Brake light switch touran golf mk5
UK Grant
C?ID=221647
Hello there this is my first time posting so do excuse me if i make some mistakes, for the last 3 years i have been trying to build a 2.0tdi dsg caddy starting from an 07 2k caddy introducing meny parts from an 06 touran and a further 07 touran, so far i have managed to get 80% of my vision compleate but am now finding some more dificult parts to figure out.
this specif falt that im tring to rectify is brake light fault the loom is from a 2007 touran where the B/S is located on the brake booster however the engin ecu cluster and BCM are all from a 2006 model where the brake switch is fitted to the brake pedal , my question is are both wired to the same location i have found relevent documentaion from erwin-VW but cant seem to find any deviation.
Saturday,06,August,2022,20:20:18:08740
VCDS Version: 22.3.1.4 (x64)
VIN: WVWZZZ1KZ8P008353   License Plate: CADDY 060822
Mileage: 131070km-81443mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76 7D
VIN: WVWZZZ1KZ8P008353   Mileage: 131070km-81443miles
25-Immobilizer -- Status: Not registered 0011
37-Navigation -- Status: Not registered 0011
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 HK    HW: 028 101 225 1
   Component: R4 2,0L EDC G000AG  7000
   Revision: 12345678    Serial number: XXXXXXXXXXXXXX
   Coding: 0000078
   Shop #: WSC 01324 785 00200
   VCID: 73E5C1AA12970C17C2-8026
   VINID: 9E69EAAAA05BA888000080C50C0763C5C1
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
                    Torque: 12.0 Nm
                    Voltage: 11.86 V
                    Bin. Bits: 00001110
                    Temperature: 59.4°C
                    (no units): 144.0
Readiness: 0 0 1 1 1
   Part No SW: 02E 300 042 G    HW: 02E 927 770 AE
   Component: GSG DSG         070 0918
   Revision: 04507000    Serial number: 00000508010704
   VCID: 173DD53A26AF80371E-8042
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0023238
   VCID: 71E9CBA2688B3E0730-8024
01486 - System Function Test Activated
   Part No: 1K0 907 044 AG
   Component: ClimatronicPQ35 066 0505
   VCID: 6CD7DAD64FA9D3EF03-8038
00402 - Auxiliary Air Heater Element (Z35)
00757 - Right Vent Temp Sensor (G151)
            010 - Open or Short to Plus
00797 - Sunlight Photo Sensor (G107)
00709 - Sunlight Photosensor 2 (G134)
            009 - Open or Short to Ground
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000005092623
   Coding: 00890F214104100064120C000000000000087B075C
   VCID: 2A5B1CCE85DD0DDFB1-807E
   Subsystem 1 - Component: Fehler Lin-Slave 01
02071 - Local Databus
                    Reset counter: 191
                    Mileage: 131074 km
                    Voltage: 11.85 V
01117 - Generator Terminal DF Load Signal
                    Fault Status: 01101000
                    Reset counter: 191
                    Mileage: 131074 km
                    Voltage: 11.85 V
                    Fault Status: 00101001
                    Reset counter: 231
                    Mileage: 131074 km
                    Voltage: 11.85 V
00483 - Control Module for Auxiliary Air Heater
                    Reset counter: 191
                    Mileage: 131074 km
                    Voltage: 11.85 V
                    Reset counter: 191
                    Mileage: 131074 km
                    Voltage: 11.85 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 191
                    Mileage: 131074 km
                    Voltage: 11.85 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD0EP0PU
   Coding: 0012345
   Shop #: WSC 35110 377 00158
   VCID: 7DF1E79224D34A67A4-8028
00591 - Seat Belt Switch; Driver (E24)
            007 - Short to Ground - MIL ON
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0003141
   Shop #: WSC 01279 785 00200
   VCID: 01099B62582B2E87C0-8054
   Component: E0221           007 0050
   Part No SW: 1K0 920 974 B    HW: 1K0 920 974 B
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G53NB8MJ
   Coding: 0000403
   Shop #: WSC 00671 210 95609
   VCID: 2D5117D2B4331AE754-8078
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001061200A8C
   Coding: 3F0F0F40057401
                    Reset counter: 191
                    Mileage: 131074 km
                    Time: 22:57:30
                    Reset counter: 191
                    Mileage: 131074 km
                    Time: 22:57:34
   Component: IMMO            VDD 1216
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 45782 km
                    Time: 15:15:55
01176 - Key
                    Mileage: 131074 km
                    Time: 22:57:28
Address 37: Navigation        Labels: 1T0-919-887.lbl
   Part No: 1T0 919 887 DX
   Component:      Navigation     0421
   Coding: 0000002
   Shop #: WSC 00445 210 83427
   VCID: 1B35C90ADA87E4573A-804E
No Faults Found
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1206
   Coding: 0000564
   Shop #: WSC 35110 377 08192
   VCID: 387F36864B71AF4F37-806C
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 336501AA52174C1702-8066
   Part No: 1K0 959 433 CP
   Coding: 808E0C087F2D0F0FC8DA031010C0
   VCID: 000F9E665321278FCF-8054
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000564
   VCID: 39793382707BB647C8-806C
Address 56: Radio        Labels: 1T0-035-095.lbl
   Part No: 1T0 035 095 X
   Component:        Radio        0421
   Coding: 0004402
   VCID: 4385516A02B7FC9792-8016
7 Faults Found:
00879 - Connection to Speaker Front Right
00880 - Connection to Speaker Rear Left
00881 - Connection to Speaker Rear Right
00857 - CD Changer Unit (R41)
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 02 Einparkhilfe     0101
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            014 - Defective
00437 - Rear Right Inner Parking Aid Sensor (G335)
            014 - Defective
00436 - Rear Left Inner Parking Aid Sensor (G334)
            014 - Defective
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            014 - Defective
Address 7D: Aux. Heat
End-------------------------(Elapsed Time: 02:15)--------------------------
NZDubNurd
New Zealand
C?ID=230482
There isn't a brake light switch fault showing? What is the actual problem you're having?
Have you changed ABS types? The ABS in the scan is a "ESP FRONT MK60" version, which Is more likely to have come from a Touran, than Caddy? The Caddy often had no ESP.
I would suggest coding it all correctly, before bothering with other faults - the fact it says "implausible signal" could be triggering other problems, or could be the cause of the brake lights not working as intended. Each of the systems has to have the correct parts and config. If the ABS is looking for different wheel speed sensors, or other modules with correct coding, but can't find them - it won't be happy!
The ABS is unhappy, as is the Cent. Elecs (local databus fault) and the CAN gateway (coding).
Some modules may need coding for what ABS is fitted (they may have coding independent of the ABS, for the ABS type) (possibly central elecs and cluster???).
Have you also made all the relevant wiring changes (like from the J519 for the difference between auto and manual?) then coded the module to suit?
Have you verified the real year of the donor cars (by VIN, not that irrelvant UK "plate" bullcrap). The scan VIN says 2008, but also appears to be from a Golf (Engine ECU?). The Cluster seems to be an IMMO4C type, which is generally 2007 onwards for MK5 based VW models.
I've never seen a Touran with a pedal mounted brake switch, but I've never seen a Touran that didn't have ESP either (I'm in NZ). I have a very early 2004 model, an early 2006 and a late 2006 (still prefacelift, but with "normal" wipers and later plastic inside etc) All have no pedal switch, but are ESP, obviously.
