B8 S4 Sport Differential Fault
LukeW
C?ID=494932
Morning All,
My first post here, only owned VCDS for a couple of days so pls excuse any silly questions!
Having an issue with the sport diff on my B8 S4. Will keep the saga as brief as possible, but a fair bit of work has been carried out so putting the info out here just to make sure it's all available.
So, initially, back in January or so, got the "sport differential system malfunction" warning on the dash. I took the car in to a specialist garage (not going to name, just to keep any comments neutral) they scanned the fault and it came back as a memory checksum fault on the module.
They believed it was a fault with the diff ecu itself, so quoted for the replacement and then after some delays on my end, I ended up having it replaced in May.
When the new diff ecu was installed, following the first time setup on ODIS they were getting the fault "DTC C102AF0" and the guided fault finding said to check the all wheel drive pump V415. See image: https://postimg.cc/qttGMcxq
They then tested the pump (not entirely certain on how they did this) however, they said the pump would not work at all, and they also noticed that one of the pressure/temp sensors was reading -40c. After some back and forth, and not being able to find a decent condition entire used sport diff it was opted to replace the components. So in total it's had: ecu, pump, control valves & both sensors (all brand new Audi OEM).
After fitting the new parts, the setup & ODIS procedures for calibrating the sensors and clutches were followed, and all seemed normal. This is when I took back delivery of the car.
Approximately 30-40 miles into driving the "sport diff system malfunction" came up again.
I returned the car to have the faults checked and it came back with the faults Oil pressure implausible on both sensors 1 & 2. They followed the ODIS procedure for calibrating the diff again but shortly after the same faults returned. On every restart the fault is cleared, and it can be driven in comfort mode with no faults, but as soon as you put it in dynamic on the first corner the fault will return. Assuming its when it requests the diff to produce pressure but the sensors don't register it.
So bringing us to now. They asked that I have a way of logging the car, so that they can do the calibration via ODIS again, and so that I can log all of the pressures when driving and see what is changing over the period before it goes into fault. So bought VCDS.
I scanned the diff module and these are still the current faults:
                Address 22: AWD       Labels: 8K0-907-163.clb
Control Module Part Number: 8K0 907 163 A    HW: 8K0 907 163 A
  Component and/or Version: 4 Wheel Drive H18 0025
           Software Coding:
            Work Shop Code:
              ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016 (AU48)
                      VCID: 2E05063A4098174B6D3-807A
0273 - Oil Pressure and Temperature Sensor
          C1004 F0 [008] - Oil Pressure Implausible
                    Fault Frequency: 11
                    Mileage: 127888 km
                    Date: 2022.06.22
                    Time: 18:51:04
0277 - Oil Pressure and Temperature Sensor 2
          C1005 F0 [008] - Oil Pressure Implausible
                    Mileage: 129743 km
                    Date: 2022.07.17
                    Time: 17:05:53
I then logged the differential pressure sensors, the current being pulled by the pump as well as the pump status.
When cornering (tested full throttle 2nd gear with about 90 degrees of steering) it is only producing approximately 1 bar maximum. On Audi's website (albeit the sport diff for an S8), in theory the pressure should be closer to 40 bar!
This link: https://postimg.cc/sBfRtqV7 is an image of the excel log (cant see how to attach the excel itself).
On the full car scan there is the ABS module (03) also complaining about the AWD module fault. However, I think this is just because the module can see the fault and is referencing it, not that the ABS module itself has any faults. There are no other modules with faults related.
   Part No SW: 8K0 907 379 AN    HW: 8K0 907 379 AN
   Component: ESP8 quattro  H04 0100
   Coding: 296D0A
   Shop #: WSC 06335 000 00000
   VCID: 05579996B52E7413FC9-8050
01324 - Control Module for All Wheel Drive (J492)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 15
                    Reset counter: 233
                    Mileage: 127888 km
                    Date: 2022.06.22
                    Time: 18:51:04
                    Hex Value: 0x3300
                    Hex Value: 0x4004
                    Hex Value: 0x1228
                    Hex Value: 0x50B4
                    Hex Value: 0x00FF
The garage is saying that the fault is "internal to the diff", however, I'm not so sure about this. They are saying it's losing pressure internally which may be the case, but before spending further money would like to be more certain of this.
A few things if possible:
Could someone with a B8 S4 take a log of their sport diff when driving, so that I have a baseline to go off of (what pressures to expect etc)?
I also noticed (which can be seen on the first scan) the "software coding" line is blank? I have only changed 1 bit on coding the instrument cluster (adding oil temp readout) before, so if anyone could offer assistance on whether this is normal for sport diff to have this section blank, or how/what I need to do in order to fill this in/code it correctly would be amazing.
On other forums, it says that the sensors need to have a tolerance from the diff coded to them? I don't think this is necessarily a matter of tolerances if it's 1/40th of the pressure, but if there's anything I should do to try and input this information I can try it!
Final thing!! I was trying to run some output tests, just to see if the pump would activate, control valves would open/close etc & also the bleed/fill settings - however on all I was met with "refused by control module". As per this image: https://postimg.cc/mz2pZWqN
Sorry for the essay but a lot of info to run through.
Any help would be greatly appreciated as this has now had over £3.5k thrown at this fault alone and to still not have it resolved is just a nightmare. If any extra info/tests are required now that I have VCDS I can try anything, the garage is happy to keep working with me so if I mess something up that ODIS is required to reset it's going there for the calibration and they're happy to reset it anyways.
Just attached full scan for reference also:
Tuesday,02,August,2022,16:12:50:62755
VIN: WAUZZZ8K5AA041675   License Plate: HV59LNE
Mileage: 80873   Repair Order:
Gateway Installation List:  8T0 907 468 AA
57-TV Tuner -- Status: Malfunction 0010
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 20 22 30 3C 42 46
          47 52 53 55 56 57 5F 62 6C 6D 72
VIN: WAUZZZ8K5AA041675   Mileage: 130150km-80871miles
Address 01: Engine (J623-CAKA)       Labels:| 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551     HW: 8K0 907 551
   Component: 3.0T SIMOS84  H06 0004
   Revision: --------    CVN: E39F1EC5
   Coding: 010C000C240F0228
   ASAM Dataset: EV_ECM30TFS8K0907551 A01006
   ROD: EV_ECM30TFS8K0907551_A01.rod
   VCID: 6E85C63A8018574B2D3-803A
   VINID: 9D196AAAA21B15144010118714502C858D
   Part No SW: 8K1 927 156 AC    HW: 0B5 927 156 E
   Component: 0B5 30TFSIRdW H03 0006
   Revision: --H03---    Serial number: 0000000082 CVN: 00000957
   ASAM Dataset: EV_TCMDL501 A02203
   ROD: EV_TCMDL501.rod
   VCID: 76B5EE5AF8486F8BE53-8022
   Coding: 296D0A
                    Fault Frequency: 15
                    Reset counter: 233
                    Mileage: 127888 km
                    Date: 2022.06.22
                    Time: 18:51:04
                    Hex Value: 0x3300
                    Hex Value: 0x4004
                    Hex Value: 0x1228
                    Hex Value: 0x50B4
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ
   Component: BCM2 1.1      H02 0321
   Coding: 051200
   VCID: 025D828AA400432BD9B-8056
   Subsystem 1 - Part No SW: 8T0 959 754 AM    HW: 8T0 959 754 AM
   Serial number: 0509000006568020
   Serial number: 0209000049940010
03285 - Sensor for Contact with Door Handle; Front Left
                    Reset counter: 184
                    Mileage: 127800 km
                    Date: 2022.06.17
                    Time: 08:09:11
03286 - Sensor for Contact with Door Handle; Front Right
                    Reset counter: 184
                    Mileage: 127800 km
                    Date: 2022.06.17
                    Time: 08:09:11
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 184
                    Mileage: 127800 km
                    Date: 2022.06.17
                    Time: 08:09:12
   Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D1000000    Serial number: 01200720090450
   Coding: 66140000
   VCID: 77ABE35EFFC21683FE5-8022
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000316234
   Coding: 260050914074AF313F01000300001D0D0F9DC74A02010141000000
   Shop #: WSC 63896 004 1048576
   VCID: 3C213C728664F5DBD37-8068
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 170709  H05 0070
   Serial number: SWF09070175421
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10551078
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001407090132
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840920101771
   Coding: 30010D
   VCID: 40D94882EA8C913B8FF-8014
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H08 0080
   Coding: 002B96
   VCID: 6FBBDB3E87925E43265-803A
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364 A    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0050
   Revision: 00000000    Serial number: 01070904100002
   Coding: 070181
   VCID: 313F1D46512608B3701-8064
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EFD04CPJJ
   Coding: 30363435363030303030554A3052384B3053
   VCID: 41DF4D86E1069833801-8014
   Serial number: 6334MSME49736839M
   Serial number: 6344MSME4974236DM
   Serial number: 6352QSME4334022C7
   Serial number: 6362QSME2D333F36Q
   Serial number: 63732SME70332912Q
   Serial number: 63832SME6C33233A%
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Revision: --------    Serial number: 90319IGE0007Z
   Coding: 00003F
   VCID: 3E25367A9078E7CBFD3-806A
   Part No SW: 8K0 920 981     HW: 8K0 920 981
   Component: KOMBIINSTR.   H04 0253
   Revision: 00100000    Serial number: BYD579079
   Coding: 2F071100BF002600010000
   VCID: 70B9D8429AAC41BB3FF-8024
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0101
   Revision: FB800054    Serial number: 5400F0961683BF
   Coding: 00C303
   VCID: 00598882AA0C513BCFF-8054
   Component: J367-BDM  H06 0160
   Serial number: 1908595C010709
   Part No SW: 8K0 907 144 D    HW: 8K0 907 144 D
   Component: DYNAMIKLENK.  H06 0570
   Revision: 50001005    Serial number: --------------
   Coding: 8C0000
   VCID: 303918425A2C01BB7FF-8064
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02029164747464545425363E
   VCID: 3333174EAB3A3AA302D-8066
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H18 0025
   Serial number: 002402210001004
                    Fault Frequency: 11
                    Mileage: 127888 km
                    Date: 2022.06.22
                    Time: 18:51:04
                    Mileage: 129743 km
                    Date: 2022.07.17
                    Time: 17:05:53
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0010
   Revision: S0H04000    Serial number: 00000000006494
   Coding: 01010101000000000000000102
   VCID: 2D0701364D1E6C53549-8078
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0010
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Coding: 0001102
   VCID: 3C213C728A64F5DBD37-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0010
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F09.07.0900H010003C320058ÿ
   Subsystem 4 - Serial number: 320058ÿ
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009101967
   Coding: 011C12205021410001
   VCID: 45D75996F5AEB413BC9-8010
   Revision: 00002001    Serial number: 0120136643
   Coding: 013B0E2220393C810030020000000000
   Shop #: WSC 19489 000 1048576
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 184
                    Mileage: 127800 km
                    Date: 2022.06.17
                    Time: 08:09:18
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 184
                    Mileage: 127800 km
                    Date: 2022.06.17
                    Time: 08:11:29
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H08 0190
   Revision: 00008001    Serial number: 34881004888903
   VCID: 7AADFA6ACCD00BEB81B-802E
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009108373
   VCID: 44D14492FE948D1BAB7-8010
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 10000000286550
   VCID: 34311452AE343D9B1B7-8060
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   VCID: 30391842562C01BB7FF-8064
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H02 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH02 S001
   Part No SW: 4F0 035 053 K    HW: 4F0 035 053
   Component: Radio U Basic H45 0074
   Revision: AB001007    Serial number: 341G/097607489
   Coding: 010003010000000001
   Shop #: WSC 12345 123 61029
   VCID: 2517F91615EE54139C9-8070
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4F0 919 129 G    HW: 4F0 919 129
   Component: HybridTV-DVB  H06 0550
   Revision: R0060000    Serial number: 76300802369502
   Coding: 03020000
02283 - Video Connection to Output [End Unit]
                    Fault Status: 00100111
                    Fault Frequency: 72
                    Reset counter: 18
                    Mileage: 127922 km
                    Date: 2022.06.23
                    Time: 07:35:20
                    Fault Status: 00101010
                    Fault Frequency: 9
                    Reset counter: 10
                    Mileage: 128054 km
                    Date: 2022.06.24
                    Time: 18:21:39
   Part No SW: 8T2 035 666 M    HW: 8T2 035 666 D
   Component: H-BN-EU       H41 0187
   Revision: --------    Serial number: 475GY097512309
   Coding: 010101010206A9EF35000B1E000000030000
   Subsystem 1 - Part No: 8R0 060 884 EM
   Component: EUR 2017/2018  2503
   Component: DU7 High  H43 0306
   Serial number: 9356G.091039928
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000327594
   Component: CD-Database  1293
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101574112
   Coding: 010C12204021210001
   VCID: 42DD428AE480832B99B-8016
   Revision: --H03---    Serial number: 525PA8-J9590KJ
   Coding: 1023007
   VCID: 38292062BE5CD9FB37F-806C
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8K9827851A
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H27 0300
   Serial number: 8K9827852A
   Revision:             Serial number: 0000101576274
End----------(Elapsed Time: 02:13, VBatt start/end: 14.0V/14.0V)-----------
           Software Coding:
            Work Shop Code:
                    Fault Frequency: 11
                    Mileage: 127888 km
                    Date: 2022.06.22
                    Time: 18:51:04
                    Mileage: 129743 km
                    Date: 2022.07.17
                    Time: 17:05:53
Many thanks - Luke
Zenerdiode
Newcastle, England
C?ID=24330
Hello Luke, welcome to the Forum - and great first post :thumbs:
Pffffff, there's a lot happened here and it's going to be difficult to sort out. With only buying VCDS after your problems have arisen; you're not going to have any 'before' type scans so we can see what we're dealing with.
I gather the specialist are not Main Dealer (that's OK) - would you know if they have a genuine licenced subscription for their ODIS?
Do you have (or can get your hands on) ALL of the bits that have been changed so far?
Would you be able to fit the original J492 and get an Auto-Scan with that fitted; so we could see the VCDS interpretation of the fault?
The shuttle valves have a spring and a ball behind them. Were they cleaned meticulously and re-fitted?
The control valves also have a spring and a ball behind them. Were they cleaned meticulously and re-fitted too?
When the four-wheel drive control unit J492 is renewed, the learnt values (adaptive values) for the deterioration of the finaldrive (clutch wear, oil ageing etc.) must be transferred using VCDS or ODIS, as otherwise the performance of the sports differential will be impaired. Was this carried out?
Has the Clutch Classification been entered into J492?
Each of the oil temp/pressure sensors (G437 and G640) must be changed individually and adapted, before doing the other one. This is so J492 knows the individual identity of each; and where it is located. Was this done - or both changed at the same time?
Were the two valves installed in the correct orientation?
Zenerdiode
Newcastle, England
C?ID=24330
p.s. An easy answer is that ABS will show that error because of the fault in the AWD module. :)
LukeW
C?ID=494932
Afternoon Zenerdiode!
Thanks for taking the time to respond - really is much appreciated.
While indeed not a main dealer, they are a very big name within the Audi/VW world - so I am 99% sure that they would have a genuine subscription for ODIS.
Unfortunately, by the time I had asked them for the original parts back they had been discarded.. so do not have access to any of the original components.
I can't believe this, but luckily going through all of the paperwork I'd kept with the car, in there was a printed auto-scan made with all of the original hardware (Please don't laugh too hard when you see the gearbox errors it had at that point! That was another £4k bill that I could've done without..).
I have uploaded the PDF scan I just took of it here: https://drive.google.com/drive/folders/1--XPQNs25H1hGf3vWq3ncShXNya8jhJj?usp=sharing
As the work was carried out by them, I'll have to ask them for details about the valves and how they were fitted (orientation included). They are closed until the 17th August so wont get any answers until then regarding that.
Directly quoting an email from them when I asked about how the new parts were set up (one at a time etc) and if the fill/bleed setting within VCDS was used they replied:
The new sensors fitted are OEM parts we did replace both at the same time followed by the ODIS procedure. The clutches were also recalibrated as per ODIS procedure too.
The pressure reads 0 when driving normally as it does not need to pressurise the clutches, when there is steering input and light throttle it raises to between 1 and 2 bar.
In regards to the clutch valves these have also both been replaced as there were part of the pump repair kit we ordered in, the clutch lines have been filled, bled and checked, using the ODIS procedure. In regards to the calibrations that have been done, ODIS has been used every time, there is a particular procedure that ODIS will do automatically when selected, it is not something we can set up manually.
Both sensors were ordered at the same time, as from what I can tell from the emails back and forth both were showing -38c, hence why they replaced both at the same time. I don't think they were aware of the process doing 1 at a time.
Regarding classifications & adaptions, I'm still very new to this so my knowledge is very limited. I'm assuming ODIS would do this automatically when performing the first time setup for them? Just in case it helps. I ran the application controller channel map and saved the measuring values + adaptation option for the AWD module 22. Those files are also in the google doc folder linked.
Thanks again and if there's anything else I can do or scans required let me know I will be next to the car all day tomorrow!
Cheers :)
Morski
Cheshire UK
C?ID=90186
ODIS is not a user friendly interface that some people think it is. When replacing the awd control module odis needs to read all the original parameters from it and then it will say fit the new one. It then transfers details across and even then it does not do it fully. You then have to enter the clutch details from the actual diff unit under the car. ODIS clearly says do not replace both oil and temp sensors at the same time as again it needs to read info from them. however they can be changed at the same time if there is a electrical failure in both and it -odis- can do that as well. Some times there is some going back and forth in odis to get the right data entered and even having to force odis to do a test plan of 22- awd module in order to get the data registered.
Morski
Cheshire UK
C?ID=90186
As far as i can see the original gearbox faults were referring to the selector sensor not reading the correct gear and not the gearbox ecu/mechatronics unit. could be wrong
LukeW
C?ID=494932
Hi Morski,
Thanks also for responding!!
Just ref the gearbox - that is no longer an issue thankfully as I had the G676 (selector) sensor replaced along with the full rebuild at Milta in Bristol so new mech, clutch packs the whole 9 yards. It was a bit jerky on gearchange and sometimes nearly stalling coming to a stop even before the selector position sensor fault came up, so mech was probably on its way out also. Has been perfect ever since on that front thankfully! Thought being an early model year B8 it may retain that money spent on getting gearbox sorted a bit on resale also.
Ref the programming of the new AWD control module - I notice that the "software coding" entry is blank (can be seen in the quoted code in the first paste) - is that missing data there that I can fill in with VCDS?
Can the clutch details printed on the diff be seen just getting under the car? Or will it need to be fully in the air? Also does that need to be put in with ODIS or can be done on VCDS?
Sorry for the noob question but basically am trying to figure out if I can input this data somehow, and then confirm any mechanical fault on my end - or if it must be done through ODIS. If so then I will have to take it back to have done :(
Is there a scan in VCDS I can do to obtain the coding info other than the one I put in google docs? I can try run that and see if any issues are more apparent?
Thanks again both for the help much appreciated :)
Morski
Cheshire UK
C?ID=90186
Re the AWD; the diff module has clutch coding imprinted on it using a 'dot' type writing so it can be read 'if' its not corroded too much. And yes getting under the car will allow you to see them. iirc yours is a new diff so should easily be readable.
I dont think it can be done with vcds. Odis can do it and it can also be done offline as well.
The awd module is one of those that doesnt really have coding nor can you input it to amend it.
by the way who is it that is doing the work? or which vicinity are they or you in?
Zenerdiode
Newcastle, England
C?ID=24330
I don't have ODIS, but have the Workshop Manual. As @Morski says, both ODIS' test plan and the WM agree, they are very explicit that the pressure/temp switches have to be changed individually, i.e. if you need to change both it is a two-step process. Change one, adapt, change the other, adapt. If you change both, it wipes all parameters from the module. New ATF is also required as the oil aging data is wiped too.
In VCDS, the only way to enter alphanumeric data is through Adaptations. To tell a module to capture and store values for itself, is usually done through Basic Settings. What do you get in the drop-downs for known Adaptation Channels and known Basic Settings?
Again, Mohsan may be on to something, that ODIS reads and transfers the data through DMA? - that VCDS doesn't support. @Uwe & @Eric, have you tried anything like this?
LukeW
C?ID=494932
Morski,
Thanks for confirming - next time I'm under the car will check for this and then at least I'll have the clutch info to hand.
Just to clarify, the diff itself is not new - only the external parts ie; ecu, pump, sensors and control valves have been replaced. At the time there were only 2 used sport diffs for sale. Both approx. £1500 and were out of cars that were still registered on the road. So was questioning why exactly they had been removed from running cars if they were working. Thought if it's just going to be a sensor or even worst case the pump then should still come in at less than one of those, and at least then the parts are of a known condition. :(
For reference, it is MRC Tuning in Banbury that have carried out the work. They are only 10 mins drive and I've used them for regular service and some other issues before. They've always had good communication & been very professional hence why it was taken there.
They are also still trying to help get it resolved - not like a lot of places that would've tried to dust their hands of it. This was the first sport diff that they've replaced individual components in, so that could potentially be a contributing factor if any mistakes were made.
Zenerdiode,
I will have to speak with them and see what process was followed exactly for sensor replacement. That will take some time though as they are closed for a break until Aug 17th.
In terms of replacing both sensors and having parameters wiped. What parameters would be wiped doing this? Is it just minor calibration of the sensors - or is it major parameters like when the pump should activate, affect the control valves etc? The thought behind it being is it pointing towards a mechanical issue, only seeing 1 bar of max pressure - or could the pressure actually be that much different at potentially 40 bar or so but the sensors aren't interpreting it properly?
I think it's worth noting that the fault only came up 30 miles or so into driving, however, after the first time the error comes up it will happen every single time the steering is turned and throttle applied in dynamic so when the diff is actually trying to create pressure (to be clear only after an engine restart, as when the fault comes up the diff becomes inactive - tested this by logging it and the pump never activates when the dtc is illuminated). Video of it happening added to the Drive link also.
It also had new oils in both sides of the diff while this was done, so new gear oil (G052145S2) & new oil on the hydraulic side (G055515A2).
I will check tomorrow for what options I have on known Adaptation Channels and known Basic Settings.
Thanks again both!! Fingers crossed Uwe & Eric can advise on your query as would be good to know if there's anything I can try other than taking it to them for another calibration and just logging from my side.
Cheers- Luke
Morski
Cheshire UK
C?ID=90186
Was the pump new or used? Used; there is a pump repair kit available which might solve pressure issues if all other avenues of adaptations dont work. I think its more of an issue with adapting the sensors in the right procedure.
MRC- i think your in good hands. like you said most places would have washed their hands of the situation by now
LukeW
C?ID=494932
Afternoon Morski,
The repair kit 0BF598074 is what was used to repair/replace parts of the pump and the also the control valves.
I will be checking shortly what basic settings are available, and what adaptations VCDS has available but I'm going to be very careful for the moment as I read that pressing reset adaptations will just wipe the adaptations and the car will not re-learn them without ODIS :(
Will get back to the thread shortly with what I have available.
Cheers
LukeW
C?ID=494932
Hi @Zenerdiode,
I have added to the link here: S4 faults Google Drive images of the pages of all the adaptation options & basic setting options along with what output tests can be run (they all get refused by control module so can't run the output tests:confused: also put an image of that issue).
While there I also did the controller channel map backup of the adaptations in hex - so in theory even if I screw anything up I should be able to hit restore with that file?
Just in case it's of any use also took a copy of the Advanced ID data (had some more info regarding software version etc than what is shown on the basic module scan).
If there are any I should run or anything to try at this point?
Cheers :)
LukeW
C?ID=494932
Why images? Why not post the actual data here? It's just text.
Hi @Uwe,
Is there any way to export/show the options available for adaptations and basic settings as text? Didn't see an option do that?
Could type the options up manually I guess but thought it easier to see in the images, as the adaptations for example has many options.
If there are any scans that I haven't provided as text to the post already that would be of use I can do that.
Cheers :)
The Adaptation maps that you already made .CSV files. CSV files are just comma separated text. Drop 'em in Notepad, then copy & paste.
Basic Settings don't have values stored, so they're not all that interesting to post. Yours should be:
IDE00498 -- Resetting of all adaptation values
IDE03012 -- Erase counter for start/stop procedures
IDE03341 -- Import identification of oil pressure and oil temp. sensors
IDE03677-ENG101982 -- Reset oil-aging adaptation values - routine_control_oil_change
IDE03678-ENG101976 -- Reset transmission adaptation values - routine_control_new_gear
LukeW
C?ID=494932
Hi @Uwe ,
Yeah the basic setting options I only posted as @Zenerdiode asked which I had available.
The adaption map (pre-label version) in text is:
;SW:8K0-907-163-A   HW:8K0-907-163-A ---  AWD
;Component:4 Wheel Drive H18 0025, Coding:
;EV_AllWheelDiffeQSPCAN,003016,EV_AllWheelDiffeQSPCAN.rod
;Wednesday,10,August,2022,17:14:35:62755
;VCDS Version: Release 22.3.1 (x64)  Data version: 20220407 DS337.0
;VCID: 2E05063A4098174B6D3-807A
IDE00820-ENG100819-Activating and deactivating all development messages-Parameter activate XCP,not active ,1
IDE00820-ENG103212-Activating and deactivating all development messages-Parameter Develop Message activate get addition information DTC,not active ,1
IDE00820-ENG102733-Activating and deactivating all development messages-Parameter Develop Message activate get DTC,not active ,1
IDE00820-ENG104147-Activating and deactivating all development messages-Parameter Develop Message activate get internal system information,not active ,1
IDE00820-ENG103750-Activating and deactivating all development messages-Parameter Develop Message activate pending error,not active ,1
IDE03199-ENG99659-Dynamic calibration-Axle rotation counter,152499815 ,76
IDE03199-ENG99684-Dynamic calibration-Axle rotation counter complement value,4142467480 ,76
IDE03199-ENG101875-Dynamic calibration-Class correction gradiant left,10 ,76
IDE03199-ENG101036-Dynamic calibration-Class correction gradiant left complement value,245 ,76
IDE03199-ENG99714-Dynamic calibration-Class correction gradiant right,9 ,76
IDE03199-ENG101016-Dynamic calibration-Class correction gradiant right complement value,246 ,76
IDE03199-ENG103096-Dynamic calibration-Class correction offset left,2 ,76
IDE03199-ENG101454-Dynamic calibration-Class correction offset left complement value,253 ,76
IDE03199-ENG101434-Dynamic calibration-Class correction offset right,7 ,76
IDE03199-ENG102472-Dynamic calibration-Class correction offset right complement value,248 ,76
IDE03199-ENG99476-Dynamic calibration-Counter DBV left,20 ,76
IDE03199-ENG103374-Dynamic calibration-Counter DBV left complement value,235 ,76
IDE03199-ENG100691-Dynamic calibration-Counter DBV right,17 ,76
IDE03199-ENG102548-Dynamic calibration-Counter DBV right complement value,238 ,76
IDE03199-ENG99454-Dynamic calibration-CRC value,48969217 ,76
IDE03199-ENG102179-Dynamic calibration-Disc Work,356631480 ,76
IDE03199-ENG101247-Dynamic calibration-Disc Work complement value,3938335815 ,76
IDE03199-ENG100930-Dynamic calibration-Fingerprint 1 complement value,2845833409 ,76
IDE03199-ENG101615-Dynamic calibration-Fingerprint 1 value,1449133886 ,76
IDE03199-ENG99645-Dynamic calibration-Fingerprint 2 complement value,2849111328 ,76
IDE03199-ENG99864-Dynamic calibration-Fingerprint 2 value,1445855967 ,76
IDE03199-ENG100364-Dynamic calibration-Identity Number,35 ,76
IDE03199-ENG99488-Dynamic calibration-Left clutch wear 1,4 ,76
IDE03199-ENG102194-Dynamic calibration-Left clutch wear 2,0 ,76
IDE03199-ENG100698-Dynamic calibration-Right clutch wear 1,1 ,76
IDE03199-ENG103441-Dynamic calibration-Right clutch wear 2,0 ,76
IDE03199-ENG99019-Dynamic calibration-Version number,2 ,76
IDE03338-Friction classes (end of line),3U61ALB601PU ,12
IDE03339-ENG103076-Friction classes (customer service)-Class Identity number left,0A 02 ,4
IDE03339-ENG104153-Friction classes (customer service)-Class Identity number right,09 07 ,4
Not really sure how to interpret the data? From what I can see it seems all lines do have some values against them in the adaptation table (notably the fingerprints 1 & 2 which are the sensors?), so it appears that the sensors have been adapted (whether correctly or not I'm not sure).
The main issue I'm trying to resolve is that the diff is only registering a max of 1 bar pressure under hard cornering + throttle and bringing up the implausible pressure fault. According to Audis website (albeit for an S8 which may be different - link for reference) sport diff should make approx 40 bar max pressure. With the pump being repaired with Audi's own kit (and all other external components being brand new OEM) I'm trying to figure out if their diagnosis of an internal diff pressure loss is correct - or does it seem to be an issue with the setup of the new components from a software perspective?
If nothing can be found in the data that suggests there is an issue with setup, then the next step is for MRC to recalibrate with ODIS as was done upon first setup, and then for me to log the diff during the short drive before the fault comes up. Seeing if pressures drop over time etc. If that happens then it's looking like it will require a new sport diff which would be a real shame as then the money spent getting it to this point is effectively a waste :cry:
Thanks all
Unfortunately, I am completely unfamiliar with those diffs.
NEtech
Denmark
C?ID=56995
You could test this. The numbers in brackets are like on VCDS buttons.
[08] = Advanced Measurement values.
Engine idling min. 10 sec.
Ign. OFF > Wait 15 sec.
Delete DTC
Ign ON
Maybe [16] 20103, maybe not.
[03] IDE03439-Bleed pressure lines
[08] IDE02035-ENG98502-Oil pressure and oil temperature pressure
[08] IDE02036-ENG98502-Oil pressure and oil temperature pressure 2
What are pressures?
Ign ON
[16] 20103
[03] IDE03340-Pressure test
What are pressures?
Test drive.
LukeW
C?ID=494932
[08] = Measurement values.
Delete DTC
Ign ON
What are pressures?
Ign ON
[16] 20103
What are pressures?
Test drive.
Morning @NEtech -
I've tried to run the output tests bleed pressure lines & pressure test previously, however, it has always returned refused by control module. I wonder if that was because I wasn't following the procedure properly of engine on - then off with just ignition on.
Measure blocks 08 has also always been greyed out, but I can view the pressures through the advanced measured values tab. If running either of the output tests will it continue if I back out of that page to go to the measured values? Or will the test page itself display these values whilst it's being performed?
I will try it this evening when home from work. Definitely worth a shot to try this. Cheers! :)
