HI WONDERING IF ANYBODY COULD HELP ME OUT WITH MY AUDI PLEASE? IT KEEPS GOING INTO LIMP MODE UNDER ACCELERATION AND LOGGING HIGH AND LOW FUEL PRESSURE FAULTS. I HAVE CHANGED FUEL FILTER, TOOK FUEL SAMPLE, CHANGED PRESSURE REGULATOR ON RAIL, CARRIED OUT A LEAK OFF TEST ON INJECTORS. NOT SURE WHERE TO GO NEXT, ANY HELP WOULD BE APPRECIATED
Monday,15,August,2022,13:49:11:61841
VCDS Version: 21.3.0.0
VIN: WAUZZZ8K09A061893 License Plate: LT58ESO
Mileage: 249490km-155025mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 0F 10 13 14 15 16 17 19 1B 1E 36 37 3C
42 46 47 52 53 56 57 5C 62 67 6C 6D 72 77
VIN: WAUZZZ8K09A061893 Mileage: 249490km-155025miles
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8K2 907 401 A HW: 8K1 907 401 A
Component: 3.0TDI EDC17 X01 0006
Revision: 15X01---
Coding: 010C002C180F0218
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM30TDI0118K2907401A 001006
ROD: EV_ECM30TDI0118K2907401A.rod
VCID: 2B552F2E42F4A1D346-807E
5215 - Fuel Rail/System Pressure
P0087 00 [167] - Too Low
Mileage: 249494 km
Date: 2022.08.15
Time: 13:34:18
Engine RPM: 627.50 /min
Normed load value: 45.1 %
Coolant temperature: 86 °C
Intake air temperature: 38 °C
Voltage terminal 30: 11.500 V
Unlearning counter according OBD: 80
Crankshaft speed (RPM): 627.5 /min
Vehicle speed: 0.00 km/h
Mean injection quantity: 12.89 mg/stroke
Fuel temperature: 31.2 °C
Fuel high pressure: actual: 107900 hPa
Rail pressure regulation: status-Bits 0-7: 00000101
Inj Crv st Inj Char Act Val 0-Bits 0-7: 00110100
5216 - Fuel Rail/System Pressure
P0088 00 [036] - Too High
Mileage: 249494 km
Date: 2022.08.15
Time: 13:32:51
Engine RPM: 3813.50 /min
Normed load value: 100.0 %
Vehicle speed: 32 km/h
Coolant temperature: 85 °C
Intake air temperature: 43 °C
Voltage terminal 30: 13.660 V
Crankshaft speed (RPM): 3813.5 /min
Vehicle speed: 31.29 km/h
Mean injection quantity: 61.51 mg/stroke
Fuel temperature: 29.4 °C
Fuel high pressure: actual: 2e+006 hPa
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Coding: 1B6D00
Shop #: WSC 06335 000 00000
VCID: 7BF5DF6EFA14F15396-802E
Part No SW: 8K0 907 064 AE HW: 8K0 907 064 AE
Component: BCM2 1.1 H71 0134
Coding: 071200
VCID: 73E5F74ED244B913CE-8026
Subsystem 1 - Part No SW: 8T0 959 754 K HW: 8T0 959 754 K
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000026984017
Component: ELVAUDIB8 H35 0039
Serial number: 0208000027874003
00193 - Rear Right Door Handle Touch Sensor (G418)
007 - Short to Ground
Fault Status: 01100111
Reset counter: 177
Mileage: 249458 km
Date: 2022.08.09
Time: 10:42:27
03287 - Sensors for Contact with Door Handles
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 177
Mileage: 249458 km
Date: 2022.08.09
Time: 12:48:15
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 P HW: 4E0 035 729 A
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 331FP087526435
Coding: 0001002
VCID: 46837E9A31567CBBB9-8012
Subsystem 1 - Part No: 8T0 919 609 C
Subsystem 2 - Serial number: 00000000106537
Subsystem 3 - Serial number: 0127.06.080000000100010349ÿ
Subsystem 4 - Serial number: 010349ÿ
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8T2 820 043 P HW: 8T2 820 043 P
Component: KLIMA 3 ZONEN H05 0120
Revision: D3000000 Serial number: 0113.03.080169
Coding: 36040002
VCID: 3F8D6B7EAE8C2D73FA-806A
Part No SW: 8K0 907 063 HW: 8K0 907 063
Component: BCM1 1.0 H22 0253
Revision: 01022001 Serial number: 00000000069980
Coding: 690040B10034A7311E01000000005F5F009D864800000163000000
VCID: 6CD7EC328F7A66EB0F-8038
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250608 H05 0060
Serial number: SWFBIE 0000220
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10167689
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000000207080408
Subsystem 4 - Part No SW: 8K0 907 410 HW: 8K0 907 410
Component: EHL205.06.02K H02 0010
Subsystem 5 - Part No SW: 8K0 959 772 HW: 8K0 959 772
Component: SLR-B8 H05 0002
Serial number: 1100054273
Coding: 4F0000
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043002 Serial number: AUZ5ZBH8477543
VCID: 2B552F2E8AF4A1D346-807E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7301180
Coding: 0000001
VCID: 2447C412E72A6EAB87-8070
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 E HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0020
Revision: 11001001 Serial number: 52840818201462
Coding: 300003
VCID: 3B751F6EBA943153D6-806E
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 HW: 8K0 907 561
Component: ACC2 H07 0080
Coding: 0079B6
VCID: 6FEDFB3EBE6C9DF32A-803A
Fault Status: 00101101
Fault Frequency: 8
Reset counter: 221
Mileage: 249461 km
Date: 2022.08.09
Time: 14:01:42
Temperature: 34.0°C
Voltage: 13.95 V
Bin. Bits: 00001
Hex Value: 0x044B
Hex Value: 0x0012
Speed: 54.0 km/h
Lateral Accel.: -0.25 m/s^2
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0044
Revision: 00000000 Serial number: 11060803900001
Coding: 070181
VCID: 70EFF842A352820B33-8024
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD16ZBBL
Coding: 30373434363030303030554A3052384B3053
VCID: 3C771C72B79A366BDF-8068
Serial number: 6334MSME3B004F46G
Serial number: 6344MSME374210786
Serial number: 6352QSME7E5B3143P
Serial number: 6362QSME7337173DM
Serial number: 63732SME726D310F3
Serial number: 63832SME7D2D7965J
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HFO000AJ
Coding: 00009F
VCID: 3E73167AA986247BF1-806A
Component: E221 - MFL H01 0003
Part No SW: 8K0 920 980 G HW: 8K0 920 980 G
Component: KOMBIINSTR. H14 0216
Revision: 00300000 Serial number: 6YM2APE38
Coding: 233D110077003600010401
Shop #: WSC 06335 123 12345
VCID: 36630E5A81B6EC3B29-8062
00438 - Fuel Supply Sensor 2 (G169)
Fault Status: 00101010
Reset counter: 217
Mileage: 249458 km
Date: 2022.08.09
Time: 11:18:47
00771 - Fuel Level Sensor (G)
Reset counter: 217
Mileage: 249458 km
Date: 2022.08.09
Time: 11:19:30
Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0092
Revision: FB402044 Serial number: 4400F0852881C5
Coding: 000303
VCID: 4A9B4AAAE54E98DB5D-801E
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18027E5A100608
Part No SW: 8K0 907 144 B HW: 8K0 907 144 B
Component: DYNAMIKLENK. H05 0490
Revision: 50000003 Serial number: --------------
Coding: 0C0000
Shop #: WSC 06334 000 00000
VCID: 2E53263A79E6D4FB61-807A
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Component: SG ext.Player H15 0850
Revision: 00000000
VCID: 2B552F2E4AF4A1D346-807E
Part No SW: 8K0 959 760 A HW: 8K0 959 760 A
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001078767
Coding: C0781B000F0000000000
VCID: 387F00628BA21A4B3B-806C
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 333FZ087585168
Shop #: WSC 00022 210 90990
VCID: 306F3842A3D2C20B73-8064
Address 3C: Lane Change Labels: None
Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 009 014-13
Coding: 0001102
VCID: 36630E5A41B6EC3B29-8062
Subsystem 1 - Part No: 8K0 907 568 B
Component: J0770_SWA_Slave_H01 0040
Subsystem 2 - Serial number: 6PZ 009 014-33
Subsystem 3 - Serial number: 5F07.07.0800H010003CD10096ÿ
Subsystem 4 - Serial number: D10096ÿ
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007186020
Coding: 011012205E01410001
Fault Status: 01101100
Reset counter: 177
Mileage: 249450 km
Date: 2022.08.09
Time: 10:26:11
Revision: 00002001 Serial number: 0112495760
Coding: 013B0E22203974C1032002
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000042563
Subsystem 2 - Part No: 8K0 951 177
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814001682600
Coding: 030101
Shop #: WSC 12336 024 394758
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007375726
Reset counter: 177
Mileage: 249450 km
Date: 2022.08.09
Time: 10:26:11
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000162366
VCID: 31693D4668D8CB037C-8064
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336G.087573961
Coding: 0000001
VCID: 2E53263AB9E6D4FB61-807A
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 D HW: 4E0 919 148
Component: R78 TVHybridDVB 0440
Revision: R0H06000 Serial number: 76300801661001
Coding: 0000203
02283 - Video Connection to Output [End Unit]
Reset counter: 219
Mileage: 249487 km
Date: 2022.08.10
Time: 14:49:26
Address 5C: Lane Maintain. Labels: None
Part No SW: 8K0 907 217 A HW: 4E0 907 217 C
Component: J759 LDW 0070
Revision: 00H07012 Serial number: 20020841100018
Coding: 0003201
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007387997
Coding: 010012204001210001
VCID: 7F0D2B7EEE0CED73BA-802A
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000804030004
Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J85904N
Coding: 1023007
VCID: 377D035E46BC153332-8062
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8K9 827 851 HW: 8K9 827 851
Component: J605 Master H24 0220
Revision: -------- Serial number: 8K9827851
Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852
Component: J756 Slave H24 0220
Serial number: 8K9827852
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007351987
VCID: 7EF3D67AE906E47BB1-802A
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H11 0960
Revision: 00H11000 Serial number: 00000007581773
Coding: 0020001
End-------------------------(Elapsed Time: 05:18)--------------------------
