                    Time: 00:01:19
                    Coolant temperature: 42 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 11.968 V
                    selected gear-Bits 0-7: 0
4718 - No Communication with Transmission Control Module
          U0101 00 [032] - -
                    Mileage: 216884 km
                    Date: 2022.08.14
                    Time: 23:35:59
                    Coolant temperature: 87 °C
                    Intake air temperature: 40 °C
Readiness: 0110 0001
   Part No SW: 0CW 300 047 T    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5202
   Revision: 00043014    Serial number: CU501403115593 CVN: 0000A038
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 4CCA0DDFD6405A3B637-8018
   Revision: 00000000    Serial number: 60844000000C06
   Coding: 13F18AA2242312730177020841C329C851244880408294F2022150388608
   Shop #: WSC 06385 790 00016
   VCID: 7BA89E03C36E2D839AD-802E
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 7
                    Mileage: 216884 km
                    Date: 2022.08.15
                    Time: 00:01:20
8222 - Databus
          [FCAN : Getriebe_11 message is not received]
                    Fault Frequency: 35
                    Reset counter: 9
                    Mileage: 216884 km
                    Date: 2022.08.15
                    Time: 00:01:20
8226 - Databus
          [FCAN : Getriebe_14 message is not received]
                    Fault Frequency: 35
                    Reset counter: 9
                    Mileage: 216884 km
                    Date: 2022.08.15
                    Time: 00:01:20
          C1146 02 [008] - Signal Failure
                    Reset counter: 8
                    Mileage: 216877 km
                    Date: 2022.08.11
                    Time: 15:33:52
32870 - Databus
          [IPB-BUS: Getriebe_11 / GE_Zielgang invalid]
                    Reset counter: 8
                    Mileage: 216877 km
                    Date: 2022.08.11
                    Time: 15:33:43
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000280478
   Coding: 03100004110000001000000000001400
   VCID: 3236732754A42CCB09B-8066
   Humidity sensor: exterior:
   Serial number: 6B298E17000000000001
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011408804670
   Coding: 07041A42C24122F543A04004000807080000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140317  041 0585
   Serial number:         140320195059
   Coding: 0A47F7
   Serial number: 22383770
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Serial number: 16 12 2013  00000706
204549 - Remote key 2
          B147A 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 8
                    Mileage: 216884 km
                    Date: 2022.08.15
                    Time: 00:06:03
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 12.4 V
                    Outside temperature: 13.0 °C
555797 - Databus
          [Getriebe_11_alt aktiv]
                    Fault Frequency: 12
                    Reset counter: 8
                    Mileage: 216884 km
                    Date: 2022.08.14
                    Time: 23:36:10
                    Terminal 15 status: On
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Voltage: 12.1 V
                    Outside temperature: 16.0 °C
   Part No SW: 5Q0 919 298 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0033
   Revision: --------    Serial number: 61131407800146
   Coding: 0130160051
   ASAM Dataset: EV_EPHVA2CAU3700000 003015
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 3E2E571790FCF8ABFD3-806A
13637426 - Databus
                    Fault Frequency: 12
                    Reset counter: 8
                    Mileage: 216884 km
                    Date: 2022.08.14
                    Time: 23:36:09
12648721 - Databus
          [Getriebesteuergerät - Getriebe_11 - kein Signal/keine Kommunikation]
                    Reset counter: 8
                    Mileage: 216884 km
                    Date: 2022.08.14
                    Time: 23:36:08
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR0148UV
   Coding: 98CCC000000000005C54000000C800000065
   VCID: 0052E9EFAA884E5BCFF-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 000 303 14
   Serial number: 357670000000C0651F0O
   Subsystem 2 - Part No SW: -----------    HW: 480 000 303 14
   Serial number: 35867000000C72651F0Y
   Subsystem 3 - Part No SW: -----------    HW: 480 402 003 14
   Serial number: 3516502A1142B1B021CZ
   Subsystem 4 - Part No SW: -----------    HW: 480 401 803 14
   Serial number: 35265029B14476B491BF
   Subsystem 5 - Part No SW: -----------    HW: 480 401 702 14
   Serial number: 3556502C914D3E72B21J
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 31031408490288
   Coding: A018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 7CAA9D1FC6602ABB937-8028
   Part No SW: 8V0 920 870 G    HW: 8V0 920 870 G
   Component: KOMBI         H03 2220
   Coding: 27A419082B9000080100E800100000
   VCID: 3FD02A1397F6F1A3F65-806A
16776983 - Databus
          [WBA_03 keine Kommunikation]
                    Reset counter: 8
                    Mileage: 216884 km
                    Date: 2022.08.14
                    Time: 23:36:00
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 29031410801008
   Coding: 030100042B0857005B000248180B00000001000000000000000000000000
   GVL: 01543C0000000000400C10000002C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 B    HW: 8U0 951 528 B
   Serial number: 28 02 2014  B1312473
   Serial number: 6187442803
131703 - No Communication with Transmission Control Module
          U0101 00 [008] - -
          [Timeout Knoten 0x77 / 02 - Steuergerät für Getriebe]
                    Reset counter: 8
                    Mileage: 216884 km
                    Date: 2022.08.14
                    Time: 23:36:11
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: On
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 30031401101025
   Coding: 00100E204101040000001002
   Serial number: 00000000000002161111
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 0303
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41D42CEBE1028753801-8014
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 21031402090235
   Coding: 001006204101040000001002
   VCID: 3D2C501B9DFAE3B3E49-8068
   Serial number: 00000000000002122998
   Coding: 150000
   Coding: 019E000001000000
   VCID: 75BC883BE54A7BF3EC9-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 045 M    HW: 8V0 035 045
   Component: MU-H-N-RW     H42 0282
   Serial number: A307C0E7504887
   Coding: 01730108FF0A000021510001000A00002F000106010001005E
   ROD: EV_MUHig6C3HBAS_VW48.rod
   VCID: 3C2A5D1F86E0EABBD37-8068
   Subsystem 1 - Part No SW: V03 959 800 SD    HW: -----------
   Component: ROW 2014  --- 0030
   Multimedia System 1:
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY200V6R
   Subsystem 3 - Part No SW: 8V0 919 614 R    HW: 8V0 919 614 D
   Component: ControlUnit_H  H64 0766
   Serial number: C1000030011400020359
   Compact disc data bank:
   Component: Gracenote  --- 4005
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 9
                    Mileage: 216884 km
                    Date: 2022.08.15
                    Time: 00:54:29
                    Voltage terminal 30: 11.8 V
                    Network diagnosis-Status: Enabled
   Part No SW: 5Q0 907 441     HW: 5Q0 907 441
   Component: MQB RVC Mid   H06 0130
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 6FB0BA5387164123265-803A
End----------(Elapsed Time: 01:17, VBatt start/end: 14.6V/12.2V)-----------
Westbury, UK
Please post an Auto-Scan so we see the fault details and how your A3 is equipped and configured.
Westbury, UK
I thought I did in my post?
Did you post it after initally saving the post, when I looked it wasn't there? But it is now so all good :thumbs:
mpauto
C?ID=490545
Oh yeah I accidentally posted mid way typing, so was editing it to finish the post.
