AUDI A4 2009 3.0L TDI V6 LOW AND HIGH FUEL PRESSURE FAULT
stureef
C?ID=229688
HI WONDERING IF ANYBODY COULD HELP ME OUT WITH MY AUDI PLEASE? IT KEEPS GOING INTO LIMP MODE UNDER ACCELERATION AND LOGGING HIGH AND LOW FUEL PRESSURE FAULTS. I HAVE CHANGED FUEL FILTER, TOOK FUEL SAMPLE, CHANGED PRESSURE REGULATOR ON RAIL, CARRIED OUT A LEAK OFF TEST ON INJECTORS. NOT SURE WHERE TO GO NEXT, ANY HELP WOULD BE APPRECIATED
Monday,15,August,2022,13:49:11:61841
VCDS Version: 21.3.0.0
VIN: WAUZZZ8K09A061893   License Plate: LT58ESO
Mileage: 249490km-155025mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 0F 10 13 14 15 16 17 19 1B 1E 36 37 3C
          42 46 47 52 53 56 57 5C 62 67 6C 6D 72 77
VIN: WAUZZZ8K09A061893   Mileage: 249490km-155025miles
57-TV Tuner -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K2 907 401 A    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  X01 0006
   Revision: 15X01---
   Coding: 010C002C180F0218
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM30TDI0118K2907401A 001006
   ROD: EV_ECM30TDI0118K2907401A.rod
   VCID: 2B552F2E42F4A1D346-807E
5215 - Fuel Rail/System Pressure
          P0087 00 [167] - Too Low
                    Mileage: 249494 km
                    Date: 2022.08.15
                    Time: 13:34:18
                    Engine RPM: 627.50 /min
                    Normed load value: 45.1 %
                    Coolant temperature: 86 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 11.500 V
                    Unlearning counter according OBD: 80
                    Crankshaft speed (RPM): 627.5 /min
                    Vehicle speed: 0.00 km/h
                    Mean injection quantity: 12.89 mg/stroke
                    Fuel temperature: 31.2 °C
                    Fuel high pressure: actual: 107900 hPa
                    Rail pressure regulation: status-Bits 0-7: 00000101
                    Inj Crv st Inj Char Act Val 0-Bits 0-7: 00110100
5216 - Fuel Rail/System Pressure
          P0088 00 [036] - Too High
                    Mileage: 249494 km
                    Date: 2022.08.15
                    Time: 13:32:51
                    Engine RPM: 3813.50 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 32 km/h
                    Coolant temperature: 85 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 13.660 V
                    Crankshaft speed (RPM): 3813.5 /min
                    Vehicle speed: 31.29 km/h
                    Mean injection quantity: 61.51 mg/stroke
                    Fuel temperature: 29.4 °C
                    Fuel high pressure: actual: 2e+006 hPa
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Coding: 1B6D00
   Shop #: WSC 06335 000 00000
   VCID: 7BF5DF6EFA14F15396-802E
   Part No SW: 8K0 907 064 AE    HW: 8K0 907 064 AE
   Component: BCM2 1.1      H71 0134
   Coding: 071200
   VCID: 73E5F74ED244B913CE-8026
   Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
   Serial number: 0508000026984017
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000027874003
00193 - Rear Right Door Handle Touch Sensor (G418)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 177
                    Mileage: 249458 km
                    Date: 2022.08.09
                    Time: 10:42:27
03287 - Sensors for Contact with Door Handles
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 177
                    Mileage: 249458 km
                    Date: 2022.08.09
                    Time: 12:48:15
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5170
   Revision: 00000000    Serial number: 331FP087526435
   Coding: 0001002
   VCID: 46837E9A31567CBBB9-8012
   Subsystem 1 - Part No: 8T0 919 609 C
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000106537
   Subsystem 3 - Serial number: 0127.06.080000000100010349ÿ
   Subsystem 4 - Serial number: 010349ÿ
   Part No SW: 8T2 820 043 P    HW: 8T2 820 043 P
   Component: KLIMA 3 ZONEN H05 0120
   Revision: D3000000    Serial number: 0113.03.080169
   Coding: 36040002
   VCID: 3F8D6B7EAE8C2D73FA-806A
   Part No SW: 8K0 907 063     HW: 8K0 907 063
   Component: BCM1 1.0      H22 0253
   Revision: 01022001    Serial number: 00000000069980
   Coding: 690040B10034A7311E01000000005F5F009D864800000163000000
   VCID: 6CD7EC328F7A66EB0F-8038
   Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 250608  H05 0060
   Serial number: SWFBIE 0000220
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10167689
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000207080408
   Subsystem 4 - Part No SW: 8K0 907 410     HW: 8K0 907 410
   Component: EHL205.06.02K  H02 0010
   Subsystem 5 - Part No SW: 8K0 959 772     HW: 8K0 959 772
   Component: SLR-B8  H05 0002
   Serial number:           1100054273
   Coding: 4F0000
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043002    Serial number: AUZ5ZBH8477543
   VCID: 2B552F2E8AF4A1D346-807E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276W7301180
   Coding: 0000001
   VCID: 2447C412E72A6EAB87-8070
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52840818201462
   Coding: 300003
   VCID: 3B751F6EBA943153D6-806E
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H07 0080
   Coding: 0079B6
   VCID: 6FEDFB3EBE6C9DF32A-803A
                    Fault Status: 00101101
                    Fault Frequency: 8
                    Reset counter: 221
                    Mileage: 249461 km
                    Date: 2022.08.09
                    Time: 14:01:42
                    Temperature: 34.0°C
                    Voltage: 13.95 V
                    Bin. Bits:    00001
                    Hex Value: 0x044B
                    Hex Value: 0x0012
                    Speed: 54.0 km/h
                    Lateral Accel.: -0.25 m/s^2
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364     HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0044
   Revision: 00000000    Serial number: 11060803900001
   Coding: 070181
   VCID: 70EFF842A352820B33-8024
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD16ZBBL
   Coding: 30373434363030303030554A3052384B3053
   VCID: 3C771C72B79A366BDF-8068
   Serial number: 6334MSME3B004F46G
   Serial number: 6344MSME374210786
   Serial number: 6352QSME7E5B3143P
   Serial number: 6362QSME7337173DM
   Serial number: 63732SME726D310F3
   Serial number: 63832SME7D2D7965J
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90315HFO000AJ
   Coding: 00009F
   VCID: 3E73167AA986247BF1-806A
   Component: E221 - MFL  H01 0003
   Part No SW: 8K0 920 980 G    HW: 8K0 920 980 G
   Component: KOMBIINSTR.   H14 0216
   Revision: 00300000    Serial number: 6YM2APE38
   Coding: 233D110077003600010401
   Shop #: WSC 06335 123 12345
   VCID: 36630E5A81B6EC3B29-8062
00438 - Fuel Supply Sensor 2 (G169)
                    Fault Status: 00101010
                    Reset counter: 217
                    Mileage: 249458 km
                    Date: 2022.08.09
                    Time: 11:18:47
00771 - Fuel Level Sensor (G)
                    Reset counter: 217
                    Mileage: 249458 km
                    Date: 2022.08.09
                    Time: 11:19:30
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0092
   Revision: FB402044    Serial number: 4400F0852881C5
   Coding: 000303
   VCID: 4A9B4AAAE54E98DB5D-801E
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 18027E5A100608
   Part No SW: 8K0 907 144 B    HW: 8K0 907 144 B
   Component: DYNAMIKLENK.  H05 0490
   Revision: 50000003    Serial number: --------------
   Coding: 0C0000
   Shop #: WSC 06334 000 00000
   VCID: 2E53263A79E6D4FB61-807A
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B552F2E4AF4A1D346-807E
   Part No SW: 8K0 959 760 A    HW: 8K0 959 760 A
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001078767
   Coding: C0781B000F0000000000
   VCID: 387F00628BA21A4B3B-806C
   Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1050
   Revision: 00000000    Serial number: 333FZ087585168
   Shop #: WSC 00022 210 90990
   VCID: 306F3842A3D2C20B73-8064
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0001102
   VCID: 36630E5A41B6EC3B29-8062
   Subsystem 1 - Part No: 8K0 907 568 B
   Component: J0770_SWA_Slave_H01 0040
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F07.07.0800H010003CD10096ÿ
   Subsystem 4 - Serial number: D10096ÿ
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007186020
   Coding: 011012205E01410001
                    Fault Status: 01101100
                    Reset counter: 177
                    Mileage: 249450 km
                    Date: 2022.08.09
                    Time: 10:26:11
   Revision: 00002001    Serial number: 0112495760
   Coding: 013B0E22203974C1032002
   Component: GTO BF  H06 0040
   Serial number: 00000000000000042563
   Subsystem 2 - Part No: 8K0 951 177
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814001682600
   Coding: 030101
   Shop #: WSC 12336 024 394758
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007375726
                    Reset counter: 177
                    Mileage: 249450 km
                    Date: 2022.08.09
                    Time: 10:26:11
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000162366
   VCID: 31693D4668D8CB037C-8064
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336G.087573961
   Coding: 0000001
   VCID: 2E53263AB9E6D4FB61-807A
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 D    HW: 4E0 919 148
   Component: R78 TVHybridDVB     0440
   Revision: R0H06000    Serial number: 76300801661001
   Coding: 0000203
02283 - Video Connection to Output [End Unit]
                    Reset counter: 219
                    Mileage: 249487 km
                    Date: 2022.08.10
                    Time: 14:49:26
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8K0 907 217 A    HW: 4E0 907 217 C
   Component: J759  LDW           0070
   Revision: 00H07012    Serial number: 20020841100018
   Coding: 0003201
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007387997
   Coding: 010012204001210001
   VCID: 7F0D2B7EEE0CED73BA-802A
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H46 0630
   Revision: 00000000    Serial number: 00000804030004
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J85904N
   Coding: 1023007
   VCID: 377D035E46BC153332-8062
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851     HW: 8K9 827 851
   Component: J605  Master  H24 0220
   Revision: --------    Serial number: 8K9827851
   Subsystem 1 - Part No SW: 8K9 827 852     HW: 8K9 827 852
   Component: J756  Slave  H24 0220
   Serial number: 8K9827852
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007351987
   VCID: 7EF3D67AE906E47BB1-802A
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 C    HW: 4F1 862 335
   Component: BTA             H11 0960
   Revision: 00H11000    Serial number: 00000007581773
   Coding: 0020001
End-------------------------(Elapsed Time: 05:18)--------------------------
TFSI
Maryland, USA
C?ID=66650
   Revision: 15X01---
                    Mileage: 249494 km
                    Date: 2022.08.15
                    Time: 13:34:18
                    Mileage: 249494 km
                    Date: 2022.08.15
                    Time: 13:32:51
   Coding: 1B6D00
   Coding: 071200
                    Reset counter: 177
                    Mileage: 249458 km
                    Date: 2022.08.09
                    Time: 10:42:27
                    Reset counter: 177
                    Mileage: 249458 km
                    Date: 2022.08.09
                    Time: 12:48:15
   Coding: 0001002
   Coding: 36040002
   Coding: 00FD11
   Coding: 025028
   Coding: 4F0000
   Coding: 0000001
   Coding: 300003
   Coding: 0079B6
                    Fault Frequency: 8
                    Reset counter: 221
                    Mileage: 249461 km
                    Date: 2022.08.09
                    Time: 14:01:42
                    Temperature: 34.0°C
                    Voltage: 13.95 V
                    Bin. Bits:    00001
                    Hex Value: 0x044B
                    Hex Value: 0x0012
                    Speed: 54.0 km/h
   Coding: 070181
   Coding: 00009F
                    Reset counter: 217
                    Mileage: 249458 km
                    Date: 2022.08.09
                    Time: 11:18:47
                    Reset counter: 217
                    Mileage: 249458 km
                    Date: 2022.08.09
                    Time: 11:19:30
   Coding: 000303
   Coding: 0C0000
   Revision: 00000000
   Coding: 0001102
                    Reset counter: 177
                    Mileage: 249450 km
                    Date: 2022.08.09
                    Time: 10:26:11
   Coding: 030101
                    Reset counter: 177
                    Mileage: 249450 km
                    Date: 2022.08.09
                    Time: 10:26:11
   Coding: 0000001
   Coding: 0000203
                    Reset counter: 219
                    Mileage: 249487 km
                    Date: 2022.08.10
                    Time: 14:49:26
   Coding: 0003201
   Coding: 1023007
   Coding: 0020001
Have you checked the fuel lines for kink/crashed under the car? Using VCDS take MVBS on the rail pressure and accelerator pedal positions while driving (of course you need a second person to help with scanner work for safety reasons) and see how pressure changes with regards to veh speed and post results or analyze the trend to be sure vehicle load demand is inline or not with fuel delivery etc.
stureef
C?ID=229688
stureef
C?ID=229688
Hi i have checked all fuel lines, had tank pump out and checked for restrictions, all ok. will be road testing tomorrow with vcds to get some data thanks for reply
HMC
C?ID=28246
Hi stureef,
You have high and low pressure codes, with a strange reading on the high pressure freeze data. Have you checked the Fuel Pressure Sensor and wiring?
Regards HMC
JMR
Romania
C?ID=432218
yeap, check that FRP sensor...it reads crap
golfi_vend
Tartu, Estonia
C?ID=195131
On 176kw for some reason the valve on HPFP has gone bad many times.
Not really a way to test.
stureef
C?ID=229688
Thank you for the reply's, we have swapped the fuel rail pressure sensor and the rail pressure regulator but that makes no difference.
could the pump metering valve cause this issue?
JMR
Romania
C?ID=432218
An unregulated diesel pump makes about 1500 + bars . So as it spins and creates pressure that pressure is then regulated to whatever the ecu needs (200-300 bars for start...and it then can fluctuate between idle and wot anywhere up to 1000 -1500 bars i think. Some cars have two regulators ( one on the HPFP and one on the actual rail , more commom on coreean/japanese diesel engines ). Usually a vag will come with a frp and a pressure regulating valve mounted on the pump. IIRC i think i ve seen couple newer than 2010 which will have 2 regulating valves. It is possible if you have 2 regulators ( one on pump and another on rail ) that one would be defective/gets stuck . I ve repaired a Mercedes Benz 2012 a while ago with common diesel injection ( cdi )that had a similar problem and had also 2 regulators. I ve found rust and dirt inside one of them , the one on the ramp. After a cleaning the errors disappeared and car started functioning proper. So , take them out and check for rust , dirt , metal shavings..
stureef
C?ID=229688
hi again, i have now replace both regulators, the one on the rail and the one on the pump but the problem is still there, it seems to throw high pressure fault code first.
any more ideas?
many thanks
If you have replaced the pressure regulator, you have to question if the sensor on the left rail is telling the truth BUT your car does have the trouble prone pre 11/2010 pump.
stureef
C?ID=229688
why would that throw high pressure? surely a troublesome pump would throw low pressure?
also we have checked for particles in the fuel and there is no sign.
I did not word that well, horrendous head cold, have you replaced the pressure sensor?
stureef
C?ID=229688
Hi, yes we have replaced the rail pressure sensor, the rail regulator and the fuel pump metering valve.
JMR
Romania
C?ID=432218
me thinks that your ECU has Covid22 or something....
stureef
C?ID=229688
I’d not noticed that on the high pressure fault.
Has any one across that kind of data before??
JMR
Romania
C?ID=432218
It reads out of the chart
A high pressure pump on a diesel makes up to 1500 + bars of pressure and in hpa ( hectopascals ) that means upwards of 1500000 hectopascals. I don t know why it reads 2e+006 hpa unless something is askew there. That s why me thinks ecu sick perhaps.. On the low press fault it reads 107xxx hpa...which is about 107 bars ( which is low and even below the idle pressure ).
= 2,000,000 hpa or 2,000 bar. That seems in the right range. But don't ask me why the heck VW uses hpa as units for this when bar would be far more sensible, or why they spec'd a goofy exponential notation. Then again, there are also modules that show battery voltage in millivolts. It seems Herr Dr. Dipl. Ing. in the white lab coat who wrote the specs for this stuff has no common sense at all...?
  • Haha
Reactions: JMR
JMR
Romania
C?ID=432218
Well , i didn t take into account that 2e+006 would mean 2000 bars , i somehow calculated that to be out of specs by far more ;). At 2000 bars would be the maximum pressure ? Also , if the OP changed the frp , the regulator and the fuel metering valve...it lets one wonder if hpfp is out of whack mechanically ( the hydraulic head part of it , the one that makes the pressure ) but then it would be regulated by the metering valve and regulator ...or is the ecu reading bananas because it s sick ? OP , are the parts genuine ? If they are , have you looked into the basic settings or adaptations tabs for something that is called " injection quantity metering valve " learning ( something or other ). I know that on the 2.0 there is such a function which would relearn the idle /load pressure points when the car is not stable at idle or under load...
