Audi TT Mk2 (8J) - Roadster Roof Flap Adaptation message - "Refused by Control Module"
SwissJetPilot
Switzerland
C?ID=317276
One of our Audi TT Forum members has been experiencing problems with his convertible top operation. I recommended that he purchase a VCDS (which he did) as the Roof Flap Servos (RFS) are generally responsible for 95% of convertible top failures. Sure enough, he came back with this and two other Address-26 (Auto Roof) faults shown below -
03246 - Sensor for Canopy Flap Left (G596)
As I have for many Mk2 Roadster owners, I recommended that he remove both the left and right RFS, clean out the excess grease that tends to migrate onto the internal PCB then reinstall them and use his VCDS to run the Roof Flap Adaptation.
• [Select]
• [26 - Auto Roof]
• [Output Tests - 03]
• [Select] Selective Output Tests
• [Choose]Convertible Top Flap Initialization
• [Start]
Oddly, it came back with this message "Refused by Control Module" which I have never seen before.
Any idea what would cause this?
Note - the other two faults; 02000 & 01097 are not unexpected since the controller lock out automatic mode and these will clear once the Adaptation has been performed.
save-jpg.390081
d0b629ce-c196-4ae6-9dfd-7149ef34de90-jpeg.489645
image-jpg.489706
Auto-Scan, please?
EuroX
Northern NJ USA
C?ID=208579
FYI this was a common problem on those cars. Make sure you have the updated part number. Should have A on the end. Otherwise your wasting your time.
SwissJetPilot
Switzerland
C?ID=317276
@ Uwe - Auto-Scan forthcoming...
@ EuroX - Not a waste of time at all. This has worked on Mk2 Roadsters going back to my 2007 and think even a 2013 owner was able to do this repair too. In some cases, intermittent operation has been resolved doing this without an Adaptation when no faults from either RFS has been logged. The RFS clean and VCDS Adaption has proven successful almost 100% of the time.
EuroX
Northern NJ USA
C?ID=208579
They are a known problem. Most of the time as long as you set the gap correctly to 10MM they will work for some time. Sorry I rather not waste my time and purchase the correct updated parts and never have the issue again.
SwissJetPilot
Switzerland
C?ID=317276
@ EuroX - When you say "...set the gap correctly to 10MM they will work for some time." What gap are you referring to?
EuroX
Northern NJ USA
C?ID=208579
Gap between electric windscreen edge and convertible top flaps in the up position. It needs to be 10mm or bigger.
SwissJetPilot
Switzerland
C?ID=317276
Seems this was due to the user trying to run this test without the engine running so he ended up draining his battery.
I advised him to try it again with the engine running and everything worked out okay.
009827f3-992a-4eb8-864a-6a7b5eee936b-jpeg.489889
Good point on the 10mm gap.
However if the copper contacts of the potentiometer are fouled with grease, this can lead to the expected range for G596 & G597 being exceeded and it will register a fault.
That's why it's important to clean the grease off the contacts inside the RFS.
Whether this is an OEM factory fitted RFS or a replacement, the presence of excess grease in the potentiometer contacts can cause this problem.
greaseoncontactprongs-jpg.416865
SwissJetPilot
Switzerland
C?ID=317276
Here's the auto-scan. As noted, there are a lot of low/under voltage faults, so the battery is suspect.
The owner has also gone through and checked the ground points, paying particular attention to the two below the air filter as these often get corroded.
But so far nothing has improved. So new battery in next.
Wednesday,10,August,2022,09:22:05:17577
VCDS Version: Release 22.3.1 (x64) Running on Windows 10 x64
                Address 03: ABS Brakes       Labels: 8J0-614-517.clb
Control Module Part Number: 8J0 614 517 A    HW: 8J0 614 517 A
  Component and/or Version: ESP MK60E1          0020
           Software Coding: 0616246
            Work Shop Code: WSC 01236 785 00200
                      VCID: 2B7BC9488A4199D74A-807E
                    Reset counter: 14
                    Mileage: 191410 km
                    Date: 2021.12.12
                    Time: 07:23:32
                    Count: 10305
                    Count: 128
                    Count: 27904
                    Reset counter: 14
                    Mileage: 190734 km
                    Date: 2021.11.24
                    Time: 01:45:15
                    Count: 128
                    Count: 9025
                    Count: 8212
                    Count: 44800
                    Reset counter: 14
                    Mileage: 191410 km
                    Count: 128
                    Count: 9025
                    Count: 297
                    Count: 38400
Wednesday,10,August,2022,09:23:49:17577
                Address 08: Auto HVAC       Labels: 8J0-820-043.clb
Control Module Part Number: 8J0 820 043 AG    HW: 8J0 820 043 AG
  Component and/or Version: J255  Klima 1 Zone  0080
           Software Coding: 1574148
                      VCID: 6BFB09484AC159D70A-803E
01810 - Actuating Motor for Temperature Flap; Right (V159)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 237
                    Mileage: 171623 km
                    Date: 2020.11.03
                    Time: 00:55:19
                    Voltage: 12.40 V
                    Temperature: 19.0°C
                    (no units): 35.0
                    (no units): 207.0
                    Temperature: 24.0°C
                    Fault Status: 01100101
                    Reset counter: 228
                    Mileage: 171623 km
                    Date: 2020.11.03
                    Time: 00:49:12
                    Reset counter: 13
                    Mileage: 191410 km
                    Date: 2021.12.12
                    Time: 07:23:36
                    Voltage: 9.90 V
Wednesday,10,August,2022,09:24:17:17577
                Address 10: Park/Steer Assist       Labels: 8P0-919-475-7X1.clb
Control Module Part Number: 8P0 919 475 G    HW: 8P0 919 475
  Component and/or Version: PARKHILFE 4K  H06 0120
           Software Coding: 000103
            Work Shop Code: WSC 06314 000 00000
                      VCID: 42A584ECDDCB789F99-8016
                    Reset counter: 13
                    Mileage: 191410 km
                    Date: 2021.12.12
                    Time: 07:24:16
                    Temperature: 18.0°C
Wednesday,10,August,2022,09:24:49:17577
                Address 14: Susp. Elect.       Labels: 8P0-907-376.lbl
Control Module Part Number: 8J0 910 376 B    HW: 8J0 907 376 B
  Component and/or Version: J250 Raddaempfung   0050
           Software Coding: 0000034
                      VCID: 2E7DC05CB953ECFF6D-807A
                    Reset counter: 12
                    Mileage: 191410 km
                    Date: 2021.12.12
                    Time: 07:24:10
                    Voltage: 8.16 V
                    Voltage: 4.99 V
Wednesday,10,August,2022,09:25:17:17577
                Address 15: Airbags       Labels: 8J0-959-655.lbl
Control Module Part Number: 8J0 959 655     HW: 8J0 959 655
  Component and/or Version: -t Airbag 9.43  H02 0020
           Software Coding: 0011636
                      VCID: 79D72300309DFB4788-802C
                    Reset counter: 12
                    Mileage: 191410 km
                    Date: 2021.12.12
                    Time: 07:24:51
Wednesday,10,August,2022,09:25:39:17577
                Address 16: Steering wheel       Labels: 8P0-953-549-F.lbl
Control Module Part Number: 8P0 953 549 F    HW: 8P0 953 549 F
  Component and/or Version: J0527           H36 0070
           Software Coding: 0013111
           Additional Info: XXXXXXXXXXX E0221           H06 0030
           Additional Info: Geraet 00200
                      VCID: 41A78BE018CD638780-8014
Wednesday,10,August,2022,09:25:59:17577
                Address 22: AWD       Labels: 0AY-907-554-V1.clb
Control Module Part Number: 0BR 907 554 A    HW: 0BR 907 554 A
  Component and/or Version: Haldex 4Motion      3016
           Software Coding: 0000005
            Work Shop Code: WSC 00000 000 00000
                      VCID: 43AB81E802D1719792-8016
00448 - Haldex Clutch Pump (V181)
                    Reset counter: 168
                    Mileage: 171623 km
                    Date: 2020.11.03
                    Time: 00:43:17
Wednesday,10,August,2022,09:26:19:17577
                Address 37: Navigation       Labels: 8E0-035-192-RNSE.clb
Control Module Part Number: 8J0 035 193 D    HW: 8J0 035 193 D
  Component and/or Version: RNS-E PU EU     H05 0220
           Software Coding: 0619757
            Work Shop Code: WSC 54516 001 1048576
                    Reset counter: 22
                    Mileage: 191410 km
                    Date: 2021.12.12
                    Time: 07:22:50
                    Voltage: 10.70 V
                    Mileage: 191750 km
                    Count: 1612
                    Clock: 19:58
02261 - Data Medium
                    Fault Status: 00101110
                    Reset counter: 13
                    Mileage: 191407 km
                    Date: 2021.12.11
                    Time: 08:07:34
                    Mileage: 191400 km
                    Count: 1212
                    Clock: 05:57
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 228
                    Mileage: 171623 km
                    Date: 2020.11.03
                    Time: 00:43:38
                    Mileage: 171620 km
                    Count: 311
                    Clock: 00:43
02446 - Disk Drive Mechanical Malfunction
                    Reset counter: 201
                    Mileage: 174304 km
                    Date: 2021.01.18
                    Time: 03:49:04
Wednesday,10,August,2022,09:26:36:17577
                Address 42: Door Elect, Driver       Labels: 8P0-959-801-MAX3.lbl
Control Module Part Number: 8J7 959 801 D    HW: 8J7 959 801 D
  Component and/or Version: Tuer-SG         H02 0060
           Software Coding: 0004661
            Work Shop Code: WSC 01463 210 00000
                      VCID: 3D5FF71064350767E4-8068
Wednesday,10,August,2022,09:27:10:17577
                Address 47: Sound System       Labels: 8J0-035-223.lbl
Control Module Part Number: 8J0 035 223 D    HW: 8J0 035 223 D
  Component and/or Version: J525 Amp High   H04 0150
           Software Coding: 0136137
                      VCID: 256F3F70ECA5AFA79C-8070
16349 - Control Module - Error in Output Stage
                    Fault Frequency: 9
                    Reset counter: 146
                    Mileage: 155718 km
                    Date: 2019.08.31
                    Time: 00:00:17
Wednesday,10,August,2022,09:27:32:17577
                Address 56: Radio       Labels: 8E0-035-192-RNSE.clb
                    Reset counter: 22
                    Mileage: 191410 km
                    Date: 2021.12.12
                    Time: 07:22:50
                    Voltage: 10.70 V
                    Mileage: 191750 km
                    Count: 1612
                    Clock: 19:58
02261 - Data Medium
                    Reset counter: 13
                    Mileage: 191407 km
                    Date: 2021.12.11
                    Time: 08:07:34
                    Mileage: 191400 km
                    Count: 1212
                    Clock: 05:57
                    Reset counter: 228
                    Mileage: 171623 km
                    Date: 2020.11.03
                    Time: 00:43:38
                    Mileage: 171620 km
                    Count: 311
                    Clock: 00:43
                    Reset counter: 201
                    Mileage: 174304 km
                    Date: 2021.01.18
                    Time: 03:49:04
1660138720735-png.489927
1660138730987-png.489928
SwissJetPilot
Switzerland
C?ID=317276
Just a follow up on the 10 mm gap between the wind-shield and the roof flap...per the TSB (61 13 22 2015779/7 September 26, 2013) which you can find here -
1660218177717-png.489949
