Hi form the UK
zola1
C?ID=112658 (NRRT)
Hi,
Just joined the forum, i sent a message to Andy Smith , he suggested posting it here....i wondered if anyone can advise :-
>>> Hi,
>>> Can you help :-
>>> I am enquiringly to see if there are any updates on the latest software
>>> to incl the Engine Management Output Tests on Skoda Fabia 2004myr 1.2
>>> 12Valve.
>>> Any help would be much appreciated.
>>> Kind Regards
>>> Derrick
>>> DFW Auto Electrical Services Ltd.
> Hi Andy,
> Thank you for response, please find enclosed AutoScan.
> I am unsure as to the possible content of the Output Tests, but in the
> past i have found this function very useful for example with remote
> cylinder cut for detecting misfires etc.
> Kind Regards
> Derrick
Log-KX04 UCD-TMBPY46Y533867733-59401.txt
Sunday,13,April,2014,12:50:34:30340
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: TMBPY46Y533867733   License Plate: KX04 UCD
Mileage: 59401   Repair Order: ERNIE
                  Address 01: Engine       Labels: Redir Fail!
 Control Module Part Number: 03E 906 033 A
    Component and/or Version: 1.2l/4V SIMOS3  00HS4672
             Software Coding: 00031
              Work Shop Code: WSC 13765
             Additional Info: TMBPY46Y533867733     SKZ7Z0C2060243
                        VCID: 1E37A6949AC151EE89B-5102
16685 - Cylinder 1
             P0301 - 35-10 - Misfire Detected - Intermittent
Readiness: 1010 0101
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBPY46Y533867733   Mileage: 95590km/59396miles
    Part No: 03E 906 033 A
    Component: 1.2l/4V SIMOS3  00HS4672
    Coding: 00031
    Shop #: WSC 13765
    VCID: 1E37A6949AC151EE89B-5120
16685 - Cylinder 1
             P0301 - 35-00 - Misfire Detected
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ABS.lbl
    Part No: 6Q0 907 379 G
    Component: ABS 5.7     FRONT   V30
    Coding: 00044
    Shop #: WSC 13765
    VCID: 418D3DE84BFF4E16D49-5120
             79-10 - Please Check Fault Codes - Intermittent
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
    Part No: 6Q1 937 049 C
    Component: 00 BN-SG.           1S33
    Coding: 25610
    Shop #: WSC 13765
    VCID: 3B714F00291324C68E5-5120
    Part No: 1C0 909 601 A
    Component: 11 AIRBAG VW51      0008
    Coding: 12593
    Shop #: WSC 13765
Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
    Part No: 6Y0 920 960 M
    Component: KOMBI+WEGFAHRSP VDO V07
    Coding: 00401
    Shop #: WSC 24066
    VCID: 46872EF462D1692EE1B-5120
    Part No: 6N0 909 901
    Component: 31 GATEWAY  CAN    1S33
    Coding: 00014
    Shop #: WSC 13765
    VCID: F0EB282CB0D5179EEB7-5120
    Part No: 6Q0 423 156 S
    Component: LenkhilfeTRW        V260
    Coding: 10140
    Shop #: WSC 13765
    VCID: 3F893B103D0B38E6A2D-5102
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
    Part No: 6Q0 959 433 E
    Component: 31 Komfortgerát     0002
    Coding: 00067
    Shop #: WSC 13765
    VCID: 3D75411837072AF6B01-4AE6
    Subsystem 1 - Part No: 6Q2959802A
    Component: 31 Tõrsteuer.FS TFK 0004
    Subsystem 2 - Part No: 6Q2959801A
    Component: 31 Tõrsteuer.BF TFK 0004
Address 56: Radio        Labels: 1U0-035-156.lbl
    Part No: 6Y0 035 156 D
    Component:  Radio YD5          0010
    Coding: 00400
    VCID: 37795330153B00A66AD-49D8
Also is it possible to attach a file/picture form my pc, e.g a browse select and attach button, newbie so i might have missed something obvious ?
cheers
Derrick
I'm not sure I understand what you're asking with:
if there are any updates on the latest software to incl the Engine Management Output Tests on Skoda Fabia 2004myr 1.2 12Valve
Are you asking whether Skoda has published any newer software for this ECU?
Or are you asking whether VCDS support something for this ECU that you think is missing?
As for attachments on this forum, no, there's no mechanism in place for that. If you want to post a picture, go to http://imgur.com/, use the Upload function there, and then post the picture here by using IMG tags, like this:
zola1
C?ID=112658 (NRRT)
Hi Uwe,
Thank you for your response.
The second one
"Or are you asking whether VCDS support something for this ECU that you think is missing?"
I was looking through the Output Tests option on VCDS, just seeing if there were some output tests in the Engine section that were available ..e.g a remote cyl cut for diagnostics of misfires etc or ?.
please see screenshot below for the screen that came up when i selected Output Tests.
all
Derrick
Your image doesn't show. The link you posted is to your "folder" on imgur.com rather than one particular image.
zola1
C?ID=112658 (NRRT)
oop's newbie with this ........try this
OK, "Function Not Available" when attempting Output Tests on an engine is usually due to the ECU objecting to the current conditions. On gasoline engines, the ECU will generally refuse to run Output Tests while the engine is running. It will also generally only run Output Tests once per ignition cycle, and you may even have to start the engine and then cycle the ignition off and back on to get the Output Test sequence to run.
zola1
C?ID=112658 (NRRT)
thanks Uwe, i'll try that sequence,
