New user from the UK
jordy_wd
Northern Ireland
C?ID=526131
Hello. I’ve owned VW group cars for approx 11 years now and have always borrowed VCDS off friends when I’ve needed it. I’ve decided to take the plunge and bought a second-hand HEX-V2. Will be registering it and upgrading to the 10-VIN version in the next week or so.
Car-wise I have a 2014 Skoda Octavia VRS TDI, based on the MQB platform.
So far I’ve been able to correct some erroneous trailer coding done by a friend, some minor lighting tweaks, enabled high beam assist, enabled traffic sign recognition, and enabled mirror-dip.
Does anyone know when I upgrade to the 10-VIN version, will I get 10 fresh VIN slots to use? For example I’ve already used 2 VINs on my 3-VIN cable, so will these count when I upgrade to the 10-VIN and only have 8?
Many thanks, and I look forward to contributing to the forum.
Reactions: JMR
The upgrade from a 3-VIN license to a 10-VIN license does not remove any of the VINs that have already been charged, so if two have already been used, you will have eight open ones.
jordy_wd
Northern Ireland
C?ID=526131
Many thanks for that. I have purchased the ownership transfer and VIN upgrade today.
Auto-scan posted below:
Tuesday,09,August,2022,06:44:15:31540
VCDS Version: 22.3.1.4  HEX-V2 CB: 0.4615.4
VIN: [hidden]   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69 A5 A9
VIN: TMBKK7NE4F0xxxxxx   Mileage: 142356km-88455miles
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EL    HW: 04L 907 309 D
   Component: R4 2,0L EDC   X22 7542
   Revision: 83X22---    CVN: 7ED3A2D0
   Coding: 11190012033501080000
   Shop #: WSC 92521 052 12345
   ASAM Dataset: EV_ECM20TDI01104L906021EL 002008
   ROD: EV_ECM20TDI01104L906021EL_SK37.rod
   VCID: 73B3DCC20B329BD3C2D-8026
   VINID: 91D49B6C77951160001420C31879F6F90F
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 61854000005022
   Coding: 1C0793915425096E007A060341C92938C92A9000608294F400630070C009
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44D14F1E1E1C6C6BAB7-8010
   Part No SW: 5E0 907 044 N    HW: 5E0 907 044 N
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 02110104000100011005000110101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 303913CEBAA4E0CB7FF-8064
   Air quality sensor:
   Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86581907140222
   Coding: 0F020B66C24722FB07A04082B11C07280000000000000000000000000000
   Shop #: WSC 73430 790 00161
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79AFEEEA295EE183881-802C
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140703  041 0570
   Serial number:         140708022021
   Coding: 0E4DFD
   Component: RLHS  037 0059
   Serial number: S4Y14M07D21H17M26S53
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1410524F1
   Serial number: 00000000000030191858
   Humidity sensor: interior:
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0048
   Revision: --------    Serial number: 39231419703182
   Coding: 0001150101
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   VCID: 3A2D31E66CD82A9BC1B-806E
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PDGZJJU
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B00F2377ACFB3B65-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 907 14
   Serial number: 3576U000000F3D144016
   Subsystem 2 - Part No SW: -----------    HW: 454 000 507 14
   Serial number: 3586U000000DD6013013
   Subsystem 3 - Part No SW: -----------    HW: 454 801 207 14
   Serial number: 3516R61001B04000000M
   Subsystem 4 - Part No SW: -----------    HW: 454 802 906 14
   Serial number: 3526R78F60D04000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 802 105 14
   Serial number: 3556V86F6B003000000D
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Revision: --------    Serial number: 18071404220547
   Coding: 1400
   VCID: 77ABE8D21F4AF7F3FE5-8022
   Part No SW: 5E0 920 947     HW: 5E0 920 947
   Component: KOMBI         204 4290
   Coding: 27AD09006984AE0001087A021000000000000000
   Shop #: WSC 73430 031 00161
   VCID: 698FBEAA59FE5103781-803C
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002223796
   Coding: 030100040F087300EF00026A080F00010001050000000000000000000000
   GVL: 01543C1000000000C08C10000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42DD49060408625B99B-8016
   Generator:
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Serial number: 000000000A2011260614
   Serial number: 1428593903
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000111140715
   Coding: 001C00208001040000001100
   Serial number: 00000000000003267211
   Coding: 1D0200
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 9103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 353722DA45C6C5E32C9-8060
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000111534605
   Coding: 001C00208E01040000001100
   VCID: 41DF460A010E7943801-8014
   Serial number: 00000000000003279086
   Coding: 050200
   Coding: 03DE02003F000000
   Shop #: WSC 73430 790 00063
   VCID: 40D9430E0A04704B8FF-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Component: MU-S-ND-ER    041 0490
   Serial number: S7F01607143599
   Coding: 03735201FF0000001111120100A800002F0001D60100010046
   Shop #: WSC 19460 666 12345
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 2615F5968860BE7B953-8072
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H60 0034
   Serial number: SKZ8Z9PT300602
   Subsystem 2 - Part No SW: 5E0 051 236 G    HW: -----------
   Component:  ECE 2019/20  --- 0081
          B201A 00 [009] - -
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0409994950
   Coding: 0101000000110000
   VCID: 3E253DF670F006BBFD3-806A
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000106201
   Coding: 0101010001030303000300000000010101
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B2334E263E21393DAD-806E
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 140620201151
End----------(Elapsed Time: 01:40, VBatt start/end: 12.3V/12.2V)-----------
Reactions: JMR
jordy_wd
Northern Ireland
C?ID=526131
@Uwe Apologies for the double post - I have now registered by transferring ownership. Could I be verified? Thanks in advance.
Looks like Uwe's on the case and I edited the 2nd instance of the full VIN in the scan.
