VW T6 Transporter - Auto Lock / Unlock Facility
Esme99
C?ID=503978
Hi
New to this forum and would like advice on setting up the auto lock / unlock facility. I have selected this function under Central Elec Adaptions but boxes underneath selection only have dashes in place. Does this mean it isn't an available function.
Log File Below:
Saturday,13,August,2022,19:16:23:38189
VIN: WV1ZZZ7HZKX019430   License Plate:
Mileage: 17630km-10954mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZKX019430   Mileage: 17630km-10954miles
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6163
   Revision: 23002001
   Coding: 00114014430401090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004012
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 76B5E984584E6F6BE53-8022
   VINID: 9E606AAAA1D8A9BA0004910300B971FFFC
Readiness: N/A
   Revision: 00000000    Serial number: 60519000000008
   Coding: 517E4098256384878A790279A48221A679F100
   VCID: 3FDB4CA037F4EE23F65-806A
   Serial number: 23121813471035
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F1A4707E272BBD3-802A
   Part No SW: 7E0 907 047 AJ    HW: 7E0 907 047 AJ
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 72BDD5943426734BC9B-8026
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 040190511
   Coding: B8AC393A0A613411922049742C2B8CD40F00710F60464960330400230800
   Shop #: WSC 35110 377 08192
   VCID: 2C010BECD60265BB437-8078
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  004 0653
   Serial number: KU0KU008021990390150
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU028011990281631
   Coding: 0400A0
   Subsystem 3 - Part No: 7E1 951 172
   Component: LIN BACKUP HO  H01 0009
   Subsystem 5 - Part No: 7E1 951 172
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32931901205076
   Coding: 108008
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 43D340505B1C8AC392D-8016
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 1402190439B30F
   Coding: 00004000FE1779
   ROD: EV_ACCBEGVW361.rod
   VCID: 3635298418CE2F6B253-8062
   Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
   Component: VW10Airbag021 010 0018
   Revision: --------    Serial number: 003EK0044GCU
   Coding: 000000000000000000000000000000003231
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D2736A83DF8FC33E49-8068
   Part No SW: 7E0 920 971 A    HW: 7E0 920 971 A
   Component: KOMBI         H02 2030
   Coding: 750B010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 290FF2F8D9707093B81-807C
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 042305
   VCID: 6889B7FC027A899B67F-803C
   Component: IMMO          H02 2030
   Coding: 000002
   VCID: 6A8DCDF41CF6BB8B71B-803E
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     070 7205
   Serial number: 20021900011754
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E0501E4E09E17AB6D3-807A
   Part No SW: 7E0 907 534     HW: 7E0 937 090 D
   Component: Batt.regelung H82 0762
   Coding: 030B7A73
   Subsystem 1 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 7588520200190129061A
End----------(Elapsed Time: 01:44, VBatt start/end: 12.1V/12.1V)-----------
VWT6
Finland
C?ID=295527
In adaptations only place to enter data is "New Value" - the boxes indeed show N/A for this controller.
Hovering your mouse on the screen you'll get information what data to enter and their meaning.
However, for auto locking/unlocking perhaps easier/more obvious way to change settings is via
Cent.Elec. - Coding (Long code helper) - byte 0
Esme99
C?ID=503978
Please advise on the long coding helper - byte 0. Just new to this, so not upto speed with long coding at present.
Westbury, UK
When you click on the coding box a screen will appear which offers the long coding helper, click on that and the lobg coding helpe will open showing Byte 0 with all the known bits detailed.
Look at the description of each bit, and choose appropriately.
Esme99
C?ID=503978
Thanks for the info. Did as suggested and found all relevant codes already selected. Checked in adaptions still same info N/A in top 4 boxes.
VWT6
Finland
C?ID=295527
That's correct (the N/A's) - the relevant value for each "Channel" is shown in "Stored value".
Anyways, the autolocking/unlocking functionality has a strange quirk on T6 BCM's.
More here:
Esme99
C?ID=503978
Hi
Thanks for this info. Not sure which made it work but lifted bonnet, changed adaptions back to default and then used long coding. Actioned the ignition a couple of times and voilà it now all works.
