2012 Passat TDI
andrewk2k
Menomonee Falls, WI, USA
C?ID=523795
Recently had the DEF heater/sensor unit replaced. The car was running fine for a few days. A few minutes into the drive, the glow plug light came on and then the check engine light shortly after. The engine was slow to respond, but able to get up to speed eventually. I was hoping I just needed to replace the glow plugs, but wanted to get feedback on the codes first. Thoughts?
Here is the autoscan:
Monday,15,August,2022,17:21:40:03207
VIN: 1VWCN7A3XCC054759   License Plate: 999-XXX
Mileage: 244310km-151807mi   Repair Order:
                Address 01: Engine       Labels: 03L-906-022-CFC.clb
Control Module Part Number: 03L 997 009 J    HW: 03L 907 309 S
  Component and/or Version: R4 2.0l TDI   H21 9981
           Software Coding: 001D0012042400008000
            Work Shop Code: WSC 02616 444 00000
              ASAM Dataset: EV_ECM20TDI01103L997009J 004004 (VW41)
                       ROD: EV_ECM20TDI01103L997009J.rod
                      VCID: 3B233AAF13E568A3DAD-806E
5171 - Boost Pressure Regulation
          P0299 00 [109] - Control Range Not Reached
                    Mileage: 244243 km
                    Date: 2022.08.15
                    Time: 14:16:45
                    Engine RPM: 1850.50 /min
                    Normed load value: 58.8 %
                    Vehicle speed: 60 km/h
                    Coolant temperature: 48 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 14.320 V
                    Charge air pressure: specified value: 1981 hPa
                    Charge air pressure: actual value: 1498 hPa
                    Air mass: actual value (mg/stroke): 651.9 mg/stroke
                    EGR Solen.val.: actual value: 99.62 %
                    Throttle valve adapter: actual value: 18.90 %
                    Charge air pressure actuator: acknowledgment: 99.91 %
                    Mean injection quantity: 24.57 mg/stroke
11515 - Exhaust Gas Recirculation System
          P240F 00 [237] - Response too Slow
                    Mileage: 244215 km
                    Date: 2022.08.13
                    Time: 23:06:46
                    Engine RPM: 1464.50 /min
                    Normed load value: 30.2 %
                    Vehicle speed: 77 km/h
                    Coolant temperature: 78 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.200 V
                    EGR Vacuum Regulator Solen.val.: activation: 69.52 %
                    EGR Solen.val.: actual value: 71.40 %
                    Charge air pressure: specified value: 1148 hPa
                    Air mass: specified value: 382.7 mg/stroke
                    Air mass: actual value (mg/stroke): 419.3 mg/stroke
                    Air mass slow response air mass specified value negative slope: 4.1 mg/stroke
12896 - Boost Pressure Regulation
          P0299 00 [237] - Control Range Not Reached
                    Mileage: 244243 km
                    Date: 2022.08.15
                    Time: 14:16:45
8851 - EGR System
          P0401 00 [032] - Insufficient Flow
Readiness: 1 2 0 0 0
Monday,15,August,2022,17:42:24:03207
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCN7A3XCC054759   Mileage: 244310km-151807miles
   Component: R4 2.0l TDI   H21 9981
   Revision: 71H21---    Serial number:                CVN: C4051C7C5C3E0D04
   Shop #: WSC 02616 444 00000
   VINID: 0669D3787443A134C01441C524EB96D0B5
                    Mileage: 244243 km
                    Date: 2022.08.15
                    Time: 14:16:45
                    Mileage: 244215 km
                    Date: 2022.08.13
                    Time: 23:06:46
                    Mileage: 244243 km
                    Date: 2022.08.15
                    Time: 14:16:45
8851 - EGR System
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9435
   Revision: 05551213    Serial number: 00001112031264
   Shop #: WSC 09003 957 00200
   VCID: 2615FBDBF4E7C54B953-8072
18149 - Clutch Pressure Adaptation
            P1741 - 002 - Limit Reached - Intermittent
                    Reset counter: 2
                    Mileage: 244214 km
                    Date: 2017.01.03
                    Time: 23:05:58
   Revision: 00H31001
   Coding: C54BC0F5492700FEA31203E992220042A71000
   VCID: 7DA7F4B74DF1A693A49-8028
                    Reset counter: 34
                    Mileage: 244059 km
                    Date: 2016.12.06
                    Time: 00:00:57
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 16390
                    Count: 42496
                    Count: 511
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0164008623
   Coding: 130C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 343111933EBBA7DB1B7-8060
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001012
   VCID: 1C61D933B62B0F9B337-8048
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0164
   Revision: BL121001
   Coding: 6F200E1B982B08D408880201360085480071008645A005F0648060009C70
   VCID: 74B1D1937EBBE7DBDB7-8020
   Component: RLS 240112 05  54  0403
   Coding: 22300A
                    Fault Status: 00101001
                    Reset counter: 32
                    Mileage: 244056 km
                    Date: 2016.12.06
                    Time: 05:59:11
                    Voltage: 11.25 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM01B1RG
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBDEFF171DC403265-803A
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000B7A402
   Coding: 303047
   Serial number: 3572MSME5C794166ZZZ0
   Serial number: 3582MSME4D0B6566ZZZ2
   Serial number: 3516KSME14452116ZZZD
   Serial number: 3526KSME08481A16ZZZS
   Serial number: 3556LSME30667814ZZZT
   Serial number: 3566LSME626B7B14ZZZ0
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110702101588
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7F4B74D71A693A49-8028
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 C    HW: 561 920 970 C
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 1A6DDF2BBC1F71AB21B-804E
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 30011201290943
   Coding: 461000
   VCID: 3D2734B70D716693E49-8068
   Component: IMMO          H07 0507
   Coding: 000007
   VCID: 6A8DCFEB2CFF212B71B-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000282775004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E0503FBD0978D0B6D3-807A
   Revision: A1001003    Serial number: 7661225803
   VCID: 290FF0E7E9F9EA33B81-807C
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000020414208
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 6099ADC3DA436B7BAFF-8034
   Part No SW: 3C8 035 684 E    HW: 3C8 035 684 E
   Component: RNS-MID       H61 3690
   Revision: AB001001    Serial number: VWZ6Z7M6025043
   Coding: 04090002010000A6000B
   VCID: 2D0704F7DD11F613549-8078
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0003779432
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 34
66304 - Switch for Drivers Side Window Regulator
          B11F0 29 [008] - Signal Implausible
                    Reset counter: 39
                    Mileage: 244076 km
                    Date: 2022.07.25
                    Time: 06:23:01
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 35
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 290    3301
   Revision: 00H22000
   VCID: 35372C973941BED32C9-8060
   Part No SW: 5C6 035 456     HW: 5C6 035 456
   Component: KonzernAmp10K H07 0468
   Revision: --------    Serial number: EAA083A0002196
   ROD: EV_AudioVerst10KanalSTT3_VW36.rod
   VCID: 6597BCD7C5E10E535C9-8030
   Component: EZE_2         H40 1623
   Coding: 01030108
   VCID: 6FBBDEFF179DC403265-803A
   Serial number: 53388786011132000115
   Coding: 181100
   Component: Analoguhr  008 0004
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0003764279
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D67D437AD310693C49-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Reset counter: 35
                    Reset counter: 35
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661549962
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270BF6DFFF6DDC43AE5-8072
End----------(Elapsed Time: 01:23, VBatt start/end: 12.1V/12.0V)-----------
I don't think glow plugs are your issue here. Have a look at this, and especially the Diesel section at the bottom:
In addition, at 150,000 miles, there's a good chance your EGR system is plugged up to some degree, but I'd address the Boost Pressure first.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Your main problem is the Boost , I would diagnose that first , clear codes and see will EGR code come back.
andrewk2k
C?ID=523795
Thanks, I will look into it. This will likely be a journey for me to figure out. I assume this is the number that is indicating the lack of boost pressure?
Can I monitor and log this number in real time as I drive? The car drove with no issues for 15+ minutes before going back to these error codes and losing power, so I assume that some pressure must be held for a bit.
Correct, those were the conditions at the time the fault code set.
Certainly. Use the following measuring values:
IDE00190 -- Charge air pressure: specified value (hPa)
IDE00191 -- Charge air pressure: actual value (hPa)
Jetta 97
C?ID=81680
You may have a leak somewhere , I would go in are where is very quite , turn off radio, open from windows , start diving very hard (pedal to floor, but make sure it is safe to do this ) then listen for hissing noise. if you hear it then you have boost leak.
andrewk2k
C?ID=523795
I am not a mechanic, but I think that this has to be connected to hold pressure :banghead: (it was loosely connected, but fell off when I was looking around for leaks). Cleared DTCs, drove around and all seems well on that front. A P2459 shows in the autoscan but no MIL shown. I will monitor and start a new thread if necessary.
Thursday,18,August,2022,13:10:05:03207
Mileage: 244320km-151813mi   Repair Order:
          52 56 62 72 77
VIN: 1VWCN7A3XCC054759   Mileage: 244320km-151813miles
8863 - Diesel Particulate Filter
          P2459 00 [039] - Regeneration Frequency
                    Mileage: 244320 km
                    Date: 2022.08.18
                    Time: 12:59:27
                    Engine RPM: 1452.00 /min
                    Vehicle speed: 33 km/h
                    Coolant temperature: 47 ∞C
                    Intake air temperature: 30 ∞C
                    Exhaust gas jet volume in particle filter: 58.3 m≥/h
                    Particle filter: difference pressure: 52 hPa
                    Particle filter: soot mass measured: 22.05 g
                    Particle filter: soot mass calculated: 22.03 g
                    Particle filter: differential pressure: dynamic offset: 2 hPa
                    Exhaust gas temperature sensor 3: 135.7 ∞C
                    Exhaust gas temperature sensor 4: 79.4 ∞C
Readiness: 0 0 0 1 1
   Revision: 00H31001
   Coding: 130C0C
   Revision: 00001001
   Coding: 0010001012
   Coding: 00003548
   Coding: 303047
   Coding: 000A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
   Coding: 000007
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
Address 46: Central Conv.
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:18, VBatt start/end: 14.0V/13.9V)-----------
Jetta 97
C?ID=81680
Good catch. BTW that do not hold pressure ,that is suction side, the problem was that AIR FLOW Meter did not read correct air flow .
I suggest to Clear DTC and see will it come back with same DTC.
Particle filter: difference pressure: 52 hPa,
This should be around 0, but it may caused from problem above ,that why I suggest to clear it and see will it come back .
