2014 Audi A4 Check Engine light/Misfire MVBs
TFSI
Maryland, USA
C?ID=66650
So I have this2.0T Audi A4 with CEL on, car runs or responds to accelerator pedal well when revving up but MVBs taken on cylinder misfire shows all cylinders are misfiring but car runs smoothly, not sure if these MVBs are real or something else. Fuel rail pressure actual and specified shows no significant differences to suggest the source of misfire. Are these values of cyl misfire for all 4 cylinders accurate?
Friday,05,August,2022,09:27:38:46890
VCDS Version: 22.3.1.4 (x64)
VIN: WAUBFAFL0EN040990   License Plate: FELICIA A4
                Address 01: Engine       Labels: 06H-907-115-CDN.clb
Control Module Part Number: 8K5 907 115 N    HW: 8K2 907 115 L
  Component and/or Version: 2.0l R4/4V TF H09 0005
           Software Coding: 4A2A0013242600062000
            Work Shop Code: WSC 62026 004 1048576
              ASAM Dataset: EV_ECM20TFS0118K5907115N 001006 (AU48)
                       ROD: EV_ECM20TFS0118K5907115N.rod
                      VCID: 3D7AF0EDACC68467E4-8068
16 Faults Found:
5582 - Oil Pressure Switch for reduced Oil Pressure
          P164D 00 [040] - Malfunction
                    Mileage: 272466 km
                    Date: 2022.08.01
                    Time: 10:08:10
                    Engine RPM: 827.00 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 13.970 V
                    Heated oxygen sensor bank 1: sensor 1: resistance: 300.94 Ohm
                    Heated oxygen sensor bank 1: sensor 1: activation: 39.572 %
                    Outside air temperature via CAN: 25.5 °C
                    Oxygen sensor 1 bank 1 ceramic temp: 779.64 °C
5646 - Leak in Air Intake System
          P2279 00 [237] - -
                    Mileage: 267260 km
                    Date: 2022.06.11
                    Time: 01:55:20
                    Engine RPM: 821.00 /min
                    Normed load value: 20.0 %
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 13.947 V
                    Engine status: COENG_RUNNING
22655 - Fuel Trim; Bank 1
          P0171 00 [096] - System Too Lean
22656 - Fuel Trim; Bank 1
          P0172 00 [236] - System Too Rich
                    Fault Frequency: 105
                    Mileage: 255341 km
                    Date: 2022.02.23
                    Time: 18:11:24
                    Engine RPM: 816.50 /min
                    Normed load value: 20.8 %
                    Coolant temperature: 98 °C
                    Intake air temperature: 48 °C
13276 - Sensor for Fuel Composition / Quality (G446)
          P0177 00 [101] - Implausible Signal
                    Mileage: 271438 km
                    Date: 2022.07.21
                    Time: 08:43:44
                    Engine RPM: 0.00 /min
                    Coolant temperature: 34 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 12.109 V
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
4113 - Camshaft Position Sensor (G40)
          P0341 00 [032] - Implausible Signal
                    Mileage: 271911 km
                    Date: 2022.07.27
                    Time: 09:47:18
                    Engine RPM: 782.50 /min
                    Normed load value: 22.4 %
                    Vehicle speed: 11 km/h
                    Coolant temperature: 97 °C
2822 - Bank 1; System Too Rich off Idle
          P2178 00 [237] - -
                    Mileage: 271438 km
                    Date: 2022.07.21
                    Time: 08:43:44
                    Engine RPM: 1648.00 /min
                    Normed load value: 13.3 %
                    Vehicle speed: 41 km/h
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 14.112 V
10434 - Catalyst System; Bank 1
          P0420 00 [096] - Efficiency Below Threshold
4010 - Idle Control System
          P0506 00 [032] - RPM Lower than Expected
4012 - Cold Start Idle Air Control System
          P050A 00 [032] - Malfunction
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [032] - -
                    Mileage: 272079 km
                    Date: 2022.07.28
                    Time: 09:32:30
                    Normed load value: 19.6 %
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 13.711 V
                    Unlearning counter according OBD: 27
10591 - Cylinder 1
          P0301 00 [032] - Misfire Detected
                    Mileage: 272079 km
                    Date: 2022.07.28
                    Time: 09:32:30
10593 - Cylinder 3
          P0303 00 [032] - Misfire Detected
10594 - Cylinder 4
          P0304 00 [032] - Misfire Detected
4106 - Bank 1; System too Rich at Idle
          P2188 00 [109] - -
                    Fault Frequency: 74
                    Mileage: 255083 km
                    Date: 2022.02.22
                    Time: 10:53:33
                    Engine RPM: 823.50 /min
                    Voltage terminal 30: 14.536 V
                    Unlearning counter according OBD: 36
4201 - Fuel Level too Low
          P1250 00 [032] - -
Address 01: Engine (8K5 907 115 N)
09:31:02
IDE00347 Air mass: actual value: 3.91 g/s
IDE00496-ENG57549 Oil pressure switch valve activation-Bits 0-7 1
IDE00949 Hide cylinder not active
IDE01773 Misfire totalizer 0
IDE01975 Numb.of misfir.: cylinder 1 10476
IDE01976 Numb.of misfir.: cylinder 2 1003
IDE01977 Numb.of misfir.: cylinder 3 970
IDE01978 Numb.of misfir.: cylinder 4 1613
09:31:21
IDE00347 Air mass: actual value: 3.27 g/s
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
          77
VIN: WAUBFAFL0EN040990   Mileage: 272950km-169603miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---    CVN: FE64ECCA
   Shop #: WSC 62026 004 1048576
   VINID: 9D195259159C01578010024900C0B90234
16 Faults Found:
                    Mileage: 272466 km
                    Date: 2022.08.01
                    Time: 10:08:10
          P2279 00 [237] - -
                    Mileage: 267260 km
                    Date: 2022.06.11
                    Time: 01:55:20
          P0172 00 [232] - System Too Rich
                    Mileage: 255341 km
                    Date: 2022.02.23
                    Time: 18:11:24
                    Mileage: 271438 km
                    Date: 2022.07.21
                    Time: 08:43:44
          P0341 00 [096] - Implausible Signal
                    Mileage: 271911 km
                    Date: 2022.07.27
                    Time: 09:47:18
          P2178 00 [237] - -
                    Mileage: 271438 km
                    Date: 2022.07.21
                    Time: 08:43:44
          P0506 00 [096] - RPM Lower than Expected
          P050A 00 [096] - Malfunction
          P0300 00 [096] - -
                    Mileage: 272079 km
                    Date: 2022.07.28
                    Time: 09:32:30
10591 - Cylinder 1
          P0301 00 [096] - Misfire Detected
                    Mileage: 272079 km
                    Date: 2022.07.28
                    Time: 09:32:30
10593 - Cylinder 3
          P0303 00 [096] - Misfire Detected
10594 - Cylinder 4
          P0304 00 [096] - Misfire Detected
          P2188 00 [109] - -
                    Fault Frequency: 74
                    Mileage: 255083 km
                    Date: 2022.02.22
                    Time: 10:53:33
          P1250 00 [032] - -
   Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H18 1005
   Revision: --H18---    CVN: 1A6EAFCC
   Coding: 000002
   VCID: 47969205FE1ADEB74E-8012
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 2D1D1001
   Shop #: WSC 02391 785 00200
   VCID: 0912543DA08E68C798-805C
   Part No SW: 8K0 907 064 JL    HW: 8K0 907 064 JL
   Component: BCM2 2.0      H14 0650
   Coding: 09814040000000000000
   VCID: 030E461582A23297D2-8056
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0514000054193011
   Serial number: 0214000057738006
   Part No SW: 8K1 820 043 AM    HW: 8K1 820 043 AM
   Component: KLIMA 1 ZONE  H02 0123
   Revision: A0000000    Serial number: 01070420141663
   Coding: 6480208000
   VCID: 73EE16D5D2020217C2-8026
   Part No SW: 8K0 907 063 DB    HW: 8K0 907 063 DB
   Revision: 02016001    Serial number: 00000788183801
   Coding: 290000B1863CA7C00000080000003F1F0F1C520822080221000004004000030000000000000000
   VCID: 72E013D1AD180B1FC9-8026
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA130314  H18 0461
   Serial number: 1403100702796
   Coding: 004577
   Serial number: 22465583
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002003144603
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RB46L03
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 02D8CC17000000000001
03351 - Bulb for DRL and Marker Light; Left
                    Fault Status: 01101100
                    Reset counter: 77
                    Mileage: 268581 km
                    Date: 2022.06.22
                    Time: 14:29:39
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KJDC0665+
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 41214 001 1048576
   VCID: 4A90AB31ED0823DF51-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000KNXU
   Serial number: 6334MSME427D082EN
   Serial number: 6344MSME427D0B7EW
   Serial number: 6352QSME51404E78K
   Serial number: 6362QSME753F4F58/
   Serial number: 63732SME6C3F2E76L
   Serial number: 63832SME674A294A9
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862ND7000VQ
   Coding: 000016
   VCID: 48949139FB04D1CF47-801C
   Part No SW: 8K0 920 951 E    HW: 8K0 920 951 E
   Component: KOMBIINSTR.   H09 0564
   Revision: 00200000    Serial number: ZA155W64F
   Coding: 8B9609000301D705020000
   VCID: 3260D3D16D984B1F09-8066
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V1432402E9
   Coding: 80C303FF00
   Serial number: 3683433003
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 3972E4FDB0EEB847C8-806C
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C03204000410001
   VCID: 56A84F4121B0773FC5-8002
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0001449116
   Coding: 100000000001
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 356AE8CD94F65C272C-8060
   Revision: 00002001    Serial number: 0332020260
   Coding: 0106023A00FA400480B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000821623
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8R1 035 223 A    HW: 8R1 035 223
   Component: DSP STD       H08 0230
   Revision: 26S00000
   Coding: 0203010102
   VCID: 2B5ECEB54AB21AD74A-807E
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55AA484D3CB67C27CC-8000
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 10000000355697
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A70FBF1BDE8B35FC1-806E
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000003    Serial number: AUZ5Z6N2026601
   Coding: 04020002010185004159070800
   VCID: 438E8615C222F29792-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
02983 - Connection between Impedance Converter 1 and Window Antenna
                    Fault Frequency: 33
                    Reset counter: 245
                    Mileage: 233244 km
                    Date: 2021.07.23
                    Time: 09:10:30
                    Reset counter: 202
                    Mileage: 272194 km
                    Date: 2022.07.29
                    Time: 01:36:33
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C03204000210001
   VCID: 59B2447D50AE5847E8-800C
   Component: TSG HR        H07 0305
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005371102
   Coding: 0010370
   VCID: 3E78F7E169C09F7FFD-806A
End-------------------------(Elapsed Time: 03:39)--------------------------
09:40:52
IDE00025 Coolant temperature 69 °C
IDE00188 Fuel high-pressure: actual value 3.9990 MPa
IDE00201 High fuel pressure: specified value 4.0000 MPa
IDE00407-ENG57549 Rail pressure regulation: status-Bits 0-7 1
EuroX
Northern NJ USA
C?ID=208579
You clearly have a vacuum/ air intake leak. Address Air intake/vacuum leak first. Please check PCV by pluggin/covering vent hole on PCV for a 20seconds and see if engine evens out.
