Rs7 with Brake Issues
shams
Auckland, NZ
C?ID=380692
Hi guys, restoring an rs7 that has had zero brake oil in its cooling system. I think the system is not bleeding correctly as there is probably air stuck in the ABS pump. Previously the car was scanned (with a different scanner) and tried to be repaired but seems to have been put into a specific mode that i cant work out now and im trying repair this issue from here.
Scan is below. I was thinking to get this out of the setup procedure and then try to bleed the abs pump (if there is a wiki on that somewhere please ?)
Monday,08,August,2022,14:25:57:15412
VIN: WUAZZZ4G9EN905102   License Plate: RS7
Mileage: 110938km-68933mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 20 22 28 34 36 3B 3C
          42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 85 8B 8E 8F 90 BA
VIN: WUAZZZ4G9EN905102   Mileage: 110938km-68933miles
20-High Beam Assist. -- Status: Cannot be reached 0100
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560     HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0012
   Revision: NCH62---    CVN: 9171956C
   Coding: 1A2A00326546030A1000
   Shop #: WSC 24444 003 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906560 001013
   ROD: EV_ECM40TFS0114G0906560.rod
   VCID: 6597B35465E205635C9-8030
   VINID: 9E546AAAA117255789005040088444CE72
8993 - Intake Manifold Flap; Bank 2
          P2007 00 [229] - Stuck Closed
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:21:08
                    Engine RPM: 706.50 /min
                    Normed load value: 11.4 %
                    Coolant temperature: 48 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.829 V
                    Engine status: COENG_RUNNING
2978 - Intake Manifold Flap; Bank 1
          P2006 00 [229] - Stuck Closed
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:21:08
Readiness: 1110 1101
   Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H18 1006
   Revision: --H18---    CVN: 0DD02556
   VCID: 71BFD704A12AD9C3301-8024
   Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
   Component: ESP PREMIUM   H09 0100
   Coding: 61B7CB0386EDD3C0CB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004036
   VCID: 3E253C38A0F476BBFD3-806A
0848 - System Function Test Activated
          C101F 00 [009] - -
                    Reset counter: 166
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: FF
                    Uz: 8C
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Ldm_ApbFailureState]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:16:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: 95
   Part No SW: 4H0 907 064 ET    HW: 4H0 907 064 ET
   Component: BCM2 2.0      H36 0521
   Coding: 05BA2F06000000000000
   VCID: 7F5B013CE7FEBFB3B65-802A
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0096
   Serial number: 24041400042130
   Coding: 682360780D
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6A8DC0688CFC2A1B71B-803E
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001538258
   Coding: 0D07201009769FE2A98100C7A0001800CF9DC3082F090201800308456F01
   VCID: 6FBBD17CB79ECF33265-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140328  H37 0080
   Serial number:         140405050004
   Coding: 0045F7
   Serial number: 22546751
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 24 04 2014  00001151
   Subsystem 4 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0002
   Serial number: 00000000001401251994
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0002
   Serial number: 00000000001403272981
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA109501000007176697
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: A3988827000000000001
   Subsystem 8 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Serial number: 00000000001402202605
   Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
   Serial number: 00000000001403212335
03395 - Control Module for High Beam Assistant
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:22:00
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2313ED4C2BD63B53F2D-8076
   Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0091
   Revision: 11001001    Serial number: 61031410101904
   Coding: A8EB0D
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 73B3DD0CDB36EBD3C2D-8026
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7E04010101
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2809FA605270D80BA7F-807C
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_EPB_FAIL]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:22:19
                    Control Module temperature: 26 °C
                    Voltage terminal 15: 14.374 V
                    Velocity_vehicle_reference: -0.00 m/s
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:22:19
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00HRE9J
   Coding: 3031453032314E303134554A305234473853
   VCID: 3635241888C4BEFB253-8062
   Serial number: 3575HRB404T2EBKS78VI
   Serial number: 3585HRB404T2EBKS7GQM
   Serial number: 3515JRB404V2DJEUF0NB
   Serial number: 3525JRB404P2DJEUK9C9
   Serial number: 3554VRB400Q50VKSL1DK
   Serial number: 3564VRB401E50VKSHHGP
   Revision: --------    Serial number: 90372NDJ0003E
   Coding: 0000FC
   VCID: 372B291C8F4E47F33E5-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 26 02 2014  C0440871
   Part No SW: 4G8 920 932 P    HW: 4G8 920 932 P
   Component: TBenRdwAccNv  H58 0622
   Revision: 29460237    Serial number: 658220414596006
   Coding: 338F010B9F530008010500
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3C213630B6E864ABD37-8068
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001365334
   Coding: 00ED074800
   GVL: FDEFE9CCFEEB600D4100
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BDD808A42CE2DBC9B-8026
   Serial number: 7464333203
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140206000000000003EC
5701 - High Beam Assistant Control Module
          U1070 00 [009] - No Communication
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:22:39
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 27 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 206
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:25:56
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 11.7 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 1
Address 20: High Beam Assist.
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0200
   Serial number: 002404140001014
   Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
   Component: KLIMA FOND    H08 0096
   Serial number: 25041400041207
   Coding: 22
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 392F2F24B9DA5183C81-806C
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E050C787094863B6D3-807A
   Revision: AA000000    Serial number: 00000097336073
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77ABE91CCFCE87F3FE5-8022
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E00Z018
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B291C8FCE47F33E5-8062
   Part No SW: 4G0 907 566 L    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0010
   Revision: 00H04000    Serial number: 6PZ 010 287-10
   Coding: 0001106
   VCID: 38292A208E50488B37F-806C
   Subsystem 1 - Part No: 4G0 907 568 L
   Component: J770  SWA Slave H04 0010
   Subsystem 2 - Serial number: 6PZ 010 287-30
   Subsystem 3 - Serial number: 5F18.02.1400H04000AMS14596ÿ
   Subsystem 4 - Serial number: S14596ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F56025E01628002080413
   VCID: 45D753D4C5A22563BC9-8010
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0023517319
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D180864ACA2DB09B-8066
   Revision: 00002001    Serial number: 0333887145
   Coding: 013A0E20A0B9B08583300A840E0314470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO29022661
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
   Serial number: 0000000AP00006904645
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA108181000007189579
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93189614
   Revision: CJ007001    Serial number: 00000000099462
   Coding: 030000
   VCID: 1D67DBB40DB20DA3C49-8048
   Component: TSG BF        H03 0507
   Coding: 011F56025E01628002080402
   VCID: 46D554D8F8A42E7BB53-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000002019550
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 313F170461AA99C3701-8064
721152 - Brake Pad Replacement Mode Active
          C1011 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.18
                    Time: 01:04:19
                    Voltage terminal 30: 14.6 V
                    Internal Fault ID: 36
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140428-0002-030
   Coding: 11236F601000A300
   ROD: EV_HeadlRegulBasic_AU21.rod
   VCID: 2D070B747D92FD23549-8078
764928 - Left/Right Driving Switch-Over Active
          C1080 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:22:59
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227DP0E8001821
   Coding: 070003010000000001
   VCID: 2615F45858E4CE7B953-8072
   Part No SW: 4G0 035 764 J    HW: 4G0 035 764 J
   Component: H-BNT-RW      H53 0798
   Revision: --------    Serial number: 192DU0E7513071
   Coding: 0B0A01040303F9EF7D90CB2E000000035C0001000000000000
   VCID: 2E050C787014863B6D3-807A
   Subsystem 1 - Part No: 8R0 060 884 BN
   Component: ROW 2014  0605
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED004BS3W
   Subsystem 3 - Part No SW: 4G2 919 612 Q    HW: 4G2 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NDB001CX
   Component: CD-Database  5571
   Component: TSG HL        H03 0507
   Coding: 010F14024001628002080002
   VCID: 49CF5FE4E9BAC103581-801C
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273     HW: 4H0 907 273
   Component: RDKBERU25     H09 0700
   Serial number: 10000000008262
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 6889BA6092F0180B67F-803C
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0147265
   Coding: 0206000001000100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
   VCID: 2C0106704688F42B437-8078
   Part No SW: 4G8 959 107 Q    HW: 4G8 959 107 F
   Component: HDSG-Modul    H13 0043
   Revision: 11013001    Serial number: 102400624
   Coding: 0A3305C002
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 43D34DCCCB161B5392D-8016
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F4585864CE7B953-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7E04010101
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
          U1113 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:23:20
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 14.544 V
          U1113 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 21:23:20
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000120305147
   Coding: 03C01A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H07 0008
   Revision: 00001001    Serial number: 97812003559501
   ROD: EV_AEMLearAU64X.rod
End----(Elapsed Time: 03:10, VBatt start/end: 11.6V/11.5V. VIgn 11.3V)-----
Monday,08,August,2022,14:57:12:15412
0E-Media Player 1 -- Status: Cannot be reached 0100
17-Instruments -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
          C101F 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:22:06
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: FF
                    Uz: 73
          U1113 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:22:06
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: 73
0732 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [SCL_QSP_Ist_Moment_Error]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:22:06
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 08
                    Uz: 73
   Coding: 682360780D
   Coding: 0045F7
   Coding: 02006E
   Coding: 020300
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:09:00
   Coding: A8EB0D
13635840 - Supply voltage
          U1011 00 [009] - Voltage too Low
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:58
          U1400 00 [009] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:58
   Coding: 7E04010101
16640 - Function Restricted due to Insufficient Voltage
          U1400 00 [009] - -
          [FAULT_VMON_VZ_LOW1]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:56
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 9.080 V
          U1113 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:09:15
                    Voltage terminal 15: 11.323 V
          U1113 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:09:15
144896 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_US_FAIL]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:20:08
                    Voltage terminal 15: 8.929 V
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:21:35
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 8.994 V
          U1011 00 [137] - Voltage too Low
          [Powersupply lower threshold fall short of]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:20:59
   Coding: 0000FC
   Coding: 00ED074800
   Voltage stabilizer:
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:09:16
                    Voltage terminal 30: 11.3 V
                    Voltage terminal 15: 11.3 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U140B 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:09:15
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 2
0002 - Supply voltage
          [Versorgungsspannung zu niedrig DTC_KL30_UNDER_VOLTAGE]
                    Reset counter: 2
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:24
   Coding: 22
   Coding: 008002
   ROD: EV_SARA2.rod
   Coding: 0001106
   Coding: 901F00
03700 - Control Module for Rear Spoiler Positioning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:58
          C1011 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.18
                    Time: 01:04:19
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
10554390 - Supply voltage
          [FC_LOW_V_BATT]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:20:00
                    Voltage terminal 30: 8.9 V
                    Internal Fault ID: 40
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          C1080 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:09:15
Address 56: Radio
   Coding: 0A3305C002
   Coding: EA060000
0232 - Function Restricted due to Insufficient Voltage
          U1400 00 [009] - -
          [Functional_restrictions_low_voltage]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:20:04
                    Outside temperature: -42.5 °C
                    Voltage terminal 15: 8.5 V
                    Control Module temperature: 40.0 °C
0233 - Supply voltage
          [Ubat_too_low]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:20:04
   Coding: 7E04010101
          U1400 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:57
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 8.972 V
          U1113 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:09:15
                    Voltage terminal 15: 11.298 V
          U1113 00 [009] - -
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:09:15
          U1113 00 [009] - -
          [FAULT_CIS_US_FAIL]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:20:08
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 8.895 V
   ROD: EV_BC7.rod
0049 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Airbag_Airbag_01_System_error]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:21:08
                    Outside temperature: 15.5 °C
                    Voltage terminal 15: 9.0 V
                    Control Module temperature: 29.0 °C
0165 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [QSP_Signal_Error]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:20:29
0173 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [APS_Signal_Error_Master]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:20:29
0091 - Function Limitation due to Missing Video Data
          C1108 00 [009] - -
          [DPC_SystemError]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:21:35
                    Control Module temperature: 30.0 °C
   ROD: EV_RGS_L.rod
12585216 - Supply voltage
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:57
   ROD: EV_RGS_R.rod
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:56
0017 - Function Restricted due to Insufficient Voltage
          U1400 00 [009] - -
          [FC_FunctionalityLimitedByUndervoltage]
                    Reset counter: 166
                    Mileage: 110938 km
                    Date: 2022.07.20
                    Time: 22:19:53
End-----(Elapsed Time: 02:51, VBatt start/end: 9.1V/9.1V. VIgn 9.0V)-------
Morski
Cheshire UK
C?ID=90186
You have air in the abs system for sure. You will need to cycle the abs pump which vcds can not do. use a pressure bleeder to get most of the air out followed by the 2 man method as well. Get you pedal as firm as you can and then either go for a drive and activate abs a few times and rebleed. OR use a different scan tool to cycle the abs. Its a pain but doable.
The test function has been activated and can not be removed until car is driven straight and left and right turn performed.
EuroX
Northern NJ USA
C?ID=208579
How about air in the master cylinder??
Morski
Cheshire UK
C?ID=90186
That will get 'bled' out when new fluid is forced through the reservoir
Huh? There's definitely an Output Test for the ABS return flow pump.
Morski
Cheshire UK
C?ID=90186
Pretty sure there is nothing there when i tried to do mine last year
shams
Auckland, NZ
C?ID=380692
Hi guys
Yes should hopefully just be air in the abs pump.
So yes there is a flow test and i can activate the pump but because only 2 lines are affected i think it is in those two chambers so not sure the abs pump activation will cycle it all. Is my best bet the pressure bleeder ?
I cant get out of the test setup at the moment even if i do the drive, not sure why.
Morski
Cheshire UK
C?ID=90186
You will need a pressure bleeder for sure. The test will auto cancel when the correct procedure is done ie straight followed by turn left then right or similar; check this out in the workshop manual
