Hi all, Problem with VCDS lite Auto Scan
Telboy
Verified VCDS-Lite User
UK, Crawley
C?ID=250830
Hi all, I'm a new user and please to meet all.
My problem is I run VCDS Lite Auto Scan with 1J setting and it seem to go fine to start, then after so many popup windows I get something strange, the window pop's up and the info is not displayed right it keep trying the process and gets stuck in a loop so I canceled it and then closed the app.
My Vehicle is a Volkswagen Golf mark 4 2004 1.8 turbo 6 speed manual, AUQ Engine, 5 Door, Electric windows, Air con.
Thanks in advance for the help:)
What module address is it trying when it "gets stuck"?
Telboy
UK, Crawley
C?ID=250830
Not sure, It was some way in. I stopped it as I was not sure if it was going to do any damage to the ECU. if its safe will do again and try to give you the report?
Yes, please watch it carefully and make a note of what address it hangs on.
Telboy
UK, Crawley
C?ID=250830
Thanks for the support so far.
It seemed to be module 46, Yet when i plugged in this time run the auto scan all seemed fine then it pop up saying Its did stuff to air bags please switch ignition off and wait 30 sec's then after told me switch back on and it completed the auto scan.
VCDS-Lite Version: Release 1.2
Saturday, 27 June 2015, 11:33:06:29282
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine       Labels: 06A-906-032-AJQ.LBL
   Controller: 06A 906 032 MJ
   Component: 1.8L R4/5VT         0003
   Coding: 11510
   Shop #: WSC 01266
   VCID: 72972BA92DB7
   WVWZZZ1JZ4W112895     VWZ6Z0C0133447
Address 03: ABS Brakes       Labels: None
   Controller: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 01266
   VCID: 341BEDB11723
Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
   Controller: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01266
   VCID: 213514E5B8D1
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 01266
   VCID: 22371BE9BDD7
Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
   Controller: 1J0 920 926 A
   Component: KOMBI+WEGFAHRS. RB8 V29
   Coding: 05414
   VCID: 282309C1DBEB
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01266
   VCID: F093A1A1A3BB
Address 46: Central Conv.       Labels: 1C0-959-799.LBL
   Controller: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 54146
   VCID: 361FD7B9015F
00931 -  Locking Module for Central Locking; Rear Right (F223)
            27-10 -  Implausible Signal - Intermittent
Address 56: Radio       Labels: 1J0-035-18x-56.LBL
   Controller: 1J0 035 186 D
   Component:  RADIO SON         0004
   Coding: 01403
   Shop #: WSC 01266
   VCID: 263F07F9D1FF
End   --------------------------------------------------------------------------------------------------
I've only had the car a short time, Just after getting the car I put in to VW to set the remote fob to open all doors as it use to just open the drivers door.
So i'm thinking this is a new error yet it don't explane why I was getting strange info from that module when i did the scan the other day.
I went in to module 46 and cleared all error and will keep eye.
The door seems to lock and open fine. yet the kids do like to try to open the door before its unlocked at times
Well, I don't see any obvious problems with VCDS-Lite there.
What kind of computer are you using? Make, model, CPU, RAM, version of Windows?
What are the exact results when you do [Options] -> [Test] (with the interface connected to your car)?
Eric
HC800000
I'll add that 46 is notorious for having its weird moments on the Mk4 platform. When it doubt with 46, do a cold boot :)
Telboy
UK, Crawley
C?ID=250830
Thanks, The labtop I am using is a Acer Aspire 5560, AMD A6-3420M with Radeon HD Graphips, 6GB Ram running Windows 7 64bit Home.
I got a pic of the test for you below.
So channel 46 is notorious for problems thanks for the heads up :)
But what do you mean by a cold boot?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Physically disconnect the module or pull the relating fuses, essentially forcing the module to boot up from scratch. As Eric stated, they were known for all sorts of funny behavior back in the day when those cars were "current". :)
Telboy
UK, Crawley
C?ID=250830
Will disconnecting the car battery for 30 sec work, count as a cold boot?
Santos
it should be fuse #14
Telboy
UK, Crawley
C?ID=250830
Thanks for all the help :)
I've just got one more question, using the autoscan report above with the modules it found. Will this work if i added it to the autoscan.txt file
01,My Golf,01,03,08,15,17,19,46,56
Telboy
UK, Crawley
C?ID=250830
Nice one. :thumbs:
Is there a way to tell the Firmware version installed on the ECU, so can check if there was any dealer updates?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
In your case? 06A-906-032-MJ @ 0003, don't think there is an update available for that one.
Telboy
UK, Crawley
C?ID=250830
Will that be the right one for the 180bhp turbo model. got told most pree mine was only 150bhp
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Your engine code is AUQ, which means it's the 180 PS version.
Telboy
UK, Crawley
C?ID=250830
thanks again :cool:
