MAP Sensor and Trans+ABS DTC mem 2013 Jetta 2.5 family car 43K miles
RayJuod
C?ID=127865
My wife's 5 mile a day driver occasionally gets the wrench symbol in the dash display, always on day trips after at least 30 or 40 miles of medium stop / go driving, or about 80+ straight ahead highway miles then stop and go, and even more so up hills. I also hear a clunk at the time that the wrench appears. The wrench goes away after the car is cycled off then on again the next day. I have not done any regular maintenance other than oil change, air filter, and changed the PCV valve 2 years ago. Could the Trans and ABS fails be due to the MAP sensor, or vice versa? Is there a way to investigate the Trans and ABS brakes further? Thanks
Saturday,06,August,2022,09:48:13:31041
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: 3VWDP7AJ7DM447079   License Plate:
Mileage: 69630km-43266mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDP7AJ7DM447079   Mileage: 69630km-43266miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CP    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 4725
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 7EA5FFE4BCF0E1EBBDE-802A
   VINID: 0E69D480745A1D474410700724A5D376AA
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal - Intermittent
                    Mileage: 69505 km
                    Date: 2016.12.22
                    Time: 00:15:43
                    RPM: 1405 /min
                    Load: 25.5 %
                    Speed: 69.0 km/h
                    Temperature: 84.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           2246
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 0059811CC604971BCF2-8054
                    Fault Status: 00101101
                    Fault Frequency: 20
                    Reset counter: 160
                    Mileage: 42620 km
                    Date: 2018.11.12
                    Time: 16:30:09
   Revision: 00H31001
   Coding: B14B400C492608018D0B02EB92221061A71000
   VCID: 7DA7F8E8BDF6FAF3A44-8028
                    Reset counter: 214
                    Mileage: 68943 km
                    Date: 2016.12.01
                    Time: 05:05:56
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 49408
                    Count: 511
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001585129
   VCID: 6099A19C2644371BAF2-8034
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371140130905
   Coding: 7B994B1808AB0B0000382000240884C500C2502E60000000300000000000
   VCID: 2F3B12A0271AD863668-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 3465
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 3465
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Serial number: 0233217 FLE 20130424
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
   Component: J388__TSG_HL  004 3464
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
   Component: J389__TSG_HR  004 3464
   Coding: 800000
   Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
   Component: AirbagVW10G   013 0851
   Serial number: 003LKM04PF1P
   Coding: 00004A33
   Shop #: WSC 00066 000 00201
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 40D9411C8A04571B8F2-8014
   Serial number: 6940000Y130000UAHZ0K
   Coding: 303036
   Serial number: 3572MSME3E585578ZZZ5
   Serial number: 3582MSME35133478ZZZS
   Serial number: 3516KSME09376E23ZZZX
   Serial number: 3526KSME3A7B2623ZZZY
   Serial number: 3556LSME0E0E6C21ZZZ0
   Serial number: 3566LSME22645B21ZZZS
   Part No SW: 5C6 920 952 B    HW: 5C6 920 952 B
   Component: KOMBI         H06 0705
   Coding: 270A01
   VCID: 2B0306B01382A4434A0-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
   VCID: 70B9D1DCFAA4879B3F2-8024
   Component: IMMO          H06 0705
   VCID: 6A8DC3B4DCF87D4B716-803E
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664534554
   Coding: 010100
   VCID: 2A0D03B41CF8BD4BB16-807E
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H03 0005
   Revision: -----07S    Serial number: VWZ4Z6N3570344
   Coding: 01000400020006
   VCID: 2517F08875E692339C4-8070
                    Reset counter: 45
                    Mileage: 57723 km
                    Date: 2015.08.18
                    Time: 01:41:57
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664544708
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2D33F4ECD80DCBC16-806E
End----(Elapsed Time: 01:11, VBatt start/end: 12.1V/12.1V. VIgn 11.9V)-----
