P0299 - Actuator adjustment -
JUSTRS
Belgium
C?ID=292518
Bonjour à tous,
désolé pour mon anglais, je vous écris de Belgique....
j'ai un RS6 C7 - Perf - 2017
J'ai un P0299 - Turbocompresseur/Compresseur A Underboost
J'ai changé l'actionneur car ceux en plastique d'origine se sont cassés. Maintenant est en aluminium.
Malheureusement à haute vitesse, seul, j'ai l'erreur de code qui revient. Je voudrais vérifier le réglage de la tringle qui je pense n'est pas correct.
Je ne sais pas comment les définir avec le VCDS et avoir les valeurs d'origine.
Pourriez-vous m'aider
Merci
Quintus Rotam
EU
C?ID=490177
Hi,
There's no reason to apologize for your English.
Really, none whatsoever.
On a serious note, I think your Google translation failed to transfer properly to this forum, I don't see it.
While you're at it, maybe you could post an Auto-Scan of your car, made by using the English language version of VCDS, to help other forum members help you.
JUSTRS
Belgium
C?ID=292518
Sorry 🙈
Hi there,
sorry for my English, I am writing to you from Belgium....
I have a RS6 C7 - Perf - 2017
I have a P0299 - Turbocharger/Compressor A Underboost
I changed the actuator because the original plastic ones broke. Now is aluminum.
Unfortunately at high speed alone I have the code error coming back. I would like to check the adjustment of the rod which I think is not correct.
I don't know how to set them with the VCDS and have the original values.
Could you help me
From @Quintus Rotam , post #2
While you're at it, maybe you could post an Auto-Scan of your car, made by using the English language version of VCDS, to help other forum members help you. (HERE ABOVE)
Please click (hover the mouse cursor over) on the words in the quote "post an Auto-Scan" above "(HERE)" !! ;)
JUSTRS
Belgium
C?ID=292518
Wednesday,10,August,2022,23:25:06:45906
VCDS Version: 22.3.1.4 (x64)  HEX-NET CB: 0.4615.4
VIN: WUAZZZ4GXHN900897   License Plate: JUSTFINE
Mileage: 103956km-64595mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 22 28 36 3B 3C 42 44
          46 52 53 55 5F 62 65 6C 6D 72 85 8B 8E 8F 90 BA 47
VIN: WUAZZZ4GXHN900897   Mileage: 103956km-64595miles
Address 01: Engine (------CWUC)       Labels: Redir Fail!
   Part No SW: 4G0 906 560 F    HW: 4H0 906 014
   Component: 4.0l V8TFSI / X63 0003
   Revision: NCX63---    CVN: 2FEB8938
   Coding: 122A00326546090B3000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM40TFS0114G0906560F 001004
   ROD: EV_ECM40TFS0114G0906560F.rod
   VCID: 2B16CBF042B662D74A-807E
   VINID: 9E546AAAA117A187890002091CE7A6B0F3
17876 - Exhaust Pressure Control Valve 2
          P049F 00 [047] - Malfunction
                    Mileage: 103898 km
                    Date: 2022.08.10
                    Time: 16:36:00
                    Engine RPM: 652.50 /min
                    Normed load value: 4.7 %
                    Coolant temperature: 80 �C
                    Intake air temperature: 45 �C
                    Voltage terminal 30: 12.934 V
                    Engine status: COENG_RUNNING
11226 - Boost Pressure Regulation
          P0299 00 [229] - Control Range Not Reached
                    Mileage: 103918 km
                    Date: 2022.08.10
                    Time: 20:42:38
                    Engine RPM: 6502.00 /min
                    Normed load value: 57.3 %
                    Vehicle speed: 164 km/h
                    Coolant temperature: 102 �C
                    Intake air temperature: 40 �C
                    Voltage terminal 30: 12.981 V
Readiness: 0110 1000
   Part No SW: 4G0 927 158 BH    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H19 1010
   Revision: --H19---    CVN: C4583776
   VCID: 75A22D88D4726427EC-8020
   Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
   Component: ESP9 Premium  H01 0100
   Coding: 64BF984926FD19929F00
   Shop #: WSC 02391 785 00200
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 42C88654D53C839F99-8016
   Part No SW: 4H0 907 064 HP    HW: 4H0 907 064 HP
   Component: BCM2 2.0      H61 0824
   Coding: 05A96F0E000000000000
   VCID: 7EB032A4E944277FBD-802A
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 08071600040090
   Coding: 680210780D0000
   VCID: 6A980EF48DCCBBDF71-803E
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001416783801
   Coding: 0105001440349FF2F90140C7A0001800CF9CC7082E08020180000894E10113020040002D0B0000
   VCID: 74A4108CD7087D2FDB-8020
   Component: WWS57X 160608  H38 0080
   Serial number:         160621152154
   Coding: 0045F7
   Serial number: 62014616
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 28 06 2016  00001331
   Component: EVLS-SG  H08 0300
   Serial number: WA127128000031316123
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: EF08483800PAG0MUFU03
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E04010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 291A31F8484A70C7B8-807C
10240 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_BLR_BLK8_31]
                    Reset counter: 97
                    Mileage: 103749 km
                    Date: 2022.08.08
                    Time: 08:53:14
                    Control Module temperature: 29 �C
                    Voltage terminal 15: 14.136 V
                    Velocity_vehicle_reference: 43.49 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.19 m/s�
Address 14: Susp. Elect.        Labels: None
   Part No SW: 4G0 907 376     HW: 4G0 907 376 A
   Component: J250 DRC FahrwerH02 0040
   Revision: 00000000    Serial number: 00894020429700
   Coding: 0000000
   VCID: 6B960BF04A36A2D70A-803E
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100AH8CX
   Coding: 30333130313730323536554A304C34473053
   VCID: 3B36FBB0B2D6F257DA-806E
   Serial number: 3575HRB405F44DAGCGFH
   Serial number: 3585HRB405B440UQ50LE
   Serial number: 3515JRB401655B78RHQG
   Serial number: 3525JRB401655B78MOPI
   Serial number: 3554VRB40025752KH9N8
   Serial number: 3564VRB400Q577JUII6C
   Revision: --------    Serial number: 90372PFT000GA
   Coding: 0000FD
   VCID: 373EE78086FED6373E-8062
   Subsystem 1 - Part No SW: 4G0 951 528 J    HW: 4G0 951 528 J
   Serial number: 28 05 2016  F0080956
   Part No SW: 4G0 920 931 R    HW: 4G0 920 931 R
   Component: TBenRdwAccNv  H14 0225
   Revision: 11001108    Serial number: 658060716596026
   Coding: 138F910BAFD500080D0400
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 3522ED8894F224272C-8060
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002306595
   Coding: C0ED07481C
   GVL: FD8DCCCCDCAB600D41840000
   VCID: 3D32F5A8ACC2FC67E4-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 2248630704
   Voltage stabilizer:
   Serial number: 1604140000000000027D
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 010100
   VCID: 3A38FEB4B5ECCB5FC1-806E
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 002706160001209
   VCID: 281C34FC534049CFA7-807C
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 06071600041127
   Coding: 20
   Revision: AA000000    Serial number: 00000289895399
   Shop #: WSC 38530 002 1048576
   VCID: 77BE2780C67E1637FE-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E029D0$
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 373EE7808EFED6373E-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0409898161
   Coding: 040311
   VCID: 393AE1B8B8EAC047C8-806C
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0408704370
   Coding: 040311
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F16015E00628002080013
   VCID: 45C29D48CC12B4A7BC-8010
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000010065
   Coding: 011001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A38FEB4BDECCB5FC1-806E
   Revision: 00002001    Serial number: 0410616577
   Coding: 013A0E20A0B93095C33009840E0312470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST0012EHOM00000
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00023114847
   Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST0012EHIG00000
   Coding: 801F00
03932 - Real Lid/Hatch Opening Sensor
                    Reset counter: 42
                    Mileage: 103248 km
                    Date: 2022.07.27
                    Time: 20:09:13
   Component: TSG BF        H03 0511
   Coding: 011F16015E00628002080002
   VCID: 46C09A44F114BFBFB5-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001904370
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 312AD998609A080770-8064
   Coding: 04FA0A202A170200
   VCID: 3424D08C9F883D2F1B-8060
   Coding: E01F00
   Coding: E01F00
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
5353456 - Fog mode active
          C118E 00 [008] - -
                    Reset counter: 102
                    Mileage: 103457 km
                    Date: 2022.07.31
                    Time: 21:38:03
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 044 F    HW: 4G1 035 044 D
   Component: MU-H-LN-EU    052 0670
   Serial number: A734G0G7504286
   Coding: 017562010000000013110002000A00102F0008E5F17001009F
   VCID: 220826D4357CA39FF9-8076
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY805KHN
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349PFU0004T
   Compact disc data bank:
   Component: Gracenote2---  --- 1013
   Component: TSG HL        H03 0511
   Coding: 010F14004000628002080002
   VCID: 49DA9178E00A50C758-801C
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000029264
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A18CEF44D4C7BDFB1-807E
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0178468
   Coding: 0218000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
   VCID: 2F2EDFE076AE1EF766-807A
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 176601680
   Coding: 093205C030
   ROD: EV_HDSGAu571.rod
   VCID: 3620EA8489F42F3F25-8062
   Component: TSG HR        H03 0511
   Component: DPC-SG        H27 0081
   Coding: 6A160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C14C8EC47B865EF43-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 271E37C05E5E46B7AE-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002452706167
   Coding: 04C0BB1B1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 3228D694659C331F09-8066
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813007039701
   ROD: EV_AEMLearAU64X.rod
   Part No SW: 4G1 035 466 D    HW: 4M1 035 466
   Component: 8RF           H10 0592
   Serial number: 2530196721
   Coding: 0175620A00A2AAAAAA0000010000
   ASAM Dataset: EV_AMPMst24C1Gen2BAO 001002
   ROD: EV_AMPMst24C1Gen2BAO_AU57.rod
End----------(Elapsed Time: 02:35, VBatt start/end: 12.2V/12.1V)-----------
JUSTRS
Belgium
C?ID=292518
Hi,
Thanks for your reply.
this fault is due to a box that opens and closes the exhaust valves. My problem is the following: boost pressure
I need to adjust the discharge of actuator.
Although the EA888 based engines set this type of fault code
... and require/support Basic Settings and Advanced Measuring values for the electromechanical turbocharger actuator this engine does not.
Instead, I believe your engine type uses traditional vacuum/pressure operated wastegates without any position sensors. For that reason the underboost DTCs are not specific to the adjustment .. and most of the time on this 4.0L the turbos are to blame but the wall of possible causes on this page does apply:
I see the Left and Right bank "Vacuum unit for exhaust gas turbocharger" in the parts catalog but I do not see any mention of those repair kits or manual adjustment specifications in the repair manual. In the event that our Edition 07.2019 repair info is too old (and pre-dates the availability of parts that were sold separately) I would encourage you to check RoW market erWin Audi based on VIN if you haven't already. We have them linked here:
I don't believe VCDS will be of much assistance since position sensors aren't installed on the turbos. You however may find it helpful to see where the actual and specified boost values are while data logging. In that case these groups may be most useful:
[*IDE00190*] Charge air pressure: specified value
[*IDE00191*] Charge air pressure: actual value
[*IDE03279*] Charge air pressure 2: actual value
[*IDE04002-ENG167462*] Charge air pressure control
Vehicle Identification No. WUAZZZ4GXHN900897
Model Audi RS6 plus Avant quattro 4.0 RS6
Date of production 25.07.2016
Year 2017
Sales type 4GDRRA
Engine Code CWUC
DJ9 8-cylinder SI engine 4.0 l/445 kW biturbo, FSI, homogeneous base engine is TV7
Transmission Code SHD
JMR
Romania
C?ID=432218
JUSTRS
Belgium
C?ID=292518
Year 2017
Sales type 4GDRRA
Engine Code CWUC
Many thanks Dana !
The log from this.
Saturday,13,August,2022,13:55:17:45906
Mileage: 104182km-64735mi   Repair Order:
                Address 01: Engine  (4G0 906 560 F)
13:55:10
  IDE00190   Charge air pressure: specified value 1418.28 hPa
  IDE00191   Charge air pressure: actual value 962.97 hPa
  IDE03279   Charge air pressure 2: actual value 959.69 hPa
  IDE04002   Charge air pressure control BP_A act:96.3 kPa / BP_B act:96.0 kPa
My problem is that I don't always have the default.
Sometimes high revs, sometimes low revs. I have the impression that the adjustment of the actuator is correct.
I replaced all, map sensor, N75 and I'm sure the turbos are fine.
I received a note from Audi for a return (21H7 - Oil strainer)
Do you think that a lack of oil in the turbos could give this error code?
Thank you
JMR
Romania
C?ID=432218
Yes, I think
For info the car have 947HP and 1175Nm
:) I'll give you 3000 euros for it and save you much money on the upkeep of this car. :) That is way too much power for a daily driver. I'd say 200-300 hp it's plenty for a car..everything over it is just for races and fun ...
  • Agree
Reactions: JMR
JUSTRS
Belgium
C?ID=292518
:) Je vous en donne 3000 euros et vous économisez beaucoup d'argent sur l'entretien de cette voiture. :) C'est beaucoup trop de puissance pour un conducteur quotidien. Je dirais que 200-300 ch, c'est beaucoup pour une voiture... tout ce qui est dessus est juste pour les courses et le plaisir...
Thank you for your opinion, but it's been 3 years that I've had fun riding it every day. And for the races I have a racing car prepared for that. And indeed, pleasure is priceless
Hmm, that may be exactly why we have independent (non-dealer) shops reporting a pair of 4.0T turbos is a 40K service item! :banghead:
This is the US market data but PDF pages 3 and 4 point in that direction:
https://static.nhtsa.gov/odi/rcl/2022/RCLRPT-22V178-6818.PDF
I couldn't locate the official Audi TSB/Recall doc but I would schedule for that repair with the MIL on (i.e. do not clear those codes) and directly ask them if they are replacing the turbos.
Edit. Found this as well but it isn't the detail packed TSB/Recall doc either: https://static.nhtsa.gov/odi/rcl/2022/RIONL-22V178-0825.pdf
Instead, that's the letter that US market owners received prior to a repair being available.
