Resolved Remote Control with "Terminal 15 ON" inactive (2021 Tiguan)
Resolved
Shagbore
Brantford, ON, Canada
C?ID=525549
Hello!
New to the community and new owner of the HEX-NET pro. I have always gotten my tweaks done by someone off of marketplace or kijiji but have decided to pull the pin and invest in my own. I have owned a VW for the last 15 years, mostly have been Jetta's but I am now driving a 2021 Tiguan Comfortline 2.0 TFSI 4Motion.
The first tweak I would like to do is disable the "Remote Control with Terminal 15 ON inactive", so that I can lock/unlock the vehicle while it is running.
I have spent some time searching and reading through posts and am quite confused.
I think I have figured it out but not really, if that makes sense haha. Meaning that I have narrowed it down to that tweaks are now found in Adaptation - 10 and not Coding - 07
I have scrolled through that long list quite a few times and can't seem to find anything that would disable the "Remote Control with "Terminal 15 ON" inactive"
Also when I try to navigate Coding -07 i get a Coding is NOT supported by this Control Model Variant...etc..
So here I am, day after getting my Hex-net looking for help! haha, TIA
Pictures and Scan Below:
Cheers
Saturday,06,August,2022,12:13:07:20884
VCDS Version: 22.3.1.4 (x64)  HEX-NET2 CB: 0.4615.4
VIN: 3VV2B7AX5MM136412   License Plate:
Mileage: 13470km-8369mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 3C 42 44 52 5F 6C 6D BB BC
VIN: 3VV2B7AX5MM136412   Mileage: 13470km-8369miles
Address 01: Engine (J623-DTEA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115 F    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0002
   Revision: 1DH31000    CVN: 63029C9B
   Coding: 012A00122426012F34000000000000000000000000000000
   Shop #: WSC 00066 790 00449
   ASAM Dataset: EV_ECM20TFS01183A907115F 001004
   ROD: EV_ECM20TFS01183A907115F.rod
   VCID: 29049253D97C3B03B81-807C
   VINID: 0E698248746815D7410C610108F6CEB332
23765 - Control unit for information electronics 1
          U1054 00 [032] - No Communication
          [Information electronics control module 1No Communication]
   Part No SW: 09G 927 158 FN    HW: 09G 927 158
   Component: AISIN AQ8     206 3756
   CVN: 7343B318
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00438
   ROD: EV_TCMAQ450031_VW32.rod
   VCID: 045AE3E71E9E066BEB7-8050
   Part No SW: 5Q0 614 517 GA    HW: 5Q0 614 517 BN
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 51131000000276
   Coding: 0BFA6BA450231B72C57B0301A2C549D0D60AD8A3C045927410415058D28A4A0B00402F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 76BE892F584224FBE53-8022
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 177
                    Mileage: 13011 km
                    Date: 2022.07.24
                    Time: 18:12:17
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0572914887
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45DC3EE35524FF63BC9-8010
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NN 907 044 AF    HW: 5NN 907 044 AF
   Component: AC Automat    H36 4901
   Revision: 20K04000    Serial number: 00000D00736654
   Coding: 0002000420011C001004000012111416
   ASAM Dataset: EV_ACClimaPrehVW37X 002030
   VCID: 1072DFB75AE66ACB5FF-8044
   Part No SW: 5Q0 937 085 CF    HW: 5Q0 937 085 CF
   Component: BCM MQBAB MNA H42 0411
   Serial number: 1140086001ÿÿÿÿ
   Shop #: WSC 00066 790 00277
   ASAM Dataset: EV_BCMMQB 021001
   ROD: EV_BCMBOSCH_021_VW27.rod
   VCID: 7F506C0B777865B3B65-802A
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 210401  034 0373
   Serial number: 21032821045030
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S6Y21M03D17H11M27S46
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 KF    HW: 5Q1 953 569 H
   Component: Lenks.Modul  H04 0190
   Serial number: 0300070520210C200437
8714 - Bulb for Left Fog Lamp
          B121F 15 [009] - Open or Short to Plus
                    Reset counter: 14
                    Mileage: 1364 km
                    Date: 2021.10.12
                    Time: 14:17:06
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 13.3 V
                    Outside temperature: 21.0 °C
   Part No SW: 2Q0 907 572 T    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H04 0383
   Coding: 3200009150FF8728749C810500408700000000000000000014
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003.rod
   Part No SW: 5Q0 959 655 CB    HW: 5Q0 959 655 CB
   Component: AirbagVW21    008 0421
   Serial number: 003J4M02YTG0
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 0256E5FF048A085BD9B-8056
   Component: BF-Gewichtss.  H16 0022
   Serial number: IBH00000000000FZDX0D
   Coding: 303451
   Subsystem 2 - Part No SW: -----------    HW: 480 000 803 21
   Serial number: 35700000000F1179615H
   Subsystem 3 - Part No SW: -----------    HW: 480 000 803 21
   Serial number: 358000000006D2414159
   Subsystem 4 - Part No SW: -----------    HW: 480 401 903 21
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001B301BA30364AT
   Subsystem 5 - Part No SW: -----------    HW: 480 402 303 21
   Component: SideSensor_Pr  003 6149
   Serial number: 35200019F0285413C42X
   Subsystem 6 - Part No SW: -----------    HW: 480 402 303 21
   Component: FrontSensor_D  003 6149
   Serial number: 3550001B10285413F2BY
   Subsystem 7 - Part No SW: -----------    HW: 480 402 303 21
   Component: FrontSensor_P  003 6149
   Serial number: 3560001B1028541463FW
   Part No SW: 5NA 920 750 E    HW: 5NA 920 750 E
   Component: KOMBI         344 8500
   Coding: 0BE40C0AA388880902886A0914000000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   VCID: 40D22FF74A06DA4B8FF-8014
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 20052100843054
   Coding: 030500347F085900FB0322481E0F00010001070000000000000000000000
   Shop #: WSC 00066 790 00271
   GVL: 01C03C0008000400404C80000002C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 74BAB3274E3E36EBDB7-8020
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 A    HW: 5NA 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H06 0025
   Serial number: 0192103031800269FE2B
   Coding: 280000
   Serial number: 6886738100
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00022.01.21
   Coding: 0101
   VCID: 4CCA0BC7764E0E2B637-8018
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 11230034315029
   Coding: 5294C640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 3924421329DC8B83C81-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 11230034194120
   Part No SW: 5Q4 959 393 N    HW: 5Q4 959 393 N
   Component: TSG FS        008 0820
   Serial number: 99028114002458
   Coding: 00301B200000048000000000
   Shop #: WSC 01383 790 50316
   VCID: 4ECE01CF80523C3B0D3-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000008619692
   Coding: 011000
   Part No SW: 5QM 909 144 C    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1082
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 51F41AB3916C23C3101-8004
   Part No SW: 5Q4 959 392 N    HW: 5Q4 959 392 N
   Component: TSG BFS       008 0820
   Serial number: 00028113903363
   Coding: 003013200000048000000000
   VCID: 4DCC06C38D540723749-8018
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000008643518
   Coding: 091000
   Part No SW: 3G5 035 842 C    HW: 3G5 035 842 A
   Component: MU-O-NS-US    H56 0805
   Serial number: WG8LGM120521000
   Coding: 23260000002000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001002
   ROD: EV_MUOIMQB_VW27.rod
   VCID: 28029757C276020BA7F-807C
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  261 8214
   Serial number: VWZ6ZMY1465501
   Subsystem 2 - Part No SW: V03 959 809 CR    HW: -----------
   Component: NAR 2021       --- 5041
   Coding: 0123060120002017300040
   Part No SW: 5Q0 959 107 AA    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0272
   Revision: --------    Serial number: A2-C773-9590-1
   Coding: 0A08
   VCID: 77A0842B5F485DF3FE5-8022
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:12, VBatt start/end: 13.1V/13.1V)-----------
Correct, this BCM doesn't have coding.
That said, I've looked through the list of Adaptation channels in this module and haven't found an obvious equivalent for "Remote Control with Terminal 15 ON inactive" either.
Shagbore
C?ID=525549
So there is no way to enable the keyfob for functionality once the vehicle is started?
The fact that I haven't found it doesn't necessarily mean there isn't a way. ;)
Shagbore
C?ID=525549
ok, phew, this was one of the main reasons I bought the Hex-Net, just had a moment of sickness thinking I just bought a $1000 (CAD) tool that could no longer do the tweak that I have had done many times before. haha,
Winter is coming and I now live in an area where I am no longer comfortable starting my car and letting it sit unattended to defrost in the mornings. Opting for a remote starter didn't seem as appealing as buying the Hex-Net as I do tend to upgrade vehicles periodically.
IS there somewhere else I can post or reach out to help with this? or do you have some resources that you can look into at your convenience?
Thanks!
Winter is coming
It's the first half of August right now. Perhaps someone more familiar with the BCM in your car will chime in here.
Shagbore
C?ID=525549
Well, I couldn't sleep and the whiskey was still going down smooth. After spending some time digging around I came across this post
"Funk bei Klemme 15 ein"
That is the adaptation channel name one needs to switch to active to be able to use their keyfobs to lock/unlock the car while the engine is running. Also an added bonus is you can lock/unlock with the door sensors! keyless locking/unlocking works as well when engine is running.
Thanks, have a good one!
