knoxsyncro
- Dec 25, 2020
- 6
- 3
- Knoxville, TN, USA
- HUC-2H
2011 Q5 2.0 TFSI, owned for 30K miles.
I've got a problem that I can't get rid of. #5671 P0299 boost pressure. Since the diverter valve is the usual suspect, I replaced it. I still had the problem afterward.
I have 8 or more scans for this problem. The other codes found are P2279, P050A, P2188, all of the cylinder misfire plus multi-cylinder misfire, the EPC code, and some more I'm sure of.
Today, I scanned and cleared and then went for an aggressive drive. It didn't take long for the engine to misfire and then when I kept pushing it, the EPC light came on and had a steady misfire. Restarting the car reset the EPC. I pulled the codes when I returned home.
Here are the early scan and the later scan
Sunday,07,August,2022,08:53:35:06799
VCDS Version: 22.3.1.4 (x64)
VIN: WA1LFAFP0BA080543 License Plate: Q5 AUG 7 2022
Mileage: 256100km-159133mi Repair Order:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62
6C 6D 72
VIN: WA1LFAFP0BA080543 Mileage: 256100km-159133miles
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0002
Revision: E1H19--- CVN: 35256D79
Coding: 0121010A290F0160
Shop #: WSC 44174 002 1048576
ASAM Dataset: EV_ECM20TFS0118R0907115P 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 418334F7D093458780-8014
VINID: 9D105C5915A00124402001440CD8C5FACF
5646 - Leak in Air Intake System
P2279 00 [237] - -
Mileage: 255755 km
Date: 2022.07.25
Time: 07:39:49
Engine RPM: 848.00 /min
Normed load value: 14.1 %
Coolant temperature: 67 °C
Intake air temperature: 30 °C
Voltage terminal 30: 13.075 V
5671 - Boost Pressure Regulation
P0299 00 [101] - Control Range Not Reached
Mileage: 255743 km
Date: 2022.07.24
Time: 15:15:00
Engine RPM: 3448.50 /min
Normed load value: 73.7 %
Vehicle speed: 73 km/h
Coolant temperature: 78 °C
Intake air temperature: 48 °C
Voltage terminal 30: 13.052 V
4106 - Bank 1; System too Rich at Idle
P2188 00 [096] - -
Mileage: 255786 km
Date: 2022.07.25
Time: 17:29:49
Engine RPM: 821.00 /min
Normed load value: 13.3 %
Coolant temperature: 76 °C
Intake air temperature: 39 °C
Voltage terminal 30: 13.216 V
Unlearning counter according OBD: 22
Part No SW: 8R0 927 158 E HW: 0BK 927 156 N
Component: 0BK 20TFSIUSA H08 0010
Revision: --H08--- CVN: 412C3465
Coding: 001112
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMAL551211 001013
ROD: EV_TCMAL551211_001.rod
VCID: 3F87320FA6673377F6-806A
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 ESP8 quattro H06 01100110
Coding: 121D18
VCID: 458B20E7CCBB69A7BC-8010
No Faults Found
Part No SW: 8K0 907 064 CS HW: 8K0 907 064 CS
Component: BCM2 2.0 H05 0435
Coding: 090500
VCID: 030FFEFF820F9797D2-8056
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000006697013
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000011202010
00955 - Key 1
Reset counter: 30
Mileage: 255857 km
Date: 2022.07.27
Time: 08:40:32
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Revision: C1000000 Serial number: 01010220112130
Coding: 64112000
VCID: 0005F1F393198C8FCF-8054
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000932393
Coding: 26001091063CAF010000080300001D0D0F1C460802010161000000
VCID: 3C7D4503BF71286FD3-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 110117 H11 0050
Serial number: 90243014110112062851
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11259097
Coding: 024D25
Component: E1 - LDS H03 0031
Serial number: 00000000002801110378
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0080
Revision: 11001001 Serial number: 12501103001530
Coding: 300105
VCID: 78F59913CBC9C44FF7-802C
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Component: AirbagVW-AU10 H44 0610
Serial number: 003GPD0N0DBI
Coding: 303633313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 47972AEFFEB77BB74E-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1100003Q5P
Serial number: 6334MSME5C253345C
Serial number: 6344MSME5C24547CP
Serial number: 6352QSME710222562
Serial number: 6362QSME3500544A9
Serial number: 63732SME7300095E.
Serial number: 63832SME73001366Q
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KAO001BI
Coding: 000017
VCID: 3D7B4807A46B2167E4-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 G HW: 8R0 920 981 G
Component: KOMBIINSTR. H19 0258
Revision: 00000000 Serial number: EK030EM1C
Coding: 8B1622000300D705020000
VCID: 3E794F0BA96D3A7FFD-806A
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E1111900E9
Coding: 00C303
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650484300
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0075
Revision: AA000000 Serial number: 00001002299756
Coding: 00581300000000000000
VCID: 42813BFBDD955E9F99-8016
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000012132193
Coding: 011D03205E00440004
VCID: 4A9113DBE5A586DF51-801E
Revision: 00002001 Serial number: 0142466691
Coding: 0126023A20FA749484B0053200000000
Component: GTO BF H01 0070
Serial number: 00000000000000356004
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Fault Status: 11101100
Reset counter: 238
Mileage: 255720 km
Date: 2022.07.23
Time: 20:21:16
03073 - Rear Lid Closed Sensor 1
Reset counter: 35
Mileage: 255941 km
Date: 2022.07.28
Time: 18:11:15
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0004000217274
VCID: 49932CD7E0A38DC758-801C
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000850640
VCID: 346D6D239721E02F1B-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 D
Component: Dynamische LWR H02 0010
Coding: 0000006
VCID: 3669572B415DF23F25-8062
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471B.0B7557175
Coding: 020007020100000001
VCID: 5DBBE887442B016784-8008
Part No SW: 8T1 035 664 C HW: 8T1 035 664 B
Component: H-BN-NA H51 0116
Revision: -------- Serial number: 490BZ0B7603819
Coding: 010200060005A1EF41000B0E000000030000
VCID: 387559138B49044F37-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466B 0B0437974
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000733494
Component: CD-Database 1886
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000112673592
Coding: 010C03204000240004
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H05--- Serial number: 525PA8-J0YA2JN
Coding: 1020010
VCID: 346D6D235721E02F1B-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H51 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B7F461FBA7F2F57DA-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H51 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000112676531
Sunday,07,August,2022,12:40:29:06799
VIN: WA1LFAFP0BA080543 License Plate: Q5 TEST 2 AUG 7
Mileage: 256120km-159145mi Repair Order:
6C 6D 72
VIN: WA1LFAFP0BA080543 Mileage: 256120km-159145miles
P0299 00 [237] - Control Range Not Reached
Mileage: 256110 km
Date: 2022.08.07
Time: 10:48:58
Engine RPM: 3949.50 /min
Normed load value: 78.8 %
Vehicle speed: 66 km/h
Coolant temperature: 77 °C
Intake air temperature: 34 °C
4054 - Cylinder 1
P0301 00 [100] - Misfire Detected
Mileage: 256110 km
Date: 2022.08.07
Time: 10:49:09
Engine RPM: 3775.00 /min
Normed load value: 88.2 %
Vehicle speed: 105 km/h
Intake air temperature: 36 °C
Voltage terminal 30: 13.169 V
Unlearning counter according OBD: 78
7960 - Cylinder Disabling
P130A 00 [032] - -
Mileage: 256110 km
Date: 2022.08.07
Time: 10:49:12
Engine RPM: 4126.00 /min
Normed load value: 85.5 %
Vehicle speed: 115 km/h
Intake air temperature: 38 °C
Voltage terminal 30: 13.193 V
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [100] - -
Mileage: 256110 km
Date: 2022.08.07
Time: 10:49:09
Readiness: 0000 0101
Coding: 001112
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Component: ESP8 quattro H06 0110
Coding: 121D18
Coding: 090500
Coding: 64112000
Coding: 01DD13
Coding: 024D25
Coding: 300105
Coding: 000017
Coding: 00C303
Reset counter: 7
Mileage: 256120 km
Date: 2022.08.07
Time: 12:32:40
Coding: 0000006
Coding: 1020010
End-------------------------(Elapsed Time: 04:37)--------------------------
End-------------------------(Elapsed Time: 07:23)--------------------------
