Any settings to get SIM to connect quicker
pnickisson
Manchester, UK
C?ID=518359
Hello All
I have a 2019 mk3 TT with Navigation and Audi Connect connected via a three SIM using the inbuilt SIM reader. It takes ages to get an online connection in the Navigation Menu. When it starts up it says TMCPro then it goes to LTE and then will get to 3G after about 4mins.
Are their any settings/adaptations that can be made to get to enable it to start the connection more quickly that anyone is aware of?
Reason it would be good to get it done more quickly is to calculate the best satnav routes based on the traffic information using Audi Connect before I set off but I'm not actually sure the Navigation does that as I don't get the 'online' symbol before it calculates the route calculation.
All assistance gratefully appreciated.
my Autoscan is as below
Friday,29,July,2022,19:00:03:40455
VIN: TRUZZZFVXXXXXXXXXX   License Plate: XXXX XXX
Mileage: 33522km-20829mi   Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
VIN: TRUZZZFV1K1006218   Mileage: 33522km-20829miles
Address 01: Engine (J623-DKZB)       Labels: None
   Part No SW: 8S0 907 115     HW: 06K 907 309 B
   Component: R4 2.0l TFSI  H60 0003
   Revision: O1H60000    CVN: 3E9843E6
   Coding: 022540122424050B24000000000000000000000000000000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0118S0907115 001005
   ROD: EV_ECM20TFS0118S0907115.rod
   VCID: 72BDD4205426C1EBC9B-8026
   VINID: 92296AAAA5A605B04000608120B52CFC51
Readiness: 1110 0001
   Part No SW: 0GC 300 044 J    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2402
   Revision: 00H06V08    CVN: AE09ED6E
   ROD: EV_TCMDQ381061.rod
   VCID: 2F3B1D548794AC03665-807A
   No subsystems:
   Part No SW: 8S0 907 379 K    HW: 8S0 907 379 F
   Component: ESC           H42 0542
   Revision: 00000000    Serial number: 60289000000022
   Coding: 11AAA08D1A9915AF41930065C299970EB3880558A8820043E970CD
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
   ROD: EV_Brake1UDSContiMK100IPB_060.rod
   VCID: 49CF53CC1930E233581-801C
   Part No SW: 3Q0 959 435 F    HW: 3Q0 959 435 F
   Component: VWKESSYMQB    027 0907
   Revision: 00027000    Serial number: 0506190730
   Coding: 000F0F1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3D27371C5DF84E93E49-8068
   Part No SW: 8S0 820 047     HW: 8S0 820 047
   Component: AC Manuell el H05 0040
   Revision: 20010000    Serial number: 19190000009000
   Coding: 410040000011100100
   ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
   ROD: EV_AirCondiMAPrehAU33x.rod
   VCID: 70B9DE285A2AF3FB3FF-8024
   Rear A/C Control Head 1:
   Subsystem 1 - Part No SW: 8S0 820 374 A    HW: 8S0 820 374 A
   Component: E774 BuA_1  H06 0010
   Serial number: 00000000000000011262
   Rear A/C Control Head 2:
   Subsystem 2 - Part No SW: 8S0 820 360 D    HW: 8S0 820 360 D
   Component: E775 BuA_2  H06 0010
   Rear A/C Control Head 3:
   Subsystem 3 - Part No SW: 8S0 820 360 C    HW: 8S0 820 360 C
   Component: E776 BuA_3  H06 0010
   Rear A/C Control Head 4:
   Subsystem 4 - Part No SW: 8S0 820 360 E    HW: 8S0 820 360 E
   Component: E777 BuA_4  H06 0010
   Rear A/C Control Head 5:
   Subsystem 5 - Part No SW: 8S0 820 374 B    HW: 8S0 820 374 B
   Component: E778 BuA_5  H06 0010
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001905404375
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CA1FA180662879B937-8028
   Subsystem 1 - Part No SW: 8S2 955 119 B    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: 43x RL 030718  038 0371
   Serial number: 00000001806280308445
   Coding: 1BC7F7
   Subsystem 2 - Part No SW: 81A 955 559 A    HW: 81A 955 559
   Component: G397_RLS  H06 0002
   Serial number: 20188574X81A955559A0
   Coding: 00005D
   Serial number: 11 10 2018  20001419
   Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY190020G35
   Serial number: 00000000000046516366
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39231903702893
   Coding: 0000040011
   VCID: 3C213A1846E2479BD37-8068
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    010 0870
   Serial number: 003M7R02S8GR
   Coding: 88CCF0C00C8000005C5000CFC0C800000065
   VCID: 4DC767DCED58FE13749-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 001 402 19
   Serial number: 3570000000084380693D
   Subsystem 2 - Part No SW: -----------    HW: 480 001 402 19
   Serial number: 35800000000A4380693G
   Subsystem 3 - Part No SW: -----------    HW: 480 010 201 19
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A0DE8B29E4BC1X
   Subsystem 4 - Part No SW: -----------    HW: 480 402 501 19
   Serial number: 3550001282BFB78495CM
   Subsystem 5 - Part No SW: -----------    HW: 480 401 402 19
   Component: FrontSensor_P  003 6149
   Serial number: 3560001BB2E4B1B4825D
   Subsystem 6 - Part No SW: -----------    HW: 480 400 502 19
   Component: PedP_Sensor_C  004 6149
   Serial number: 2300001042B7F1C4920U
   Subsystem 7 - Part No SW: -----------    HW: 480 000 102 19
   Serial number: I0M00000000803D0483-
   Subsystem 8 - Part No SW: -----------    HW: 480 000 102 19
   Serial number: I0N00000000F1321E731
   Part No SW: 8S0 907 129 AG    HW: 8S0 907 129 AG
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335SB600171
   Coding: 201C
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_050.rod
   VCID: 7F5B0D1417749C83B65-802A
   Part No SW: 8S0 920 790 D    HW: 8S0 920 790 D
   Component: FBenRDW       H45 0359
   Coding: 24A50150298006000100E8C09000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001032
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 3A2D3C004CD679ABC1B-806E
   Part No SW: 8S0 907 468 J    HW: 8S0 907 468 E
   Component: GW MQB TT3    023 0366
   Serial number: 17021910802195
   Coding: 030100042F025B004B0002681C0B00000000000000000000000000000001
   GVL: 01543C1000000600400C10000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewContiAU33X 013025
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 47CB55F40F2414434E5-8012
   Generator:
   Component: 1-01-0d-01-04
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0002
   Serial number: 20190130002134 00031
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 1045930405
   Serial number: 18000421071006
   Coding: 0900000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 333311246BBC88E302D-8066
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SAJ3463B
   Coding: 001042225001000100001402
   VCID: 44D142F83E123F5BAB7-8010
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SAH31376
   Coding: 001042225C01000100001402
   VCID: 43D341E43B1C386392D-8016
   Coding: 039E000001000000
   VCID: 75B7EF3C2548D6D3EC9-8020
   Part No SW: 8S0 035 021 M    HW: 8S0 035 021 K
   Component: MU-H-LND-EU   055 1339
   Serial number: A710B0KS011927
   Coding: 01330401FF00000011111101000A00312F0000E300700000DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK112121800010316
   Compact disc data bank:
   Component: Gracenote2  --- 1017
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8S0 907 159 E    HW: 81A 907 159 A
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 190122201351
   VCID: 3FDB4D1457F45C83F65-806A
End----------(Elapsed Time: 01:18, VBatt start/end: 12.9V/12.7V)-----------
