Touareg 2013 7P radio issues
Derek7P
Australia
C?ID=524376
Hi, ok a few months ago we got stuck in a massive storm at a camp ground, next day the radio and phone would not work all stations gone, could not scan, could not adjust volume the red bar is at 50% but when to try adjust it it doesn't move. also dont have sound on the navigation. Have tried the 5 finger reboot, does nothing. when my VCDS arrived I attached it while waiting for the registration to be activated, I navigated to the radio and it said no comm's. any ideas as to possible cause? thanks in advance.
Derek7P
Australia
C?ID=524376
I would but my registration keep failing
Westbury, UK
Your status is "Verified VCDS User" so there is no restriction on posting in any public forum here?
Do an Auto-Scan, go to the C:\Ross-Tech\VCDS\Scans folder and open the most recent .txt file in Notepad, then Select All and Copy. Start a new post in this thread then click on the "</>" icon and paste the copied Auto-Scan into the box that opens.
Derek7P
Australia
C?ID=524376
Sorry i meant that the registration for my HEX-V2 keeps failing even with the code you guys sent me.
Westbury, UK
Even if the HEX-V2 isn't yet registered you can still do an Auto-Scan and post it here so we can help you with that.
@Uwe @Dana any clues what's going on with @Derek7P registration?
Derek7P
Australia
C?ID=524376
Monday,08,August,2022,16:31:22:19286
VCDS Version: 22.3.1.4  HEX-V2 CB: 0.4615.4
Dealer/Shop Name: Whyte workshop
Chassis Type: 7P6
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 42 46 52 53 55 56 5F 62
          6C 6D 72
   Mileage: 242362km-150596miles
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 05: Acc/Start Auth.
Address 08: Auto HVAC
Address 09: Cent. Elect.
Address 10: Park/Steer Assist
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 881 G    HW: 7P6 920 881 G
   Component: Kombi         H13 0318
   Revision: 13240077    Serial number: 658200213592015
   Coding: 332731003A00000800000C
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526.rod (VIN: N/A)
   VCID: 40D94D868A07766B8FF-8014
9459739 - Can't Decode, CODE File Not Loaded!
          - 1B [008]
                    Fault Frequency: 35
                    Reset counter: 227
                    Mileage: 238262 km
                    Date: 2022.05.04
                    Time: 15:21:57
   Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H11 6028
   Revision: --------    Serial number: 00000000835158
   Coding: 000D07AD00
   GVL: FB4F40851D67000000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod (VIN: N/A)
   VCID: 3B233A6AE3E115B3DAD-806E
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000004190193601
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 13044000575011200181
4875 - Can't Decode, CODE File Not Loaded!
          - 0B [008]
                    Reset counter: 221
                    Mileage: 240958 km
                    Date: 2022.06.05
                    Time: 10:04:59
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 25 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
5271 - Unlicensed Version. Not all DTCs
          - 97 [008]
                    Reset counter: 221
                    Mileage: 240958 km
                    Date: 2022.06.05
                    Time: 09:47:51
                    Voltage terminal 30: 11.8 V
                    Control Module temperature: 21 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6226 - Unlicensed Version. Not all DTCs
          - 52 [009]
                    Reset counter: 203
                    Mileage: 242362 km
                    Date: 2022.08.08
                    Time: 12:56:22
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 28 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0267 - Can't Decode, CODE File Not Loaded!
          - 0B [008]
                    Reset counter: 243
                    Mileage: 239533 km
                    Date: 2022.05.14
                    Time: 13:06:24
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 38 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0268 - Unlicensed Version. Not all DTCs
          - 0C [008]
                    Fault Frequency: 8
                    Reset counter: 243
                    Mileage: 239533 km
                    Date: 2022.05.14
                    Time: 13:03:23
                    Control Module temperature: 40 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
16384 - Unlicensed Version. Not all DTCs
          - 00 [008]
                    Fault Frequency: 75
                    Reset counter: 242
                    Mileage: 236594 km
                    Date: 2022.04.14
                    Time: 09:26:55
                    Voltage terminal 30: 14.6 V
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 35 °C
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 34: Level Control
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
Address 56: Radio
   Part No SW: 7P6 035 764 D    HW: 7P6 035 764
   Component: H-BNT-RW      H46 0593
   Revision: --------    Serial number: 479B/0D7524066
   Coding: 010A01050040C1EF01000B0E00000003F00001030000000000
   VCID: 3A2D3F6EEC5B2CBBC1B-806E
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M780223J
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  4949
8 Faults Found:
00384 - Can't Decode, CODE File Not Loaded!
            011 - Can't Decode, CODE File Not Loaded! - Intermittent
                    Fault Status: 00101011
                    Reset counter: 243
                    Mileage: 239474 km
                    Date: 2022.05.13
                    Time: 07:28:06
                    Voltage: 12.00 V
00658 - Unlicensed Version. Not all DTCs
            004 - will be decoded. - Intermittent
                    Reset counter: 215
                    Mileage: 239533 km
                    Date: 2022.05.14
                    Time: 12:31:08
                    Voltage: 11.90 V
            012 - will be decoded. - Intermittent
                    Fault Status: 00101100
                    Reset counter: 215
                    Time Indication: 15
                    Voltage: 11.90 V
                    Bin. Bits:      100
02244 - Can't Decode, CODE File Not Loaded!
            000 - Can't Decode, CODE File Not Loaded! - Intermittent
                    Reset counter: 243
                    Mileage: 242362 km
                    Date: 2022.08.08
                    Time: 16:26:52
                    Voltage: 11.80 V
                    CODES Not Loaded: TXT 005 126
                    Hex Value: 0x0001
02259 - Unlicensed Version. Not all DTCs
            014 - will be decoded. - Intermittent
                    Fault Status: 00101110
                    Reset counter: 241
                    Mileage: 242236 km
                    Date: 2022.08.02
                    Time: 15:34:00
                    Voltage: 11.40 V
                    Bin. Bits:       10
                    Reset counter: 215
                    Mileage: 239533 km
                    Date: 2022.05.14
                    Time: 12:35:23
                    Voltage: 11.50 V
02612 - Can't Decode, CODE File Not Loaded!
                    Reset counter: 221
                    Time Indication: 15
                    Voltage: 12.10 V
00822 - Unlicensed Version. Not all DTCs
                    Reset counter: 175
                    Mileage: 239474 km
                    Date: 2022.05.13
                    Time: 12:28:45
                    Voltage: 11.30 V
Derek7P
Australia
C?ID=524376
Monday,08,August,2022,16:40:01:19286
VIN: WVGZZZ7PZDD032125 License Plate:
Chassis Type: 7P-VW52 (7P6)
6C 6D 72
VIN: WVGZZZ7PZDD032125 Mileage: 242362km-150596miles
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H40 0003
Revision: 53H40--- CVN: F49CE9BD
Coding: 292A4012232E01020000
ASAM Dataset: EV_ECM30TDI0117P0907401F 001004
ROD: EV_ECM30TDI011_VW52.rod
VCID: 323D174E34ABD4FB09B-8066
VINID: 9E65EAAAA1E0A945000C2042147D202EA3
Westbury, UK
Did you have the ignition off when you did the first scan?
To get a full scan you have to have the ignition on as many modules are 'asleep' with the ignition off, no need to have the engine running just the ignition on.
Derek7P
Australia
C?ID=524376
Second scan was with ignition on
@PetrolDave Thanks for tagging us.
Derek, as far as I can tell your interface was Finalized on 2022-08-02 10:27:04 (eastern) so the interface registration in addition to your forum status look good on our end.
What I suspect is happening is 2-part.
1) PC side. Either VCDS wasn't installed using an Administrator account with read/write access -or- there's overly aggressive anti-virus / Nannyware creating issues.​
2) Car side. It is entirely possible there is a car side issue but until we get VCDS showing a valid license and decrypting DTCs correctly I don't think we can go further on that.​
If this is a personally owned laptop (rather than one from work) make sure you are using an Admin account. Next, verify VCDS is installed into the default location: C:\Ross-Tech\VCDS
After doing so, right click on the VCDS folder, choose properties and click on the |Security Tab| to see if your user account has full access like this example:
If you don't have ALL of those checks enabled (Full control, Modify, Read & Execute, etc...) click Edit and correct the settings for all Admin accounts followed by [Apply] and [OK].
At that point Windows is going to make changes to the permissions for all of the files and after that's complete I'd expect it to work correctly.
If that fails to work you can install VCDS onto another laptop or try this My Docs work-around instead but I would NOT uninstall or delete the old VCDS installation as per these instructions:
If you uninstall the installation located at the default location any and all log files and debug files will be deleted as well.
Derek7P
Australia
C?ID=524376
Ok Guys, finally sorted out the registration and security setting in the software, thanks for the help. please see the latest scan below.
Tuesday,09,August,2022,09:11:37:19286
          6C 6D 72
56-Radio -- Status: Cannot be reached 0100
   Part No SW: 0C8 927 750 BK    HW: 0C8 927 750 BK
   Component: AL1000 AISIN  002 2268
   Serial number:                CVN: 3CF24403
   Coding: 001568
   Shop #: WSC 99999 999 83333
   ASAM Dataset: EV_TCMAL991031 002114
   ROD: EV_TCMAL991031_002_VW52.rod
   VCID: 76B5EB5E984388DBE53-8022
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 404830010EC815
   Coding: 5B6B13C34B272555DAF5C895D2D7A450F700
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4ACD6FAEBC3BBC3B51B-801E
336397 - Databus
          U1123 00 [072] - Received Error Message
          [Motorsteuergerät: bitte Fehlerspeicher auslesen]
                    Reset counter: 221
                    Mileage: 240958 km
                    Date: 2022.06.05
                    Time: 09:47:42
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 00 00 00 01 20 01
   Part No SW: 4H0 907 064 CM    HW: 4H0 907 064 CM
   Component: BCM2 2.0      H33 0433
   Coding: 01B60010000000000000
   VCID: 76B5EB5E98C388DBE53-8022
   Subsystem 1 - Part No SW: 7P6 959 754 AC    HW: 7P6 959 754 AC
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0513000005347004
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2313000022468011
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: 3626200890
   VCID: 7EA5F37EB073C09BBD3-802A
0251 - Air Blower
          B10BE 12 [008] - Short to Plus
          [Frischluftgebläse Kurzschluss nach Plus]
                    Fault Frequency: 106
                    Reset counter: 241
                    Mileage: 236707 km
                    Date: 2022.04.16
                    Time: 11:22:21
          U1101 00 [008] - Active
                    Fault Frequency: 25
                    Reset counter: 243
                    Mileage: 236798 km
                    Date: 2022.04.25
                    Time: 08:27:01
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001687188
   Coding: 26001010D1345D010021000300005D0C431D470807010241000000020000
   VCID: 6C81C936D68F420B037-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    130208  031 0021
   Serial number: 90243401130221192537
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20068102
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002102131079
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Reset counter: 215
                    Mileage: 239533 km
                    Date: 2022.05.14
                    Time: 12:33:00
                    Reset counter: 221
                    Mileage: 240958 km
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28261304600009
   Coding: 308501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43D3428A9B116D7392D-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag00T H05 0025
   Revision: --------    Serial number: 003L0006PBJ%
   Coding: 000000000000000000000000000000003054
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41DF4882810D7F63801-8014
   Serial number: 3575LRB40024UPPODPS1
   Serial number: 3585LRB40064UPPOA0JC
   Serial number: 3515RRB401250ET8N1LF
   Serial number: 3525RRB401E50ET8KQ2V
   Serial number: 3555NRB400650DEKEQ09
   Serial number: 3565NRB400650DEKEQAK
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815MBP00012
   Coding: 000015
   VCID: 36352B5ED843C8DB253-8062
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0238532
9459739 - Fuel Level Sensor 2
          B1058 1B [008] - Resistance Too High
                    Fault Frequency: 35
                    Reset counter: 227
                    Mileage: 238262 km
                    Date: 2022.05.04
                    Time: 15:21:57
   Coding: 000D07AD00
   Voltage stabilizer:
4875 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Reset counter: 221
                    Mileage: 240958 km
                    Date: 2022.06.05
                    Time: 10:04:59
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5271 - No Communications with Parking Assist Control Module A
          U0159 00 [008] - -
                    Reset counter: 221
                    Mileage: 240958 km
                    Date: 2022.06.05
                    Time: 09:47:51
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6226 - Radio
          U1066 00 [009] - No Communication
                    Reset counter: 203
                    Mileage: 242362 km
                    Date: 2022.08.08
                    Time: 12:56:22
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 243
                    Mileage: 239533 km
                    Date: 2022.05.14
                    Time: 13:06:24
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0268 - Optical data bus
                    Fault Frequency: 8
                    Reset counter: 243
                    Mileage: 239533 km
                    Date: 2022.05.14
                    Time: 13:03:23
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschraenkung Pausenempfehlung]
                    Fault Frequency: 75
                    Reset counter: 242
                    Mileage: 236594 km
                    Date: 2022.04.14
                    Time: 09:26:55
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AA    HW: 7P0 907 553 AA
   Component: PASM          H04 1800
   Revision: 00000000    Serial number: 00000130420373
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
0838 - Indicator Lamp in Operating Control for Loading-Sill Lowering
          C10DA 13 [008] - Open Circuit
                    Fault Frequency: 243
                    Reset counter: 3
                    Mileage: 503040 km
                    Date: 2087.03.08
                    Time: 25:28:59
                    Default: 00
                    Default: 86
                    Default: 00
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000052225952
   Coding: 011D0620D001451005080002
   VCID: 44D141969E9F6A4BAB7-8010
   Revision: 00002001    Serial number: 0301189430
   Coding: 011A162028B9108083200624010000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Fault Frequency: 9
                    Reset counter: 240
                    Mileage: 239532 km
                    Date: 2022.05.14
                    Time: 15:10:16
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 236
                    Mileage: 240977 km
                    Date: 2022.06.08
                    Time: 12:46:30
00230 - Transmission Park Selector Switch (F305)
                    Reset counter: 227
                    Mileage: 241166 km
                    Date: 2022.06.24
                    Time: 10:39:12
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000052893022
   Coding: 011D0620D001451005080000
   VCID: 3B233A6AE36115B3DAD-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1322100587
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 36352B5ED8C3C8DB253-8062
   Slave 3:
12656768 - Databus
          [CAN-Signalfehler MotorSG]
                    Reset counter: 221
                    Mileage: 240958 km
                    Date: 2022.06.05
                    Time: 09:47:42
                    Voltage: 12.0 V
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AE00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1F976A66FD28B937-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
5275953 - Power Output Module for Left Headlamp
          C1081 31 [008] - No Signal
                    Reset counter: 221
                    Mileage: 239533 km
                    Date: 2022.05.14
                    Time: 12:09:25
Address 56: Radio
   Component: H-BNT-RW      H46 H-BNT-RW      H46 05930593
   VCID: 3A2D3F6EEC5B2CBBC1B-FFFE
No Faults Found
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000053356274
   Coding: 011C04200001251005080000
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H06000    Serial number: 525 PA8J320306
   Coding: 0020001
   VCID: 372B265AD34931D33E5-8062
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 029301299
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   VCID: 3FDB4E7AF7F90993F65-806A
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000052901302
End----(Elapsed Time: 02:49, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
Quintus Rotam
EU
C?ID=490177
Have you checked the fuses?
Specifically, the SC51 fuse (20A, yellow) for the radio?
Derek7P
Australia
C?ID=524376
Yeah fuse is good, i have power at the radio
Westbury, UK
An awful lot of those fault codes are marked intermittent, have you tried doing a Clear All and doing another Auto-Scan to see which are still current fault codes?
Derek7P
Australia
C?ID=524376
Ok will do a clear and get back
Derek7P
Australia
C?ID=524376
all faults cleared except for the radio and infotainment system. so time to start looking for a new radio, had a look and looks like the PCb got wet, how this happened i am not sure.
