Does my steering rack support lane keep assist?
brendan_
Boston, MA, USA
C?ID=516305
On a few online forums, I have seen that most recent VAG vehicles come with EPS (electronic power steering) from the factory. It is my understanding that this is a requirement for lane keep assist so that the wheel can steer itself. My 2015 Volkswagen Golf Sportwagen TDI did not come factory equipped with any ADAS features, but I am currently in the process of retrofitting lane keep assist using 3Q0980654. I have done some research, and found a few people who have retrofitted lane keep assist but they were not clear on if they had to do anything with the steering system. I unfortunately have not been able to find any conclusive answers online as to whether or not my steering rack can support lane keep assist, which is why I'm posting on here. I will also provide an auto-scan if that helps.
Wednesday,03,August,2022,18:21:26:55940
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version 22.3.1.4 (arm64)  HEX-V2 CB: 0.4615.4
VIN: 3VWCA7AU3FM515369   License Plate:
Mileage: 166597km-103518mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU3FM515369   Mileage: 166597km-103518miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9459
   Revision: 85H23---    CVN: B5ADD45238D3FF82B866C2AD
   Coding: 021D0012032410081000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B23395723E80893DAD-806F
   VINID: 0E69D34474650D67450450C624EBB8C5E7
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 166597 km
                    Date: 2022.08.03
                    Time: 18:19:36
                    Engine RPM: 772.00 /min
                    Normed load value: 31.4 %
                    Coolant temperature: 91 ∞C
                    Intake air temperature: 75 ∞C
                    Voltage terminal 30: 13.600 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 17
                    Acceleration: 0.000 m/s≤
Readiness: 0 0 0 1 1
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01503163011 CVN: 0000EF4F
   Shop #: WSC 00066 790 00218
   ROD: EV_TCMDQ250021.rod
   VCID: 2313E137BB585053F2D-8077
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 51085000000641
   Coding: 04FA6AA124210971007A020681CC2520562490004081A4B200630050C002
   VCID: 47CB55A76F205C734E5-8013
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Reset counter: 55
                    Date: 2022.08.03
                    Time: 18:19:34
   Revision: 00021000    Serial number: 0365009729
   Coding: 030C0C
   VCID: 3A2D3C532CD2319BC1B-806F
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104202100000000000000000000
   Shop #: WSC 01383 790 50316
   VCID: 05579FAF15AC8E63FC9-8051
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Revision: --------    Serial number: 86582903150149
   Coding: 0001184240C1804169E44000000403001808000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 49CF539F7934AA03581-801D
   Component: WWS    150327  043 0581
   Serial number:         150518181529
565764 - LED Light Bar
          B1664 31 [009] - No Signal
                    Reset counter: 55
                    Mileage: 166597 km
                    Date: 2022.08.03
                    Time: 18:19:33
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 13.5 V
                    Outside temperature: 33.5 ∞C
   Serial number: 003GCR01MTC-
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J150002Q8BT0I
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 002 403 15
   Serial number: 3570000000053D41831A
   Subsystem 3 - Part No SW: -----------    HW: 480 002 403 15
   Serial number: 35800000000870718318
   Subsystem 4 - Part No SW: -----------    HW: 480 403 103 15
   Serial number: 3510002C71941315012E
   Subsystem 5 - Part No SW: -----------    HW: 480 403 103 15
   Serial number: 3520002A31A87850C1E5
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 15
   Serial number: 3550002C3194131211EO
   Subsystem 7 - Part No SW: -----------    HW: 480 402 603 15
   Serial number: 3560002C31941313D38Y
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150407400739
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045182AB1E96B76BEB7-8051
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA5121A2180CF0502087E001000000000000000
   VCID: 6597BF2FF5EC6E635C9-8031
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 30041510000436
   Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07030
   GVL: 01503C0000000600400C00008000C80000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 71BFDB7F3124B2C3301-8025
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150000777580105164
   Coding: 31FFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0056486
   Revision: 00000000    Serial number: 15000072186002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431126B0EB6C7EB1B7-8061
   Serial number: 01071506050371
   Coding: 003113205000040000000000
   VCID: 43D341B75B18705392D-8017
   Serial number: 00000000000001068099
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   Serial number: 141016060509XD
   Coding: 003113205C00040000000000
   VCID: 42DD44B34402795B99B-8017
   Serial number: 00000000000001127988
   Coding: 091000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730200FF00000051220001001808001F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6C81CA0B16065F2B037-8039
   Subsystem 1 - Part No SW: 7C0 919 606     HW: 7C0 919 606
   Component: ABT_HIGH  H54 1031
   Serial number: VWZ8Z9SGY00Q5E
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:19, VBatt start/end: 13.7V/13.8V)-----------
Cuzoe
C?ID=279487
This post has a pretty recent auto scan of mine you can use for comparison. My car is a 2015 Golf TDI S, no ADAS from factory but several retrofits, including lane assist and parking aid. Both work and I have done no steering rack/module related upgrades.
brendan_
Boston, MA, USA
C?ID=516305
Thank you, I will take a look at this.
