- Nov 23, 2014
- 154
- 45
- Los Angeles CA.
- C?ID=242342
Issue is: Harsh Up/Down Shift from Transmission when Cold and Hot.
Hello. Question: When replacing Valve Body. what Adaptation am I able to do using VCDS? is there any information related to this transmission in Wiki?
also, have you guys read TSB 2012810/17
01-13-37 - Update Programming TCM and Valve Body Replacement. it didn't work for us. I like to hear you opinion about it, I like to Try VCDS to see we can fix this tranny issue.
regards Victor
regards Victor
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: 3VWGG71KX7M032686 License Plate: 5WFD887
Mileage: 88470mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWGG71KX7M032686 Mileage: 142380km-88470miles
01-Engine -- Status: Status: OK 0000
42-Door Elect, Driver -- Status: Status: OK 0000
46-Central Conv. -- Status: Status: OK 0000
62-Door, Rear Left -- Status: Status: OK 0000
72-Door, Rear Right -- Status: Status: OK 0000
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 Q HW: 07K 906 032 Q
Component: 2.5l R5/4V G 9650
Revision: --H01--- Serial number: VWZ7Z0F4483712
Coding: 0000003
Shop #: WSC 00066 000 00000
VCID: 377D176B46CED3999F5-8062
Part No SW: 09G 927 750 FL HW: 09G 927 750 FL
Component: AQ 250 6F 0920
Revision: 00H25000 Serial number:
Coding: 0000072
VCID: 000FBCB7538054216EF-8055
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8D7F4B6EFEEBD9575-806A
Part No: 1K0 820 047 FP
Component: Climatic PQ35 120 0606
VCID: 77FDD76B064E13995F5-8022
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 P HW: 3C0 937 049 P
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000425560
Coding: 14050E234004150007140000001400000008730B5C0000
VCID: 36631A6F41C42A91843-8063
Component: Wischer 180806 020 0501
Coding: 00038805
Shop #: WSC 00066
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D05JEE%
Coding: 0013889
VCID: 6CD7F8074F08A041A27-8039
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME10073638%
Subsystem 3 - Serial number: 6342MSME11235842+
Subsystem 4 - Serial number: 6351HSME0A200E171
Subsystem 5 - Serial number: 6361HSME0A3B204FD
Subsystem 6 - Serial number: 63727SME097F1430%
Subsystem 7 - Serial number: 63827SME0A031C02W
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
Component: J0527 035 0070
Coding: 0010021
VCID: 020BB6BF5D8C463178B-8057
Part No SW: 1K0 920 953 H HW: 1K0 920 953 H
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4483712
Coding: 0023203
Shop #: WSC 22161 067 57207
VCID: 306F2C77A3A004A1DEF-8065
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066260210
Coding: 3FBF034007001002
VCID: 2C5738078F886041E27-8079
Component: IMMO 3HL 1610
Shop #: WSC 22161 444 84538
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1125
Revision: 12006001 Serial number: 00000022968802
Coding: 0001205
VCID: 3B750B5B7AE6F7F97BD-806E
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 3467206757B83881BA7-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 74E7E067173878817A7-8021
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1125
Revision: 12006001 Serial number: 00000520368723
Coding: 0001204
VCID: 3C7708477FE8F0C1727-8069
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0016
Revision: 00014000 Serial number: VWZ4Z7F6156601
Coding: 0040401
VCID: 1E33E2CFC93482D17C3-804B
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000374665
Coding: 0001168
VCID: 3E73024F69F4E2D15C3-806B
Component: RDK 0420
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12004001 Serial number: 00000000302676
Coding: 0001168
