VW caddy MK4 Address 61 Battery Regulation
D3luded
England
C?ID=353973
Replaced an AGM battery recently with a new AGM battery and registered via VCDS, all ok.
In address 61 battery regulation for coding my code is 030F1873 everything seem correct except the last 2 digits (73).
The last two digits is for "Generator ratio", 73 is generator ratio 2.65 (3.6 V6 and V6 TFSI)
Is this correct as there is other options ie: 5A ratio 2.4 for all other engines + CFWA
64 ratio 2.5 (1.2l and 1.4 FSI)
76 ratio 2.68 (110A)
FE ratio 4.04 (140A)
58 ratio 2.38
I was unable to really find any information on this to see if its correct or not
Hope someone can shed some light
Cheers
Hi and welcome. Please post an Auto-Scan for context, so people can see how the car is equipped and configured.
D3luded
England
C?ID=353973
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
Mileage: 46270km-28750miles
Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 GT    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1774
   Revision: 8AH20---    CVN: 366C86B5B866C2AD
   Coding: 01110012042509090000
   Shop #: WSC 12345 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906016GT 001003
   ROD: EV_ECM20TDI01104L906016GR_001.rod
   VCID: 015F8749C18E0F63C01-8054
   VINID: 9E606AAAA09BA98A0108610114F126902E
15733 - SCR NOx Catalyst Bank 1
          P20EE 00 [096] - Efficiency too Low
   Revision: 00000000    Serial number: 40677000000018
   Coding: 1079409B9264A48408790277498725E3790000
   Shop #: WSC 35110 790 50316
   VCID: 3FDB41B1F7FAB993F65-806A
   Part No SW: 1K8 907 426 AM    HW: 1K8 907 426 AM
   Component: AC Manuell    H21 0909
   Revision: 00001002
   Coding: 0010004003
   VCID: 7EA5FCB5B070709BBD3-802A
   Part No SW: 5K0 937 085 AD    HW: 5K0 937 085 AD
   Component: BCM PQ35 B+   122 0184
   Revision: BB122001
   Coding: 411A583A8025086A088000829000006403010008424F8160648087000041
   Shop #: WSC 35110 377 08192
   VCID: 75B7E39985C633C3EC9-8020
   Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 14021  26  0512
   Coding: 009795
   Part No SW: 1K8 919 465 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0480
   Revision: --------    Serial number: 39261705504986
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14VW364GP00 001007
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   VCID: 372B2991DFCA81D33E5-8062
   Part No SW: 2K5 959 655 B    HW: 2K5 959 655 B
   Component: VW10Airbag00K H08 0018
   Revision: --------    Serial number: 003V10035C6I
   Coding: 00000000000000000000000000000000304B
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3B2335A1E3E2A5B3DAD-806E
   Serial number: 3497ARB400I599
   Serial number: 3507ARB400I599
   Part No SW: 8X0 953 501 D    HW: 5K0 953 569 AL
   Revision: FF010018    Serial number: 20140317201067
   Coding: 1082160000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Coding: 240000
   Part No SW: 2K5 920 966 C    HW: 2K5 920 966 C
   Component: KOMBI         H04 1107
   Coding: 410A021200
   VCID: 35372399C5C673C32C9-8060
   Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1682
   Revision:   H58       Serial number: 270217F1000919
   Coding: 357421
   Shop #: WSC 15271 003 1048576
   VCID: 79AFEFA9A9DE57A3881-802C
   Component: IMMO          H04 1107
   VCID: 6A8DC0E5DCF8EC3B71B-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71BFD789FDAE1FE3301-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 392F2FA9E55E97A3C81-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72BDD885F8A824FBC9B-8026
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     055 7085
   Serial number: 21021700011843
   Coding: 063307002800000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E050CF52090401B6D3-807A
0517 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
                    Reset counter: 37
                    Mileage: 42119 km
                    Date: 2021.09.28
                    Time: 13:49:38
                    Voltage terminal 30: 12.7 V
0522 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
                    Reset counter: 37
                    Mileage: 42119 km
                    Date: 2021.09.28
                    Time: 13:49:38
   Component: Batt.regelung H58 1682
   Coding: 030F1873
   VCID: 71BFD789F1AE1FE3301-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 75885800001702180F5E
End----------(Elapsed Time: 01:01, VBatt start/end: 14.6V/14.7V)-----------
If you do a search like this, you'll find scans from a number of other cars with that same engine and battery management. The first two I checked also have coding that ends in 73, so I don't think it's wrong. Feel free to check more of them yourself.
D3luded
England
C?ID=353973
Thankyou for your reply !
It seems this is pretty common then with same engine and battery management, just seems strange it wouldnt be on the 140 amp setting or similar
